AndyW
17 -
Tested "Armbian_23.09_Starfive2_lunar_current_6.1.31_xfce_desktop.img.xz" and it works well. Video appears to be a bit better as I can play back a 720p video, though not full 720p size. Sound is still great on HDMI and crackly on the jack. Did you want feedback on which programs work/don't work? __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.09 Lunar with Linux 6.1.31-star64 No end-user support: built from trunk System load: 44% Up time: 5 min Memory usage: 5% of 7.72G IP: 192.168.2.164 CPU temp: 39°C Usage of /: 8% of 58G [ General system configuration (beta): armbian-config ] Last login: Sun Sep 24 16:58:11 EDT 2023 on ttyS0 root@starfive2:~# neofetch root@starfive2 -------------- ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ OS: Armbian (23.09) riscv64 ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ Host: StarFive VisionFive V2 __¦¦ ¦¦__ Kernel: 6.1.31-star64 __¦¦ ¦¦¦¦¦¦¦¦¦¦¦ ¦¦__ Uptime: 6 mins __¦¦ ¦¦ ¦¦ ¦¦__ Packages: 1514 (dpkg) __¦¦ ¦¦ ¦¦ ¦¦__ Shell: bash 5.2.15 __¦¦ ¦¦ ¦¦ ¦¦__ Resolution: 1920x1080 __¦¦ ¦¦¦¦¦¦¦¦¦¦¦¦¦ ¦¦__ Terminal: /dev/ttyS0 __¦¦ ¦¦ ¦¦ ¦¦__ CPU: (4) @ 1.500GHz __¦¦ ¦¦ ¦¦ ¦¦__ Memory: 425MiB / 7908MiB __¦¦ ¦¦ ¦¦ ¦¦__ __¦¦ ¦¦__ ¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ ¦ root@starfive2:~#
@balbes150 No problem on testing as that's what I do for work, along with maintaining an old C++/MFC program. Yes, that change did it, thanks. Still learning the boot environment so good to know how "bootcmd" is used.
@balbes150 Tried the above but it didn't work for me. As per your instructions above I: - Changed firmware to 3.6.1 - Burned SD card with "reset-default-env-uboot-visionfive2-3.6.1.img" and booted, then turned device off. Attached file "boot-reset-default.txt" shows this. - Burned SD card with "update_uboot-visionfive2-3.6.1.img" and booted, then turned device off. Attached file "boot-update-uboot.txt" shows this - Booted again (stopped autoboot by hitting key) and did a "printenv" so you can see if the changes above worked, then turned device off. Attached file "boot-printenv.txt" shows this - Burned SD card with "Armbian_23.09_Starfive2_lunar_edge_6.6.0.img.xz" and booted, which failed. Attached file "boot-lunar_edge_6.6.0-failed.txt" shows this So, had a look at the "printenv" output and found nothing "runs" your new env variables "boot_mmc_new", "boot_emmc_new", or "boot_nvme_new"! I also noticed that in the failed boot log the message "## Error: "boot2" not defined". So I booted again, stopped autoboot, did a "setenv boot2 run boot_mmc_new", then "env save", booted again and it worked! Attached file "boot-lunar_edge_6.6.0-worked.txt" shows this. I don't think this is the correct way to "fix" this issue, but it works. Let me know if I did something wrong. boot-reset-default.txt boot-update-uboot.txt boot-printenv.txt boot-lunar_edge_6.6.0-failed.txt boot-lunar_edge_6.6.0-worked.txt
Tested 5.15.130, lunar and sid and both worked fine.
I have a Philips 227E-QPH, 1080p IPS display. I also thought this may be the issue so tried my main monitor, an AOC AGON AG271QX 1440p monitor, but it makes no difference.
I've included a few files in case it helps. This is just after downgrading to 2.11.5, rebooting to u-boot, then defaulting and saving the environment: 1 - 2.11.5-UBoot-clean-before-update-printenv.log 2 - 2.11.5-Doing-update-and-printenv.log 3 - 6.5-Normal-startup-fails.log - normal startup with monitor, keyboard and mouse plugged in. This fails. 4 - 6.5-Startup-HDMI_KB_Mouse_Unplugged.log - starts okay, get login prompt on UART console. Plug in monitor, no video. Login and neofetch below (doesn't show up well in log with my terminal emulator): Armbian 23.06 Lunar ttyS0 starfive2 login: root Password: __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.06 Lunar with Linux 6.5.0-rc1-star64 No end-user support: built from trunk System load: 2% Up time: 16 min Memory usage: 1% of 7.76G IP: 192.168.2.164 CPU temp: 37°C Usage of /: 2% of 58G [ Menu-driven system configuration (beta): sudo apt update && sudo apt install a rmbian-config ] Last login: Thu Sep 7 18:49:20 EDT 2023 on ttyS0 root@starfive2:~# neofetch root@starfive2 -------------- O O OS: Armbian 23.06 Lunar riscv64 ##### Host: StarFive VisionFive 2 v1.3B ####### Kernel: 6.5.0-rc1-star64 ########## Uptime: 16 mins ############ Packages: 352 (dpkg) ############ Shell: bash 5.2.15 ## ########### # Terminal: /dev/ttyS0 ###### ####### ###### CPU: (4) ####### ##### ####### Memory: 88MiB / 7948MiB ##### ##### root@starfive2:~# I've also tried the same steps with u-boot 3.0.4 and 3.1.5, but it makes no difference. 2.11.5-UBoot-clean-before-update-printenv.log 2.11.5-Doing-update-and-printenv.log 6.5-Normal-startup-fails.log 6.5-Startup-HDMI_KB_Mouse_Unplugged.log
Sorry about the delay, was on vacation. I did install 2.11.5 and your updater then worked. However, I am still unable to run anything with kernel 6.5. All other releases work fine. I played a bit and found that with kernel 6.5, if I replace the regular dtb (jh7110-starfive-visionfive-2-v1.3b.dtb) with the 4Gig one (jh7110-starfive-visionfive-2-v1.3b-4gb.dtb), unplug the video and start the board it starts okay, and if I then plug in the video it works. But if I leave the video plugged in it fails the same way as with the regular dtb. The console output is the same as I provided before. If I leave the video unplugged with the 8Gig dtb it also fails as before. Maybe I have a defective board.
