Celona
7 -
I have Mango MQ Pro, Nezha and VisionFive2 boards and the solution for this RISC-V board was really simple, I installed Ubuntu Server and I'm happy with it, I just had to remove some unnecessary features, like DietPi does with Armbian. It is not mandatory to find excuses. https://ubuntu.com/download/risc-v
- 189 replies
- MangoPi MQ Pro
- Sipeed Nezha
(and 1 more)
Tagged with:
I've now resigned myself to the fact that using Raxda's SBCs requires external adapters, they are not able to provide even a minimal working system, as their latest Debian image demonstrates: https://github.com/radxa-build/rock-3c/releases/tag/b43. So yours don't work either, or am I doing something wrong? ____ _ _____ ____ | _ \ ___ ___| | __ |___ / / ___| | |_) / _ \ / __| |/ / |_ \| | | _ < (_) | (__| < ___) | |___ |_| \_\___/ \___|_|\_\ |____/ \____| Welcome to Armbian_community 24.11.0-trunk.4 Bookworm with Linux 6.6.47-current-rockchip64 No end-user support: untested automated build System load: 21% Up time: 0 min Memory usage: 5% of 1.93G IP: 192.168.1.163 CPU temp: 63°C Usage of /: 6% of 29G uname -a Linux rock2g 6.6.47-current-rockchip64 #1 SMP PREEMPT Mon Aug 19 04:04:32 UTC 2024 aarch64 GNU/Linux sudo dmesg -l 0,1,2,3 [ 11.942338] of_dma_request_slave_channel: dma-names property of node '/serial@fe650000' missing or empty [ 14.090200] Bluetooth: hci0: command 0x0c03 tx timeout [ 14.090306] Bluetooth: hci0: BCM: Reset failed (-110) ip a | grep "inet " inet 127.0.0.1/8 scope host lo inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether a6:a2:b0:36:4d:8f brd ff:ff:ff:ff:ff:ff inet6 2a01:e11:1400:5d0:6bf9:d83d:a987:dc3f/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 85098sec inet6 2a01:e11:1400:5d0:a4a2:b0ff:fe36:4d8f/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::a4a2:b0ff:fe36:4d8f/64 scope link valid_lft forever preferred_lft forever 3: enxb88d1254cda3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether b8:8d:12:54:cd:a3 brd ff:ff:ff:ff:ff:ff inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 valid_lft 41689sec preferred_lft 41689sec inet6 fd8c:df22:1b60:a94b:8d64:46a6:bfb8:62b8/64 scope global temporary deprecated dynamic valid_lft 475sec preferred_lft 0sec inet6 fd8c:df22:1b60:a94b:ba8d:12ff:fe54:cda3/64 scope global deprecated dynamic mngtmpaddr noprefixroute valid_lft 475sec preferred_lft 0sec inet6 2a01:e11:1400:5d0:f759:2829:fa0b:ad4e/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 84745sec inet6 2a01:e11:1400:5d0:ba8d:12ff:fe54:cda3/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::ba8d:12ff:fe54:cda3/64 scope link valid_lft forever preferred_lft forever sudo dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 4.039090] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 4.042387] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 4.042420] rk_gmac-dwmac fe010000.ethernet: TX delay(0x47). [ 4.042435] rk_gmac-dwmac fe010000.ethernet: RX delay(0x27). [ 4.042461] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 4.042527] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 4.050680] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 4.055059] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.055098] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 4.055113] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 4.055123] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 4.055133] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 4.055142] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 4.055276] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 4.055291] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.055305] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 4.055319] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 4.055331] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.302372] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.656403] asix 6-1:1.0 eth0: register 'asix' at usb-fd880000.usb-1, ASIX AX88772 USB 2.0 Ethernet, b8:8d:12:54:cd:a3 [ 4.664025] asix 6-1:1.0 enxb88d1254cda3: renamed from eth0 [ 