Dombo 71
50 -
I have 4 usb device in my odroid N2 with bookworm. A powered USB hub, which has always woken up, and the found device are in the hub. If I put them in the N2 no difference. If I: ls -l /dev/serial/by-id pi@odroidn2:~$ ls -l /dev/serial/by-id total 0 lrwxrwxrwx 1 root root 13 Jul 22 02:51 usb-0658_0200-if00 -> ../../ttyACM0 lrwxrwxrwx 1 root root 13 Jul 22 02:51 usb-RFXCOM_RFXtrx433_A1XSS661-if00-port0 -> ../../ttyUSB1 And with.. sudo lsusb -v I get this output 23 from 192.168.5.101 pi@odroidn2:~$ sudo lsusb -v [sudo] wachtwoord voor pi: Bus 002 Device 005: ID 0bda:0411 Realtek Semiconductor Corp. Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.00 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 3 bMaxPacketSize0 9 idVendor 0x0bda Realtek Semiconductor Corp. idProduct 0x0411 Hub bcdDevice 1.17 iManufacturer 1 Generic iProduct 2 4-Port USB 3.0 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x001f bNumInterfaces 1 bConfigurationValue 1 iConfiguration 4 USB3.0 Hub bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 5 Interrupt In Interface Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 19 Transfer Type Interrupt Synch Type None Usage Type Feedback wMaxPacketSize 0x0002 1x 2 bytes bInterval 8 bMaxBurst 0 Hub Descriptor: bLength 12 bDescriptorType 42 nNbrPorts 4 wHubCharacteristic 0x0009 Per-port power switching Per-port overcurrent protection bPwrOn2PwrGood 0 * 2 milli seconds bHubContrCurrent 8 milli Ampere bHubDecLat 0.2 micro seconds wHubDelay 3202 nano seconds DeviceRemovable 0x00 Hub Port Status: Port 1: 0000.02a0 5Gbps power Rx.Detect Port 2: 0000.02a0 5Gbps power Rx.Detect Port 3: 0000.02a0 5Gbps power Rx.Detect Port 4: 0000.02a0 5Gbps power Rx.Detect Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x0000f41e BESL Link Power Management (LPM) Supported BESL value 1024 us Deep BESL value 61440 us SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 1023 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {20b9cde5-7039-e011-a935-0002a5d5c51b} Device Status: 0x0001 Self Powered Bus 002 Device 003: ID 0bda:0411 Realtek Semiconductor Corp. Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.00 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 3 bMaxPacketSize0 9 idVendor 0x0bda Realtek Semiconductor Corp. idProduct 0x0411 Hub bcdDevice 1.17 iManufacturer 1 Generic iProduct 2 4-Port USB 3.0 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x001f bNumInterfaces 1 bConfigurationValue 1 iConfiguration 4 USB3.0 Hub bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 5 Interrupt In Interface Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 19 Transfer Type Interrupt Synch Type None Usage Type Feedback wMaxPacketSize 0x0002 1x 2 bytes bInterval 8 bMaxBurst 0 Hub Descriptor: bLength 12 bDescriptorType 42 nNbrPorts 4 wHubCharacteristic 0x0009 Per-port power switching Per-port overcurrent protection bPwrOn2PwrGood 0 * 2 milli seconds bHubContrCurrent 8 milli Ampere bHubDecLat 0.2 micro seconds wHubDelay 3202 nano seconds DeviceRemovable 0x00 Hub Port Status: Port 1: 0000.0203 5Gbps power U0 enable connect Port 2: 0000.02a0 5Gbps power Rx.Detect Port 3: 0000.02a0 5Gbps power Rx.Detect Port 4: 0000.02a0 5Gbps power Rx.Detect Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x0000f41e BESL Link Power Management (LPM) Supported BESL value 1024 us Deep BESL value 61440 us SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 1023 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {20b9cde5-7039-e011-a935-0002a5d5c51b} Device Status: 0x0001 Self Powered Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.10 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 3 bMaxPacketSize0 9 idVendor 0x05e3 Genesys Logic, Inc. idProduct 0x0620 GL3523 Hub bcdDevice 93.04 iManufacturer 1 GenesysLogic iProduct 2 USB3.1 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x001f bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 19 Transfer Type Interrupt Synch Type None Usage Type Feedback wMaxPacketSize 0x0002 1x 2 bytes bInterval 8 bMaxBurst 0 Hub Descriptor: bLength 12 bDescriptorType 42 nNbrPorts 4 wHubCharacteristic 0x0009 Per-port power switching Per-port overcurrent protection bPwrOn2PwrGood 50 * 2 milli seconds bHubContrCurrent 576 milli Ampere bHubDecLat 0.4 micro seconds wHubDelay 1508 nano seconds DeviceRemovable 0x00 Hub Port Status: Port 1: 0000.02a0 lowspeed L1 Port 2: 0000.02a0 lowspeed L1 Port 3: 0000.0203 lowspeed enable connect Port 4: 0000.02a0 lowspeed L1 Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x00000006 BESL Link Power Management (LPM) Supported SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 8 micro seconds bU2DevExitLat 190 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {f8f4da75-89ce-f34e-8dcb-5467f29cbd36} Device Status: 0x0001 Self Powered Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.00 