Can't get 20230825-current xfce desktop to boot. I have 8G. Note I'm still on u-boot 3.1.5. as I can't update using your updater, as per previous posts. Which is the "correct file"? The one on the SD Card appears to be the same as the one I downloaded today: kernel_comp_addr_r=0x90000000 kernel_comp_size=0x10000000 U-Boot SPL 2021.10 (Jun 21 2023 - 13:42:04 +0800) DDR version: dc2e84f0. Trying to boot from SPI OpenSBI v1.2 ____ _____ ____ _____ / __ \ / ____| _ \_ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ \___ \| _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ \____/| .__/ \___|_| |_|_____/|___/_____| | | |_| Platform Name : StarFive VisionFive V2 Platform Features : medeleg Platform HART Count : 5 Platform IPI Device : aclint-mswi Platform Timer Device : aclint-mtimer @ 4000000Hz Platform Console Device : uart8250 Platform HSM Device : --- Platform PMU Device : --- Platform Reboot Device : pm-reset Platform Shutdown Device : pm-reset Platform Suspend Device : --- Firmware Base : 0x40000000 Firmware Size : 392 KB Firmware RW Offset : 0x40000 Runtime SBI Version : 1.0 Domain0 Name : root Domain0 Boot HART : 1 Domain0 HARTs : 0*,1*,2*,3*,4* Domain0 Region00 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: () Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: () Domain0 Region02 : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: () Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X) Domain0 Next Address : 0x0000000040200000 Domain0 Next Arg1 : 0x0000000042200000 Domain0 Next Mode : S-mode Domain0 SysReset : yes Domain0 SysSuspend : yes Boot HART ID : 1 Boot HART Domain : root Boot HART Priv Version : v1.11 Boot HART Base ISA : rv64imafdcbx Boot HART ISA Extensions : none Boot HART PMP Count : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count : 2 Boot HART MIDELEG : 0x0000000000000222 Boot HART MEDELEG : 0x000000000000b109 U-Boot 2021.10 (Jul 31 2023 - 18:33:53 -0400) CPU: rv64imacu_zba_zbb Model: StarFive VisionFive V2 DRAM: 8 GiB MMC: sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash... SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB OK StarFive EEPROM format v2 --------EEPROM INFO-------- Vendor : StarFive Technology Co., Ltd. Product full SN: VF7110B1-2253-D008E000-00006332 data version: 0x2 PCB revision: 0xb2 BOM revision: A Ethernet MAC0 address: 6c:cf:39:00:64:74 Ethernet MAC1 address: 6c:cf:39:00:64:77 --------EEPROM INFO-------- In: serial Out: serial Err: serial Model: StarFive VisionFive V2 Net: eth0: ethernet@16030000, eth1: ethernet@16040000 starfive_pcie pcie@2C000000: Starfive PCIe bus probed. PCI: Failed autoconfig bar 10 pci enum ... no nvme devices available switch to partitions #0, OK mmc1 is current device found device 1 Couldn't find partition mmc 0xa0000000 Can't set block device Couldn't find partition mmc 0xa0000000 Can't set block device bootmode flash device 1/0 Hit any key to stop autoboot: 0 ** Invalid partition 3 ** Couldn't find partition mmc 1:3 Can't set block device Importing environment from 1/0 ... ## Warning: Input data exceeds 1048576 bytes - truncated ## Info: input data size = 1048578 = 0x100002 ## Error: "boot2" not defined pci enum ... no nvme devices available switch to partitions #0, OK mmc1 is current device found device 1 ** Invalid partition 3 ** Couldn't find partition mmc 1:3 Can't set block device ## Warning: defaulting to text format switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 346 bytes read in 7 ms (47.9 KiB/s) 1: Armbian Retrieving file: /boot/uInitrd 21227702 bytes read in 915 ms (22.1 MiB/s) Retrieving file: /boot/Image 8818775 bytes read in 385 ms (21.8 MiB/s) append: root=UUID=ca0358c3-b739-4670-9cec-e007169efaf6 console=ttyS0,115200n8 console=tty0 earlycon=sbi rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.res Retrieving file: /boot/dtb/starfive/jh7110-starfive-visionfive-2-v1.3b.dtb 41511 bytes read in 11 ms (3.6 MiB/s) Uncompressing Kernel Image ## Loading init Ramdisk from Legacy Image at 46100000 ... Image Name: uInitrd Image Type: RISC-V Linux RAMDisk Image (gzip compressed) Data Size: 21227638 Bytes = 20.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 46000000 Booting using the fdt blob at 0x46000000 Using Device Tree in place at 0000000046000000, end 000000004600d226 Starting kernel ... clk u2_dw_i2c_clk_core already disabled clk u2_dw_i2c_clk_apb already disabled clk u5_dw_i2c_clk_core already disabled clk u5_dw_i2c_clk_apb already disabled [ 0.000000] Linux version 6.5.0-rc1-star64 (root@user-VirtualBox) (riscv64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubunt3 [ 0.000000] Machine model: StarFive VisionFive 2 v1.3B [ 0.000000] SBI specification v1.0 detected [ 0.000000] SBI implementation ID=0x1 Version=0x10002 [ 0.000000] SBI TIME extension detected [ 0.000000] SBI IPI extension detected [ 0.000000] SBI RFENCE extension detected [ 0.000000] SBI SRST extension detected [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000080000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000009fffffff (524288 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable opensbi@40000000 [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff] [ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff] [ 0.000000] node 0: [mem 0x0000000040080000-0x000000023fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff] [ 0.000000] SBI HSM extension detected [ 0.000000] CPU with hartid=0 is not available [ 0.000000] riscv: base ISA extensions acdfim [ 0.000000] riscv: ELF capabilities acdfim [ 0.000000] percpu: Embedded 20 pages/cpu s41656 r8192 d32072 u81920 [ 0.000000] Kernel command line: root=UUID=ca0358c3-b739-4670-9cec-e007169efaf6 console=ttyS0,115200n8 console=tty0 earlycon=sbi rw no_console_suspend consoles [ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 7591584K/8388608K available (10868K kernel code, 4998K rwdata, 4096K rodata, 2237K init, 479K bss, 272736K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4. [ 0.000000] rcu: RCU debug extended QS entry/exit. