dirkhh
  1. Hi @Igor -- is it possible that the broken mirror is back? I just got this in a couple of builds: 2023-10-01T18:48:04.0451876Z Ign:2 http://armbian.lv.auroradev.org/apt bookworm/main arm64 armbian-firmware all 23.8.3 2023-10-01T18:48:04.0461377Z Err:2 http://apt.armbian.com bookworm/main arm64 armbian-firmware all 23.8.3 2023-10-01T18:48:04.0462970Z 404 Not Found [IP: 23.186.113.5 80] 2023-10-01T18:48:04.0677050Z Get:1 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 base-files arm64 23.8.3-bookworm [53.0 kB] 2023-10-01T18:48:04.2046316Z Fetched 53.0 kB in 1s (76.1 kB/s) 2023-10-01T18:48:04.2050986Z E: Failed to fetch http://apt.armbian.com/pool/main/a/armbian-firmware/armbian-firmware_23.8.3_all__1-SA01f9-B981c-R448a.deb 404 Not Found [IP: 23.186.113.5 80] 2023-10-01T18:48:04.2051716Z E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
  2. thanks for the pointers. I'll look at the code and see if I can contribute some improvements. really appreciate the responsiveness!
  3. Thanks for the quick response, @Igor I know that others are running into this - I am wondering if there is a way to get engaged and help. But one particular question that I have is about the mirror redirector. Because when I get a failure response and retry, it would be amazing if the redirector could recognize that I just asked for that same file and that maybe it shouldn't direct me to that same mirror again? A simple redis cache with a short timeout for originating IP plus requested URL and if you see it a second time, given them a different answer? Just a thought...
  4. I started seeing this happen "now and then" a couple of months ago, but over the last month it has gone to "multiple times a day". It's not always the same mirror. Frequently it's the airframes.io mirrors, this morning it was lv.auroradev.org The pattern is usually like this: Err:1 https://armbian.lv.auroradev.org/apt bookworm/main arm64 linux-libc-dev arm64 23.02.2 404 Not Found [IP: 23.186.113.5 443] E: Failed to fetch https://armbian.lv.auroradev.org/apt/pool/main/l/linux-6.1.11-sunxi64/linux-libc-dev_23.02.2_arm64.deb 404 Not Found [IP: 23.186.113.5 443] Is there a place to report these issues to get those mirrors fixed?
  5. Different boards, but same issue. It seems that the airframes.io mirror keeps failing. Maybe this should be removed from the mirrors list until it gets fixed?
