KanexMarcus
  1. @jock thanks, It worked, I just added the line "overlays=led-conf7" to /boot/armbianEnv.txt
  2. @well83 thanks for the uboot, now my system is booting just fine before it would just bootloop like this I'm using the image Armbian_community_24.5.0-trunk.123_Aml-s9xx-box_bookworm_current_6.6.20_minimal.img with the meson-sm1-a95xf3-air.dtb in my tv box a95x f3 air
  3. @jock with the original armbian dtb the tvbox didn't boot
  4. Here I have managed to get it "working" with the Armbian_community_24.5.0-trunk.93_Aml-s9xx-box_bookworm_current_6.6.18_minimal.img but it keeps bootlooping...
  5. Here is my A95X F3 Air, I have installed the slimbox tv firmware that works fine, and now I'm trying to install armbian, with an sdcard and utilizing the meson-sm1-a95xf3-air.dtb file and the uboot u-boot-s905x3 I'm able to get an image, but it keeps in this infinite bootloop, nothing seems wrong, but why isn't booting?
  6. @Sigma7 Here are the Libreelec and Armbian that I have used, you don't actually need to download the libreelec if you have access to a linux machine, because you can just download the .dtb file above and put them into the armbian image flashed to the sd card (replace the file /boot/dtb-6.6.18-current-rockchip/rk322x-box.dtb with the rk322x-box.dtb from the libreelec image), I think it should work on other armbian images (I suggest you to try the latest stable Armbian build) note that I use the images without desktop environment because I mainly use for servers, if you want grab a xfce desktop image and should work as well. Let me know if it worked for you.
  7. I have successfully booted the Armbian_community_24.5.0-trunk.93_Rk322x-box_bookworm_current_6.6.18_minimal.img on my new MXQ PRO 4k rk3229, first I use the MultiTool to flash the armbian to internal storage (if it doesn't find the internal storage reboot the device in the menu), then download the LibreELEC-RK322X.arm-11.0-nightly-20240218-d7324fb-rk322x.img and flashed to an sd card, I booted on this sdcard and use the SSH to copy the rk322x-box.dtb to the internal storage, then it boots just fine, here is the .dtb file I use rk322x-box.dtb