11.660738] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.758203] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 11.768291] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found [ 11.768322] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported [ 11.768670] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock [ 11.769109] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode [ 673.250279] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx Module Size Used by lz4hc 12288 0 lz4 12288 0 zram 32768 3 binfmt_misc 20480 1 nls_iso8859_1 12288 1 hci_uart 135168 0 hantro_vpu 249856 0 v4l2_vp9 20480 1 hantro_vpu rockchip_rga 20480 0 btqca 20480 1 hci_uart videobuf2_dma_contig 20480 1 hantro_vpu btrtl 28672 1 hci_uart snd_soc_simple_card 20480 0 snd_soc_rk817 40960 1 snd_soc_hdmi_codec 20480 1 v4l2_h264 16384 1 hantro_vpu snd_soc_rockchip_i2s_tdm 20480 4 v4l2_mem2mem 24576 2 hantro_vpu,rockchip_rga videobuf2_dma_sg 16384 1 rockchip_rga btintel 40960 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card snd_soc_core 208896 5 snd_soc_rockchip_i2s_tdm,snd_soc_hdmi_codec,snd_soc_rk817,snd_soc_simple_card_utils,snd_soc_simple_card videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_dma_sg btbcm 20480 1 hci_uart videobuf2_v4l2 20480 3 hantro_vpu,rockchip_rga,v4l2_mem2mem pwm_fan 20480 0 snd_compress 24576 1 snd_soc_core bluetooth 663552 6 btrtl,btqca,btintel,hci_uart,btbcm videodev 229376 4 videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem panfrost 69632 0 snd_pcm_dmaengine 12288 1 snd_soc_core display_connector 16384 0 rk_crypto2 36864 0 snd_pcm 106496 5 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine videobuf2_common 49152 7 videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops gpu_sched 36864 1 panfrost snd_timer 36864 1 snd_pcm dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 mc 53248 5 videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem drm_shmem_helper 16384 1 panfrost sm3_generic 12288 1 rk_crypto2 snd 77824 5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm sm3 20480 1 sm3_generic at24 20480 0 rk817_charger 20480 0 soundcore 12288 1 snd apple_mfi_fastcharge 16384 0 cpufreq_dt 16384 0 cfg80211 802816 0 rfkill 24576 3 bluetooth,cfg80211 dm_mod 126976 0 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 40960 2 ax88796b 12288 1 realtek 32768 1 spi_rockchip_sfc 16384 0 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 233472 3 stmmac_platform,dwmac_rk pcs_xpcs 20480 1 stmmac asix 49152 0 usbnet 40960 1 asix
At this moment fails on ARM Cortex-A53 and Cortex-A55, works on RISC-V 64. wget https://downloads.xiph.org/releases/opus/opus-1.5.1.tar.gz tar -xf opus-1.5.1.tar.gz cd opus-1.5.1 sudo apt install autoconf automake libtool gcc make ./configure sudo make install This version brings non-marginal improvements for spoken content at low bitrate.
IngwiePhoenix, you are welcome!
I wanted to ask you why the RISC-V images are missing and in particular in one case the previous ones are also missing, e.g. https://imola.armbian.com/archive/mangopi-mq/archive
The RNNoise code and instructions for compiling it are located at https://gitlab.xiph.org/xiph/rnnoise and highlight the latest addition of Jean-Marc Valin, a developer who I can never thank enough for the work he has done. Two years have passed since the highlighted addition and therefore updated instructions on how to complete the compilation would be useful in general and not just for the hardware we have. This is the sequence of commands: sudo atp update sudo apt install autogen sudo apt install configure-debian sudo apt install dh-autoreconf ./autogen.sh ./configure make -j36 sudo make install -j36 You will now have the RNNoise libraries installed on your system and the demo program to try them in the examples folder. RNNoise is an audio noise suppression library based on a recurrent neural network and it cannot be missing on the hardware used to record the human voice. Those who don’t know it yet can find the documentation on Archiv website and further information on the Mozilla and Jean-Marc Valin's website. I’m sure someone will appreciate it.
