elsabz
  1. @royk thanks for the answer but this Virtual Desktop is out of the discussion, what I want is to reach the same point that I had experimented with Raspberrypi. With the raspi-config I could set a fixed resolution that was activated even if there was no display connected to the hdmi. Achieving this result would be the goal of this discussion, thanks anyway!
  2. On my Orange Pi 5, I have successfully installed the X11VNC server. I followed the guide at the following link X11VNC and everything works as expected. I can connect with Real VNC from another device and see the desktop of the Orange Pi as if I were in front of its display. However, when the Orange Pi 5 is powered on without a display connected to the HDMI port, the access with Real VNC doesn't work as before. I get a black screen and I am unable to interact with the Orange Pi. I had a similar issue with Raspberry Pi, where I could resolve it by setting a default screen resolution. How can I achieve this with Armbian? How can I configure an alternative resolution when the HDMI port is not connected?
  3. I don't know why, I think after doing "sudo apt update/upgrade" (but I'm not sure), the wiringOP library on "orange pi 5" with Armbian 23.02.2 doesn't work anymore. If I run the command "sudo gpio readall" I get the following output: Oops: Unable to determine board revision from /proc/device-tree/system/linux,revision or from /proc/cpuinfo -> No "Hardware" line -> You'd best google the error to find out why. Can anyone help me solve this problem?
  4. Hello, i need to activate the serial port on the odroid N2-plus, the serial port is on pins (J2 - 2x20 PINS) 8/10. Usually this uart with ubuntu is at /dev/ttyS1. If I try to use it on armbian I get an input/output error. I read the following post, I understand that it is not implemented yet. Can anyone point me in the direction of trying to do this?
  5. Hi all, after installing the latest version of Armbian (Jammy 6.1.11 desktop) I found that HDMI monitor audio is not working. With the Ubuntu MATE version of odroid the audio worked. Armbian seems more powerful and its look is much better than MATE, I hope I can solve all the problems because I don't want to go back to MATE anymore, How can I make HDMI audio work? Thanks in advance... PS. I have already updated the firmware to full with the WiFi USB stick problem which has since been resolved
