footz
3 -
https://forum.armbian.com/topic/12227-rockpi-4-spi/RockPI 4 SPI
footz replied to Marko Buršič's question in Rockchip
So, I got 5.15.18 working (it had an unrelated error in which the included wifi-driver for rtl8821cu was not working for me, so I needed an out-of-tree driver). Good news is that the "Connection timed out"-error disappeared. However the issue remained that the hardware chipselect SPI2_CSn0 on pin GPIO2_B4 continued to toggle regardless if I used spidev2.0 or spidev2.1. This essentially means that cs-gpios = <0>, <&gpio3 16 1>; will not work, since the device on CS0 is always selected. The only way I see this working is something like this: cs-gpios = <&gpio3 16 1>, <gpio4, 30 1>; and then leaving pin GPIO2_B4 unused and open, thus wasting a pin. Also recognize the significance of @usual user's statement: In earlier kernel version you got an error when you used meaningless values but things continued to work. This is not the case anymore in at least 5.15.18. You will not get a device like /dev/spidevX.Y! You will have to enter a valid client driver, however pointless it seems, given that you're not going to use an in-kernel driver. There should exist a dummy value for device node to be created when you want to use userspace drivers. Instead, people are now going to use compatible = "rohm,dh2228fv"; instead of compatible = "spidev"; I'm not sure that is going to make things better. But that is another discussion … I have to conclude that cs-gpios does not really work with the Rock Pi hardware (as far as I understand the TRM you have to select either hardware chip select 0 or 1 and the selected line will toggle.) Instead I'm going to use an external mux and use spi-mux instead. -
Hey all! I'm trying to use cs-gpios on a Rock Pi 4B on SPI channel 2, but I have a couple of issues. Status quo: I'm running an Armbian kernel version 5.10.63, so I assume all required patches should have been applied. I'm using the following overlay, to both (1) enable SPI 2 and (2) define two GPIOs as CS signals (namely GPIO3_C0 and GPIO4_D6): /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target-path = "/spi@ff1e0000"; __overlay__ { #address-cells = <1>; #size-cells = <0>; cs-gpios = <&gpio3 16 1>, <&gpio4 30 1>; status = "okay"; spidev@0 { compatible = "spidev"; status = "okay"; reg = <0>; spi-max-frequency = <10000000>; }; spidev@1 { compatible = "spidev"; status = "okay"; reg = <1>; spi-max-frequency = <10000000>; }; }; }; }; I add the overlay using armbian-add-overlay and I confirmed it is loaded via U-Boot output. I also get corresponding messages in the Kernel log and two SPI devices in Linux: [ 3.118032] spi:spi_register_controller: rockchip-spi ff1e0000.spi: registered master spi2 [ 3.118265] spi:spi_setup: spi spi2.1: setup mode 0, 8 bits/w, 10000000 Hz max --> 0 [ 3.119331] spi:spi_add_device: rockchip-spi ff1e0000.spi: registered child spi2.1 [ 3.119412] spi:spi_setup: spi spi2.0: setup mode 0, 8 bits/w, 10000000 Hz max --> 0 [ 3.120415] spi:spi_add_device: rockchip-spi ff1e0000.spi: registered child spi2.0 > ls /dev/spi* /dev/spidev2.0 /dev/spidev2.1 Note, that I enabled additional debug output via dyndbg, so I might have addional messages in my dmesg output that are not "standard". So far so good. Next, I tested the configuration using spi_test in loopback mode like so: sudo ./spidev_test --device /dev/spidev2.0 -S 2 --iter 99999 --speed 10000 sudo ./spidev_test --device /dev/spidev2.1 -S 2 --iter 99999 --speed 10000 And here the problems start: (1) I noticed, testing spidev2.0, that the hardware CS pin, GPIO2_B4 (aka SPI2_CSn0) toggles inverted to the chip select signal of spidev@0, namely GPIO3_C0, i.e. whenever GPIO3_C0 goes low, GPIO2_B4 goes high and vice-versa. This does not seem to happen if I use spidev@1, aka /dev/spidev2.1. Is this known/intended behaviour? If not, how do I fix it? (2) I also tried to use the hardware chipselect pin, GPIO2_B4 together with a GPIO pin as chip select, i.e.: cs-gpios = <0>, <&gpio3 16 1>; This configuration resulted in spidev2.0 working as expected, but when testing spidev2.1 I got the following error message: spi mode: 0x4 bits per word: 8 max speed: 10000 Hz (10 kHz) can't send spi message: Connection timed out and the following lines were logged to dmesg: [ 326.295637] spidev spi2.1: SPI transfer timed out [ 326.296133] spi_master spi2: failed to transfer one message from queue What is the issue here? Posts by @martinayotte, @Marko Buršič, and @p-i-u.de made me think that this mode of operation was supported. Or am I still missing kernel patches? I also tried the method of @Marko Buršič adding a spi2_cs1 and then extending pinctrl-0 of spi2 like so: /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target-path ="/pinctrl/spi2"; __overlay__ { spi2_cs1: spi2-cs1 { rockchip,pins = <0x03 0x16 0x02 &pcfg_pull_up>; }; }; }; fragment@1 { target-path = "/spi@ff1e0000"; __overlay__ { #address-cells = <1>; #size-cells = <0>; cs-gpios = <0>, <&gpio3 16 1>; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0 &spi2_cs1>; status = "okay"; spidev@0 { compatible = "spidev"; status = "okay"; reg = <0>; spi-max-frequency = <10000000>; }; spidev@1 { compatible = "spidev"; status = "okay"; reg = <1>; spi-max-frequency = <10000000>; }; }; }; }; But that had the same result of spidev2.0 working and spidev2.1 failing with the "Connection timed out" error message. Does anyone have any suggestion what the issue(s) might be? Thanks in advance! -
Hi, can you add an additional SPI NOR Flash chip, please? I have a 32MBit MX25L25645 SPI Nor flash. Boot log: U-Boot 2020.10-armbian (May 06 2021 - 19:22:15 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... unrecognized JEDEC id bytes: c2, 20, 19 *** Warning - spi_flash_probe_bus_cs() failed, using default environment PS: Maybe it's also not such a good idea to white-list individual Flash chips, since this breaks users' setup by default when there is no real reason to do so. Imho it is a better idea to blacklist chips, if they are known to not work. Thanks and best regards!
