Stephen Graf
158 -
Other groups
Contributor/Maintainer
Composite TV OUT WORKING in Orange Pi One H3, 6.12 current
Stephen Graf replied to Error1429's topic in Orange Pi One
That is a lot of work to get video for TVs that today have HDMI anyway. The audio out for an orangepione would also require audio amplifiers. Not many people have the skills to solder to the tiny pads on the orangepione and could easily destroy the board. HDMI for the orangepione works very well for both audio and video. That said, the orangepione with 512KB memory is under powered to run a desktop environment. -
@psygnosis Can you run "armbianmonitor -m" (as root) to see what the processor speed and system load is when you are experiencing the high temperature. I found an old distro and loaded it on my test system and the temperature did not change: Welcome to Armbian 22.11.1 Bullseye with Linux 5.15.80-sunxi System load: 10% Up time: 5 min Memory usage: 14% of 491M IP: 192.168.1.69 CPU temp: 49°C Usage of /: 1% of 109G sysadmin@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 16:09:02: 816MHz 0.18 15% 3% 7% 0% 3% 0% 49.9 °C 0/4 16:09:07: 816MHz 0.16 1% 1% 0% 0% 0% 0% 45.6 °C 0/4 16:09:12: 648MHz 0.15 1% 0% 0% 0% 0% 0% 46.0 °C 0/4 16:09:17: 648MHz 0.14 1% 0% 0% 0% 0% 0% 45.6 °C 0/4 16:09:22: 648MHz 0.12 1% 0% 0% 0% 0% 0% 45.6 °C 0/4 16:09:27: 816MHz 0.11 1% 0% 0% 0% 0% 0% 45.8 °C 0/4
It looks like my test system just runs a little hotter, probably because it is in a case. I took the SD card out of the test (hot) system and put it in the operational system and the operational system still ran cool. So it is not the os. Changing to noble from bookworm made no difference in the running temperature.
@psygnosis Which version of Armbian and os are you running? Yesterday I loaded current noble on a test system and I just noticed that it is running hot (45) even with a significant heat sink. Another operational system that is running current bookworm runs much cooler (32). If you are running noble, could I ask you to try bookworm to see if there is a difference. I will load up my test system with bookworm to check also.
@ER Samson To help figure out why your unit is stopping you could connect to it via an ssh session and as root run "journalctl -f". this might catch any error messages just prior to failure. When running with logs in zram, as Armbian does, the last messages in the logs are quite often lost when the system abruptly stops.
I have an orangepione running bookworm and am not having any problems with it. I will load up another unit with noble and see how it runs. v25.5.1 for Orange Pi One running Armbian Linux 6.12.30-current-sunxi Packages: Debian stable (bookworm) IPv4: (LAN) 192.168.1.65 (WAN) 209.121.228.132 IPv6: fd05:ce26:d593:0:81:2fff:fe1a:671e (WAN) 2001:569:5143:f100:81:2fff:fe1a:671e Performance: Load: 2% Up time: 11 days 2:09 Memory usage: 19% of 484M Zram usage: 1% of 1.00G CPU temp: 36°C Usage of /: 31% of 15G
@going I have a few questions about the kernel sound configuration: why is the SUN50IW9_CODEC configured in two places? do we need CONFIG_SND_SUN8I_CODEC=y and CONFIG_SND_SUN8I_CODEC_ANALOG=y? # # Allwinner SoC Audio support # CONFIG_SND_SUN4I_CODEC=y CONFIG_SND_SUN50IW9_CODEC=m CONFIG_SND_SUN8I_CODEC=y CONFIG_SND_SUN8I_CODEC_ANALOG=y CONFIG_SND_SUN50I_CODEC_ANALOG=y CONFIG_SND_SUN4I_I2S=m CONFIG_SND_SUN4I_SPDIF=m CONFIG_SND_SUN50I_DMIC=m CONFIG_SND_SUN9I_HDMI_AUDIO=m CONFIG_SND_SUN8I_ADDA_PR_REGMAP=y # end of Allwinner SoC Audio support CONFIG_SND_SOC_SUNXI_MACH=m CONFIG_SND_SOC_SUNXI_AHUB_DAM=m CONFIG_SND_SOC_SUNXI_INTERNALCODEC=m CONFIG_SND_SOC_SUNXI_SUN50IW9_CODEC=m # # Allwinner SoC Audio support V2 # CONFIG_SND_SOC_SUNXI_AAUDIO=m CONFIG_SND_SOC_SUNXI_AHUB=m # end of Allwinner SoC Audio support V2
@going I am starting to compare the original sound patches from kernel 6.6 to the latest. I came accross a minor point that I suspect does not affect anything, but should be corrected. The patch file: arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero.dtsi has two entries for the audio codec. They are the same so I don't think it affects the final dtb. &codec { allwinner,audio-routing = "Line Out", "LINEOUT"; status = "okay"; }; &de { status = "okay"; }; &codec { allwinner,audio-routing = "Line Out", "LINEOUT"; status = "okay"; };
@going I have an image from when I tested the tcon patch a few weeks ago, v25.02 rolling for Orange Pi Zero3 running Armbian Linux 6.12.13-edge-sunxi64, and the analog audio works properly until I try to use the pulseaudio volume control at which point the audio speeds up. Restarting celluloid clears the problem. The Celluloid volume control works properly and does not cause a problem. Too confusing! Dmesg does not show an error about the codec clock. Can you tell what changed?
