dolphs
Profile Information
  • Gender
    Male
  • Location
    Netherlands
  1. Hello, Noticed the NanoPi Zero2 the other day and it might help me setting up a wifibridge WiFi (WiFi6) to LAN. Since it has the RK3528A SoC there is an image avaiable based on that SoC , though for the Rock 2F Therefore wondering about its status and if it will be (not) adapted? Thanks
  2. ah I see default is: nameserver 127.0.0.53 options edns0 trust-ad search . so it must be related then to /etc/systemd/resolved.conf ( DNSStubListener ) Same question applies, would like to limit this to DNS=127.0.0.1 ::1 ( for now )
  3. Hello, My spare R4S is currently running the Rolling releases with Armbian Linux v6.12 Trixie image It seems /etc/resolved.conf got filled by at least /etc/systemd/resolved.conf [ global ] /etc/netplan/armbian.yaml [ per link/ ethernets: ] However I miss from which script the IPv6 nameservers are gathered and added as currently /etc/resolv.conf shows something like this and Iike to have just the ones from [ global ]: ( Please note I removed nameservers from the yaml file already ) # operation for /etc/resolv.conf. nameserver 127.0.0.1 nameserver ::1 nameserver fda8:5894:4e78:0:xxxx:xxxx:xxxx:xxxx # Too many DNS servers configured, the following entries may be ignored. nameserver 2001:1c00:2a02:ba00:xxxx:xxxx:xxxx:xxxx nameserver fda8:5894:4e78:0:xxxx:xxxx:xxxx:xxxx nameserver 2001:1c00:2a02:ba00:xxxx:xxxx:xxxx:xxxx search . Aiming for just the localhost nameservers in resolv.conf as unbound and pihole ( +wireguard ) will be running on the SBC only ... Hoping one can guide me as I could not find it from the Networking - Armbian Documentation TiA!
  4. This is due to wrong cable being used: moin moin moin ( p1mon ) : duh therefore this topic can be removed as I will find proper AP9827 cable first...
  5. hmm once cable is attached it does report FTDI USB Serial Device converter is attached, however apcupsd does not want to comm. with my APC Back-UPS 650, so either Modular or compiled in does not resolve my issue. [160575.289133] usb 7-1: new full-speed USB device number 3 using xhci-hcd [160575.444894] usb 7-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00 [160575.444943] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [160575.444966] usb 7-1: Product: FT232R USB UART [160575.444985] usb 7-1: Manufacturer: FTDI [160575.445003] usb 7-1: SerialNumber: AL[hidden] [160575.453241] ftdi_sio 7-1:1.0: FTDI USB Serial Device converter detected [160575.453585] usb 7-1: Detected FT232R [160575.455687] usb 7-1: FTDI USB Serial Device converter now attached to ttyUSB0
  6. Hello, I would like to propose a change to the default kernel config for the r4s. Currently in .config # # USB HID support # CONFIG_USB_HID=y CONFIG_HID_PID=y CONFIG_USB_HIDDEV=y This should be altered to CONFIG_USB_HID=m This change has been requested previously for other boards: here and is also explained properly. To summarise : the change would allow those using APCUPSD to communicate with their APC UPS device. TiA!
