Helios64: Kernel oops when starting docker container
Hello! I'm able to reproducibly get a kernel oops whenever I start a docker container on my Helios64 The SD card I was running my Helios64 from died and so I reinstalled Armbian using the steps to install bookworm from this post. I did skip the steps related to hs400 and L2 cache as I'm currently running the system from an SD card. After the install seemed to be working well I installed zfs, imported my existing pool, and then installed docker. My previous setup was using docker's ZFS storage driver so I got that configured as well. Now, whenever I start up a docker container (ie by running "sudo docker run hello-world") I get the following oops from the kernel: [ 246.422387] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000038 [ 246.422400] Mem abort info: [ 246.422403] ESR = 0x0000000096000005 [ 246.422406] EC = 0x25: DABT (current EL), IL = 32 bits [ 246.422411] SET = 0, FnV = 0 [ 246.422414] EA = 0, S1PTW = 0 [ 246.422417] FSC = 0x05: level 1 translation fault [ 246.422421] Data abort info: [ 246.422423] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000 [ 246.422426] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 246.422430] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 246.422434] user pgtable: 4k pages, 48-bit VAs, pgdp=000000000942d000 [ 246.422439] [0000000000000038] pgd=0800000016225003, p4d=0800000016225003, pud=0000000000000000 [ 246.422452] Internal error: Oops: 0000000096000005 [#1] PREEMPT SMP [ 246.423015] Modules linked in: veth xt_nat xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xfrm_user xfrm_algo xt_addrtype nft_compat nf_tables nfnetlink br_netfilter bridge rfkill sunrpc lz4hc lz4 zram binfmt_misc zfs(PO) crct10dif_ce leds_pwm panfrost spl(O) gpio_charger gpu_sched drm_shmem_helper pwm_fan snd_soc_hdmi_codec snd_soc_rockchip_i2s rockchip_vdec(C) hantro_vpu rk_crypto snd_soc_core rockchip_rga snd_compress v4l2_vp9 v4l2_h264 videobuf2_dma_sg videobuf2_dma_contig ac97_bus v4l2_mem2mem snd_pcm_dmaengine snd_pcm videobuf2_memops videobuf2_v4l2 snd_timer videodev nvmem_rockchip_efuse videobuf2_common mc snd soundcore gpio_beeper ledtrig_netdev lm75 ip_tables x_tables autofs4 efivarfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear cdc_ncm cdc_ether usbnet r8152 realtek rockchipdrm dw_mipi_dsi fusb302 dw_hdmi tcpm analogix_dp dwmac_rk typec drm_display_helper stmmac_platform cec [ 246.423214] drm_dma_helper stmmac drm_kms_helper drm adc_keys pcs_xpcs [ 246.431612] CPU: 5 PID: 2686 Comm: dockerd Tainted: P C O 6.6.8-edge-rockchip64 #1 [ 246.432383] Hardware name: Helios64 (DT) [ 246.432731] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 246.433344] pc : get_device_state+0x28/0x88 [ledtrig_netdev] [ 246.433854] lr : netdev_trig_notify+0x13c/0x1fc [ledtrig_netdev] [ 246.434387] sp : ffff80008b2ab3e0 [ 246.434680] x29: ffff80008b2ab3e0 x28: ffff0000154d3378 x27: ffff80007a36dc30 [ 246.435313] x26: ffff800081c89a40 x25: ffff800081907008 x24: ffff80008b2ab5b8 [ 246.435944] x23: 000000000000000b x22: ffff000005efb000 x21: ffff0000154d3300 [ 246.436575] x20: ffff0000154d3378 x19: ffff0000154d3300 x18: ffff80008d293c58 [ 246.437206] x17: 000000040044ffff x16: 00500074b5503510 x15: 0000000000000000 [ 246.437837] x14: ffffffffffffffff x13: 0000000000000020 x12: 0101010101010101 [ 246.438468] x11: 7f7f7f7f7f7f7f7f x10: 000000000f5d83a0 x9 : 0000000000000020 [ 246.439099] x8 : 0101010101010101 x7 : 0000000080000000 x6 : 0000000080303663 [ 246.439729] x5 : 6336300000000000 x4 : 0000000000000000 x3 : 0000000000000000 [ 246.440360] x2 : ffff000021bdbc00 x1 : ffff000021bdbc00 x0 : 0000000000000000 [ 246.440991] Call trace: [ 246.441210] get_device_state+0x28/0x88 [ledtrig_netdev] [ 246.441683] netdev_trig_notify+0x13c/0x1fc [ledtrig_netdev] [ 246.442185] notifier_call_chain+0x74/0x144 [ 246.442561] raw_notifier_call_chain+0x18/0x24 [ 246.442956] call_netdevice_notifiers_info+0x58/0xa4 [ 246.443399] dev_change_name+0x190/0x318 [ 246.443751] do_setlink+0xb7c/0xde4 [ 246.444064] rtnl_setlink+0xf8/0x194 [ 246.444383] rtnetlink_rcv_msg+0x12c/0x398 [ 246.444748] netlink_rcv_skb+0x5c/0x128 [ 246.445089] rtnetlink_rcv+0x18/0x24 [ 246.445408] netlink_unicast+0x2e8/0x350 [ 246.445755] netlink_sendmsg+0x1d4/0x444 [ 246.446102] __sock_sendmsg+0x5c/0xac [ 246.446432] __sys_sendto+0x124/0x150 [ 246.446760] __arm64_sys_sendto+0x28/0x38 [ 246.447117] invoke_syscall+0x48/0x114 [ 246.447453] el0_svc_common.constprop.0+0x40/0xe8 [ 246.447871] do_el0_svc+0x20/0x2c [ 246.448168] el0_svc+0x40/0xf4 [ 246.448442] el0t_64_sync_handler+0x13c/0x158 [ 246.448829] el0t_64_sync+0x190/0x194 [ 246.449158] Code: f9423c20 f90047e0 d2800000 f9404e60 (f9401c01) [ 246.449695] ---[ end trace 0000000000000000 ]--- TIA for the help and for keeping this unsupported hardware alive!
mikeakers
