69 -
Heya, No issue here with a rock 5b plus with rkmppenc v0.15 under kernel 6.1.115 on armbian 25.5.1 using HEVC transcoding: acas@rock-5b-plus:~$ rkmppenc -c hevc --preset best --audio-codec aac --vbr 700 -i ~hts/recordings/foo.ts -o ts.mkv -------------------------------------------------------------------------------- ts.mkv -------------------------------------------------------------------------------- [h264 @ 0xaaab23a61de0] non-existing PPS 0 referenced arm_release_ver: g24p0-00eac0, rk_so_ver: 6 rkmppenc (aarch64) 0.14 (r493) by rigaya, Apr 5 2025 09:08:50 (gcc 13.3.0/Linux) OS: Armbian 25.5.2 noble (6.1.115-vendor-rk35xx) aarch64 CPU: Cortex-A76 aarch64 (4P+4E,8C/8T) Input Info: avmpp: H.264/AVC, 1920x1080, 25/1 fps Output: H.265/HEVC main @ Level auto (main tier) 1920x1080p 1:1 25.000fps (25/1fps) avwriter: hevc, #1:mp2/stereo -> aac/stereo/128kbps, #2:aac_latm/stereo -> aac/stereo/128kbps => matroska Quality: best VBR: 700 kbps Max bitrate: 875 kbps QP: Min: 0, Max: 51 GOP Len: 300 frames CHECKPTS: check_pts(1/1): timestamp of video frame is smaller than previous frame, changing pts: -16 -> 2 (previous pts 0). CHECKPTS: check_pts(2/2): timestamp of video frame is smaller than previous frame, changing pts: -24 -> 4 (previous pts 2). CHECKPTS: check_pts(3/3): timestamp of video frame is smaller than previous frame, changing pts: -8 -> 6 (previous pts 4). ^C.8%] 8506 frames: 496.29 fps, 743 kbps, remain 0:05:37, est out size 624.3MB Encoding aborted. encoded 8917 frames, 489.43 fps, 743.66 kbps, 31.62 MB encode time 0:00:18, CPULoad: 0.0% frame type IDR 30 frame type I 30, avgQP 26.73, total size 1.22 MB frame type P 8887, avgQP 30.84, total size 30.40 MB Finished with error in rkmppenc. From looking at your logs, looks like a Device TRee issue - failed to identify key hardware parameters by the looks of it for some reason - change in boot settings? regards Andrew
At a guess, you are probably running the panthor gpu driver rather than the mali kernel driver. To check this, run something like: sudo dmesg | grep -i panthor and report what comes back. Further information can be found at https://forum.jellyfin.org/t-rockchip-transcode-missing-dev-mali0 Hope this helps,
My installation became crazy after a 222 packages update on OPI5-Plus.
ozacas replied to Jorge Cury's topic in Rockchip
This sounds like a problem during login - perhaps your display manager logs can give clues. I've seen a problem where kwin_wayland finds the wrong libgbm,so and crashes during login causing the login screen to re-appear. I dont know what display manager you are using, but hopefully one of the following commands can give clues: grep sddm /var/log/* grep lightdm /var/log/* grep kwin_wayland /var/log/* -
i run kodi via flatpak: acas@t6:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Armbian 24.11.2 noble Release: 24.04 Codename: noble acas@t6:~$ flatpak list Name Application ID Version Branch Installation Freedesktop Platform org.freedesktop.Platform freedesktop-sdk-23.08.27 23.08 system Freedesktop Platform org.freedesktop.Platform freedesktop-sdk-24.08.9 24.08 system Mesa org.freedesktop.Platform.GL.default 24.3.1 23.08 system Mesa (Extra) org.freedesktop.Platform.GL.default 24.3.1 23.08-extra system Mesa org.freedesktop.Platform.GL.default 24.3.1 24.08 system Mesa (Extra) org.freedesktop.Platform.GL.default 24.3.1 24.08extra system openh264 org.freedesktop.Platform.openh264 2.1.0 2.2.0 system openh264 org.freedesktop.Platform.openh264 2.4.1 2.4.1 system Freedesktop SDK org.freedesktop.Sdk freedesktop-sdk-24.08.10 24.08 system OpenJDK 17 SDK Extension org.freedesktop.Sdk.Extension.openjdk17 24.08 system Kodi tv.kodi.Kodi 21.1-Omega stable system the video output I believe is hardware accelerated as it reports 'Mali-G610 (panfrost)' under settings -> system info -> video (as opposed to llvmpipe) with Mesa 24.3.1 and wayland
Hi all, armbianmonitor -u output - https://paste.next.armbian.com/donixuwuno saw the following stack trace: [52815.041752] ------------[ cut here ]------------ [52815.041820] NETDEV WATCHDOG: enP4p65s0 (r8169): transmit queue 0 timed out [52815.042019] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:525 dev_watchdog+0x1a8/0x1e0 [52815.042081] Modules linked in: tls rpcsec_gss_krb5 nft_chain_nat xt_MASQUERADE nf_nat xt_addrtype nft_compat nf_tables overlay bnep nf_conntrack_irc nf_conntrack_sane nf_conntrack_tftp nf_conntrack_sip nf_conntrack_netlink xt_conntrack nf_conntrack_pptp nf_conntrack_snmp ts_kmp nf_conntrack_amanda nf_conntrack_netbios_ns nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast nf_conntrack_bridge bridge stp nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 llc binfmt_misc pwm_fan rtw89_8852be rtw89_8852b rk805_pwrkey rtk_btusb rtw89_pci rtw89_core btusb btmtk btrtl btbcm btintel panfrost drm_shmem_helper gpu_sched sch_fq_codel nvme_fabrics fuse dm_mod nfnetlink ip_tables ipv6 nvmem_rockchip_otp r8169 rockchip_cpuinfo uio_pdrv_genirq uio [52815.042774] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 6.1.84-vendor-rk35xx #1 [52815.042804] Hardware name: Radxa ROCK 5B+ (DT) [52815.042823] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [52815.042854] pc : dev_watchdog+0x1a8/0x1e0 [52815.042886] lr : dev_watchdog+0x1a8/0x1e0 [52815.042916] sp : ffff800008003e40 [52815.042933] x29: ffff800008003e40 x28: ffff80000a206000 x27: 0000000000000100 [52815.042986] x26: ffff800008f1ac38 x25: ffff800008003f00 x24: 0000000100f059c0 [52815.043038] x23: 0000000000000100 x22: 0000000000000001 x21: ffff0004f6164488 [52815.043087] x20: 0000000000000000 x19: ffff0004f6164000 x18: 0000000000000000 [52815.043137] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000 [52815.043186] x14: 0000000000000000 x13: 74756f2064656d69 x12: 7420302065756575 [52815.043236] x11: 712074696d736e61 x10: 7274203a29393631 x9 : ffff80000868a590 [52815.043285] x8 : 35367034506e6520 x7 : 3a474f4448435441 x6 : 572056454454454e [52815.043335] x5 : ffff80000926ad60 x4 : ffffffffffffffff x3 : 0000000000000001 [52815.043384] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff80000a2150c0 [52815.043434] Call trace: [52815.043450] dev_watchdog+0x1a8/0x1e0 [52815.043485] call_timer_fn+0x7c/0x110 [52815.043523] __run_timers+0x1c8/0x1ec [52815.043556] run_timer_softirq+0x2c/0x50 [52815.043590] __do_softirq+0x1e4/0x29c [52815.043619] ____do_softirq+0x18/0x24 [52815.043649] call_on_irq_stack+0x24/0x4c [52815.043679] do_softirq_own_stack+0x24/0x30 [52815.043709] __irq_exit_rcu+0x74/0xc4 [52815.043739] irq_exit_rcu+0x18/0x24 [52815.043767] el1_interrupt+0x98/0xa4 [52815.043802] el1h_64_irq_handler+0x18/0x24 [52815.043835] el1h_64_irq+0x74/0x78 [52815.043860] arch_local_irq_enable+0xc/0x28 [52815.043894] cpuidle_enter+0x40/0x58 [52815.043925] do_idle+0x230/0x250 [52815.043960] cpu_startup_entry+0x3c/0x40 [52815.043994] kernel_init+0x0/0x138 [52815.044028] arch_post_acpi_subsys_init+0x0/0x28 [52815.044058] start_kernel+0x6f4/0x734 [52815.044085] __primary_switched+0xbc/0xc4 [52815.044120] PC: 0xffff800008f1ade0: [52815.044138] abe0 d503201f 52800022 f9000001 b9000802 d503233f 3900301f b40000e1 d2994003 [52815.044247] ac00 52800464 f2a77343 9ac10862 36f80082 b9000802 d50323bf d65f03c0 71000484 [52815.044351] ac20 54ffff80 39403002 d37ff863 11000442 39003002 17fffff5 aa1e03e9 d503201f [52815.044455] ac40 d503233f a9bd7bfd 910003fd a90153f3 d1122013 a9025bf5 aa0003f5 d102b000 [52815.044559] ac60 97fffe47 b943ca76 d000ae61 91090021 d2800000 d2802802 6b0002df 540001a8 [52815.044663] ac80 52800020 d102b2a2 52800001 089ffc41 34000060 aa1303e0 97fffdf6 a94153f3 [52815.044767] aca0 a9425bf5 a8c37bfd d50323bf d65f03c0 f941e274 9b025003 91000400 f9400463 [52815.044871] acc0 eb01007f 54fffda0 d14022a0 f97dd801 721f003f 54fffd60 f97dd800 3607fd20 [52815.044974] ace0 aa1303e0 97fffc8d 72001c1f 54fffca0 aa1403e1 90009762 52800014 6b16029f [52815.045078] ad00 54000181 90009760 b984b261 f944e000 8b000020 97c7efb3 aa0003e1 aa1503e0 [52815.045181] ad20 97c7f94f 7100001f 1a9f07e0 17ffffd6 f9404820 f9404423 f240041f 54000680 [52815.045285] ad40 f944e044 b984b260 cb040000 ab03001f 540005e5 91018021 f9800031 c85f7c20 [52815.045389] ad60 91000400 c8027c20 35ffffa2 d000b1e0 911d0000 b9400800 7100001f 5400018d [52815.045492] ad80 97fffb2b b00063f6 910022d6 b8606ac0 97fffb1d 72001c1f 540000a0 d2800000 [52815.045596] ada0 2a1403e2 aa1303e1 97ffa8f9 9000b140 3956e801 35000181 52800021 3916e801 [52815.045699] adc0 aa1303e0 97fed836 aa0003e2 2a1403e3 aa1303e1 b00050e0 91320400 97c59cb6 [52815.045803] ade0* d4210000 aa1303e0 97fffe73 f9406a60 2a1403e1 f9404c02 aa1303e0 d63f0040 [52815.045906] ae00 aa1303e0 97fffc18 17ffffbf 11000694 91050021 17ffffba aa1e03e9 d503201f [52815.046010] ae20 d503233f a9b77bfd 910003fd a90153f3 a9025bf5 2a0103f5 d5384101 a90363f7 [52815.046113] ae40 a9046bf9 a90573fb f9429c22 f90047e2 d2800002 91060001 f9003be1 91090001 [52815.046217] ae60 910c0000 a90783e1 90005220 d2800302 52819801 f947cc00 97cc6880 b4000200 [52815.046320] ae80 aa0003f3 d37d7eb7 d2800014 2a1403f6 8b140e60 714202bf 54000169 f900001f [52815.046423] aea0 510006d4 8b34ce74 510006d6 310006df 54000ba1 aa1303e0 97cc6be2 12800160 [52815.046527] aec0 1400004b aa1703e0 12800002 5281b801 97cc3744 f8347a60 b4fffe40 91000694 [52815.046631] aee0 f1000e9f 54fffd41 71007ebf f000ba58 f000ba57 9101c3fc 912ff318 913042f7 [52815.046734] af00 52800216 d280001b 1a9fc6c0 b9006fe0 f9400380 91012000 d53b4239 12190321 [52815.046837] af20 35000101 b9400301 52801402 7100003f 52800c01 1a82d021 92401c21 d50343df [52815.046941] af40 97fffd7e 52800016 f9400394 91001280 97fffd8b f87b6a7a aa1403e0 97fffb9f [52815.047045] af60 aa0003e1 6b1602bf b5000500 b9406fe0 1a9fc2d6 29100295 91001281 f9404680 [52815.047148] af80 b9000296 f900229f f900469a f83b6a60 52800000 089ffc20 f9400381 91012021 [52815.047252] afa0 089ffc20 d51b4239 b94002e0 7100001f 5400004d d5033f9f 9100237b 9100239c [52815.047357] afc0 f100637f 54fffa61 f9400260 97cc3749 f9400660 97cc3747 f9400a60 97cc3745 [52815.047461] LR: 0xffff800008f1ade0: [52815.047478] abe0 d503201f 52800022 f9000001 b9000802 d503233f 3900301f b40000e1 d2994003 [52815.047582] ac00 52800464 f2a77343 9ac10862 36f80082 b9000802 d50323bf d65f03c0 71000484 [52815.047686] ac20 54ffff80 39403002 d37ff863 11000442 39003002 17fffff5 aa1e03e9 d503201f [52815.047790] ac40 d503233f a9bd7bfd 910003fd a90153f3 d1122013 a9025bf5 aa0003f5 d102b000 [52815.047894] ac60 97fffe47 b943ca76 d000ae61 91090021 d2800000 d2802802 6b0002df 540001a8 [52815.047998] ac80 52800020 d102b2a2 52800001 089ffc41 34000060 aa1303e0 97fffdf6 a94153f3 [52815.048101] aca0 a9425bf5 a8c37bfd d50323bf d65f03c0 f941e274 9b025003 91000400 f9400463 [52815.048205] acc0 eb01007f 54fffda0 d14022a0 f97dd801 721f003f 54fffd60 f97dd800 3607fd20 [52815.048308] ace0 aa1303e0 97fffc8d 72001c1f 54fffca0 aa1403e1 90009762 52800014 6b16029f [52815.048412] ad00 54000181 90009760 b984b261 f944e000 8b000020 97c7efb3 aa0003e1 aa1503e0 [52815.048516] ad20 97c7f94f 7100001f 1a9f07e0 17ffffd6 f9404820 f9404423 f240041f 54000680 [52815.048619] ad40 f944e044 b984b260 cb040000 ab03001f 540005e5 91018021 f9800031 c85f7c20 [52815.048723] ad60 91000400 c8027c20 35ffffa2 d000b1e0 911d0000 b9400800 7100001f 5400018d [52815.048827] ad80 97fffb2b b00063f6 910022d6 b8606ac0 97fffb1d 72001c1f 540000a0 d2800000 [52815.048930] ada0 2a1403e2 aa1303e1 97ffa8f9 9000b140 3956e801 35000181 52800021 3916e801 [52815.049034] adc0 aa1303e0 97fed836 aa0003e2 2a1403e3 aa1303e1 b00050e0 91320400 97c59cb6 [52815.049137] ade0* d4210000 aa1303e0 97fffe73 f9406a60 2a1403e1 f9404c02 aa1303e0 d63f0040 [52815.049241] ae00 aa1303e0 97fffc18 17ffffbf 11000694 91050021 17ffffba aa1e03e9 d503201f [52815.049344] ae20 d503233f a9b77bfd 910003fd a90153f3 a9025bf5 