20 -
GmP replied to Hqnicolas's topic in Rockchip CPU Boxes
@GBEM yes the service file can be improved, also it might be worth it to blacklist some unuseful module like: sudo nano /etc/modprobe.d/blacklist.conf # Add: blacklist btusb blacklist btrtl blacklist btbcm blacklist btintel -
@jock Hi, I have updated the build source for the leds overlay files (leds 6 and 7) for both the the rockchip64 H50 tvbox and the T9 tvbox, for kernels 6.12 (old non scrolling driver) and 6.18 (new scrolling driver) the version for 6.18 is also fine for 6.19. Have a look at my fork in https://github.com/gpaesano/build. Some modifications are just refinements other are functional. I have built all the images and variants on a ubuntu linux and are running well. I am not familiar with pull requests and do not want to be impolite, so If you think there is some added value please support it. All the best @GmP
T9 TvBox Sunwell - Pcb Label T9-RK3328-8x4-V1.8
GmP replied to GmP's topic in TV Boxes running Armbian
https://github.com/armbian/community/releases/download/26.2.0-trunk.385/Armbian_community_26.2.0-trunk.385_Rk3318-box_trixie_current_6.18.8_minimal.img.xz this is the latest console build compatible with T9. You will need to configure a little bit the environment after booting to enable all the features via ssh and wired lan. If the device is still on android the best is to follow the tutorial from @jock in -
First of all, thank you to @Hqnicolas and all the members for this great effort. Just bought an H96 rk3566, having this hardware configuration: BOARD LABEL: HCY-RK3566-1X32-V20 2023-01-13 SOC RK3566 PMIC RK809-5 LAN RTL8211F DISPLAY FD6551 WIFI AIC8800D40 eMMC H26M74002HMR - SK Hynix eMMC 5.1 NAND Flash 64Gb. It seems to be a mix of the other versions described in this topic, although very close to the one of @WINEDS (thanks for the hints). Everything seems to work so far. Installed using rockchip dev tools, as advised. here its: _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |___| |__/ v26.2 rolling for h96-tvbox-3566 running Armbian Linux 6.12.61-current-rockchip64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) IPv4: (LAN) 192.168.111.228, 192.168.111.91 (WAN) xxxxxxxxxxx Containers: big-bear-photoprism-db Performance: Load: 8% Uptime: 46 minutes Memory usage: 6% of 7.50G CPU temp: 38°C Usage of /: 31% of 57G To enable Bluetooth I have used this small overlay in /boot/overlay-user/ (which enables SPDIF as well): /dts-v1/; /plugin/; /* &{/serial@fe650000} */ &uart1 { status = "okay"; dma-names = "tx\0rx"; bluetooth { status = "disabled"; }; }; &spdif { clock-names = "mclk\0hclk"; status="okay"; }; The followings are the drivers used for wifi-bluetooth wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb Service to enable bluetooth : [Unit] Description=Bluetooth HCI Attach (AIC8800) After=systemd-modules-load.service Requires=systemd-modules-load.service After=dev-ttyS1.device Requires=dev-ttyS1.device [Service] Type=oneshot # Load AIC module ExecStartPre=/sbin/modprobe aic8800_btlpm_sdio # Just a small delay ExecStartPre=/bin/sleep 2 # Attach HCI ExecStart=/usr/bin/hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep To re-enable display in Linux 6.12 another small overlay is required: (the display itself it is not scrolling and available at: /sys/class/leds/display/value ) /dts-v1/; /plugin/; &{/i2c-aux-display} { compatible = "i2c-gpio"; #address-cells = <0x01>; #size-cells = <0x00>; display@24 { compatible = "fdhisi,fd6551"; reg = <0x24>; #address-cells = <0x01>; #size-cells = <0x00>; tm16xx,digits = [04 03 02 01]; tm16xx,segment-mapping = [00 01 02 03 04 05 06]; led@0,0 { reg = <0x00 0x00>; function = "alarm"; }; led@0,1 { reg = <0x00 0x01>; function = "usb"; linux,default-trigger = "usb-host"; }; led@0,2 { reg = <0x00 0x02>; function = "pause"; linux,default-trigger = "mmc2"; }; led@0,3 { reg = <0x00 0x03>; function = "play"; linux,default-trigger = "mmc0"; }; led@0,4 { reg = <0x00 0x04>; function = "colon"; }; led@0,5 { reg = <0x00 0x05>; function = "lan"; linux,default-trigger = "stmmac-0:00:link"; }; led@0,6 { reg = <0x00 0x06>; function = "wlan"; linux,default-trigger = "mmc1"; }; digits { status = "disabled"; }; leds { status = "disabled"; }; }; }; rk3566-bt-fix.dtso rk3566-led-fix.dtso -
