hi @chris178!
1 - factory 8gb, not modded, lpddr4
2 - boot log:
[151]HELLO! BOOT0 is starting!
[154]BOOT0 commit : {9f6fab4f-dirty}
[168]dram_para_total:0xf
[171]vaild para:6 select dram para10
[175][mmc]: mmc driver ver 2024-03-20 10:36
[184][mmc]: Wrong media type 0x0
[188][mmc]: ***Try SD card 0***
[197][mmc]: HSSDR52/SDR25 4 bit
[200][mmc]: 50000000 Hz
[202][mmc]: 59638 MB
[205][mmc]: ***SD/MMC 0 init OK!!!***
[210]DRAM BOOT DRIVE INFO: V0.601
[215]DRAM_VCC set to 1100 mv
[217]DRAM CLK =1800 MHZ
[220]DRAM Type =8 (8:LPDDR4,9:LPDDR5)
[320]Training result is = 7
[323]DRAM Pstate 1 training, frequency is 1200 Mhz
[433]Training result is = 7
[436]DRAM Pstate 2 training, frequency is 800 Mhz
[642]Training result is = 7
[645]DRAM Pstate 3 training, frequency is 400 Mhz
[3829]Training result is = 7
[3832]DRAM Pstate 0 training, frequency is 1800 Mhz
[3840]Actual DRAM SIZE =8192 M
[3843]DRAM SIZE =8192 MBytes, para1 = 311a, para2 = 20001001, dram_tpr13 = 6067
[3858]DRAM simple test OK.
[3864]error:bad magic.
[3928]error: dtb not found for scp
[3931]mmc not para
[3933]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0
NOTICE: BL31: OP-TEE 32bit detected
NOTICE: BL31: U-BOOT 32bit detected
NOTICE: BL31: v2.5(debug):5fc237a6a
NOTICE: BL31: Built : 09:05:28, Feb 26 2025
NOTICE: BL31: No DTB found.
ERROR: Error initializing runtime service opteed_fast
U-Boot 2018.07-12-boot-aw2501-gb2d229198b2-dirty (Jan 06 2026 - 03:45:33 +0000) Allwinner Technology
[03.985]CPU: Allwinner Family
[03.988]Model: Radxa Cubie A7A
I2C: ready
[04.052]DRAM: 8 GiB
[04.061]Relocation Offset is: 75d89000
[04.114]secure enable bit: 0
[04.117]PMU: AXP8191
[04.119]PMU: AXP8191 VER_A
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[04.131]bmu_axp515_probe pmic_bus_read fail
[04.135][AXP8191] onoff status: 0x50 = 0x1, 0x51 = 0x0
[04.140][AXP8191] charge status: 0x4 = 0x0
[04.144]CPU=1014 MHz,PLL6=1200 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=600Mhz
[04.150]gic: sec monitor mode
SPI ALL: ready
[04.194]flash init start
[04.196]workmode = 0,storage type = 1
[04.200][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00
[04.208][mmc]: get sdc_type fail and use default host:tm1.
[04.216][mmc]: can't find node "mmc0",will add new node
[04.221][mmc]: fdt err returned <no error>
[04.224][mmc]: Using default timing para
[04.228][mmc]: SUNXI SDMMC Controller Version:0x50530
[04.246][mmc]: card_caps:0x3000000a
[04.249][mmc]: host_caps:0x3000003f
[04.252]sunxi flash init ok
get value error
[04.262]Loading Environment from SUNXI_FLASH... OK
No ethernet found.