2a0103f5 d5384101 a90363f7 [52815.049448] ae40 a9046bf9 a90573fb f9429c22 f90047e2 d2800002 91060001 f9003be1 91090001 [52815.049551] ae60 910c0000 a90783e1 90005220 d2800302 52819801 f947cc00 97cc6880 b4000200 [52815.049655] ae80 aa0003f3 d37d7eb7 d2800014 2a1403f6 8b140e60 714202bf 54000169 f900001f [52815.049759] aea0 510006d4 8b34ce74 510006d6 310006df 54000ba1 aa1303e0 97cc6be2 12800160 [52815.049862] aec0 1400004b aa1703e0 12800002 5281b801 97cc3744 f8347a60 b4fffe40 91000694 [52815.049966] aee0 f1000e9f 54fffd41 71007ebf f000ba58 f000ba57 9101c3fc 912ff318 913042f7 [52815.050069] af00 52800216 d280001b 1a9fc6c0 b9006fe0 f9400380 91012000 d53b4239 12190321 [52815.050173] af20 35000101 b9400301 52801402 7100003f 52800c01 1a82d021 92401c21 d50343df [52815.050277] af40 97fffd7e 52800016 f9400394 91001280 97fffd8b f87b6a7a aa1403e0 97fffb9f [52815.050380] af60 aa0003e1 6b1602bf b5000500 b9406fe0 1a9fc2d6 29100295 91001281 f9404680 [52815.050484] af80 b9000296 f900229f f900469a f83b6a60 52800000 089ffc20 f9400381 91012021 [52815.050587] afa0 089ffc20 d51b4239 b94002e0 7100001f 5400004d d5033f9f 9100237b 9100239c [52815.050691] afc0 f100637f 54fffa61 f9400260 97cc3749 f9400660 97cc3747 f9400a60 97cc3745 [52815.050795] SP: 0xffff800008003e40: [52815.050812] 3c40 08003c60 ffff8000 08031604 ffff8000 08003cf0 ffff8000 00000000 00000000 [52815.050917] 3c60 08003cb0 ffff8000 0922e818 ffff8000 08003cf0 ffff8000 09b972f4 ffff8000 [52815.051021] 3c80 f2000800 00000000 00000200 6f8bdfff 60400009 00000000 00f059c0 00000001 [52815.051125] 3ca0 08003f00 ffff8000 08f1ac38 ffff8000 08003ce0 ffff8000 0922ec3c ffff8000 [52815.051229] 3cc0 f6164000 ffff0004 00000000 00000000 08003e40 ffff8000 08f1ade0 ffff8000 [52815.051332] 3ce0 08003e20 ffff8000 080112e0 ffff8000 0a2150c0 ffff8000 00000000 00000000 [52815.051436] 3d00 00000000 00000000 00000001 00000000 ffffffff ffffffff 0926ad60 ffff8000 [52815.051539] 3d20 4454454e 57205645 48435441 3a474f44 506e6520 35367034 0868a590 ffff8000 [52815.051643] 3d40 29393631 7274203a 6d736e61 71207469 65756575 74203020 64656d69 74756f20 [52815.051746] 3d60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.051848] 3d80 00000000 00000000 f6164000 ffff0004 00000000 00000000 f6164488 ffff0004 [52815.051951] 3da0 00000001 00000000 00000100 00000000 00f059c0 00000001 08003f00 ffff8000 [52815.052055] 3dc0 08f1ac38 ffff8000 00000100 00000000 0a206000 ffff8000 08003e40 ffff8000 [52815.052159] 3de0 08f1ade0 ffff8000 08003e40 ffff8000 08f1ade0 ffff8000 60400009 00000000 [52815.052262] 3e00 08003e30 ffff8000 f6164000 ffff0004 01283aad ffff8000 00000000 00000000 [52815.052366] 3e20 08003e40 ffff8000 08f1ade0 ffff8000 00000000 00000000 fdd9beb0 ffff0004 [52815.052469] 3e40* 08003e70 ffff8000 08118588 ffff8000 0a5447c0 ffff8000 00000000 00000000 [52815.052573] 3e60 f6164488 ffff0004 08f1ac38 ffff8000 08003eb0 ffff8000 08119620 ffff8000 [52815.052677] 3e80 fdd9be40 ffff0004 00000000 00000000 f6164488 ffff0004 0a206000 ffff8000 [52815.052780] 3ea0 00000000 00000000 00f059c0 00000001 08003f50 ffff8000 08119670 ffff8000 [52815.052884] 3ec0 09b99e40 ffff8000 00000282 00000000 00000002 00000000 09ba9880 ffff8000 [52815.052987] 3ee0 0a543400 ffff8000 0a2050c0 ffff8000 00000001 00000000 0000000a 00000000 [52815.053090] 3f00 00000000 00000000 00000001 00000000 fcafceac ffff0003 09ba9848 ffff8000 [52815.053193] 3f20 00000000 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.053297] 3f40 08003f60 ffff8000 44b83200 4b641291 08003f70 ffff8000 080104b4 ffff8000 [52815.053400] 3f60 0a2050c8 ffff8000 080ef1fc ffff8000 08003ff0 ffff8000 08016440 ffff8000 [52815.053504] 3f80 09ba9880 ffff8000 080100a8 ffff8000 0a203d00 ffff8000 08d4c974 ffff8000 [52815.053608] 3fa0 20400009 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.053712] 3fc0 097978db ffff8000 0a2150c0 ffff8000 08003fe0 04200002 00f059c1 00000001 [52815.053816] 3fe0 09b99870 ffff8000 08016400 ffff8000 0a203b30 ffff8000 08016400 ffff8000 [52815.053920] 4000 ******** ******** ******** ******** ******** ******** ******** ******** [52815.054040] 4020 ******** ******** ******** ******** ******** ******** ******** ******** [52815.054154] X0: 0xffff80000a2150c0: [52815.054172] 4ec0 32303220 00000034 00000000 00000000 00000000 00000000 00000000 00000000 [52815.054276] 4ee0 00000000 63726161 00343668 00000000 00000000 00000000 00000000 00000000 [52815.054378] 4f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.054480] 4f20 00000000 6f6e2800 0029656e 00000000 00000000 00000000 00000000 00000000 [52815.054583] 4f40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.054685] 4f60 00000000 00000000 0a2281b8 ffff8000 00000000 00000000 00000000 00000000 [52815.054788] 4f80 0926f3a8 ffff8000 effffffe 00000002 00008001 00000000 097b7020 ffff8000 [52815.054892] 4fa0 00000000 00000000 08015008 ffff8000 00000000 00000000 00000000 00000000 [52815.054994] 4fc0 08297cb4 ffff8000 00000000 00000000 00000000 00000000 fcb21100 ffff0003 [52815.055097] 4fe0 09784852 ffff8000 0a5e4078 ffff8000 00000004 000001a4 00000000 00000000 [52815.055201] 5000 0808d2bc ffff8000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.055304] 5020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.055405] 5040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.055507] 5060 097847d4 ffff8000 00000000 00000000 0a215070 ffff8000 0a215070 ffff8000 [52815.055611] 5080 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.055712] 50a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.055814] 50c0* 00000008 00000000 00000100 00000001 00000000 00000000 00000000 00000000 [52815.055916] 50e0 0a200000 ffff8000 00000002 04200002 00000000 00000001 00000000 00000000 [52815.056019] 5100 00000030 00000000 00000003 00000000 00f059c0 00000001 f4400000 ffff0004 [52815.056122] 5120 00000000 00000000 00000001 00000078 00000078 00000078 00000000 00000000 [52815.056225] 5140 00100000 00000000 00400000 00000000 00000000 00000000 00000000 00000000 [52815.056327] 5160 00000000 00000000 0a215168 ffff8000 0a215168 ffff8000 00000000 00000000 [52815.056430] 5180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.056532] 51a0 00000000 00000000 00000000 00000000 00000000 00000000 fddac0c0 ffff0004 [52815.056634] 51c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.056736] 51e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.056837] 5200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.056939] 5220 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.057040] 5240 0a215240 ffff8000 0a215240 ffff8000 00000000 00000000 00000000 00000000 [52815.057143] 5260 0000001e 00000000 00000000 00000000 0a215270 ffff8000 00000000 00000000 [52815.057246] 5280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.057348] 52a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.057457] X5: 0xffff80000926ad60: [52815.057474] ab60 00000000 00000000 00000000 00000000 00000000 00000000 0807e0a0 ffff8000 [52815.057577] ab80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.057679] aba0 00000000 00000000 6b736174 00000000 00000000 00000000 00000000 00000000 [52815.057782] abc0 08435840 ffff8000 08436418 ffff8000 00000000 00000000 00000000 00000000 [52815.057885] abe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.057987] ac00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.058088] ac20 080821cc ffff8000 00000000 00000000 082c3058 ffff8000 00000000 00000000 [52815.058192] ac40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.058294] ac60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.058396] ac80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.058497] aca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.058598] acc0 00000000 00000000 46014750 20530120 00205200 4200204d 20550020 00204400 [52815.058702] ace0 57002041 20430020 00204901 4501204f 204c0120 01204b00 54012058 204e0120 [52815.058806] ad00 61726301 6b5f6873 63657865 736f705f 6f6e5f74 69666974 00737265 696e6170 [52815.058909] ad20 6e6f5f63 7261775f 6170006e 5f657375 6f5f6e6f 0073706f 696e6170 72705f63 [52815.059013] ad40 00746e69 696e6170 00000063 00000000 05000500 00000000 00000000 00000000 [52815.059116] ad60* 00000001 00000000 00000002 00000000 00000004 00000000 00000008 00000000 [52815.059218] ad80 00000010 00000000 00000020 00000000 00000040 00000000 00000080 00000000 [52815.059320] ada0 00000100 00000000 00000200 00000000 00000400 00000000 00000800 00000000 [52815.059423] adc0 00001000 00000000 00002000 00000000 00004000 00000000 00008000 00000000 [52815.059526] ade0 00010000 00000000 00020000 00000000 00040000 00000000 00080000 00000000 [52815.059630] ae00 00100000 00000000 00200000 00000000 00400000 00000000 00800000 00000000 [52815.059733] ae20 01000000 00000000 02000000 00000000 04000000 00000000 08000000 00000000 [52815.059836] ae40 10000000 00000000 20000000 00000000 40000000 00000000 80000000 00000000 [52815.059940] ae60 00000000 00000001 00000000 00000002 00000000 00000004 00000000 00000008 [52815.060041] ae80 00000000 00000010 00000000 00000020 00000000 00000040 00000000 00000080 [52815.060144] aea0 00000000 00000100 00000000 00000200 00000000 00000400 00000000 00000800 [52815.060247] aec0 00000000 00001000 00000000 00002000 00000000 00004000 00000000 00008000 [52815.060350] aee0 00000000 00010000 00000000 00020000 00000000 00040000 00000000 00080000 [52815.060453] af00 00000000 00100000 00000000 00200000 00000000 00400000 00000000 00800000 [52815.060556] af20 00000000 01000000 00000000 02000000 00000000 04000000 00000000 08000000 [52815.060660] af40 00000000 10000000 00000000 20000000 00000000 40000000 00000000 80000000 [52815.060769] X9: 0xffff80000868a590: [52815.060787] a390 1a939000 b9007420 52800020 a94153f3 a9425bf5 a8c37bfd d50323bf d65f03c0 [52815.060891] a3b0 aa1e03e9 d503201f d503233f a9be7bfd 910003fd f9000bf3 aa0003f3 97fffe4f [52815.060995] a3d0 7100041f 540000a0 2a0003e1 51104260 71000c3f 54000040 51004260 f9400bf3 [52815.061098] a3f0 a8c27bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9bb7bfd 910003fd [52815.061202] a410 a90153f3 aa0003f3 a9025bf5 b000a875 910022b5 a90363f7 aa0103f7 f90023f9 [52815.061306] a430 97fffe12 b8756800 97e64c0f d360fc14 aa0003f6 12005c00 2a146014 910022e0 [52815.061409] a450 97fffe0e eb40829f 54000501 b000dc34 91040294 97fffe05 f9400279 f9401298 [52815.061513] a470 b838681f cb1902f9 97fffe00 f9401298 8b180000 f9000417 97fffdfc f9400661 [52815.061617] a490 f9401297 8b170000 8b190021 f9000c01 97fffdf6 a9419281 b201f3e3 f2955563 [52815.061720] a4b0 aa1603e2 8b040004 91006084 cb010273 b8756801 b0008b20 91148c00 9343fe73 [52815.061824] a4d0 1b037e63 942d85c8 52800000 a94153f3 a9425bf5 a94363f7 f94023f9 a8c57bfd [52815.061927] a4f0 d50323bf d65f03c0 52800020 17fffff8 d503233f a9bf7bfd 910003fd 97fe7cbf [52815.062031] a510 a8c17bfd d50323bf d65f03c0 aa1e03e9 d503201f d503233f a9ba7bfd 910003fd [52815.062134] a530 a90153f3 aa0003f4 a9025bf5 a90363f7 a9046bf9 f9002bfb f9400400 f1003c1f [52815.062238] a550 540008a9 d4210000 a94153f3 a9425bf5 a94363f7 a9446bf9 f9402bfb a8c67bfd [52815.062341] a570 d50323bf d65f03c0 5280001a 2a1903e0 97e64bbd 927cec13 2a1903e0 97e64bba [52815.062445] a590* b9400303 110006e2 2a0303e1 93407c42 6b0302ff 54000222 12000c03 aa1503e0 [52815.062549] a5b0 1ac322c3 2a030343 12003c7a 97ffffd1 aa0003f9 b9400300 6b19001f 540000e9 [52815.062652] a5d0 2a1903e0 97e64ba8 927cec01 eb01027f 540003e0 51000737 d360fe60 d350fe61 [52815.062755] a5f0 92403f5a d3601c21 d3501c00 aa010000 d348fe61 d3585e73 92540e73 d3701c21 [52815.062859] a610 aa130021 aa010000 f9400681 53081c21 aa1a0021 aa010000 d518cba0 110006e2 [52815.062963] a630 b9400301 93407c42 aa1503e0 97ffffb1 aa0003f9 2a0003f7 b9400300 6b00033f [52815.063066] a650 54fff943 d5033fdf 17ffffc0 2a1903f7 17ffffcc aa0103f5 d5033a9f f000dc18 [52815.063170] a670 52800002 9130c318 52800036 17ffffed aa1e03e9 d503201f d503233f a9bb7bfd [52815.063274] a690 910003fd a9025bf5 b000dc36 910402d6 a90153f3 aa0103f3 a90363f7 aa0003f8 [52815.063377] a6b0 d5384100 f9429c01 f90027e1 d2800001 f9403ec0 b4000200 b9401a60 aa0203f7 [52815.063480] a6d0 aa0303f4 941cc8f4 aa0003f5 b5000320 d4210000 128002a0 d5384101 f94027e3 [52815.063584] a6f0 f9429c22 eb020063 d2800002 54000340 942e93e4 12800160 17fffff8 f94023e0 [52815.063687] a710 97ffff28 f9403ec2 910062a1 f8605840 94002508 37fffe20 93407c00 f90002e0 [52815.063791] a730 b9401660 12000c00 b9000280 14000008 aa1403e3 910103e2 aa1303e1 aa1803e0 [52815.063895] a750 97fffe61 34fffdc0 d4210000 52800000 17ffffe2 a94153f3 a9425bf5 a94363f7 [52815.063998] a770 a8c57bfd d50323bf d65f03c0 d503233f d503201f d503201f 14000008 52800020 [52815.064116] X19: 0xffff0004f6164000: [52815.064133] 3e00 f6163e00 ffff0004 f6163e00 ffff0004 00000000 00000000 f6163e18 ffff0004 [52815.064237] 3e20 f6163e18 ffff0004 f61d7600 ffff0004 94f88501 00000000 00000000 00000000 [52815.064340] 3e40 00000000 00000000 00000000 00000000 00000000 00000000 00000002 00000000 [52815.064442] 3e60 00020000 00800000 00000000 00200002 00000100 00000000 00021000 00000080 [52815.064546] 3e80 40002000 00000080 00000000 00200000 00000000 00000000 000a0000 00000020 [52815.064650] 3ea0 00821040 00000100 00000000 00000000 10010200 00012000 00000000 10000000 [52815.064753] 3ec0 00000000 00000008 00000000 00000000 00200000 00000000 00000000 00400000 [52815.064856] 3ee0 00000008 00000000 00000000 01020000 00000000 00400010 00010100 01000000 [52815.064959] 3f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.065061] 3f20 50001000 00000000 03000001 00000000 00000000 00000000 00040000 00000200 [52815.065164] 3f40 00000000 00000000 00000000 08001000 00000000 00000000 00000100 01000000 [52815.065267] 3f60 00000000 00000000 00020000 00000000 00000000 00000001 01008000 10020800 [52815.065370] 3f80 00000000 00000000 00000000 01000000 00000000 00000000 20000000 00002000 [52815.065473] 3fa0 40000104 04000002 00040000 02020008 00000000 01800400 00200000 01001000 [52815.065577] 3fc0 00000000 00000002 01200000 04000002 04000000 00000000 00000000 00000000 [52815.065679] 3fe0 00400040 00010000 00400000 00010840 00040000 04400200 00004000 40000011 [52815.065784] 4000* 34506e65 73353670 00000030 00000000 f5dae300 ffff0004 00000000 00000000 [52815.065887] 4020 00000000 00000000 00000000 00000000 00000000 00000000 00000003 00000000 [52815.065989] 4040 f0994040 ffff0004 fdb68040 ffff0003 f6164b00 ffff0004 f6164b00 ffff0004 [52815.066093] 4060 f6164060 ffff0004 f6164060 ffff0004 f6164070 ffff0004 f6164070 ffff0004 [52815.066196] 4080 f6164080 ffff0004 f6164080 ffff0004 f13605b8 ffff0004 f13605b8 ffff0004 [52815.066299] 40a0 f61640a0 ffff0004 f61640a0 ffff0004 f61640b0 ffff0004 f61640b0 ffff0004 [52815.066403] 40c0 00001003 00000000 00028820 00000000 01282a18 ffff8000 00000002 000e0000 [52815.066507] 40e0 000005dc 00000000 000041b2 00000100 00194993 0a001b00 00004992 00000100 [52815.066611] 4100 00090023 00000000 10000001 00000000 00000001 00000000 00000000 00000000 [52815.066713] 4120 00000044 000023ea 040e0001 00000000 00000000 00000000 00000000 00000000 [52815.066816] 4140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.066918] 4160 00000000 00000000 00000000 00000000 00000080 00000000 00000000 00000000 [52815.067020] 4180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.067122] 41a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.067223] 41c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.067325] 41e0 00000000 00000000 00000000 00000000 00000001 00000001 00000000 00000000 [52815.067429] X21: 0xffff0004f6164488: [52815.067447] 4288 0c3a0280 ffff0001 f7e82a80 ffff0004 00000003 00000000 f7e82610 ffff0004 [52815.067550] 42a8 f6c19e80 ffff0004 f6c19e80 ffff0004 00000001 00000000 f6c19e90 ffff0004 [52815.067654] 42c8 f3f92780 ffff0004 00000000 00000000 00000000 00000000 fed9c400 ffff0003 [52815.067757] 42e8 f5e84800 ffff0004 00000000 00000000 00000000 00000000 00000000 00000000 [52815.067859] 4308 00000000 00000000 00000000 00000000 f6c19ea8 ffff0004 ff872000 ffff0003 [52815.067962] 4328 00000001 00000001 00000000 00000000 00000000 00000000 00000000 00010000 [52815.068064] 4348 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.068166] 4368 00000000 00000000 ffffffff 0000ffff 00000000 00000000 00000000 00000000 [52815.068268] 4388 00000000 00000000 00000000 00000000 00000000 00000000 fdb60010 ffff0003 [52815.068371] 43a8 00000000 00000000 00000000 00000000 00000000 00000000 f6156200 ffff0004 [52815.068473] 43c8 00000001 00000001 0dd98c00 ffff0001 000003e8 00000001 00000000 00000000 [52815.068576] 43e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.068677] 4408 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.068779] 4428 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.068881] 4448 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.068982] 4468 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.069083] 4488* 00000122 dead0000 00000000 00000000 00f059b4 00000001 08f1ac38 ffff8000 [52815.069187] 44a8 29c00000 00000000 000005dc 00000000 00000000 00000000 00000000 00000000 [52815.069290] 44c8 fbd14da0 00007bfa f61644d0 ffff0004 f61644d0 ffff0004 00000001 00000000 [52815.069393] 44e8 00000000 00000000 00000000 00000000 0a6848c0 ffff8000 00000000 00000000 [52815.069495] 4508 00000000 00000000 fbd14de0 00007bfa 00000000 00000000 00000000 00000000 [52815.069598] 4528 00000000 00000000 f6e68c00 ffff0004 fd27ac08 ffff0003 f117e808 ffff0004 [52815.069701] 4548 f5dae200 ffff0004 fd235100 ffff0003 0a44edd8 ffff8000 fec6fd00 ffff0003 [52815.069805] 4568 00000004 00000007 f08250c8 ffff0004 ff8e0e00 ffff0003 00000000 00000000 [52815.069907] 4588 00000000 00000000 00000000 00000000 00000000 00000000 f6164000 ffff0004 [52815.070009] 