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 3 bMaxPacketSize0 9 idVendor 0x1d6b Linux Foundation idProduct 0x0003 3.0 root hub bcdDevice 6.01 iManufacturer 3 Linux 6.1.30-meson64 xhci-hcd iProduct 2 xHCI Host Controller iSerial 1 xhci-hcd.1.auto bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x001f bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 bMaxBurst 0 Hub Descriptor: bLength 12 bDescriptorType 42 nNbrPorts 1 wHubCharacteristic 0x0009 Per-port power switching Per-port overcurrent protection bPwrOn2PwrGood 50 * 2 milli seconds bHubContrCurrent 0 milli Ampere bHubDecLat 0.0 micro seconds wHubDelay 0 nano seconds DeviceRemovable 0x00 Hub Port Status: Port 1: 0000.0203 5Gbps power U0 enable connect Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x000f bNumDeviceCaps 1 SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x02 Latency Tolerance Messages (LTM) Supported wSpeedsSupported 0x0008 Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 0 micro seconds bU2DevExitLat 0 micro seconds Device Status: 0x0001 Self Powered Bus 001 Device 010: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x0403 Future Technology Devices International, Ltd idProduct 0x6001 FT232 Serial (UART) IC bcdDevice 6.00 iManufacturer 1 RFXCOM iProduct 2 RFXtrx433 iSerial 3 A1XSS661 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0020 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xa0 (Bus Powered) Remote Wakeup MaxPower 90mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 255 Vendor Specific Protocol iInterface 2 RFXtrx433 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Device Status: 0x0000 (Bus Powered) Bus 001 Device 009: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x0403 Future Technology Devices International, Ltd idProduct 0x6001 FT232 Serial (UART) IC bcdDevice 6.00 iManufacturer 1 FTDI iProduct 2 FT232R USB UART iSerial 3 AI05V71S bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0020 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xa0 (Bus Powered) Remote Wakeup MaxPower 90mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 255 Vendor Specific Subclass bInterfaceProtocol 255 Vendor Specific Protocol iInterface 2 FT232R USB UART Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Device Status: 0x0000 (Bus Powered) Bus 001 Device 011: ID 10c4:ea60 Silicon Labs CP210x UART Bridge Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x10c4 Silicon Labs idProduct 0xea60 CP210x UART Bridge bcdDevice 1.00 iManufacturer 1 Silicon Labs iProduct 2 Sonoff Zigbee 3.0 USB Dongle Plus iSerial 3 0001 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0020 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 0 iInterface 2 Sonoff Zigbee 3.0 USB Dongle Plus Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Device Status: 0x0000 (Bus Powered) Bus 001 Device 008: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.10 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 2 TT per port bMaxPacketSize0 64 idVendor 0x0bda Realtek Semiconductor Corp. idProduct 0x5411 RTS5411 Hub bcdDevice 1.17 iManufacturer 1 Generic iProduct 2 4-Port USB 2.0 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0029 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 1 Single TT iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 1 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 2 TT per port iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 4 wHubCharacteristic 0x00a9 Per-port power switching Per-port overcurrent protection TT think time 16 FS bits Port indicators bPwrOn2PwrGood 0 * 2 milli seconds bHubContrCurrent 100 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Port 2: 0000.0100 power Port 3: 0000.0103 power enable connect Port 4: 0000.0100 power Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x0000f41e BESL Link Power Management (LPM) Supported BESL value 1024 us Deep BESL value 61440 us SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 1023 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {20b9cde5-7039-e011-a935-0002a5d5c51b} Device Status: 0x0001 Self Powered Bus 001 Device 004: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.10 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 2 TT per port bMaxPacketSize0 64 idVendor 0x0bda Realtek Semiconductor Corp. idProduct 0x5411 RTS5411 Hub bcdDevice 1.17 iManufacturer 1 Generic iProduct 2 4-Port USB 2.0 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0029 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 1 Single TT iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 1 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 2 TT per port iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 4 wHubCharacteristic 0x00a9 Per-port power switching Per-port overcurrent protection TT think time 16 FS bits Port indicators bPwrOn2PwrGood 0 * 2 milli