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@0/interrupt-controller [ 0.000000] riscv-intc: 64 local interrupts mapped [ 0.000000] plic: interrupt-controller@c000000: mapped 136 interrupts with 4 handlers for 9 contexts. [ 0.000000] riscv: providing IPIs using SBI IPI extension [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 881590404240 ns [ 0.000001] sched_clock: 64 bits at 4MHz, resolution 250ns, wraps every 2199023255500ns [ 0.000398] Console: colour dummy device 80x25 [ 0.000409] printk: console [tty0] enabled [ 0.000936] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=16000) [ 0.000965] pid_max: default: 32768 minimum: 301 [ 0.001254] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.001402] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.002551] CPU node for /cpus/cpu@0 exist but the possible cpu range is :0-3 [ 0.003676] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.003797] riscv: ELF compat mode unsupported [ 0.003805] ASID allocator disabled (0 bits) [ 0.003969] rcu: Hierarchical SRCU implementation. [ 0.003986] rcu: Max phase no-delay instances is 1000. [ 0.004312] EFI services will not be available. [ 0.004638] smp: Bringing up secondary CPUs ... [ 0.006786] smp: Brought up 1 node, 4 CPUs [ 0.009496] devtmpfs: initialized [ 0.017344] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.017383] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.036416] pinctrl core: initialized pinctrl subsystem [ 0.037796] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.038531] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.038672] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.038746] audit: initializing netlink subsys (disabled) [ 0.038909] audit: type=2000 audit(0.036:1): state=initialized audit_enabled=0 res=1 [ 0.039359] thermal_sys: Registered thermal governor 'step_wise' [ 0.039410] cpuidle: using governor menu [ 0.045084] platform soc: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000 [ 0.053351] platform 19840000.camss: Fixed dependency cycle(s) with /soc/csi-bridge@19800000/ports/port@1/endpoint [ 0.053944] platform 29590000.hdmi: Fixed dependency cycle(s) with /soc/lcd-controller@29400000/port/endpoint@0 [ 0.056572] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.056595] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page [ 0.056611] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.056626] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page [ 0.124685] raid6: int64x8 gen() 589 MB/s [ 0.192792] raid6: int64x4 gen() 953 MB/s [ 0.260911] raid6: int64x2 gen() 982 MB/s [ 0.329046] raid6: int64x1 gen() 744 MB/s [ 0.329062] raid6: using algorithm int64x2 gen() 982 MB/s [ 0.397129] raid6: .... xor() 547 MB/s, rmw enabled [ 0.397144] raid6: using intx1 recovery algorithm [ 0.397267] ACPI: Interpreter disabled. [ 0.397577] iommu: Default domain type: Translated [ 0.397595] iommu: DMA domain TLB invalidation policy: strict mode [ 0.398082] SCSI subsystem initialized [ 0.398421] usbcore: registered new interface driver usbfs [ 0.398466] usbcore: registered new interface driver hub [ 0.398516] usbcore: registered new device driver usb [ 0.398912] mc: Linux media interface: v0.10 [ 0.398973] videodev: Linux video capture interface: v2.00 [ 0.399388] Advanced Linux Sound Architecture Driver Initialized. [ 0.400705] vgaarb: loaded [ 0.401066] clocksource: Switched to clocksource riscv_clocksource [ 0.401519] pnp: PnP ACPI: disabled [ 0.411196] NET: Registered PF_INET protocol family [ 0.412205] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.423661] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.423858] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.423895] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.424778] TCP bind hash table entries: 65536 (order: 10, 4194304 bytes, linear) [ 0.431444] TCP: Hash tables configured (established 65536 bind 65536) [ 0.431745] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 0.432314] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear) [ 0.433148] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.433745] RPC: Registered named UNIX socket transport module. [ 0.433768] RPC: Registered udp transport module. [ 0.433781] RPC: Registered tcp transport module. [ 0.433795] RPC: Registered tcp-with-tls transport module. [ 0.433808] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.435117] PCI: CLS 0 bytes, default 64 [ 0.435332] Unpacking initramfs... [ 0.436137] Initialise system trusted keyrings [ 0.437377] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.438061] NFS: Registering the id_resolver key type [ 0.438109] Key type id_resolver registered [ 0.438124] Key type id_legacy registered [ 0.438161] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.438179] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.438220] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.441279] fuse: init (API version 7.38) [ 0.441659] 9p: Installing v9fs 9p2000 file system support [ 0.441909] NET: Registered