45a8 00000000 00000000 00000000 00000000 00000000 00000000 f61645c0 ffff0004 [52815.070112] 45c8 f61645c0 ffff0004 f61645d0 ffff0004 f61645d0 ffff0004 f61645e0 ffff0004 [52815.070215] 45e8 f61645e0 ffff0004 f61645f0 ffff0004 f61645f0 ffff0004 00000000 00000000 [52815.070319] 4608 00000000 00000104 00000000 00000000 fd27ace8 ffff0003 f117e8e8 ffff0004 [52815.070422] 4628 ffffffff 00000000 00000000 00000000 f6164638 ffff0004 f6164638 ffff0004 [52815.070525] 4648 00000000 00000000 00000004 00000000 f6164658 ffff0004 00000000 00000000 [52815.070627] 4668 00000000 00000000 00000000 00000000 00000000 00000000 0897faa8 ffff8000 [52815.070736] X25: 0xffff800008003f00: [52815.070753] 3d00 00000000 00000000 00000001 00000000 ffffffff ffffffff 0926ad60 ffff8000 [52815.070857] 3d20 4454454e 57205645 48435441 3a474f44 506e6520 35367034 0868a590 ffff8000 [52815.070961] 3d40 29393631 7274203a 6d736e61 71207469 65756575 74203020 64656d69 74756f20 [52815.071065] 3d60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.071167] 3d80 00000000 00000000 f6164000 ffff0004 00000000 00000000 f6164488 ffff0004 [52815.071270] 3da0 00000001 00000000 00000100 00000000 00f059c0 00000001 08003f00 ffff8000 [52815.071373] 3dc0 08f1ac38 ffff8000 00000100 00000000 0a206000 ffff8000 08003e40 ffff8000 [52815.071477] 3de0 08f1ade0 ffff8000 08003e40 ffff8000 08f1ade0 ffff8000 60400009 00000000 [52815.071580] 3e00 08003e30 ffff8000 f6164000 ffff0004 01283aad ffff8000 00000000 00000000 [52815.071684] 3e20 08003e40 ffff8000 08f1ade0 ffff8000 00000000 00000000 fdd9beb0 ffff0004 [52815.071787] 3e40 08003e70 ffff8000 08118588 ffff8000 0a5447c0 ffff8000 00000000 00000000 [52815.071891] 3e60 f6164488 ffff0004 08f1ac38 ffff8000 08003eb0 ffff8000 08119620 ffff8000 [52815.071995] 3e80 fdd9be40 ffff0004 00000000 00000000 f6164488 ffff0004 0a206000 ffff8000 [52815.072098] 3ea0 00000000 00000000 00f059c0 00000001 08003f50 ffff8000 08119670 ffff8000 [52815.072202] 3ec0 09b99e40 ffff8000 00000282 00000000 00000002 00000000 09ba9880 ffff8000 [52815.072305] 3ee0 0a543400 ffff8000 0a2050c0 ffff8000 00000001 00000000 0000000a 00000000 [52815.072407] 3f00* 00000000 00000000 00000001 00000000 fcafceac ffff0003 09ba9848 ffff8000 [52815.072510] 3f20 00000000 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.072613] 3f40 08003f60 ffff8000 44b83200 4b641291 08003f70 ffff8000 080104b4 ffff8000 [52815.072718] 3f60 0a2050c8 ffff8000 080ef1fc ffff8000 08003ff0 ffff8000 08016440 ffff8000 [52815.072821] 3f80 09ba9880 ffff8000 080100a8 ffff8000 0a203d00 ffff8000 08d4c974 ffff8000 [52815.072925] 3fa0 20400009 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.073029] 3fc0 097978db ffff8000 0a2150c0 ffff8000 08003fe0 04200002 00f059c1 00000001 [52815.073133] 3fe0 09b99870 ffff8000 08016400 ffff8000 0a203b30 ffff8000 08016400 ffff8000 [52815.073237] 4000 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073350] 4020 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073462] 4040 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073572] 4060 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073683] 4080 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073793] 40a0 ******** ******** ******** ******** ******** ******** ******** ******** [52815.073904] 40c0 ******** ******** ******** ******** ******** ******** ******** ******** [52815.074015] 40e0 ******** ******** ******** ******** ******** ******** ******** ******** [52815.074127] X26: 0xffff800008f1ac38: [52815.074145] aa38 f9404400 f861d813 b4000093 aa1503e0 97fffce4 aa0003f3 110006d6 f100027f [52815.074250] aa58 910302b5 7a420ac0 54fffe2d b4000493 b9401280 362802e0 aa1303e1 aa1403e0 [52815.074354] aa78 97fffc33 97fffbec aa1303e1 f9402a95 8b0002a0 97ffff9b aa1403e0 97fffc49 [52815.074458] aa98 aa1303e0 a94153f3 a9425bf5 a94363f7 f94023f9 a8c57bfd d50323bf d65f03c0 [52815.074561] aab8 d2800013 17ffffc1 d2800013 17ffffe3 b9402a61 b940c680 4b010000 b900c680 [52815.074666] aad8 aa1303e1 9102c280 97ffff86 b940aa80 51000400 b900aa80 17ffffea d2800013 [52815.074769] aaf8 17ffffe8 aa1e03e9 d503201f d503233f a9bb7bfd 910003fd a90153f3 a9025bf5 [52815.074873] ab18 aa0003f5 a90363f7 f90023f9 f9402000 f9400000 b943d816 34000536 910602b3 [52815.074976] ab38 71007edf 52800217 d37d7ed8 1a9fc6f7 aa1303f9 52800014 714202df 540000e9 [52815.075080] ab58 93407e94 d2801800 9b006694 f900469f 12800160 14000013 aa1803e0 12800002 [52815.075184] ab78 5281b801 97cc3819 f9004660 b4ffff20 11000694 29007e7f 29087e7f b9004a7f [52815.075287] ab98 29105e76 91030273 71000e9f 54fffd61 b94012a0 321e0000 b90012a0 52800000 [52815.075391] abb8 a94153f3 a9425bf5 a94363f7 f94023f9 a8c57bfd d50323bf d65f03c0 128002a0 [52815.075494] abd8 17fffff8 aa1e03e9 d503201f 52800022 f9000001 b9000802 d503233f 3900301f [52815.075597] abf8 b40000e1 d2994003 52800464 f2a77343 9ac10862 36f80082 b9000802 d50323bf [52815.075701] ac18 d65f03c0 71000484 54ffff80 39403002 d37ff863 11000442 39003002 17fffff5 [52815.075805] ac38* aa1e03e9 d503201f d503233f a9bd7bfd 910003fd a90153f3 d1122013 a9025bf5 [52815.075908] ac58 aa0003f5 d102b000 97fffe47 b943ca76 d000ae61 91090021 d2800000 d2802802 [52815.076012] ac78 6b0002df 540001a8 52800020 d102b2a2 52800001 089ffc41 34000060 aa1303e0 [52815.076116] ac98 97fffdf6 a94153f3 a9425bf5 a8c37bfd d50323bf d65f03c0 f941e274 9b025003 [52815.076220] acb8 91000400 f9400463 eb01007f 54fffda0 d14022a0 f97dd801 721f003f 54fffd60 [52815.076323] acd8 f97dd800 3607fd20 aa1303e0 97fffc8d 72001c1f 54fffca0 aa1403e1 90009762 [52815.076427] acf8 52800014 6b16029f 54000181 90009760 b984b261 f944e000 8b000020 97c7efb3 [52815.076531] ad18 aa0003e1 aa1503e0 97c7f94f 7100001f 1a9f07e0 17ffffd6 f9404820 f9404423 [52815.076635] ad38 f240041f 54000680 f944e044 b984b260 cb040000 ab03001f 540005e5 91018021 [52815.076738] ad58 f9800031 c85f7c20 91000400 c8027c20 35ffffa2 d000b1e0 911d0000 b9400800 [52815.076842] ad78 7100001f 5400018d 97fffb2b b00063f6 910022d6 b8606ac0 97fffb1d 72001c1f [52815.076946] ad98 540000a0 d2800000 2a1403e2 aa1303e1 97ffa8f9 9000b140 3956e801 35000181 [52815.077050] adb8 52800021 3916e801 aa1303e0 97fed836 aa0003e2 2a1403e3 aa1303e1 b00050e0 [52815.077153] add8 91320400 97c59cb6 d4210000 aa1303e0 97fffe73 f9406a60 2a1403e1 f9404c02 [52815.077257] adf8 aa1303e0 d63f0040 aa1303e0 97fffc18 17ffffbf 11000694 91050021 17ffffba [52815.077361] ae18 aa1e03e9 d503201f d503233f a9b77bfd 910003fd a90153f3 a9025bf5 2a0103f5 [52815.077468] X28: 0xffff80000a206000: [52815.077485] 5e00 0a205e00 ffff8000 0a205e00 ffff8000 00000000 00000000 0a205e18 ffff8000 [52815.077590] 5e20 0a205e18 ffff8000 00000000 00000000 0a205e30 ffff8000 0a205e30 ffff8000 [52815.077693] 5e40 00000000 00000000 0a205e48 ffff8000 0a205e48 ffff8000 00000000 00000000 [52815.077797] 5e60 0a205e60 ffff8000 0a205e60 ffff8000 00000000 00000000 0a205e78 ffff8000 [52815.077900] 5e80 0a205e78 ffff8000 00000000 00000000 0a205e90 ffff8000 0a205e90 ffff8000 [52815.078004] 5ea0 00000000 00000000 0a205ea8 ffff8000 0a205ea8 ffff8000 00000000 00000000 [52815.078108] 5ec0 0a205ec0 ffff8000 0a205ec0 ffff8000 00000000 00000000 0a205ed8 ffff8000 [52815.078211] 5ee0 0a205ed8 ffff8000 00000000 00000000 0a205ef0 ffff8000 0a205ef0 ffff8000 [52815.078315] 5f00 00000000 00000000 0a205f08 ffff8000 0a205f08 ffff8000 00000000 00000000 [52815.078418] 5f20 0a205f20 ffff8000 0a205f20 ffff8000 00000000 00000000 0a205f38 ffff8000 [52815.078521] 5f40 0a205f38 ffff8000 00000000 00000000 0a205f50 ffff8000 0a205f50 ffff8000 [52815.078625] 5f60 00000000 00000000 0a205f68 ffff8000 0a205f68 ffff8000 00000000 00000000 [52815.078728] 5f80 0a205f80 ffff8000 0a205f80 ffff8000 00000000 00000000 0a205f98 ffff8000 [52815.078832] 5fa0 0a205f98 ffff8000 00000000 00000000 0a205fb0 ffff8000 0a205fb0 ffff8000 [52815.078935] 5fc0 00000000 00000000 0a205fc8 ffff8000 0a205fc8 ffff8000 00000000 00000000 [52815.079039] 5fe0 0a205fe0 ffff8000 0a205fe0 ffff8000 00000000 00000000 0a205ff8 ffff8000 [52815.079142] 6000* 0a205ff8 ffff8000 00000000 00000000 0a206010 ffff8000 0a206010 ffff8000 [52815.079246] 6020 00000000 00000000 0a206028 ffff8000 0a206028 ffff8000 00000000 00000000 [52815.079349] 6040 0a206040 ffff8000 0a206040 ffff8000 00000000 00000000 0a206058 ffff8000 [52815.079452] 6060 0a206058 ffff8000 00000000 00000000 0a206070 ffff8000 0a206070 ffff8000 [52815.079555] 6080 00000000 00000000 0a206088 ffff8000 0a206088 ffff8000 00000000 00000000 [52815.079658] 60a0 0a2060a0 ffff8000 0a2060a0 ffff8000 00000000 00000000 0a2060b8 ffff8000 [52815.079762] 60c0 0a2060b8 ffff8000 00000000 00000000 0a2060d0 ffff8000 0a2060d0 ffff8000 [52815.079866] 60e0 00000000 00000000 0a2060e8 ffff8000 0a2060e8 ffff8000 00000000 00000000 [52815.079969] 6100 0a206100 ffff8000 0a206100 ffff8000 00000000 00000000 0a206118 ffff8000 [52815.080072] 6120 0a206118 ffff8000 00000000 00000000 0a206130 ffff8000 0a206130 ffff8000 [52815.080176] 6140 00000000 00000000 0a206148 ffff8000 0a206148 ffff8000 00000000 00000000 [52815.080279] 6160 0a206160 ffff8000 0a206160 ffff8000 00000000 00000000 0a206178 ffff8000 [52815.080383] 6180 0a206178 ffff8000 00000000 00000000 0a206190 ffff8000 0a206190 ffff8000 [52815.080486] 61a0 00000000 00000000 0a2061a8 ffff8000 0a2061a8 ffff8000 00000000 00000000 [52815.080589] 61c0 0a2061c0 ffff8000 0a2061c0 ffff8000 00000000 00000000 0a2061d8 ffff8000 [52815.080693] 61e0 0a2061d8 ffff8000 00000000 00000000 0a2061f0 ffff8000 0a2061f0 ffff8000 [52815.080798] X29: 0xffff800008003e40: [52815.080815] 3c40 08003c60 ffff8000 08031604 ffff8000 08003cf0 ffff8000 00000000 00000000 [52815.080919] 3c60 08003cb0 ffff8000 0922e818 ffff8000 08003cf0 ffff8000 09b972f4 ffff8000 [52815.081023] 3c80 f2000800 00000000 00000200 6f8bdfff 60400009 00000000 00f059c0 00000001 [52815.081127] 3ca0 08003f00 ffff8000 08f1ac38 ffff8000 08003ce0 ffff8000 0922ec3c ffff8000 [52815.081231] 3cc0 f6164000 ffff0004 00000000 00000000 08003e40 ffff8000 08f1ade0 ffff8000 [52815.081335] 3ce0 08003e20 ffff8000 080112e0 ffff8000 0a2150c0 ffff8000 00000000 00000000 [52815.081438] 3d00 00000000 00000000 00000001 00000000 ffffffff ffffffff 0926ad60 ffff8000 [52815.081541] 3d20 4454454e 57205645 48435441 3a474f44 506e6520 35367034 0868a590 ffff8000 [52815.081645] 3d40 29393631 7274203a 6d736e61 71207469 65756575 74203020 64656d69 74756f20 [52815.081748] 3d60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [52815.081850] 3d80 00000000 00000000 f6164000 ffff0004 00000000 00000000 f6164488 ffff0004 [52815.081953] 3da0 00000001 00000000 00000100 00000000 00f059c0 00000001 08003f00 ffff8000 [52815.082056] 3dc0 08f1ac38 ffff8000 00000100 00000000 0a206000 ffff8000 08003e40 ffff8000 [52815.082160] 3de0 08f1ade0 ffff8000 08003e40 ffff8000 08f1ade0 ffff8000 60400009 00000000 [52815.082263] 3e00 08003e30 ffff8000 f6164000 ffff0004 01283aad ffff8000 00000000 00000000 [52815.082366] 3e20 08003e40 ffff8000 08f1ade0 ffff8000 00000000 00000000 fdd9beb0 ffff0004 [52815.082470] 3e40* 08003e70 ffff8000 08118588 ffff8000 0a5447c0 ffff8000 00000000 00000000 [52815.082574] 3e60 f6164488 ffff0004 08f1ac38 ffff8000 08003eb0 ffff8000 08119620 ffff8000 [52815.082678] 3e80 fdd9be40 ffff0004 00000000 00000000 f6164488 ffff0004 0a206000 ffff8000 [52815.082781] 3ea0 00000000 00000000 00f059c0 00000001 08003f50 ffff8000 08119670 ffff8000 [52815.082884] 3ec0 09b99e40 ffff8000 00000282 00000000 00000002 00000000 09ba9880 ffff8000 [52815.082988] 3ee0 0a543400 ffff8000 0a2050c0 ffff8000 00000001 00000000 0000000a 00000000 [52815.083091] 3f00 00000000 00000000 00000001 00000000 fcafceac ffff0003 09ba9848 ffff8000 [52815.083194] 3f20 00000000 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.083297] 3f40 08003f60 ffff8000 44b83200 4b641291 08003f70 ffff8000 080104b4 ffff8000 [52815.083401] 3f60 0a2050c8 ffff8000 