JamesCL
  1. I am having issues with eMMC detection… The kernel does not detect the eMMC, but apparently U-Boot does. Attached are images.
  2. JamesCL
    Orange Pi RV2
    Hi @sven-ola I downloaded this version, "Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_minimal.img", and it's working on an SD card without problems... Is it possible for the OPI RV2 to boot from the eMMC with this image? Thanks.
  3. JamesCL
    Orange Pi RV2
    Thanks for your work, @sven-ola. I'm going to try your image. I only need Ethernet (no sound, no wireless, no Bluetooth, and definitely no HDMI). Cheers!
  4. @Ángel Luis Pérez You don't have to apologize because the type of image was very clear in the post where you reported it... it's just a matter of reading 🙂
  5. @Nick AI made the change, but there were no changes in the log
  6. @JuanEsf Ok, I'll try again, connect everything and let you know... Thanks for your work 🙂
  7. @JuanEsf Have this : it gets stuck there : U-Boot 2025.01-armbian-2025.01-S2ebd-Pe2be-H8869-V77e1-Bb703-R448a+ (Feb 24 2025 - 23:31:20 -0300) Allwinner Technology CPU: Allwinner A523 (SUN55I) Model: OrangePi 4A DRAM: 4 GiB sunxi_set_gate: (CLK#32) unhandled Core: 52 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@2050000 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@2500000 Out: serial@2500000 Err: serial@2500000 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 5 ms (906.3 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 156 bytes read in 3 ms (50.8 KiB/s) Load fdt: /boot/dtb/allwinner/sun55i-t527-orangepi-4a.dtb 17256 bytes read in 13 ms (1.3 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/sun55i-t527-fixup.scr' 8116855 bytes read in 2781 ms (2.8 MiB/s) 42523136 bytes read in 14555 ms (2.8 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42b40000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8116791 Bytes = 7.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 49842000, end 49fffa37 ... OK Loading Device Tree to 00000000497d5000, end 0000000049841fff ... OK Working FDT set to 497d5000 Starting kernel ...
  8. @JuanEsf Thanks for the image, I'm going to try it on my opi 4a and I'll let you know. Regards
  9. Is there any armbian image that we can try with the Orange pi 4A ? Many thanks
  10. In my case, my opi5 never worked no matter how many armbian versions I changed. I was disappointed with the SBC and left it lying around for many months... until one day I tried the "trunk" and error... error of versions, one after another... and suddenly I found a particular version... "24.5.0-trunk.276" and it has been working for months without problems... until now... This versión work fine for me: Armbian_24.5.0-trunk.276_Orangepi5_trixie_edge_6.8.1_minimal.img.tar.gz root@orangepi5:~# dpkg -l | grep '^h' hi armbian-bsp-cli-orangepi5-edge 24.11.0-trunk.204 arm64 Armbian CLI BSP for board 'orangepi5' branch 'edge' hi armbian-firmware 24.5.0-trunk.276 all Armbian - Linux firmware hi linux-dtb-edge-rockchip-rk3588 24.5.0-trunk.276 arm64 Armbian Linux edge DTBs in /boot/dtb-6.8.1-edge-rockchip-rk3588 hi linux-image-edge-rockchip-rk3588 24.5.0-trunk.276 arm64 Armbian Linux edge kernel image 6.8.1-edge-rockchip-rk3588 hi linux-u-boot-orangepi5-edge 24.5.0-trunk.276 arm64 Das U-Boot for orangepi5 root@orangepi5:~# apt-mark showhold armbian-bsp-cli-orangepi5-edge armbian-firmware linux-dtb-edge-rockchip-rk3588 linux-image-edge-rockchip-rk3588 linux-u-boot-orangepi5-edge
  11. Hi, in my case... after many problems, I decided to use only nvme on my opi5. Regards cat /proc/cmdline root=UUID=f43263a1-3f44-43aa-bb0b-415ba559deab rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 uname -a Linux orangepi5 6.8.1-edge-rockchip-rk3588 #4 SMP PREEMPT Fri Mar 15 18:19:29 UTC 2024 aarch64 GNU/Linux
  12. for some strange reason the content of armbianEnv.txt (rootdev) is not applied in my opi5, if anyone can help me. Thank !!!
  13. After applying the following changes I was able to obtain the temperatures in my OPI5. https://github.com/htop-dev/htop/pull/1411/files#diff-cd34c934b018d562cd6c276738f8e4ff18638bff20de91ef057e83a425dd68a1 Thank
  14. Hello, I am trying to create a custom uboot using armbian. it's possible? I am using the following command but I cannot generate the "uboot.bin" to save it to the spi: ./compile.sh uboot-config BOARD=orangepi5 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes BUILD_ONLY=u-boot CONFIGURATION=stable KERNEL_CONFIGURE=no KERNEL_ONLY=no PROGRESS_DISPLAY=plain RELEASE=bookworm UBOOT_ONLY=yes Thank.
