dd5xl
  1. My DDRAM is "H9CCNNNBJTMLARNUM" where according to the datasheet the B" should be read as a "8" (8GB density). And yes, I've read the specs and voltages as well. From my experiences any platform has to be tuned in terms of clocks and voltages to become stable. You can't rely e.g. on a PMIC delivering exactly the voltages as programmed in the registers due to chip variations and PCB layout constraints. Its not the programmed value but the effective voltage at the consuming chip which makes the difference.
  2. @going Are you sure you don't mess up different threads? For me your comments don't fit to this thread...
  3. @goingI'm on Armbian 24.2: bert@bananapim3:~$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 24.2.0-trunk.550 bookworm Release: 12 Codename: bookworm bert@bananapim3:~$ uname -a Linux bananapim3 6.1.63-current-sunxi #1 SMP Mon Nov 20 10:52:19 UTC 2023 armv7l GNU/Linux
  4. @going I'm still on CONFIG_DRAM_CLK=480 as preset by defconfig. Please see my .config against U-Boot V2024.01 below! BananaPiM3_u-boot_2024.zip
  5. I've finally managed to fix my (rather old) M3 by building a new U-Boot V2024.01 and modifying BananapiM3-defconfig by: CONFIG_AXP_DCDC2_VOLT=1000 # (VDD CPUA, was: 900) CONFIG_AXP_DCDC3_VOLT=1000 # (VDD CPUB, was: 900) CONFIG_AXP_DCDC5_VOLT=1400 # (VCC_DDRAM, was: 1200) This increases the voltage for LPDDRAM by 200mV and CPU cores by 100mV each. I'm now able to build C++ projects even with -j8, where BPiM3 crashed immediately before. Also, armbianmonitor -z now works and shows its final statistics: bert@bananapim3:~$ sudo armbianmonitor -z [sudo] Passwort für bert: Preparing benchmark. Be patient please... 7-Zip (a) [32] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=de_DE.UTF-8,Utf16=on,HugeFiles=on,32 bits,8 CPUs LE) LE CPU Freq: 21333333 64000000 - - - - - - 2048000000 RAM size: 2011 MB, # CPU hardware threads: 8 RAM usage: 1765 MB, # Benchmark threads: 8 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 1926 773 242 1874 | 94698 791 1021 8077 23: 1753 756 236 1787 | 90053 789 988 7793 24: 1669 764 235 1795 | 85688 786 956 7521 25: 1587 770 235 1812 | 82218 792 923 7317 ---------------------------------- | ------------------------------ Avr: 766 237 1817 | 790 972 7677 Tot: 778 605 4747 Monitoring output recorded while running the benchmark: Two CPU clusters are available for monitoring Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq C.St. 20:08:36 1728/1728 MHz 0.11 6% 2% 2% 0% 0% 0% 0/5 20:08:41 576/ 576 MHz 0.10 0% 0% 0% 0% 0% 0% 0/5 20:08:46 1728/ 576 MHz 0.09 1% 0% 0% 0% 0% 0% 0/5 20:08:56 1728/1728 MHz 0.95 83% 3% 79% 0% 0% 0% 0/5 20:09:02 1728/1728 MHz 1.60 98% 2% 95% 0% 0% 0% 0/5 20:09:07 1728/1728 MHz 2.88 97% 2% 95% 0% 0% 0% 0/5 20:09:13 1728/1728 MHz 3.53 98% 2% 96% 0% 0% 0% 0/5 20:09:26 1728/1728 MHz 3.89 98% 0% 97% 0% 0% 0% 0/5 20:09:31 1728/1728 MHz 4.60 90% 0% 90% 0% 0% 0% 0/5 20:09:37 1728/1728 MHz 5.03 91% 6% 85% 0% 0% 0% 0/5 20:09:44 1728/1728 MHz 5.94 98% 4% 94% 0% 0% 0% 0/5 20:09:49 1728/1728 MHz 6.35 98% 4% 94% 0% 0% 0% 0/5 20:10:02 1728/1728 MHz 6.48 96% 1% 95% 0% 0% 0% 0/5 20:10:11 1728/1728 MHz 6.96 82% 2% 80% 0% 0% 0% 0/5 Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq C.St. 20:10:17 1728/1728 MHz 7.20 92% 4% 87% 0% 0% 0% 0/5 20:10:28 1728/1728 MHz 7.48 99% 3% 95% 0% 0% 0% 0/5 20:10:35 1728/1728 MHz 7.94 99% 4% 95% 0% 0% 0% 0/5 20:10:43 1728/1728 MHz 8.26 99% 3% 95% 0% 0% 0% 0/5 20:10:48 1728/1728 MHz 8.32 97% 3% 93% 0% 0% 0% 0/5 20:11:01 1728/1728 MHz 8.29 96% 1% 94% 0% 0% 0% 0/5 20:11:09 1728/ 576 MHz 7.81 70% 0% 69% 0% 0% 0% 0/5 20:11:15 1728/1728 MHz 8.14 79% 7% 70% 0% 0% 0% 0/5 20:11:20 1728/1728 MHz 8.21 92% 4% 88% 0% 0% 0% 0/5 20:11:26 1728/1728 MHz 8.52 98% 4% 94% 0% 0% 0% 0/5 20:11:32 1728/1728 MHz 8.64 98% 4% 94% 0% 0% 0% 0/5 20:11:39 1728/1728 MHz 8.91 99% 3% 95% 0% 0% 0% 0/5 20:11:46 1728/1728 MHz 9.00 99% 3% 95% 0% 0% 0% 0/5 20:11:51 1728/1728 MHz 9.08 99% 3% 95% 0% 0% 0% 0/5 20:11:58 1728/1728 MHz 9.53 98% 3% 95% 0% 0% 0% 0/5 Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq C.St. 20:12:05 1728/1728 MHz 9.65 98% 3% 95% 0% 0% 0% 0/5 20:12:11 1728/1728 MHz 9.76 99% 3% 95% 0% 0% 0% 0/5 20:12:16 1728/1728 MHz 9.70 99% 3% 95% 0% 0% 0% 0/5 20:12:22 1728/1728 MHz 9.72 97% 3% 93% 0% 0% 0% 0/5 20:12:28 1728/1728 MHz 9.68 97% 3% 94% 0% 0% 0% 0/5 20:12:40 1728/1728 MHz 9.47 92% 4% 88% 0% 0% 0% 0/5 20:12:49 1728/1728 MHz 9.28 99% 0% 99% 0% 0% 0% 0/5
