nhudson
  1. received this kernel panic today. 24.5.0 with the 6.6.30 kernel using the 75mV dtb reverting the dtb, to see if that makes it more stable. cpu settings are ENABLE=true MIN_SPEED=408000 MAX_SPEED=1800000 GOVERNOR=ondemand [73481.995035] Insufficient stack space to handle exception! [73481.995044] ESR: 0x000000009a000000 -- SP Alignment [73481.995050] FAR: 0x000000000000012b [73481.995052] Task stack: [0xffff80008abe0000..0xffff80008abe4000] [73481.995054] IRQ stack: [0xffff800081d40000..0xffff800081d44000] [73481.995056] Overflow stack: [0xffff0000f778a310..0xffff0000f778b310] [73481.995061] CPU: 5 PID: 40075 Comm: rsync Tainted: P C O 6.6.30-current-rockchip64 #1 [73481.995067] Hardware name: Helios64 (DT) [73481.995070] pstate: 800003c5 (Nzcv DAIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [73481.995075] pc : el1h_64_sync+0x0/0x68 [73481.995084] lr : dequeue_task_fair+0xa8/0x3e8 [73481.995095] sp : 000000000000012b [73481.995097] x29: ffff80008abe3650 x28: 0000000000000000 x27: 0000000000000009 [73481.995104] x26: ffff0000f779e540 x25: ffff00000078e980 x24: ffff0000f779e4c0 [73481.995109] x23: 0000000000000001 x22: ffff00000078e900 x21: 0000000000000001 [73481.995114] x20: ffff0000f779e540 x19: 0000000000000000 x18: 0000000000000000 [73481.995119] x17: 0000000000000000 x16: 0000000000000000 x15: 0000110e637753ac [73481.995123] x14: 0020f1c8fb93347c x13: 0000000000000001 x12: 0000000000000001 [73481.995127] x11: 0000000000000001 x10: 0000000000000137 x9 : 00000000000001e4 [73481.995132] x8 : ffff0000f779e5c0 x7 : 0000000000000005 x6 : 000000000000006b [73481.995137] x5 : ffff800076092000 x4 : ffff800081a4dc98 x3 : 00000000f779e4c0 [73481.995141] x2 : ffff0000f779e578 x1 : ffff8000817094c0 x0 : 000000000000006b [73481.995148] Kernel panic - not syncing: kernel stack overflow [73481.995151] CPU: 5 PID: 40075 Comm: rsync Tainted: P C O 6.6.30-current-rockchip64 #1 [73481.995155] Hardware name: Helios64 (DT) [73481.995156] Call trace: [73481.995159] dump_backtrace+0x94/0x114 [73481.995164] show_stack+0x18/0x24 [73481.995167] dump_stack_lvl+0x48/0x60 [73481.995175] dump_stack+0x18/0x24 [73481.995179] panic+0x324/0x38c [73481.995183] nmi_panic+0x8c/0x90 [73481.995186] panic_bad_stack+0x104/0x124 [73481.995189] handle_bad_stack+0x34/0xb8 [73481.995196] __bad_stack+0x78/0x7c [73481.995199] el1h_64_sync+0x0/0x68 [73481.995202] __schedule+0x518/0xb60 [73481.995205] schedule+0x5c/0xc4 [73481.995207] schedule_hrtimeout_range_clock+0xc8/0x1f8 [73481.995212] schedule_hrtimeout_range+0x14/0x20 [73481.995216] do_select+0x598/0x640 [73481.995223] core_sys_select+0x1e0/0x4b8 [73481.995226] __arm64_sys_pselect6+0x150/0x21c [73481.995231] invoke_syscall+0x48/0x118 [73481.995236] el0_svc_common.constprop.0+0x40/0xe8 [73481.995241] do_el0_svc+0x20/0x2c [73481.995246] el0_svc+0x40/0xf4 [73481.995250] el0t_64_sync_handler+0x13c/0x158 [73481.995255] el0t_64_sync+0x190/0x194 [73481.995259] SMP: stopping secondary CPUs [73481.995385] Kernel Offset: disabled [73481.995386] CPU features: 0x0,80000208,24020000,1000421b [73481.995389] Memory Limit: none [73482.017954] ---[ end Kernel panic - not syncing: kernel stack overflow ]---
  2. Thanks. I will look through that. For now I have updated from the beta channel to the latest version 24.5.0 with kernel 6.6.30 and hope that helps in some way.
  3. I have a Helios64 that I recently reinstalled/updated to the latest Armbain Jammy image after not updating for quite some time and finding some of the repos to be dead. Without the drives initialized the system seems like it will run for days, but with the drives initialized (ZFS), I will get the below error after a few hours of uptime (~8-10 hours). I have seen some threads saying to set the CPU clock to one speed to fix the issue and some people installing a newer kernel (via beta.armbian.com). If anyone has any thoughts on how I could try and make this more stable I would appreciate it. [477435.475903] rcu: INFO: rcu_preempt self-detected stall on CPU [477435.476481] rcu: 3-....: (90606038 ticks this GP) idle=8c74/1/0x4000000000000000 softirq=715905/93001225 fqs=43038032 [477435.477488] rcu: (t=90606039 jiffies g=2287601 q=1361150 ncpus=6) [477549.183778] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 1-.... 3-.... } 65978929 jiffies s: 781 root: 0xa/. [477549.184885] rcu: blocking rcu_node structures (internal RCU debug): [477615.481330] rcu: INFO: rcu_preempt self-detected stall on CPU [477615.481904] rcu: 3-....: (90651041 ticks this GP) idle=8c74/1/0x4000000000000000 softirq=715905/93047138 fqs=43059171 [477615.482913] rcu: (t=90651042 jiffies g=2287601 q=1361150 ncpus=6) [477729.401197] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 1-.... 3-.... } 66023985 jiffies s: 781 root: 0xa/. [477729.402304] rcu: blocking rcu_node structures (internal RCU debug): [477795.486758] rcu: INFO: rcu_preempt self-detected stall on CPU [477795.487338] rcu: 3-....: (90696044 ticks this GP) idle=8c74/1/0x4000000000000000 softirq=715905/93092997 fqs=43080230 [477795.488344] rcu: (t=90696045 jiffies g=2287601 q=1361150 ncpus=6) [477909.618629] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 1-.... 3-.... } 66069041 jiffies s: 781 root: 0xa/. [477909.619735] rcu: blocking rcu_node structures (internal RCU debug): [477975.492185] rcu: INFO: rcu_preempt self-detected stall on CPU [477975.492764] rcu: 3-....: (90741047 ticks this GP) idle=8c74/1/0x4000000000000000 softirq=715905/93138939 fqs=43101769 [477975.493771] rcu: (t=90741048 jiffies g=2287601 q=1361150 ncpus=6) [478089.836039] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 1-.... 3-.... } 66114097 jiffies s: 781 root: 0xa/. [478089.837147] rcu: blocking rcu_node structures (internal RCU debug):