@jock this is the user-overlay patch I am using to enable both leds on the board. The "working" led is as usual a couple of alternating leds of red/blue. The led-ir is a standalone blue, I have triggered one to the "timer" and the other to "activity" , both running. I can confirm bluetooth, IR remote receiver are also working. Bluetooth needs BCM.hd (I have used BCM43342.hcd). For the wifi 2/5G the correct overlay is rk3318-box-wlan-ap6334. HDMI, despite apparently is initialized correctly and answering to all commands still gives a black screen. rk3318-box-led-overlay-ledA.dtso.txt
TV Box Status Information Template Version 1.0 TV Box Name (example: TX3 mini): T9 CPU (example: amlogic s905w): RK3328 Armbian build file name: Armbian_community_25.11.0-trunk.367_Rk3318-box_trixie_current_6.12.54_minimal.img DTB file used: rockchip/rk3318-box.dtb Kernel Version: 6.12.56-current-rockchip64 Distribution Installed (focal, buster, etc): trixie Working Ethernet (Yes/No):Yes Max Ethernet Speed that works (100/1000): 100 Max Does wifi work (Yes/No): Yes 2/5 Does bluetooth work (Yes/No): Yes Does HDMI audio work (Yes/No): Yes - after last update , (also analog and spdif ports are available - not tested). Additional Comments (provide any additional information you feel is important): IR Receiver yes 5 Digit display working: yes MASKROM PINS for recovery flashing available on the back side. SOC RK3328 RAM 4Gx4 D9PQL VFD DRIVER FD6551 WLAN CHIP SP6330 32 GB EMMc KLMBG2JENB VT RT9045 vfd.conf rk3318-t9.dtso Log android gpio T9.txt
GmP replied to Jean-Francois Lessard's topic in Amlogic meson
Update I have opened the box. Indeed the driver is an FD6551 and the SOC is RK3328. I was using the FD655 just because that was the one used in a working vfd-openvfd conf file. So I have just changed the dtso file directive compatible = "fdhisi,fd6551"; The advantage is that 8 levels of intensity are now available using 1..8 in "echo 1 > /sys/class/leds/display/brightness". I did not chage the filename but as a matter of fact it should be as well the working rk3328-t9.dtso. rk3318-t9.dtso -
Both senteces are correct , I have reviewed the DT and now display-service is working properly and consequently there is no more sysfs "value" attribute. "Message" attribute is working as expected (scrolling, etc). Notes: It seems to me that the automatically generated dtso file for rk3328-t9 in the git repository is not valid. There are a lot of "T9" TVBOXES all around, mine is labelled T9-RK3328-8x4-V1.8 , (although I have always used it as an rk3318-t9 due to the main dtb file), so I will reopen it one of these day and be back. Anyway the latest driver is working as well with another box, another chip (FD650), please see: -
the two tv box are quite different.The rk3318-H50 of this post is quite cheap, so are the component inside. By the way for the rk3318-H50: the PMIC is a DF1517, not an usual one. The Board has three leds (one red is power on always on the other two are both blu but I have never seen them on) and a 4 digit display plus (colon) usb, lan and wlan icons. Wifi works with the base configuration 2 and 5 ghz (although some warnings in the log). Bluetooth is recognized as well. I do not see any message related to the IR receiver. By the way it seems to be quite stable. This is the gpio list: android_tv_box_32:/ $ cat /sys/kernel/debug/gpio gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0: gpio-2 ( |vcc_otg_vbus ) out hi gpio-30 ( |vcc_sd ) out hi gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1: gpio-42 ( |bt_default_rts ) out lo gpio-50 ( |reset ) out hi gpio-53 ( |bt_default_poweron ) out hi gpio-56 ( |fd650_scl ) out hi gpio-57 ( |fd650_sda ) out hi gpio-58 ( |bt_default_wake_host) in hi gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2: gpio-81 ( |vcc_host_vbus ) out hi gpio-82 ( |power-led-ir ) out lo gpio-90 ( |power-led-normal ) out lo gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3: The T9 is an old and quite different TVBOX (cames in two flavours rk3318 and rk3328 from Sunwell) and everything is working "out of the box" - wifi, bluetooh, lan, hdmi, ir receiver. It has no leds but a 5 digit display + 6 icons but if you think it would be useful I can open it and peraphs describe it in a different post to avoid confusion. It seems to me that is more widespread as there are configuration files all around. Let me know if it is of ant interest.
