I have the same version.
root@nanopct6:~# uname -a
Linux nanopct6 6.8.1-edge-rockchip-rk3588 #1 SMP PREEMPT Fri Mar 15 18:19:29 UTC 2024 aarch64 GNU/Linux
root@nanopct6:~# fdisk -l
Disk /dev/mmcblk0: 232.96 GiB, 250139901952 bytes, 488554496 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 2C6E7417-4E9E-4651-A5E6-A6A4833C8ADF
Device Start End Sectors Size Type
/dev/mmcblk0p1 32768 483655679 483622912 230.6G Linux filesystem
Should be visible even on 6.8.1-edge (listing above is from Debian).
So bottom line:
There is an error in menu of compile.sh stating that NanoPC-T6 is based on 3588S (should be without S)
Recent builds (above vendor) have issues with cpu frequency scheduling
cpu-info incorrectly shows all cores as ARM Cortex-A55 on NanoPC-T6. But at the same time lscpu shows correct info. And yes, bigger cache is expected due to different processor version.
Any other issues?
