7 -
@digwer Thank's for your proposition, but I'm not interested anymore. I have fixed mine, and I don't have the budget to have a second one as backup or for experiment. I wish you good sales.
I have do again the process of Maskrom Mode, but this time I write the helios64_sdcard_u-boot-only.img image. And after this (not 100% sure of the link) I was able to start again the Armbian + OMV system on my helios64. It's also seems than i have more information dump on serial console than before. Before the u-boot process I have this informations dumped : DDR Version 1.24 20191016 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 254 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 47527 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xe5ba8 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Sep 08 2021 - 10:55:50 +0000)
Hello, after some u-boot test, my helios64 don't start the bootloader stage. I can etablish a serial connection on USB Type-c port, but when I tried to start the system, I have no output on it. After I disconnected everything : - I connect usb-c cable, I'm able to connect to serial console with picocom - I connect the power cable, The LED1 (System Rail Power) is on, and the LED9 (Battery Status) flashes. - I press the power botton (without sdcard) : - LED2 and LED3 (Periph. Rail Power and HDD Rail Power) are on - LED4 and LED5 (System ON and HDD Activity) are on. - nothing happen on serial console - If I keep SWI (power botton pressed 5 seconds, i'm able to shutdown the system. I also follow the process of Maskrom Mode (https://wiki.kobol.io/helios64/maskrom/) with success, with no difference at end. > $ sudo tools/rkdeveloptool db rk3399_loader_v1.24_RevNocRL.126.bin > Downloading bootloader succeeded. > $ sudo tools/rkdeveloptool wl 0 /mnt/astav/distrib/Helios64/Armbian_21.05.1_Helios64_buster_current_5.10.35.img > Write LBA from file (100%) > $ sudo tools/rkdeveloptool rd > Reset Device OK. Questions : - What is the role of SPI Flash in the boot process ? - Does the SPI Flash can be erased ? And if yes, this can be affect the boot process ? - Can we supposed to be able to boot the armbian image writen on sd-card with SPI FLash skipped from the boot ? (with P11 jumper closed) - Could the Maskmode procedure help me, or allow me to repair my card ? - u-boot TPL is supposed to be writed on armbian sdcard ? - armbian image (like Armbian_21.05.1_Helios64_buster_current_5.10.35.img) are supposed to be able to boot, even when SPI and eMMc boot are skipped ? Thank you in advance for any help you can give me
@Alexander Eiblinger : Yes, i could be interested. When could you sell it ? At which price (including shipping) ? From where ? Thank you.
thank you @mrjpaxton for the idea. For the moment I will use a second-hand NAS, and tried to fix my board and look at buying a second one.
Hello, i have trouble with my Helios64 (possibly bricked), so I am interested to by a new one. And if i can fix mine, the second one could allow me to participate to armbian support for it. Anyone have one for sale ? Preferably in Europe. Thank you.
Hello, with the last kernel update I have untimely reboot of my nas. some info : hardware : helios64 os : armbian bullseye based with openmediavault 6 on top kernel : armbian-bsp-cli-helios64-current:arm64 23.8.1 before the update to armbian-bsp-cli 23.8.1 the system have some unexpected restarts, but less than 1 by day. With last version, the system restarts itself sometime only few minutes after the start. With a debug console, I got the following kernel panic : [ 510.791607] Internal error: Oops: 0000000096000044 [#1] PREEMPT SMP [ 510.792174] Modules linked in: xt_nat xt_tcpudp veth xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xfrm_user xfrm_algo xt_addrtype nft_compat nf_tables nfnetlink br_netfilter bridge rfkill quota_v2 quota_tree snd_soc_hdmi_codec snd_soc_rockchip_i2s snd_soc_core hantro_vpu rockchip_vdec(C) snd_compress v4l2_vp9 leds_pwm videobuf2_dma_contig rockchip_rga v4l2_h264 videobuf2_dma_sg v4l2_mem2mem videobuf2_memops snd_pcm_dmaengine pwm_fan snd_pcm videobuf2_v4l2 gpio_charger videobuf2_common snd_timer videodev panfrost gpu_sched snd mc drm_shmem_helper rockchip_rng rng_core soundcore fusb302 sg tcpm typec lz4hc lz4 gpio_beeper cpufreq_dt zram softdog ledtrig_netdev lm75 nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables x_tables autofs4 raid10 raid0 multipath linear raid1 dm_raid raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx md_mod dm_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys [ 510.800061] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G C 6.1.50-current-rockchip64 #3 [ 510.800866] Hardware name: Helios64 (DT) [ 510.801219] pstate: 600000c5 (nZCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 510.801840] pc : ct_kernel_enter.constprop.0+0xb8/0x180 [ 510.802323] lr : ct_kernel_enter.constprop.0+0xa8/0x180 [ 510.802794] sp : ffff800009eebd80 [ 510.803094] x29: ffff800009eebd80 x28: 0000000000000000 x27: 0000000000000000 [ 510.803739] x26: ffff000000761e00 x25: ffff800009474298 x24: ffff800009a3dc70 [ 510.804382] x23: fffe800100ee71e0 x22: ffff8000097668f0 x21: ffff8000094ea818 [ 510.805023] x20: 0000000000000000 x19: ffff8000097668f0 x18: 0000000000000000 [ 510.805664] x17: 0000000000000000 x16: ffff0000f7765f00 x15: 0000000000000000 [ 510.806306] x14: 0000000000000001 x13: 00000000000001ef x12: 0000000000000001 [ 510.806946] x11: 0000000000000000 x10: 0000000000000a90 x9 : ffff800009eebd50 [ 510.807587] x8 : ffff0000007628f0 x7 : 0000000000000000 x6 : 00000002f5f32d3a [ 510.808228] x5 : 00ffffffffffffff x4 : 0000000000152374 x3 : ffff800009757008 [ 510.808870] x2 : ffff000000761e00 x1 : ffff8000094868b0 x0 : 0000000000000001 [ 510.809510] Call trace: [ 510.809733] ct_kernel_enter.constprop.0+0xb8/0x180 [ 510.810177] ct_idle_exit+0x1c/0x30 [ 510.810498] default_idle_call+0x48/0x17c [ 510.810864] do_idle+0x23c/0x2b0 [ 510.811164] cpu_startup_entry+0x28/0x30 [ 510.811521] secondary_start_kernel+0x124/0x150 [ 510.811934] __secondary_switched+0xb0/0xb4 [ 510.812322] Code: f8605b00 b8606ac4 d503201f d2800020 (f90006e0) [ 510.812868] ---[ end trace 0000000000000000 ]--- [ 510.813283] Kernel panic - not syncing: Attempted to kill the idle task! [ 510.813877] SMP: stopping secondary CPUs [ 510.814234] Kernel Offset: disabled [ 510.814548] CPU features: 0x40000,20834084,0000421b [ 510.814987] Memory Limit: none [ 510.815273] Rebooting in 90 seconds.. Someone have ideas to have this fixed ? Where to report this problem ? Where to have help to get more informations ? Thank you Note : I have some programming skilled (and debugging), but no kernel development experience.
