mmie4jbcu
  1. @Hqnicolas Take a chill pill dude. I am not trying to prove/disprove anything. I am simply suggesting that the board may indeed be of 8/64 config. Sometimes, due to screwed up u-boot, not all the RAM is reported correctly. And here, I can see that adding up the memory (3.8) and zram (1.9), it comes to around 6GB. Hence, I suspect the memory is still there, it's just not reported correctly because of the zram/swap thing. Removing the swap/zram completely may indeed show it to be 8GB. On your note of TV boxes being unreliable, I never refuted your claim. I agree about the unreliability. At the same time, I own two of these x88 pro20 boxes (8/128 and 4/32) and looking at the chips and the markings on the board, I have certain confidence that it would be an 8/64 indeed. And, I own a total of 4 tv boxes, and a total of 4 sbcs (2 raspberry pis, one orange pi 5 plus, 1 starfive vision V 2), so I know what to expect and how wild things are out in the tv box world. I am sure you also know better than to claim to be the final authority on declaring all tv boxes as "unreliable"
  2. @MMorales I think your board may still be of the 8GB RAM/64 GB emmc config. Why don't you try installing the armbian image for station m2 from here: https://www.armbian.com/station-m2/ After flashing the image, change the fdtfile=rockchip/rk3566-firefly-roc-pc.dtb line in the boot/armbianEnv.txt file to fdtfile=rockchip/rk3566-box-demo.dtb And also remove or comment out the line overlay_prefix=rk35xx
  3. @FuSan Cheers! Have fun with your device Do you mean which Armbian build I started with for my device? I started with Station M2 community builds (edge), because it is also a rk3566 device. These days I run Fedora on my box.
  4. @FuSan So, you have kernel 6.1.x running on your Armbian install. The driver for RTL8821CS chip was added in version 6.3 or 6.4 in the mainline kernel. You can change to a kernel with version 6.6 or later. Try searching for 'linux-image-rockchip64' using apt search command and install that kernel. I usually prefer the edge kernels because I like to stay on the bleeding edge Then, also install 'armbian-firmware-full' because it has firmware blobs to enable both wifi and bt for 8821cs.
  5. @FuSan Please share the output of the dmesg command just after you log in into Armbian. I recall that the swap configuration can be changed by editing the file /etc/default/armbian-zram-config. If you disable zram, then you will see almost 8GB ram in your htop output.
  6. Hi @FuSan The latest version of Armbian will work just fine. The mainline dtb named rk3566-box-demo.dtb has pretty much everything working for a x88 pro 20 box (except BT and USB 2.0 port) I have attached the dtb file that I use (and its source dts file too, in case you want to have a look). This dtb enables the bluetooth to work and also USB 2.0 port. Try it out and let us know. rk3566-box-demo.dtb rk3566-box-demo.dts
  7. Place this u-boot file file in the /boot directory on s905x3 devices. It should be able to boot the new Armbian images, without any other changes to any files. u-boot.ext
  8. Try an image from here: https://fi.mirror.armbian.de/archive/aml-s9xx-box/archive/ Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11.img.xz - only command line Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11_xfce_desktop.img.xz - with XFCE desktop environment. Extract the .xz file to get the .img file. After you have written the img file to your sdcard, you would need to do the following 2 steps: 1. Use the correct dtb for your box. For TV boxes, it can be difficult to get the exact dtb file. However, you can try out the different dtb files that are for the same amlogic chip as your TV box and see what works best for you. In the /boot partition in your sdcard (the partition named armbi_boot), go to dtb -> amlogic directory. You would need to look for dtb files named meson-g12a-*.dtb (g12a is the codename for S905x2). Then open up the file /boot/extlinux/extlinux.conf and look for a line FDT /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb or similar that is not commented out. Replace the name of the dtb file with the one that you want to try out. 2. Inside the /boot directory, rename the file u-boot-s905x2-s922 to u-boot.ext Insert the sdcard in your box and power it on. If anything shows up on the screen after sometime, its good!. If not, then you have to try another dtb from the list of meson-g12a-* dtbs. If no dtb seems to work, then things are going to get complex. However, for now, try out the steps and let us know how it goes. Also, read this informative post by @SteeMan for amlogic boxes:
