Efe Çetin
149 -
Other groups
Contributor/Maintainer
Will check it when i back to PC, will be away from pc for around a week
Orange Pi 5 won’t boot from SSD after armbian-install
Efe Çetin replied to Renoria's topic in Orange Pi 5
Choose install/update bootloader on spi flash option on armbian-install. Some uart logs could be useful if you have usb-ttl converter stuff -
Could you try to write SPI image to spi flash manually? (not the sata one) Also, can you send the content of /boot/armbianEnv.txt which is located in the ssd. -
Has anyone got a Bluetooth usb dongle to work with mainline kernel?
Efe Çetin replied to Fredrik's topic in Orange Pi 5
Can you send dmesg lsusb and lsmod outputs using paste.armbian.com -
Desktop not showing Armbian 25.5.1 Noble Gnome, Orange Pi 5
Efe Çetin replied to compent's topic in Orange Pi 5
The image from https://dl.armbian.com/orangepi5/Noble_vendor_gnome works well for me. It might be good to see some GDM logs as i am not sure where the problem arises from. -
@Egertcan you send inxi -G output
What if you clear SPI Flash and then try to boot emmc?
Yes it's not supported by mainline kernels yet. Perhaps it might be worth to try to backport wacom drivers to 6.1 kernel.
It is fixed now. It should work if you update kernel from beta repo
I will check it to find what's wrong. Unfortunately it might take some time since i don't have any 2k screen
Which resolution are they working at? And does it work with Khadas images
1440p should be supported on both 6.1 and 6.10 images but it's recommended using 6.1 images as 6.10 HDMI is still WIP
It will get fixed by this PR: https://github.com/armbian/build/pull/7015 If you don't want to wait approval of the PR, copy this overlay https://github.com/efectn-forks/build/blob/rk3588-edge-v6.11/patch/kernel/archive/rockchip-rk3588-6.11/overlay/rockchip-rk3588-hdmirx.dtso & replace okay with disabled and then add if as an user overlay using armbian-add-overlay -> https://docs.armbian.com/User-Guide_Allwinner_overlays/
Building Armbian Distribution with Kernel 6.10 for Orange Pi 5 Pro
Efe Çetin replied to Sergey Dulimov's topic in Rockchip
OPi 5 Pro is not yet supported for 6.10 kernel and if you want it supported someone has the board needs to add its DT tohttps://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip-rk3588-6.10/dt. If you're interested in making the board work in mainline you can take https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip-rk3588-6.10/dt/rk3588s-orangepi-5.dts devicetree as reference. You need to adjust regulators, some devicetree nodes, properties etc. -
Hope to get rtl8852be wifi driver support for kernel 6.1
Efe Çetin replied to Gypsophila .'s topic in Orange Pi 5 Plus
It won't be requiring any external packages soon -> https://github.com/armbian/build/pull/6947/files