PF_ALG protocol family [ 0.441933] xor: measuring software checksum speed [ 0.446173] 8regs : 2342 MB/sec [ 0.450429] 8regs_prefetch : 2333 MB/sec [ 0.454669] 32regs : 2340 MB/sec [ 0.458933] 32regs_prefetch : 2333 MB/sec [ 0.458955] xor: using function: 8regs (2342 MB/sec) [ 0.458978] Key type asymmetric registered [ 0.458993] Asymmetric key parser 'x509' registered [ 0.459087] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.459110] io scheduler mq-deadline registered [ 0.459125] io scheduler kyber registered [ 0.459180] io scheduler bfq registered [ 0.548199] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled [ 0.551663] SuperH (H)SCI(F) driver initialized [ 0.553472] random: crng init done [ 0.560320] loop: module loaded [ 0.564689] starfive-dwmac 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52 [ 0.564734] starfive-dwmac 16030000.ethernet: DWMAC4/5 [ 0.564758] starfive-dwmac 16030000.ethernet: DMA HW capability register supported [ 0.564784] starfive-dwmac 16030000.ethernet: RX Checksum Offload Engine supported [ 0.564809] starfive-dwmac 16030000.ethernet: Wake-Up On Lan supported [ 0.564898] starfive-dwmac 16030000.ethernet: TSO supported [ 0.564920] starfive-dwmac 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.564949] starfive-dwmac 16030000.ethernet: Enabled L3L4 Flow TC (entries=1) [ 0.564976] starfive-dwmac 16030000.ethernet: Enabled RFS Flow TC (entries=10) [ 0.565004] starfive-dwmac 16030000.ethernet: TSO feature enabled [ 0.565026] starfive-dwmac 16030000.ethernet: Using 40/40 bits DMA host/device width [ 1.700296] Freeing initrd memory: 20724K [ 1.718889] starfive-dwmac 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52 [ 1.718938] starfive-dwmac 16040000.ethernet: DWMAC4/5 [ 1.718961] starfive-dwmac 16040000.ethernet: DMA HW capability register supported [ 1.718987] starfive-dwmac 16040000.ethernet: RX Checksum Offload Engine supported [ 1.719012] starfive-dwmac 16040000.ethernet: Wake-Up On Lan supported [ 1.719100] starfive-dwmac 16040000.ethernet: TSO supported [ 1.719122] starfive-dwmac 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 1.719150] starfive-dwmac 16040000.ethernet: Enabled L3L4 Flow TC (entries=1) [ 1.719177] starfive-dwmac 16040000.ethernet: Enabled RFS Flow TC (entries=10) [ 1.719206] starfive-dwmac 16040000.ethernet: TSO feature enabled [ 1.719227] starfive-dwmac 16040000.ethernet: Using 40/40 bits DMA host/device width [ 1.732078] usbcore: registered new interface driver cdc_acm [ 1.732113] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.732183] usbcore: registered new interface driver cdc_wdm [ 1.732429] usbcore: registered new interface driver uas [ 1.732487] usbcore: registered new interface driver usb-storage [ 1.732823] mousedev: PS/2 mouse device common for all mice [ 1.733584] i2c_dev: i2c /dev entries driver [ 1.736524] sdhci: Secure Digital Host Controller Interface driver [ 1.736550] sdhci: Copyright(c) Pierre Ossman [ 1.736606] Synopsys Designware Multimedia Card Interface Driver [ 1.737242] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.737933] ledtrig-cpu: registered to indicate activity on CPUs [ 1.738327] clocksource: 13050000.timer.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 1.738481] clocksource: 13050000.timer.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 1.738628] clocksource: 13050000.timer.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 1.738775] clocksource: 13050000.timer.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 1.739039] usbcore: registered new interface driver usbhid [ 1.739062] usbhid: USB HID core driver [ 1.739418] riscv-pmu-sbi: SBI PMU extension is available [ 1.739462] riscv-pmu-sbi: 16 firmware and 4 hardware counters [ 1.739483] riscv-pmu-sbi: Perf sampling/filtering is not supported as sscof extension is not available [ 1.740276] usbcore: registered new interface driver snd-usb-audio [ 1.741847] NET: Registered PF_INET6 protocol family [ 1.743349] Segment Routing with IPv6 [ 1.743411] In-situ OAM (IOAM) with IPv6 [ 1.743522] NET: Registered PF_PACKET protocol family [ 1.743833] 9pnet: Installing 9P2000 support [ 1.743912] Key type dns_resolver registered [ 1.765365] Loading compiled-in X.509 certificates [ 1.777937] Btrfs loaded, zoned=no, fsverity=no [ 1.806416] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 1.806841] starfive-jh7110-sys-pinctrl 13040000.pinctrl: StarFive GPIO chip registered 64 GPIOs [ 1.808441] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 1.808735] starfive-jh7110-aon-pinctrl 17020000.pinctrl: StarFive GPIO chip registered 4 GPIOs [ 1.815163] dw_axi_dmac_platform 16050000.dma-controller: DesignWare AXI DMA Controller, 4 channels [ 1.816305] printk: console [ttyS0] disabled [ 1.836930] 10000000.serial: ttyS0 at MMIO 0x10000000 (irq = 28, base_baud = 1500000) is a 16550A [ 1.837002] printk: console [ttyS0] enabled [ 3.117159] dwmmc_starfive 16020000.mmc: IDMAC supports 32-bit address mode. [ 3.119058] starfive-jh7110-sys-pinctrl 13040000.pinctrl: pin GPIO44 already requested by 120c0000.i2s; cannot claim for 10090000.tdm [ 3.124299] dwmmc_starfive 16020000.mmc: Using internal DMA controller. [ 3.136274] starfive-jh7110-sys-pinctrl 13040000.pinctrl: pin-44 (10090000.tdm) status -22 [ 3.136295] dwmmc_starfive 16020000.mmc: Version ID is 290a [ 3.136314] starfive-jh7110-sys-pinctrl 13040000.pinctrl: could not request pin 44 (GPIO44) from group tdm-0.tx-pins on device 13040000.pinctrl [ 3.136376] dwmmc_starfive 16020000.mmc: DW MMC controller