OttawaHacker
112 -
I have my kernel locked to 6.1.75 but still after 25.8.2 update, I lost all USB devices on both of my Orange PI 5. Only the USB3 port is working. The only way I've been able to get access to the USB is by switching to the latest `current` kernel... Any clues on what is going on? Firmware or kernel upgrades are not doing anything... where can the issue be???? I tried downgrading to many different versions but beside the current branch, USB is gone. Thanks
Analog Audio out not working (25.2.1 / 6.1 kernel / KDE Neon)
OttawaHacker replied to deskwizard's topic in Orange Pi 5
I had to use 6.1.75 to get the analog out working. It is the only version where the analog out works - it shows in other versions but there is no playback -
Armbian_25.8.2_Orangepi5_noble_current_6.12.49.img.xz fails to boot
OttawaHacker replied to djtecha6's topic in Orange Pi 5
/dev/serial is also gone on 25.8.2 -
Thanks - I'm worried my main issue was with the overlay loading issue I mentioned. I did try 6.15 but prob need to retry with the hack with overlay-user. But man... it is SO incredibly simple to switch the kernels.
See for more details but without using the overlay-user folder - I was not able to get the pwm to work on a fresh download.
OMG - I can confirm this issue is also happening on orange pi 5 with latest armbian v25.5.1 + Linux 6.1.*-vendor-rk35xx This is my armbianEnv.txt The pwm only loads when I copy it into overlay-user. The really strange thing is that I have two of these boxes and the one that went through upgrades is working just fine but I'm trying a fresh install on another and no way to get the overlay to work except this hack
Been trying to enable multiple overlays on kernel 6.12 (orange pi 5) but I am not able to get any pwm device in /sys/class/pwm/ The i2c also seems to be missing. Is going back to 6.1 the safest option? Thanks
Patch kernel? DRM video kernel message flooding logs
OttawaHacker replied to OttawaHacker's topic in Orange Pi 5
I sent a PR on the build with a patch - not sure about removing that log entry directly from kernel but on most common armbian builds, this log entry is a pain -
With the vendor kernel, my logs are getting flooded with drm error messages Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 this seems an old issue (Kernel messages flooding logs · Issue #86 · Joshua-Riek/ubuntu-rockchip) - it doesn't seem complicated to fix, I am familiar with the build system but I cannot figure out how I can create a patch for the kernel source. Which repo should I patch? Can I just put my patch into build/patch/kernel/rk35xx-vendor-6.1? Thanks
Also just tested ubuntu-rockchip - this one works perfectly (6.1 vendor) and is stable so there must be some patches missing in the armbian-linux repo. I don't mind looking into that but no clue how to test this with armbian-build
So current aka 6.12 is a no-go because armbian/bcmdhd-dkms: Broadcom ap6xxx dkms package doesn't build yet on 6.12 (support for the Orange Pi 5 Max with kernel 6.13-rc1 by shenmintao · Pull Request #7537 · armbian/build) Vendor 6.1 is unstable, after boot, lsmod, modprobe are broken and there are pcie errors. I'm going to assume something is wrong with the dts file. I was hoping to try some hacks there... From what I understand that one is hosted on armbian/linux-kernel but how can I tweak it for the build? I see the dts files in the uboot/legacy but is there any way to customize the dts files without cloning the whole linux kernel repo?
I'm happy to help - but so far the build is unstable and hangs when I request lsmod. The wifi doesn't seem to be enabled out of the box. I checked on the orange pi build and they use the wl module (broadcomm) however I think there are some serious pcie exceptions in the armbian journal that cause the box to blow up. I will probably try ubuntu rockchip version and see if their figured out all the opi max 5 details. If so, I assume this could be a start to bring more board features to armbian?
Oh lol of course 😛 Are there only trunk releases for the opi-max? Was hoping to get a current build instead, anyway, if this doesn't exist, I will build my own image. I got the opi 5 max working by changing the dtb on the 5 plus image - booted fine except I have no wifi.
