Jean-Philippe
  1. I am also having problems with USB3 hub. When plugging a hub in the USB3 top port, the journal log is filled with usb usb6-port1: Cannot enable. Maybe the USB cable is bad? lsusb -t gives: /: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 480M |__ Port 004: Dev 003, If 0, Class=Hub, Driver=hub/4p, 480M /: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=ohci-platform/1p, 12M |__ Port 001: Dev 003, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M /: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 5000M Plugging a USB3 drives without a hub works correctly. Everything works fine with legacy kernel.
  2. Thank you very much for the hard work! I've spent the whole evening trying various combinations of kernels and dtbs. Unfortunately, I was not able to have that USB3 hub working (except for legacy 5.10). With 6.2 kernel and usb-c dtb, it shows as USB2 only. What is strange is that I'm sure I had it working in the past, with a 6.2 kernel. Plugging a single device in the USB3 port works. Plugging the hub on another machine works. Using 5.10 kernel works. Plugging the hub with 6.2 or 6.6 kernel on either USB3 or USB-C does not work. If anyone is willing to help me debug this, it would be very welcomed. I'm not sure what I should try to go further.
  3. Hello @balbes150, Sorry to insist, I'm still looking for a working 6.x kernel with wireguard and usb3 (or usb-c). I'm willing to try compiling the module by myself, but I'm not sure what repository to use. Could you share your building process? Best regards
  4. Hi, I tried this dtb and the kernel does not boot. Tried with loglevel 7 and there aren't any error messages, the boot just hangs at some point. If you could add wireguard module to 6.2 current build, I would be more than happy to use this until mainline support is fixed. Many thanks
  5. Thank you for your reply. I understand there is no guarantee, and that mainline kernel is still a work in progress. I don’t have a problem with that, I was just wondering it usb-c and usb3 are supposed to be working (hence I should try to find why this isn’t working for me), or this known not to work (and I should stick with current kernel).
  6. Hello @balbes150, I still can't get neither USB3 nor USB-C working with edge kernel (log shows usb usb2-port1: Cannot enable. Maybe the USB cable is bad? for USB3 and nothing for USB-C). Is this expected? Also, could you add wireguard module for current kernel? Best regards, Jean-Philippe
  7. Hi, Did you manage to have USB3 or USB-C working?
  8. USB-C is also not working with latest 6.5-rc.
  9. I can't get an USB3 hub working properly, with either 6.2 or latest 6.5-rc kernel. Plugging a single device works fine, but plugging a hub won't work. I get "Cannot enable. Maybe the USB cable is bad?" errors. With 5.10 kernel everything works fine. Hub also works fine on another machine. Anyone knows about this?
  10. Hello all, Is there any chance to run mainline kernel? Support for rk3588 seems to be starting with 6.2 and 6.3 (mainline has dts for rock 5b).