[04.299]NOT support bridge yet
[04.302]Warn: no find panel or bridge
[04.403]drm hdmi get mode: 1920x1080@60Hz
hdmi0@5520000: use force output detailed mode clock 139190 kHz, flags[5]
H: 1920 2008 2052 2080
V: 1080 1082 1087 1115
bus_format: 0
clk_set_rate: <NULL> has NULL parent
[04.505]suxni tcon hdmi set rate: 139190000Hz and get diff: -139190000Hz
[04.577]the secure storage item0 copy0 magic is bad
[04.589]the secure storage item0 copy1 magic is bad
[04.593]usb burn from boot
delay time 0
[04.599]usb prepare ok
[04.902]overtime
[04.906]do_burn_from_boot usb : no usb exist
skip update boot_param
cann't get the boot_base from the env
[04.917]update part info
[04.922]battery temp is -1
[04.926]update bootcmd
[04.934](not enough data: expected >= 8 cells, got 4 cells)
Link up timeout
Speed change timeout
PCIe speed of Gen1
Override default fdtfile to allwinner/sun60i-a733-cubie-a7z.dtb
[07.376]libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[07.382]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC
[07.388][mmc]: get sunxi-mmc0 string failed
[07.392]The storage not support sample function
[07.398]## error: update_fdt_dram_para_from_bootpara : FDT_ERR_NOTFOUND
ret 0
[07.408]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62
[07.414]mac addr => 08:51:49:58:7f:71
[07.417]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62
[07.423]mac addr => 08:51:49:58:7f:70
[07.427]/chosen/rng-seed node not exit
[07.430]no battery, disabled battery functons
[07.434]Could not find nodeoffset for bat_supply
[07.439]update dts
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: ff
OEM: 0
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.2 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
[ufs]info:Driver version 0.0.24 2024.12.30 16:00
[ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959
[ufs]err:uic c 16,uic a 0,1,0
[ufs]err:e 80000010,0,0,0,0
[ufs]err:int s 0,400
[ufs]err:Device not present
[ufs]err:wait device link startup failed
[ufs]info:peer link startup timeout
[ufs]err:link startup failed -6
[ufs]err:ufshcd_probe() failed -6
fail to init ufs
sunxi_flash - sunxi_flash sub-system
Usage:
sunxi_flash sunxi_flash init storage_type
sunxi_flash read mem_addr part_name [size]
sunxi_flash read_mtd mem_addr part_name [size]
sunxi_flash write <mem_addr> <part_name> [size]
sunxi_flash write <mem_addr> <part_name> [offset] [size]
sunxi_flash write_mtd <mem_addr> <part_name>
sunxi_flash boot0 force_dram_update_size <new_val>
sunxi_flash boot0 force_dram_update_flag <new_val>
Hit any key to stop autoboot: 0
starting USB...
USB0: start sunxi USB-DRD...
config usb clk ok
sunxi USB-DRD init ok...
USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1: start sunxi USB1-Host...
config usb clk ok
sunxi USB1-Host init ok...
USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
mmc0 is current device
Scanning mmc 0:2...
Scanning mmc 0:3...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1307 bytes read in 19 ms (66.4 KiB/s)
U-Boot menu
1: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733
2: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733 (rescue target)
Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733
Retrieving file: /boot/initrd.img-5.15.147-14-a733
31153067 bytes read in 1310 ms (22.7 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.147-14-a733
19030528 bytes read in 808 ms (22.5 MiB/s)
append: root=UUID=6f750720-329a-45f0-a4b5-abc5797b040a console=ttyAS0,115200n8 rootwait clk_ignore_unused mac_addr=08:51:49:58:7f:71 mac1_addr=08:51:49:58:7f:70 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off
Retrieving file: /usr/lib/linux-image-5.15.147-14-a733/allwinner/sun60i-a733-cubie-a7z.dtb
193692 bytes read in 145 ms (1.3 MiB/s)
[16.025]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC
[16.034]The storage not support sample function
ret 0
[16.136]mac addr => 08:51:49:58:7f:71
[16.140]mac addr => 08:51:49:58:7f:70
[16.145]no battery, disabled battery functons
[16.152]update dts
stop sunxi USB-DRD ok...
stop sunxi USB1-Host ok...
Loading Ramdisk to 4824a000, end 49fffbab ... OK
ERROR: reserving fdt memory region failed (addr=48000000 size=1000000)
[16.232]Starting kernel ...
[16.235]total: 16235 ms
[16.237][mmc]: MMC Device 2 not found
[16.240][mmc]: mmc 2 not find, so not exit
NOTICE: [SCP] :wait arisc ready....
NOTICE: [SCP] :arisc version: [d463b9da43dc50320f21ba51c6c51afe2db20d83]
NOTICE: [SCP] :arisc startup ready
NOTICE: [SCP] :arisc startup notify message feedback
NOTICE: [SCP] :sunxi-arisc driver is starting
NOTICE: BL3-1: Next image address = 0x40200000
NOTICE: BL3-1: Next image spsr = 0x3c5
nothing happen after that
my workaround ( with claude help )
edit extlinux.conf and add mem=4G
append root=UUID=0e1a597a-1884-4b41-a07c-733efecf176c console=ttyAS0,115200n8 earlyprintk=sunxi-uart,0x2500000 rootwait mem=4G clk_ignore_unused
any higher value dosent work.
