David Parushev
1 Follower
  1. Hi, I have orange pi 5. I searched all over internet for information how to set on startup/power on GPIO pins behavior, but i cannot find anything. Most of GPIO pins are set to IN mode 1. Sadly I need them to output mode 1. I am scared something could burn this way since i set them to though wiringPI after kernel boot sequence is complete. Can some one give information how I can set them up at earlier point when I power on the board? I found that DTB/DTS file could do it. But there is no clear information / pin addresses I should set. Thanks in advance! Regards!
  2. Is it possible apt update/armbian-config flashed my SPI flash and that's why i have such issues ?
  3. last image burned my ethernet port 😐 installed apt-get update / apt-get upgrade / reboot and it stopped linking to my router even with static IP tried my last ubuntu image and it's still not working [ 9.795160] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree [ 9.795199] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed [ 9.795234] rk_gmac-dwmac fe010000.ethernet: no regulator found [ 9.795246] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 9.795259] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30). [ 9.795270] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10). [ 9.795291] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 9.795367] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 9.795650] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 9.796042] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 9.796060] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 9.796074] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 9.796083] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 9.796091] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 9.796099] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 9.796210] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 9.796222] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 9.796237] rk_gmac-dwmac fe010000.ethernet: rk_get_eth_addr: use serial to generate eth mac address: 00:00:a4:ab:5f:fd [ 9.796247] rk_gmac-dwmac fe010000.ethernet: rk_get_eth_addr: mac address: 00:00:a4:ab:5f:fd [ 9.796256] rk_gmac-dwmac fe010000.ethernet: device MAC address 00:00:a4:ab:5f:fd [ 9.796266] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 9.796277] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 00:00:a4:ab:5f:fd txqueuelen 1000 (Ethernet) RX packets 16 bytes 1710 (1.7 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 114 bytes 11820 (11.8 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 41