080ef1fc ffff8000 08003ff0 ffff8000 08016440 ffff8000 [52815.083505] 3f80 09ba9880 ffff8000 080100a8 ffff8000 0a203d00 ffff8000 08d4c974 ffff8000 [52815.083609] 3fa0 20400009 00000000 7175dd5b 00003006 00000001 00000000 097978db ffff8000 [52815.083712] 3fc0 097978db ffff8000 0a2150c0 ffff8000 08003fe0 04200002 00f059c1 00000001 [52815.083816] 3fe0 09b99870 ffff8000 08016400 ffff8000 0a203b30 ffff8000 08016400 ffff8000 [52815.083920] 4000 ******** ******** ******** ******** ******** ******** ******** ******** [52815.084032] 4020 ******** ******** ******** ******** ******** ******** ******** ******** [52815.084145] ---[ end trace 0000000000000000 ]--- [52815.098393] r8169 0004:41:00.0 enP4p65s0: ASPM disabled on Tx timeout No evidence of NIC related errors as suggested by various google hits as suggested by https://unix.stackexchange.com/questions/737187/linux-e1000e-nic-crashes-randomly-with-transmit-queue-0-timed-out
Using compile.sh for Orange Pi, PCIe/NVMe not working
ozacas replied to ScottN's topic in Advanced users - Development
this doesnt look good in your logs - means the device tree information is possibly missing/corrupted (and likely devices are missing as a result) - Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 i would check that any configuration related to DTB's is valid and pointing to the correct files. Some clues to look at include /boot/dtb* and /boot/armbianEnv.txt eg (this is a different rk3588 board, but results should be similar): $ more /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-radxa-rock-5b+.dtb rootdev=UUID=7050d993-d3c0-457c-baf0-282bfb0afb63 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u $ ls /boot/dtb* /boot/dtb: rockchip /boot/dtb-6.1.84-vendor-rk35xx: rockchip $ ls -l /boot/dtb-6.1.84-vendor-rk35xx/rockchip/rk3588-radxa-rock-5b+.dtb -rwxr-xr-x 1 root root 272592 Dec 15 10:37 /boot/dtb-6.1.84-vendor-rk35xx/rockchip/rk3588-radxa-rock-5b+.dtb -
To ease dependency maintenance, I've used the flatpak kodi on a different rk3588 SBC - works well, but surround sound is not something i've spent time on (i'm happy with stereo) The only gotcha, is migrating your kodi settings to the flatpak storage location, which is a bit funky ~/.var/app/tv.kodi.Kodi/ See https://flathub.org/apps/tv.kodi.Kodi for install details this results in the attached kodi startup log which you can inspect for the current configured capabilities: kodi.log
https://sg.sbcmirror.org/armbian/dl/orangepi5-plus/archive/ with a download labelled as 'vendor' (6.1.x kernel derived from linux-rockchip)
https://www.bjonnh.net/article/20210721_nvme4k may offer some improvements. What kernel are you using?
Question about SATA power supply on RADXA ROCK 5 ITX
ozacas replied to SuperKali's topic in Radxa Rock 5 ITX
perhaps https://github.com/ThomasKaiser/Knowledge/blob/master/articles/Quick_Preview_of_ROCK_5_ITX.md#sata-power-ports may help -
Problem with KODI on Armbian Noble Gnome + trunk MESA/VPU
ozacas replied to Tomogo's topic in Radxa Rock 5B
This is a known issue - https://github.com/xbmc/xbmc/issues/24069 not really related to Armbian per-se, but a matter of the versions being used. I used a flatpak version of kodi instead to resolve this issue, which also supports hardware acceleration. See https://flathub.org/apps/tv.kodi.Kodi -
Hi all, https://paste.armbian.com/koqimivaro vendor kernel boots, detects ethernet, wifi & nvme (booting from SD card) and seem to be working well. Also attached are the UART gathered first boot/install logs. I think the SBC accidentally skipped over the root password by resting on the enter key 😁 uart-logs.txt
OPi5 went (almost) "dead" after an "apt upgrade" (uSD card).
ozacas replied to laurentppol's topic in Orange Pi 5
Hi, There is a lot going on there - lets try to divide it up into smaller, more manageable pieces: Please report armbianmonitor -u results here so we can see a wide range of performance monitoring and debug results when the box "hangs" can you login to it anymore via another ssh connection? or is it completely non-responsive until you power cycle? does it recover automatically? are you able to connect a keyboard/monitor and login that way? libc is a very important component - it may have been corrupted by powering off just as it was being configured resulting in further unintended consequences. May need to reinstall how long was the hang? some downloads can take quite many minutes to fetch. A network issue could be a culprit here. If it hangs again, running dmesg as superuser, just after it starts to hang, can yield valuable information about problems hope this helps, -
@going a pretty broad question, but i'll try 😁 hardware accelerated video processing on rk3588 and linux - https://github.com/blakeblackshear/frigate/discussions/11502 hardware accelerated NPU via linux - https://github.com/airockchip/rknn-toolkit2/ large language models (LLM's) using NPU - https://github.com/airockchip/rknn-llm Its important to understand you will need a compatible kernel driver to connect to the hardware - most likely the best option is the vendor kernel 6.1.75 with armbian. Also this is a rapidly evolving space - hard to keep up! Depending on what you read though, often the CPU can offer better performance, although it is dependent on your requirements and the ability to utilise the hardware effectively.
@going consider https://codingfield.com/blog/2024-01/install-frigate-in-proxmox-on-orangepi5plus/ for context - it is about how fast you can detect objects in order to be able to respond as fast as the video is changing. Depends on the model and key parameters. If you wanted to process video at 30 frames per second, you'll need to make adequate detection sufficiently quickly: 1000 / 30 = 33.3ms allowing for zero other overheads. These days you might have multiple cameras, so object detection speed can be pretty important.