at irq 29,32 bit host data width,32 deep fifo [ 3.142984] jh7110-tdm 10090000.tdm: Error applying setting, reverse things back [ 3.143221] mmc_host mmc1: card is polling. [ 3.159455] i2c 6-0010: Fixed dependency cycle(s) with /soc/csi-bridge@19800000/ports/port@0/endpoint [ 3.200537] starfive-dphy-rx 19820000.phy: supply mipi_0p9 not found, using dummy regulator [ 3.209768] cdns-csi2rx 19800000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY [ 3.221973] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 3.247437] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 3.253267] clk: Disabling unused clocks [ 3.257581] ALSA device list: [ 3.260565] No soundcards found. [ 3.377096] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248) [ 3.595784] Freeing unused kernel image (initmem) memory: 2236K [ 3.609143] Run /init as init process [ 3.651544] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 50000000Hz, actual 49500000HZ div = 2) [ 3.661550] mmc1: new high speed SDXC card at address aaaa [ 3.668227] mmcblk1: mmc1:aaaa SD64G 59.5 GiB [ 3.680540] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 3.688032] GPT:10534911 != 124735487 [ 3.691745] GPT:Alternate GPT header not at the end of the disk. [ 3.691752] GPT:10534911 != 124735487 [ 3.691759] GPT: Use GNU Parted to correct GPT errors. [ 3.691800] mmcblk1: p1 [ 4.438405] ssp-pl022 10060000.spi: ARM PL022 driver, device ID: 0x00041022 [ 4.445467] ssp-pl022 10060000.spi: mapped registers from 0x0000000010060000 to 00000000a3fc6c01 [ 4.533434] pcie-starfive 940000000.pcie: host bridge /soc/pcie@940000000 ranges: [ 4.541072] pcie-starfive 940000000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000 [ 4.549684] pcie-starfive 940000000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000 [ 4.777101] pcie-starfive 940000000.pcie: port link up [ 4.784014] pcie-starfive 940000000.pcie: PCI host bridge to bus 0000:00 [ 4.790789] pci_bus 0000:00: root bus resource [bus 00-ff] [ 4.796345] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff] [ 4.803304] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref] [ 4.810916] pci 0000:00:00.0: [1556:1111] type 01 class 0x060400 [ 4.817089] pci 0000:00:00.0: supports D1 D2 [ 4.821415] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 4.831425] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.845557] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 4.851701] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 4.858675] pci 0000:01:00.0: PME# supported from D0 D3cold [ 4.865768] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 4.872508] pci 0000:00:00.0: BAR 8: assigned [mem 0x30000000-0x300fffff] [ 4.875040] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008 [ 4.879385] pci 0000:01:00.0: BAR 0: assigned [mem 0x30000000-0x30000fff 64bit] [ 4.888140] Oops [#1] [ 4.888147] Modules linked in: vs_drm(+) drm_dma_helper drm_kms_helper syscopyarea [ 4.888212] pci 0000:00:00.0: PCI bridge to [bus 01] [ 4.895510] sysfillrect sysimgblt fb_sys_fops pcie_starfive(+) drm drm_panel_orientation_quirks [ 4.895569] pci 0000:00:00.0: bridge window [mem 0x30000000-0x300fffff] [ 4.895583] backlight [ 4.895808] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 4.897899] spi_pl022 fb [ 4.897915] CPU: 0 PID: 113 Comm: systemd-udevd Not tainted 6.5.0-rc1-star64 #23.06 [ 4.897928] Hardware name: StarFive VisionFive 2 v1.3B (DT) [ 4.897936] epc : dc_isr+0x2e/0x7c [vs_drm] [ 4.905858] pcieport 0000:00:00.0: PME: Signaling with IRQ 51 [ 4.910509] ra : dc_isr+0x2e/0x7c [vs_drm] [ 4.919622] pci 0000:01:00.0: enabling device (0000 -> 0002) [ 4.926131] epc : ffffffff017c0dfe ra : ffffffff017c0dfe sp : ffffffc800003e30 [ 4.926142] gp : ffffffff8170ff90 tp : ffffffd8c106bac0 t0 : 0000000000046600 [ 4.926151] t1 : ffffffff80a971f8 t2 : 0000002ac8069995 s0 : ffffffc800003e80 [ 4.926159] s1 : ffffffd8c6a54040 a0 : 0000000000000000 a1 : ffffffd8c6a54040 [ 4.927951] starfive display-subsystem: bound 29400000.lcd-controller (ops dc_component_ops [vs_drm]) [ 4.928559] a2 : 0000000000000001 a3 : 0000000000000000 a4 : 0000000000000000 [ 4.929131] starfive-hdmi 29590000.hdmi: [drm:starfive_hdmi_bind [vs_drm]] registered Starfive HDMI I2C bus driver success [ 4.934685] a5 : ffffffd8c6a57040 a6 : ffffffffffffffff a7 : 0000000000000000 [ 4.934695] s2 : 0000000000000000 s3 : 0000000000000002 s4 : 0000000000000031 [ 4.934703] s5 : ffffffd8c6a54050 s6 : 0000000000000000 s7 : 0000000000000031 [ 4.934916] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x9f8 took 14943 usecs [ 4.937367] s8 : ffffffff816f3a44 s9 : ffffffff812169e0 s10: 0000000000000001 [ 4.937375] s11: 0000000000000000 t3 : ffffffffffffffff t4 : 0000000000000017 [ 4.937383] t5 : 0019de5080000000 t6 : ffffffffffffffff [ 4.937390] status: 0000000200000100 badaddr: 0000000000000008 cause: 000000000000000d [ 4.937623] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.945093] [<ffffffff017c0dfe>] dc_isr+0x2e/0x7c [vs_drm] [ 4.950745] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 4.954909] [<ffffffff800632e2>] __handle_irq_event_percpu+0x4c/0x102 [ 4.955340] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000040000000890 [ 4.960715] [<ffffffff80063422>] handle_irq_event+0x3c/0x86 [ 4.960730] [<ffffffff80066c94>] handle_fasteoi_irq+0x9e/0x1d4 [ 4.960745] [<ffffffff8006268a>] generic_handle_domain_irq+0x1c/0x2a [ 4.961502] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.963987] starfive display-subsystem: bound 29590000.hdmi (ops starfive_hdmi_ops [vs_drm]) [ 