Hello,
I cloned the master branch of WiringOP one month ago, it reported same version 2.46 and it was working except for the option to activate internal pull up/down.
Trying it in C code using:
pullUpDnControl(n, PUD_DOWN);
or by terminal with:
gpio mode 1 down
same behavior, nothing happen.. by default, unfortunately in my case, it seem active a pull up resistor for all inputs.
I searched on the web and found there was a bug, fixed.
I checked again the main branch and in effect it is different now, the new code is:
*(gpio + GPPUD) = pud & 3 ; delayMicroseconds (5) ;
*(gpio + gpioToPUDCLK [pin]) = 1 << (pin & 31) ; delayMicroseconds (5) ;
*(gpio + GPPUD) = 0 ; delayMicroseconds (5) ;
*(gpio + gpioToPUDCLK [pin]) = 0 ; delayMicroseconds (5) ;
but executing it I get "segmentation fault", debugging deeply the reason is that "gpio" address is zero.
I tried to clone the "next" branch but it is even worst, it won't compile, many errors, log from terminal attached.
What I can do in order to fix.. of simply to setup all inputs with pulldown resistor active?
Thanks in advance
Andrea
log.txt
