9 -
ArmSoM-LM5 uses Rockchip RK3588, a new generation flagship eight-core 64-bit processor with a main frequency of up to 2.4GHz, a 6 TOPS computing power NPU, and can be equipped with a maximum of 32GB of large memory. It supports 8K video encoding and decoding and adopts LGA packaging, which has stronger transmission capability and stability. It has rich interfaces and supports multiple hard drives, Gigabit network, WiFi6, 5G/4G expansion and a variety of video input and output. Supports multiple operating systems; provides baseboard reference design materials, allowing users to customize in depth. Applicable to ARM PC, edge computing, cloud server, artificial intelligence, cloud computing, virtual/augmented reality, blockchain, smart NVR and other fields armbian github commit: https://github.com/armbian/build/pull/5854: wiki: http://wiki.armsom.org/index.php/ArmSoM-w3
I try # sudo rm -rf cache # ./compile.sh https://paste.next.armbian.com/ofokehatag
tks https://paste.next.armbian.com/najocatuwi Here is the full log
how to disable artifact usage?
helloοΌThis is the full log
[π±] Configuration prepared for BOARD build [ orangepi5.conf ] [β¨] Repeat Build Options (early) [ ./compile.sh BOARD=orangepi5 BRANCH=legacy RELEASE=bullseye BUILD_MINIMAL=no BUILD_DESKTOP=yes KERNEL_CONFIGURE=no DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DESKTOP_APPGROUPS_SELECTED="3dsupport browsers chat desktop_tools editors internet multimedia office programming remote_desktop" COMPRESS_OUTPUTIMAGE=sha,img ] [π±] Checked directory OK for mount options [ /media/jack/data2/bpi/build/.tmp ('main temporary dir') ] [π±] Preparing [ host ] [πΈ] Using Python 3.9 for [ hostdeps: 'focal' has outdated python3, using python3.9 ] [π±] Syncing clock [ host ] [π¨] 5 May 15:37:14 ntpdate[610843]: adjust time server 84.16.73.33 offset -0.008535 sec [π±] Ignoring toolchains [ SKIP_EXTERNAL_TOOLCHAINS: yes ] [π±] Aggregating packages [ rootfs ] [πΈ] Using '/usr/bin/python3.9' for [ 'focal' has outdated python3, using python3.9 ] [π±] Python3 version [ 3.9.5 - 'Python 3.9.5' ] [π±] pip3 version [ 20.0.2: 'pip 20.0.2 from /usr/lib/python3/dist-packages/pip (python 3.9)' ] [π±] Using cached pip packages for Python tools [ 6cdd997428ebeabcce97fcf0ae0ebf06c436ba17d1e826be134e18a1a18554d4 ] [π¨] Summary: Aggregation: debootstrap: 9; rootfs: 113; image: 1; desktop: 97; apt-sources: 2; hash: aa7a4a172569aa59 [π±] artifact [ uboot :: uboot() ] [π±] Using cached [ GIT_INFO_UBOOT ] [π] artifact [ present in local cache: uboot-orangepi5-legacy 23.05.0-trunk--2017.09-S90d4-Pb417-He8c0-V4107-Baf4d ] [π±] artifact [ kernel :: kernel() ] [π±] Using cached [ GIT_INFO_KERNEL ] [π±] Using kernel config file [ config/kernel/linux-rockchip-rk3588-legacy.config ] [π] artifact [ present in local cache: kernel-rockchip-rk3588-legacy 23.05.0-trunk--5.10.110-Se454-De8b2-Pbb66-C2865Hfe66-HK01ba-Vc222-Bb229 ] [π±] artifact [ firmware :: firmware() ] [π±] Using cached [ GIT_INFO_ARMBIAN_FIRMWARE ] [π] artifact [ present in local cache: armbian-firmware 23.05.0-trunk--1-SA56ad-Bf566 ] [π±] artifact [ armbian-config :: armbian-config() ] [π±] Using cached [ GIT_INFO_ARMBIAN_CONFIG ] [π] artifact [ present in local cache: armbian-config 23.05.0-trunk--1-SAed8f-Ba894 ] [π±] artifact [ armbian-zsh :: armbian-zsh() ] [π±] Using cached [ GIT_INFO_ARMBIAN_ZSH ] [π] artifact [ present in local cache: armbian-zsh 23.05.0-trunk--1-SA5a3f-B379b ] [π±] artifact [ armbian-plymouth-theme :: armbian-plymouth-theme() ] [π] artifact [ present in local cache: armbian-plymouth-theme 23.05.0-trunk---B24e2 ] [π±] artifact [ armbian-bsp-cli :: armbian-bsp-cli() ] [π] artifact [ present in local cache: armbian-bsp-cli-orangepi5-legacy 23.05.0-trunk--1-PCb99b-Vba92-Hfdbd-B243d ] [π±] artifact [ armbian-desktop :: armbian-desktop() ] [π] artifact [ present in local cache: armbian-bullseye-desktop-gnome 23.05.0-trunk--1-V5999-B8177 ] [π±] artifact [ armbian-bsp-desktop :: armbian-bsp-desktop() ] [π] artifact [ present in local cache: armbian-bsp-desktop-orangepi5-legacy 23.05.0-trunk--1-B0996 ] [πΏ] Building image [ orangepi5 ] [π±] Checking for rootfs cache [ legacy orangepi5 bullseye 3dsupport browsers chat desktop_tools editors internet multimedia office programming remote_desktop gnome no ] [π±] artifact [ rootfs :: rootfs() ] [π±] Going to build rootfs [ packages_hash: 'aa7a4a172569B9536b3' cache_type: 'gnome' rootfs_cache_id: 'gnome-aa7a4a172569B9536b3' ] [π±] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-root/arm64-bullseye-gnome:23.05.0-trunk--gnome-aa7a4a172569B9536b3 ] Error: GET "https://ghcr.io/v2/armbian/cache-root/arm64-bullseye-gnome/manifests/23.05.0-trunk--gnome-aa7a4a172569B9536b3": GET "https://ghcr.io/token?scope=repository%3Aarmbian%2Fcache-root%2Farm64-bullseye-gnome%3Apull&service=ghcr.io": response status code 403: denied: requested access to the resource is denied [π±] Artifact is not available in remote cache [ ghcr.io/armbian/cache-root/arm64-bullseye-gnome:23.05.0-trunk--gnome-aa7a4a172569B9536b3 ] [π¨] mkdir: created directory '/media/jack/data2/bpi/build/.tmp/rootfs-f4975c62-d96b-4e68-bcdf-68779ba9e210' [π¨] mkdir: created directory '/media/jack/data2/bpi/build/.tmp/mount-f4975c62-d96b-4e68-bcdf-68779ba9e210' [π±] Using tmpfs for rootfs build [ RAM available: 15553MiB > 5000MiB estimated ] [π±] Creating new rootfs cache [ 'arm64-bullseye-gnome-aa7a4a172569B9536b3.tar.zst' ] [π±] Installing base system with 9 packages [ Stage 1/2 ] [π¨] E: unrecognized or invalid option --cache-dir=/media/jack/data2/bpi/build/cache/aptcache/bullseye-arm64/archives [π₯] error! [ Debootstrap first stage failed bullseye 3dsupport browsers chat desktop_tools editors internet multimedia office programming remote_desktop gnome no ] [π₯] Exiting with error 43 [ at /media/jack/data2/bpi/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 create_new_rootfs_cache_via_debootstrap() --> lib/functions/rootfs/rootfs-create.sh:100 create_new_rootfs_cache() --> lib/functions/rootfs/create-cache.sh:60 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_rootfs_build_from_sources() --> lib/functions/artifacts/artifact-rootfs.sh:73 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:227 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:278 get_or_create_rootfs_cache_chroot_sdcard() --> lib/functions/rootfs/create-cache.sh:74 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:14 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:24 do_with_default_build() --> lib/functions/main/default-build.sh:30 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:29 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [π₯] Cleaning up [ please wait for cleanups to finish ] [πΏ] Unmounting recursively [ SDCARD - be patient ] [πΏ] Unmounting recursively [ MOUNT - be patient ] /media/jack/data2/bpi/build/lib/functions/logging/logging.sh: line 154: wait: pid 612028 is not a child of this shell [πΏ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-f4975c62-d96b-4e68-bcdf-68779ba9e210.log.ans ] [πΏ] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-f4975c62-d96b-4e68-bcdf-68779ba9e210.log.ans https://paste.next.armbian.com/log ] jack@jack:/media/jack/data2/bpi/build$