4.964977] [<ffffffff80505330>] plic_handle_irq+0x88/0xf0 [ 4.964994] [<ffffffff8006268a>] generic_handle_domain_irq+0x1c/0x2a [ 4.965033] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 4.965044] [<ffffffff80504fee>] riscv_intc_irq+0x2e/0x46 [ 4.965057] [<ffffffff80a9683e>] handle_riscv_irq+0x4a/0x74 [ 4.965101] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 4.965113] [<ffffffff80a972f2>] do_irq+0x58/0x80 [ 4.966111] [drm] Initialized starfive 1.0.0 202305161 for display-subsystem on minor 0 [ 4.966120] hub 1-0:1.0: USB hub found [ 4.966177] hub 1-0:1.0: 1 port detected [ 4.970821] Code: bb03 5b87 8a93 0105 8556 84ae f097 ffff 80e7 7e80 (4783) 008b [ 4.970830] ---[ end trace 0000000000000000 ]--- [ 4.970836] Kernel panic - not syncing: Fatal exception in interrupt [ 4.970842] SMP: stopping secondary CPUs [ 5.228092] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Tested 20230824 lunar legacy 5.15.127 xfce and icewm desktop images. Everything was fine except didn't get desktop on HDMI once with the xfce image. andy@andy-ubuntu-20-04:~$ ssh andy@192.168.2.164 andy@192.168.2.164's password: __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.06 Lunar with Linux 5.15.127-star64 No end-user support: built from trunk System load: 2% Up time: 13 min Local users: 2 Memory usage: 5% of 7.72G IP: 192.168.2.164 CPU temp: 39°C Usage of /: 7% of 58G Tip of the day: Submit your desktop wallpaper creation! https://forum.armbian.com/topic/29433-armbian-desktop-wallpaper-contest/ [ General system configuration (beta): armbian-config ] Last login: Sun Aug 27 05:31:11 2023 from 192.168.2.10 andy@starfive2:~$ andy@starfive2:~$ neofetch andy@starfive2 -------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.06) riscv64 ███████████████████████ Host: StarFive VisionFive V2 ▄▄██ ██▄▄ Kernel: 5.15.127-star64 ▄▄██ ███████████ ██▄▄ Uptime: 11 mins ▄▄██ ██ ██ ██▄▄ Packages: 1547 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Resolution: 1920x1080 ▄▄██ █████████████ ██▄▄ Terminal: /dev/pts/0 ▄▄██ ██ ██ ██▄▄ CPU: (4) @ 1.500GHz ▄▄██ ██ ██ ██▄▄ Memory: 435MiB / 7910MiB ▄▄██ ██ ██ ██▄▄ ▄▄██ ██▄▄ ███████████████████████ █ █ █ █ █ █ █ █ █ █ █
Probably not done the right way, but got 5.15.115 to boot from nvme! It seems to work fine and things start a fair bit faster. Even FireFox is bearable, though it has trouble with video. __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.06 Trixie with Linux 5.15.115-star64 No end-user support: built from trunk System load: 24% Up time: 1 min Memory usage: 3% of 7.74G IP: 192.168.2.164 CPU temp: 39°C Usage of /: 2% of 230G Tip of the day: Submit your desktop wallpaper creation! https://forum.armbian.com/topic/29433-armbian-desktop-wallpaper-contest/ [ 0 security updates available, 298 updates total: apt upgrade ] Last check: 2023-08-25 18:44 Last login: Fri Aug 25 18:09:41 2023 from 192.168.2.10 andy@starfive2:~$ neofetch andy@starfive2 -------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.06) riscv64 ███████████████████████ Host: StarFive VisionFive V2 ▄▄██ ██▄▄ Kernel: 5.15.115-star64 ▄▄██ ███████████ ██▄▄ Uptime: 1 min ▄▄██ ██ ██ ██▄▄ Packages: 1386 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Resolution: 1920x1080 ▄▄██ █████████████ ██▄▄ Terminal: /dev/pts/0 ▄▄██ ██ ██ ██▄▄ CPU: (4) @ 1.500GHz ▄▄██ ██ ██ ██▄▄ Memory: 278MiB / 7927MiB ▄▄██ ██ ██ ██▄▄ ▄▄██ ██▄▄ ███████████████████████ █ █ █ █ █ █ █ █ █ █ █ andy@starfive2:~$ df -h Filesystem Size Used Avail Use% Mounted on udev 3.7G 0 3.7G 0% /dev tmpfs 793M 3.2M 790M 1% /run /dev/nvme0n1p4 230G 4.4G 225G 2% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs 3.9G 4.0K 3.9G 1% /tmp armbian-ramlog 50M 1.9M 49M 4% /var/log tmpfs 793M 60K 793M 1% /run/user/107 tmpfs 793M 52K 793M 1% /run/user/0 tmpfs 793M 56K 793M 1% /run/user/1000 overlaid 793M 56K 793M 1% /run/user/1000/andy-firefox-kqb9yw3i.default overlaid 793M 56K 793M 1% /run/user/1000/andy-firefox-42c5zef3.default-release andy@starfive2:~$ ls /dev/nvm* /dev/nvme0 /dev/nvme0n1 /dev/nvme0n1p1 /dev/nvme0n1p2 /dev/nvme0n1p3 /dev/nvme0n1p4 Essentially used an nvme image from the 2306 Debian release to burn the nvme drive under Linux, then copied a working (already booted once) Armbian SD card root to partition 4 of the nvme. Also copied most of the /boot folder from the Armbian SD card to nvme partition 3 and renamed as required. I think I broke some things as sound is a little worse, but it's nice to have it a little more responsive! Besides, I have too much time on my hands;-) Also attached the console startup, for anyone interested. It does show some unusual stuff. bootlog.txt Now going to try some of the new images.
Okay, log is attached, from an SD burned with 'Armbian_23.06_Starfive2_sid_legacy_5.15.115_xfce_desktop.img'. It is not from the first boot. Let me know if you wanted this from a freshly burned SD card and I'll redo. Quick observation - this morning when I booted I had no video on the monitor (again, this was not the first boot with the SD card). Rebooted and got video, but it had some tearing. Rebooted again and it was fine. Has not happened again over several reboots since then. Understood about not installing u-boot/spl 3.4.5. Will stick with 3.1.5 for now. Thanks for the warning. startup.log
Yes, that worked. Was confused when I saw this yesterday because both options under Default Sink are 'Built-in Audio Stereo 100%'.
Okay, tried that and do get 8 Gig, but no display on the monitor. Only UART console works. No problem as I can test with 4 Gig for now.