seconds bHubContrCurrent 100 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0503 highspeed power enable connect Port 2: 0000.0103 power enable connect Port 3: 0000.0103 power enable connect Port 4: 0000.0100 power Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x0000f41e BESL Link Power Management (LPM) Supported BESL value 1024 us Deep BESL value 61440 us SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 1023 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {20b9cde5-7039-e011-a935-0002a5d5c51b} Device Status: 0x0001 Self Powered Bus 001 Device 003: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 2 Communications bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x0658 Sigma Designs, Inc. idProduct 0x0200 Aeotec Z-Stick Gen5 (ZW090) - UZB bcdDevice 0.00 iManufacturer 0 iProduct 0 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0043 bNumInterfaces 2 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 2 Abstract (modem) bInterfaceProtocol 1 AT-commands (v.25ter) iInterface 0 CDC Header: bcdCDC 1.10 CDC Call Management: bmCapabilities 0x00 bDataInterface 1 CDC ACM: bmCapabilities 0x00 CDC Union: bMasterInterface 0 bSlaveInterface 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0008 1x 8 bytes bInterval 32 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Device Status: 0x0000 (Bus Powered) Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.10 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 2 TT per port bMaxPacketSize0 64 idVendor 0x05e3 Genesys Logic, Inc. idProduct 0x0610 Hub bcdDevice 93.04 iManufacturer 1 GenesysLogic iProduct 2 USB2.1 Hub iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0029 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 1 Single TT iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 1 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 2 TT per port iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0001 1x 1 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 4 wHubCharacteristic 0x00e9 Per-port power switching Per-port overcurrent protection TT think time 32 FS bits Port indicators bPwrOn2PwrGood 50 * 2 milli seconds bHubContrCurrent 100 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Port 2: 0000.0103 power enable connect Port 3: 0000.0503 highspeed power enable connect Port 4: 0000.0100 power Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x002a bNumDeviceCaps 3 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x00000006 BESL Link Power Management (LPM) Supported SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 8 micro seconds bU2DevExitLat 190 micro seconds Container ID Device Capability: bLength 20 bDescriptorType 16 bDevCapabilityType 4 bReserved 0 ContainerID {f8f4da75-89ce-f34e-8dcb-5467f29cbd36} Device Status: 0x0001 Self Powered Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 1 Single TT bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 6.01 iManufacturer 3 Linux 6.1.30-meson64 xhci-hcd iProduct 2 xHCI Host Controller iSerial 1 xhci-hcd.1.auto bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0019 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 2 wHubCharacteristic 0x0009 Per-port power switching Per-port overcurrent protection TT think time 8 FS bits bPwrOn2PwrGood 10 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0503 highspeed power enable connect Port 2: 0000.0100 power Device Status: 0x0001 Self Powered pi@odroidn2:~$ Also modified this, in: armbianEnv.txt extraargs=usbcore.autosuspend=-1 Try also: https://www.domoticz.com/wiki/PersistentUSBDevices Als no differents Look there are only 2 usb ports funtctioning.. only otherwise there are more ports viable...:-) Try a lot other things. No luck @ all What could be wrong here? a solution?
libssl1.1 Not possible to install
Dombo 71 replied to Dombo 71's topic in Software, Applications, Userspace
I try this options also. Not working. Perhaps other options? Or is this just a domotcz problem? And need domoticz change something? -
Hope there is a option.. for install libssl1.1 Drive me cray. I run: ___ _ _ _ _ _ ____ / _ \ __| |_ __ ___ (_) __| | | \ | |___ \ | | | |/ _` | '__/ _ \| |/ _` | | \| | __) | | |_| | (_| | | | (_) | | (_| | | |\ |/ __/ \___/ \__,_|_| \___/|_|\__,_| |_| \_|_____| Welcome to Armbian 23.05.1 Bookworm with Linux 6.1.30-meson64 System load: 2% Up time: 31 min Memory usage: 9% of 3.69G IP: 192.168.5.70 CPU temp: 34°C Usage of /: 9% of 57G RX today: 499.3 MiB Last login: Tue Jul 18 01:39:33 2023 from 192.168.5.101 Fow my Domoticz, in need, libssl1.1 Still get an error when run: pi@Domoticz:~$ cd domoticz pi@Domoticz:~/domoticz$ ./domoticz ./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory pi@Domoticz:~/domoticz$ Where i google and try to find solutions.. No option to install libssl1.1 on my ondroid. [ also not with jammy ] Help please...... THANKS!!!