@going There might be a clue to the sound problem in the following: sysadmin@orangepizero3:~$ sudo dmesg | grep -iE 'audio|ahub|video|codec|hdmi|drm' [ 0.079206] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.079254] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.084097] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.084454] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.084604] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.086562] /soc/hdmi@6000000: Fixed dependency cycle(s) with /connector [ 0.086632] /connector: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.912097] sun4i-codec 5096000.codec: Failed to get the module clock [ 0.912123] sun4i-codec 5096000.codec: probe with driver sun4i-codec failed with error -2 [ 1.893626] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff8000811bd460) [ 1.893826] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff8000811c2200) [ 1.894162] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff8000811ba228) [ 1.894226] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 1.894461] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 1.894775] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1.895002] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 1.895247] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff8000811bc528) [ 1.895741] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0 [ 1.895777] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.082951] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 6.372421] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 6.470837] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.471579] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 7.573250] videodev: Linux video capture interface: v2.00 [ 7.688212] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 7.887240] [drm] Initialized panfrost 1.3.0 for 1800000.gpu on minor 1 [ 9.349292] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugout [ 9.349334] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 2 [ 9.498174] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 9.498214] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 9.498316] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 19.333441] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 19.333474] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 19.333494] ahub_plat-i2s-hifi: ASoC: error at __soc_pcm_open on ahub_plat-i2s-hifi: -22 [ 29.107222] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 29.107251] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 29.107270] ahub_plat-i2s-hifi: ASoC: error at __soc_pcm_open on ahub_plat-i2s-hifi: -22 [ 941.536296] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1049.709728] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugout [ 1049.709779] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 2 [ 1049.859960] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1049.859997] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 1049.860100] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1066.819613] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1463.903829] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugout [ 1463.903883] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 2 [ 1464.055245] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 1464.055282] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 1464.055381] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin
Yes that works fine. I have to edit this post as the video only works "fine" on a small window with a lower bit rate avi file (H264). Other videos I tested stuttered and got worse as the window size was increased. Most videos would not play in full screen mode (1920x1080), filling only 1/4 of the screen. I watched the system monitor while playing a video and cpu usage was very high 80-100% on all cores. Ok so I did some more investigation. The first quick test I did was with Celluloid and Media Player, the programs that come with Mate. I then installed vlc, because I wanted to see the codec info about the media. It is vlc that is a cpu hog! Both Celluloid and Media Player work well even at full screen. The cpu usage is around 50%.
I was hoping that there was a clock rate that needed to be divided by 2 or 4.
I think so. sysadmin@orangepizero3:~$ lsmod | grep lima lima 65536 0 gpu_sched 49152 2 lima,panfrost drm_shmem_helper 24576 2 lima,panfrost sysadmin@orangepizero3:~$ lsmod | grep gpu_sched gpu_sched 49152 2 lima,panfrost sysadmin@orangepizero3:~$ glxinfo -B name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 22.3.6 Accelerated: yes Video memory: 1975MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 3.1 Max compat profile version: 3.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Panfrost OpenGL renderer string: Mali-G31 (Panfrost) OpenGL core profile version string: 3.1 Mesa 22.3.6 OpenGL core profile shading language version string: 1.40 OpenGL core profile context flags: (none) OpenGL version string: 3.1 Mesa 22.3.6 OpenGL shading language version string: 1.40 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.1 Mesa 22.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 ********* display show gears running.*********** sysadmin@orangepizero3:~$ glxgears Running synchronized to the vertical refresh. The framerate should be approximately the same as the monitor refresh rate. 303 frames in 5.0 seconds = 60.491 FPS 301 frames in 5.0 seconds = 60.000 FPS 301 frames in 5.0 seconds = 60.000 FPS 300 frames in 5.0 seconds = 59.994 FPS ^C ************** Display show G3D **************** sysadmin@orangepizero3:~$ g3dviewer Gtk-Message: 09:52:52.184: Failed to load module "canberra-gtk-module" (g3dviewer:3131): LibG3D-WARNING **: 09:52:52.232: libg3d: plugins: failed to load /usr/lib/aarch64-linux-gnu/libg3d/plugins/import/imp_vrml.so: /usr/lib/aarch64-linux-gnu/libg3d/plugins/import/imp_vrml.so: undefined symbol: yywrap ** (g3dviewer:3131): CRITICAL **: 09:52:53.802: add_objects: assertion 'object->name != NULL' failed screenshot "g3dviewer-screenshot-g3d.ac.png" saved.
Using a Mate desktop provides the same results for the HDMI and sound as the Cinnamon tested previously. However the Mate desktop is very stable.
