deb2016
3218 profile views
  1. I installed the latest stable (and updated) debian image on clearfogpro from SD card. I then chose "boot from SD, install on SATA ..." as I have a M.2 SSD card which is viewed as /dev/sda device, with the "armbian-install" utility. However, this one does not offer to boot directly from M2. SSD, which should be possible as there is a DIP switch configuration for it. I tried to burn the iso image on sata with "dd" and then, to "dd" the u-boot.sata on "/dev/sda" (bs=512 seek=1). When switching to sata boot (dip switch), it begins well, the sata device is found, but nothing happens after, the iso image is not loaded. How can I boot directly from M.2 SSD with system installed on it ?
