yongwn
  1. I tried Armbina25.5.1 with 6.16.0-rc3-edge-rockchip64 on nanopc t4(rk3399), both hdmi and dp(type-c) works ok. But Armbina25.5.1 with 6.12 only works ok when both typec(dp) and hdmi are pulgged in. There is no output when I only plug in hdmi or typec(dp) .
  2. the config not work, I don't why MKIMAGE u-boot.img CC tpl/arch/arm/mach-rockchip/rk3399/rk3399.o In file included from include/part.h:9, from include/mmc.h:17, from include/spl.h:17, from arch/arm/mach-rockchip/rk3399/rk3399.c:9: include/blk.h: In function 'blk_dread': include/blk.h:552:30: error: 'struct blk_desc' has no member named 'block_read' 552 | blks_read = block_dev->block_read(block_dev, start, blkcnt, buffer); | ^~ include/blk.h: In function 'blk_dwrite': include/blk.h:564:25: error: 'struct blk_desc' has no member named 'block_write' 564 | return block_dev->block_write(block_dev, start, blkcnt, buffer); | ^~ include/blk.h: In function 'blk_derase': include/blk.h:571:25: error: 'struct blk_desc' has no member named 'block_erase' 571 | return block_dev->block_erase(block_dev, start, blkcnt);