[π±] artifact [ armbian-desktop :: armbian-desktop() ] [π] artifact [ present in local cache: armbian-bullseye-desktop-gnome 23.05.0-trunk--1-V5999-B8177 ] [π±] artifact [ armbian-bsp-desktop :: armbian-bsp-desktop() ] [π±] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-packages/armbian-bsp-desktop-orangepi5-legacy:23.05.0-trunk--1-B0996 ] Error: GET "https://ghcr.io/v2/armbian/cache-packages/armbian-bsp-desktop-orangepi5-legacy/manifests/23.05.0-trunk--1-B0996": GET "https://ghcr.io/token?scope=repository%3Aarmbian%2Fcache-packages%2Farmbian-bsp-desktop-orangepi5-legacy%3Apull&service=ghcr.io": response status code 403: denied: requested access to the resource is denied [π±] Artifact is not available in remote cache [ ghcr.io/armbian/cache-packages/armbian-bsp-desktop-orangepi5-legacy:23.05.0-trunk--1-B0996 ] [π±] Creating bsp-desktop for release 'bullseye' common to all desktops on board 'orangepi5' branch 'legacy' [ armbian-bsp-desktop-orangepi5-legacy :: 23.05.0-trunk--1-B0996 ] [π±] shellcheck found no problems in package scripts [ shellchecked 1 scripts in 'armbian-bsp-desktop-orangepi5-legacy' ] [π¨] dpkg-deb: building package 'armbian-bsp-desktop-orangepi5-legacy' in '/media/jack/data2/bpi/build/output/debs/bullseye/armbian-bsp-desktop-orangepi5-legacy_23.05.0-trunk--1-B0996_arm64.deb'. [πΏ] Building image [ orangepi5 ] [π±] Checking for rootfs cache [ legacy orangepi5 bullseye 3dsupport browsers chat desktop_tools editors internet multimedia office programming remote_desktop gnome no ] [π±] artifact [ rootfs :: rootfs() ] [π±] Going to build rootfs [ packages_hash: 'aa7a4a172569B9536b3' cache_type: 'gnome' rootfs_cache_id: 'gnome-aa7a4a172569B9536b3' ] [π±] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/cache-root/arm64-bullseye-gnome:23.05.0-trunk--gnome-aa7a4a172569B9536b3 ] Error: ghcr.io/armbian/cache-root/arm64-bullseye-gnome:23.05.0-trunk--gnome-aa7a4a172569B9536b3: not found [π±] Artifact is not available in remote cache [ ghcr.io/armbian/cache-root/arm64-bullseye-gnome:23.05.0-trunk--gnome-aa7a4a172569B9536b3 ] [π¨] mkdir: created directory '/media/jack/data2/bpi/build/.tmp/rootfs-8ddce467-1aa4-48a4-bcb1-00523784b9f9' [π¨] mkdir: created directory '/media/jack/data2/bpi/build/.tmp/mount-8ddce467-1aa4-48a4-bcb1-00523784b9f9' [π±] Using tmpfs for rootfs build [ RAM available: 12619MiB > 5000MiB estimated ] [π±] Creating new rootfs cache [ 'arm64-bullseye-gnome-aa7a4a172569B9536b3.tar.zst' ] [π±] Installing base system with 9 packages [ Stage 1/2 ] [π¨] E: unrecognized or invalid option --cache-dir=/media/jack/data2/bpi/build/cache/aptcache/bullseye-arm64/archives [π₯] error! [ Debootstrap first stage failed bullseye 3dsupport browsers chat desktop_tools editors internet multimedia office programming remote_desktop gnome no ] [π₯] Exiting with error 43 [ at /media/jack/data2/bpi/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 create_new_rootfs_cache_via_debootstrap() --> lib/functions/rootfs/rootfs-create.sh:100 create_new_rootfs_cache() --> lib/functions/rootfs/create-cache.sh:60 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_rootfs_build_from_sources() --> lib/functions/artifacts/artifact-rootfs.sh:73 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:227 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:278 get_or_create_rootfs_cache_chroot_sdcard() --> lib/functions/rootfs/create-cache.sh:74 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:14 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:24 do_with_default_build() --> lib/functions/main/default-build.sh:30 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:29 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [π₯] Cleaning up [ please wait for cleanups to finish ] [πΏ] Unmounting recursively [ SDCARD - be patient ] [πΏ] Unmounting recursively [ MOUNT - be patient ] /media/jack/data2/bpi/build/lib/functions/logging/logging.sh: line 154: wait: pid 558099 is not a child of this shell [πΏ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-8ddce467-1aa4-48a4-bcb1-00523784b9f9.log.ans ] [πΏ] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-8ddce467-1aa4-48a4-bcb1-00523784b9f9.log.ans https://paste.next.armbian.com/log ]
