Hello everyone,
I know this topic is older but I have a similar problem to the topic creator.
1. For me the fstab looks normal but after the reboot there are a lot of errors when booting (see picture). I don't really know what it is or what I can do.
I had burned the image "Armbian_23.11.1_Odroidc2_bookworm_current_6.1.63.img" onto the SD card several times, every time the same problem, sometimes the Odroid C2 gets into a boot loop, when I unplug the external SSD from the USB port and plug it back in, many come up Error on the screen (see picture).
2. Another problem I discovered is that a reboot doesn't work if you use zsh instead of bash, with zfs reboot doesn't work if you use bash, reboot works normally.
The image with only white lines is a boot loop, but it goes so fast that I can't take a picture that quickly.
