9 -
Profile Information
Location
Earth ⨁
&ergio's Achievements
I confirm this bug. After updating orange pi zero to 4.14.15-sunxi it hangs occasionally. Feb 4 06:32:27 localhost kernel: [24810.496488] NMI backtrace for cpu 0 Feb 4 06:32:27 localhost kernel: [24810.496498] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.15-sunxi #28 Feb 4 06:32:27 localhost kernel: [24810.496501] Hardware name: Allwinner sun8i Family Feb 4 06:32:27 localhost kernel: [24810.496506] task: c0d07780 task.stack: c0d00000 Feb 4 06:32:27 localhost kernel: [24810.496523] PC is at arch_cpu_idle+0x28/0x2c Feb 4 06:32:27 localhost kernel: [24810.496529] LR is at arch_cpu_idle+0x27/0x2c Feb 4 06:32:27 localhost kernel: [24810.496533] pc : [<c01070e8>] lr : [<c01070e7>] psr: 40070033 Feb 4 06:32:27 localhost kernel: [24810.496536] sp : c0d01f80 ip : 00000018 fp : c0c5ea30 Feb 4 06:32:27 localhost kernel: [24810.496539] r10: 00000000 r9 : 00000000 r8 : c0ddd8eb Feb 4 06:32:27 localhost kernel: [24810.496544] r7 : c0cb6438 r6 : c0d03f6c r5 : c0d03fcc r4 : ffffe000 Feb 4 06:32:27 localhost kernel: [24810.496547] r3 : c0116561 r2 : 00000000 r1 : 00000000 r0 : 00000001 Feb 4 06:32:27 localhost kernel: [24810.496554] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none Feb 4 06:32:27 localhost kernel: [24810.496558] Control: 50c5387d Table: 5a21006a DAC: 00000051 Feb 4 06:32:27 localhost kernel: [24810.496564] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.15-sunxi #28 Feb 4 06:32:27 localhost kernel: [24810.496566] Hardware name: Allwinner sun8i Family Feb 4 06:32:27 localhost kernel: [24810.496592] [<c010db15>] (unwind_backtrace) from [<c010a0d9>] (show_stack+0x11/0x1 4) Feb 4 06:32:27 localhost kernel: [24810.496605] [<c010a0d9>] (show_stack) from [<c0867e49>] (dump_stack+0x69/0x78) Feb 4 06:32:27 localhost kernel: [24810.496621] [<c0867e49>] (dump_stack) from [<c086bc0f>] (nmi_cpu_backtrace+0x8b/0x d4) Feb 4 06:32:27 localhost kernel: [24810.496634] [<c086bc0f>] (nmi_cpu_backtrace) from [<c010ca01>] (handle_IPI+0x75/0x 278) Feb 4 06:32:27 localhost kernel: [24810.496645] [<c010ca01>] (handle_IPI) from [<c01013e3>] (gic_handle_irq+0x67/0x68) Feb 4 06:32:27 localhost kernel: [24810.496654] [<c01013e3>] (gic_handle_irq) from [<c010aa25>] (__irq_svc+0x65/0x94) Feb 4 06:32:27 localhost kernel: [24810.496659] Exception stack(0xc0d01f30 to 0xc0d01f78) Feb 4 06:32:27 localhost kernel: [24810.496666] 1f20: 00000001 00000000 00000000 c 0116561 Feb 4 06:32:27 localhost kernel: [24810.496675] 1f40: ffffe000 c0d03fcc c0d03f6c c0cb6438 c0ddd8eb 00000000 00000000 c 0c5ea30 Feb 4 06:32:27 localhost kernel: [24810.496682] 1f60: 00000018 c0d01f80 c01070e7 c01070e8 40070033 ffffffff Feb 4 06:32:27 localhost kernel: [24810.496693] [<c010aa25>] (__irq_svc) from [<c01070e8>] (arch_cpu_idle+0x28/0x2c) Feb 4 06:32:27 localhost kernel: [24810.496708] [<c01070e8>] (arch_cpu_idle) from [<c014c93d>] (do_idle+0x115/0x16c) Feb 4 06:32:27 localhost kernel: [24810.496721] [<c014c93d>] (do_idle) from [<c014cb89>] (cpu_startup_entry+0x19/0x1c) Feb 4 06:32:27 localhost kernel: [24810.496733] [<c014cb89>] (cpu_startup_entry) from [<c0c00ad5>] (start_kernel+0x353 /0x36a) Feb 4 06:32:27 localhost kernel: [24810.497496] rcu_sched kthread starved for 6304 jiffies! g12210 c12209 f0x0 RCU_GP_ WAIT_FQS(3) ->state=0x402 ->cpu=0 Feb 4 06:32:27 localhost kernel: [24810.497502] rcu_sched I 0 8 2 0x00000000 Feb 4 06:32:27 localhost kernel: [24810.497523] [<c08762d9>] (__schedule) from [<c087684f>] (schedule+0x2f/0x68) Feb 4 06:32:27 localhost kernel: [24810.497538] [<c087684f>] (schedule) from [<c08790ed>] (schedule_timeout+0x75/0x314 ) Feb 4 06:32:27 localhost kernel: [24810.497555] [<c08790ed>] (schedule_timeout) from [<c0164f95>] (rcu_gp_kthread+0x41 5/0x674) Feb 4 06:32:27 localhost kernel: [24810.497572] [<c0164f95>] (rcu_gp_kthread) from [<c0131a9d>] (kthread+0xfd/0x104) Feb 4 06:32:27 localhost kernel: [24810.497587] [<c0131a9d>] (kthread) from [<c0106719>] (ret_from_fork+0x11/0x38) Feb 4 06:32:50 localhost kernel: [24833.077001] INFO: rcu_sched detected stalls on CPUs/tasks: Feb 4 06:32:50 localhost kernel: [24833.077650] 0-...: (0 ticks this GP) idle=252/140000000000000/0 softirq=212 452/212452 fqs=0 Feb 4 06:32:50 localhost kernel: [24833.077743] (detected by 3, t=2102 jiffies, g=12216, c=12215, q=2956) Feb 4 06:32:50 localhost kernel: [24833.077921] Sending NMI from CPU 3 to CPUs 0:
Hi. Is it possible to toggle usb power on Orange PI Zero? What does PL2 do?
Is it possible to see it in future, or it's difficult and there are no plan for this task?
USB audio is not usable with 4.x dev kernels on OPI Zero board. I don't see any errors, but audio goes with scratchs. Other usb devises works fine with 4.x dev. USB audio works well with 3.x stable kernel.
Am I right, that there are no wifi support at uboot level for sunxi boards? And the only similar solution to use wifi at early level is to boot linux kernel with wifi support from SPI flash.
Yes, under development, you're right. And yes, I can't boot stock Debian kernel. But I've just asked to include in config common modules, like usb drivers.
armbianmonitor shows about 40C in idle for Nanopi Neo2 with stock radiator
The kernel is poorly configured. Compare it with debian config-4.9.0-3-arm64 or even with config-3.4.113-sun8i. There are no CONFIG_USB_SERIAL_WWAN and many other drivers.