@jock, sorry for the confusion actually there are two boards (two different TV-BOX) one (here in this post) is an rk3318-H50 as you say T98... using FD650, the other one is rk3318-T9 (only T9) using FD655. All the dtso files posted are correct: for the H50 (T98) in this post you have the versions for the old kernel and the new one. Same in the other post "HELP WANTED" for the other TV BOX. At the end the two latest dtso are valid for the latest kernel. One of the difference between FD650 and FD655 is that the first one has 4 digits but 8 segments (0-7) on the contrary FD655 drives 5 digits and 7 segments (0..6). DTSO files are configured accordingly and fully working. Hope it clarifies.
@jock I have also tested the driver for a rk3318-T9, please see below in case it is useful for the device tree overlay.
Here you are the correct dtso for the latest version of the tm16xx / kernel. Note that this is not the same model of rk3328-t9.dtso found in https://github.com/jefflessard/tm16xx-display however I do think it will work with that model as well. The automatic generated dtso file for the rk3328 from vfd seems to be icorrect as it is addressing segment 7 of fd655. rk3318-t9.dtso -
Yes you are perfectly right. It took me some "minutes" to figure out. Just in case I do have the overlay dtso for the previous tm16xx version. No scrolling message however. Use ../value instead. rx3318-H50.dtso-old.txt
Attached the source overlay file for the tm16xx driver. All features working. See for details and thanks to https://github.com/jefflessard . rx3318-H50.dtso.txt
Hi - thank you for the nice driver. Here is my contrbute: Device under test : T9_RK3318 (T9 Sunwell 3318 version 4+32 GB) Running: v25.11 rolling for RK3318 Box running Armbian Linux 6.12.55-current-rockchip64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) Some info: RK3318:~# lsmod | grep tm tm16xx 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac lsmod | grep i2c i2c_gpio 16384 0 i2c_algo_bit 12288 1 i2c_gpio ls /sys/bus/i2c/devices/ 5-0024 i2c-4 i2c-5 ls /sys/class/leds/display brightness device digits map_seg7 max_brightness num_digits num_segments power segments subsystem trigger uevent value ls -l /sys/class/leds/ total 0 lrwxrwxrwx 1 root root 0 Oct 26 11:53 display -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::alarm -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::alarm lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::colon -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::colon lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::lan -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::lan lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::pause -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::pause lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::play -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::play lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::usb -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::usb lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::wlan -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::wlan lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::capslock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::capslock lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::compose -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::compose lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::kana -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::kana lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::numlock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::numlock lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::scrolllock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::scrolllock lrwxrwxrwx 1 root root 0 Jan 1 1970 working -> ../../devices/platform/gpio-leds/leds/working Testing... echo "1234" > /sys/class/leds/display/value echo 1 > /sys/class/leds/display\:\:lan/brightness echo 1 > /sys/class/leds/display\:\:usb/brightness All the 7 functions and 4 digits are working and correctly associated. Also trigges are working. I still have this small bug which is stopping rolling messages: display-service -c [INFO] all digits and leds on /usr/sbin/display-service: 116: cannot create /sys/class/leds/display/message: Permission denied All the function leds reacts well (all on) but the four clock digits do not switch, most likey because of the message permission denied. However they do work writing directly in the "value" as above and in the picture. Edit: I have investigated a little and it seems that I am still using the tm16xx which came with the distribution, as depmod was failng. After a fresh recompile all your module load but nodes under "leds" are not there, it seems that the dtso/dtbo is not read - nothing appears in dmesg. Attached the working dtso file. rk3318-t9.dtso