Because it didn't work! Just to be sure it wasn't an SD card issue I just burned update-uboot-star64.img the same way I burned the sid image I used for testing yesterday to it. Here's what I get when I try to boot: root@andy-ubuntu-20-04:/home/andy# minicom -b 115200 -D /dev/ttyACM0 Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on Dec 23 2019, 02:06:26. Port /dev/ttyACM0, 17:02:37 Press CTRL-A Z for help on special keys U-Boot SPL 2021.10 (Jun 21 2023 - 13:42:04 +0800) DDR version: dc2e84f0. Trying to boot from SPI OpenSBI v1.2 ____ _____ ____ _____ / __ \ / ____| _ \_ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ \___ \| _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ \____/| .__/ \___|_| |_|_____/|___/_____| | | |_| Platform Name : StarFive VisionFive V2 Platform Features : medeleg Platform HART Count : 5 Platform IPI Device : aclint-mswi Platform Timer Device : aclint-mtimer @ 4000000Hz Platform Console Device : uart8250 Platform HSM Device : --- Platform PMU Device : --- Platform Reboot Device : pm-reset Platform Shutdown Device : pm-reset Platform Suspend Device : --- Firmware Base : 0x40000000 Firmware Size : 392 KB Firmware RW Offset : 0x40000 Runtime SBI Version : 1.0 Domain0 Name : root Domain0 Boot HART : 1 Domain0 HARTs : 0*,1*,2*,3*,4* Domain0 Region00 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/) Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U:) Domain0 Region02 : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U:) Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/) Domain0 Next Address : 0x0000000040200000 Domain0 Next Arg1 : 0x0000000042200000 Domain0 Next Mode : S-mode Domain0 SysReset : yes Domain0 SysSuspend : yes Boot HART ID : 1 Boot HART Domain : root Boot HART Priv Version : v1.11 Boot HART Base ISA : rv64imafdcbx Boot HART ISA Extensions : none Boot HART PMP Count : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count : 2 Boot HART MIDELEG : 0x0000000000000222 Boot HART MEDELEG : 0x000000000000b109 U-Boot 2021.10 (Jun 21 2023 - 13:42:04 +0800), Build: jenkins-github_visionfive5 CPU: rv64imacu_zba_zbb Model: StarFive VisionFive V2 DRAM: 8 GiB MMC: sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash... SF: Detected gd25lq128 with page size 256 B *** Warning - bad CRC, using default environment StarFive EEPROM format v2 --------EEPROM INFO-------- Vendor : StarFive Technology Co., Ltd. Product full SN: VF7110B1-2253-D008E000-00006332 data version: 0x2 PCB revision: 0xb2 BOM revision: A Ethernet MAC0 address: 6c:cf:39:00:64:74 Ethernet MAC1 address: 6c:cf:39:00:64:77 --------EEPROM INFO-------- In: serial Out: serial Err: serial Model: StarFive VisionFive V2 Net: eth0: ethernet@16030000, eth1: ethernet@16040000 starfive_pcie pcie@2C000000: Starfive PCIe bus probed. PCI: Failed autoconfig bar 10 pci enum ... no nvme devices available switch to partitions #0, OK mmc1 is current device found device 1 Couldn't find partition mmc 0xa0000000 Can't set block device Couldn't find partition mmc 0xa0000000 Can't set block device bootmode flash device 1/0 Hit any key to stop autoboot: 0 Failed to load 'vf2_uEnv.txt' Importing environment from 1/0 ... ## Warning: Input data exceeds 1048576 bytes - truncated ## Info: input data size = 1048578 = 0x100002 ## Error: "boot2" not defined pci enum ... no nvme devices available switch to partitions #0, OK mmc1 is current device found device 1 230 bytes read in 5 ms (44.9 KiB/s) ## Warning: defaulting to text format switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... libfdt fdt_check_header(): FDT_ERR_BADMAGIC Card did not respond to voltage select! : -110 No EFI system partition ethernet@16030000 Waiting for PHY auto negotiation to complete...... done BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 DHCP client bound to address 192.168.2.184 (6299 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET BOOTP broadcast 1 DHCP client bound to address 192.168.2.184 (10 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET StarFive # And here's the output from 'printenv': StarFive # printenv baudrate=115200 boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${pref} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} ei boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};i boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr}} boot_pci_enum=pci enum boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_syslinux_conf=extlinux/extlinux.conf boot_targets=mmc0 dhcp bootargs=console=tty1 console=ttyS0,115200 debug rootwait earlycon=sbi bootcmd=run load_vf2_env;run importbootenv;run boot2; run scan_boot_dev; run lod bootcmd_dhcp=devtype=dhcp; run boot_pci_enum; if dhcp ${scriptaddr} ${boot_scri; bootcmd_distro=run fdt_loaddtb; run fdt_sizecheck; run set_fdt_distro; sysboot bootcmd_mmc0=devnum=0; run mmc_boot bootdelay=2 bootdev=mmc bootdir=/boot bootenv=uEnv.txt bootmode=flash bootpart=1:3 chip_vision=B chipa_gmac_set=fdt set /soc/ethernet@16030000/ethernet-phy@0 tx_inverted_10 <0x chipa_set=if test ${chip_vision} = A; then run chipa_gmac_set;fi; chipa_set_linux=fdt addr ${fdt_addr_r};run visionfive2_mem_set;run chipa_set; chipa_set_linux_force=fdt addr ${fdt_addr_r};run visionfive2_mem_set;run chipa_ chipa_set_uboot=fdt addr ${uboot_fdt_addr};run chipa_set; chipa_set_uboot_force=fdt addr ${uboot_fdt_addr};run chipa_gmac_set; cpu_max_vol=1040000 cpu_speed_1250_set=fdt rm /opp-table-0/opp-375000000;fdt rm /opp-table-0/opp-50; cpu_speed_1500_set=fdt rm /opp-table-0/opp-312500000;fdt rm /opp-table-0/opp-41; cpu_vol_1020_set=fdt set /opp-table-0/opp-1500000000 opp-microvolt <1020000>; cpu_vol_1040_set=fdt set /opp-table-0/opp-1500000000 opp-microvolt <1040000>; cpu_vol_1060_set=fdt set /opp-table-0/opp-1500000000 opp-microvolt <1060000>; cpu_vol_set=if test ${cpu_max_vol} = 1000000; then run cpu_speed_1250_set; else devnum=1 devnvme=0 distro_bootcmd=setenv nvme_need_init; for target in ${boot_targets}; do run booe distroloadaddr=0xb0000000 efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth0addr=6c:cf:39:00:64:74 eth1addr=6c:cf:39:00:64:77 ethaddr=6c:cf:39:00:64:74 ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv} fatbootpart=1:3 fdt_addr_r=0x46000000 fdt_high=0xffffffffffffffff fdt_loaddtb=fatload ${bootdev} ${fatbootpart} ${fdt_addr_r} /dtbs/${fdtfile}; f fdt_sizecheck=fatsize ${bootdev} ${fatbootpart} /dtbs/${fdtfile}; fdtaddr=cce36d60 fdtcontroladdr=cce36d60 fdtfile=starfive/starfive_visionfive2.dtb fdtoverlay_addr_r=0x4f000000 importbootenv=echo Importing environment from ${devnum}/${devnvme} ...; env imp} initrd_high=0xffffffffffffffff ipaddr=192.168.120.230 kernel_addr_r=0x40200000 kernel_comp_addr_r=0x90000000 kernel_comp_size=0x10000000 load_distro_uenv=fatload ${bootdev} ${devnum}:3 ${distroloadaddr} /${bootenv}; load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefi} load_vf2_env=fatload mmc ${bootpart} ${loadaddr} ${testenv} loadaddr=0xa0000000 loadbootenv=fatload mmc ${bootpart} ${loadaddr} ${bootenv} memory_addr=40000000 memory_size=200000000 mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi mmcbootenv=run scan_mmc_dev; setenv bootpart ${devnum}:${mmcpart}; mmcpart=3 netmask=255.255.255.0 nvme_boot=run boot_pci_enum; run nvme_init; if nvme dev ${devnum}; then devtypei nvme_env=vf2_nvme_uEnv.txt nvme_init=if ${nvme_need_init}; then setenv nvme_need_init false; nvme scan; fi nvmepart=3 partitions=name=loader1,start=17K,size=1M,type=${type_guid_gpt_loader1};name=lo; preboot=run chipa_set_uboot;run mmcbootenv pxefile_addr_r=0x45900000 ramdisk_addr_r=0x46100000 scan_boot_dev=if test ${bootmode} = flash; then if pci enum; then nvme scan; ec scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env et scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixee scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${e scan_mmc_dev=if test ${bootmode} = flash; then if pci enum; then nvme scan; ech; scan_sf_for_scripts=${devtype} read ${scriptaddr} ${script_offset_f} ${script_s. script_offset_f=0x1fff000 script_size_f=0x1000 scriptaddr=0x43900000 serial#=VF7110B1-2253-D008E000-00006332 set_fdt_distro=if test ${chip_vision} = A; then if test ${memory_size} = 200000 sf_boot=if sf probe ${busnum}; then devtype=sf; run scan_sf_for_scripts; fi testenv=vf2_uEnv.txt type_guid_gpt_loader1=5B193300-FC78-40CD-8002-E86C45580B47 type_guid_gpt_loader2=2E54B353-1271-4842-806F-E436D6AF6985 type_guid_gpt_system=0FC63DAF-8483-4772-8E79-3D69D8477DE4 uboot_fdt_addr=0xcce36d60 ver=U-Boot 2021.10 (Jun 21 2023 - 13:42:04 +0800) visionfive2_mem_set=fdt memory ${memory_addr} ${memory_size}; Environment size: 8956/65532 bytes StarFive # I just burned the sid image back to the same SD card and it works fine. Let me know if I did something wrong.
@balbes150, I'm using an old Philips 227E QPH which is 1080p, and it was running at 1080p. Tried 'Armbian_23.06_Starfive2_sid_legacy_5.15.115_xfce_desktop.img.xz' last night: __ ___ _ _____ _ ____ \ \ / (_)___(_) ___ _ __ | ___(_)_ _____|___ \ \ \ / /| / __| |/ _ \| '_ \| |_ | \ \ / / _ \ __) | \ V / | \__ \ | (_) | | | | _| | |\ V / __// __/ \_/ |_|___/_|\___/|_| |_|_| |_| \_/ \___|_____| Welcome to Armbian 23.06 Trixie with Linux 5.15.115-star64 No end-user support: built from trunk System load: 2% Up time: 17 min Memory usage: 11% of 3.80G IP: 192.168.2.164 CPU temp: 37°C Usage of /: 6% of 58G Last login: Fri Aug 18 05:24:43 EDT 2023 on ttyS0 andy@starfive2:~$ andy@starfive2:~$ neofetch andy@starfive2 -------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.06) riscv64 ███████████████████████ Host: StarFive VisionFive V2 ▄▄██ ██▄▄ Kernel: 5.15.115-star64 ▄▄██ ███████████ ██▄▄ Uptime: 2 mins ▄▄██ ██ ██ ██▄▄ Packages: 1375 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Resolution: 1920x1080 ▄▄██ █████████████ ██▄▄ DE: Xfce 4.18 ▄▄██ ██ ██ ██▄▄ WM: Xfwm4 ▄▄██ ██ ██ ██▄▄ WM Theme: NumixBlue ▄▄██ ██ ██ ██▄▄ Theme: Numix [GTK2], Adwaita [GTK3] ▄▄██ ██▄▄ Icons: Humanity-Dark [GTK2], Adwaita [GTK3] ███████████████████████ Terminal: x-terminal-emul █ █ █ █ █ █ █ █ █ █ █ CPU: (4) @ 1.500GHz Memory: 384MiB / 3893MiB I have 8 Gig memory but it's only using 4. My Visionfive 2 board is 1.3b and has 3.1.5 bootloader. The sound was much better, although it played out of the HDMI and I couldn't find a way to get it to go out the jack. I know you mentioned I should be able to switch between the two (jack or HDMI), but couldn't find that setting. Had some trouble grabbing windows for sizing. Seems to be offset a bit as the sizing indicator appears while the mouse cursor is well inside the window on the bottom, and above the window at the top. Same issue at the corners.
