rreignier
3214 profile views
  1. Hi! Now that the camera interface has been merged in mainline Kernel, I would like to try to use the OrangePi OV5640 camera module on my OrangePi One. So with the latest Armbian Bionic (20.02.1, kernel 5.4.20), I have been trying to get a device tree overlay. But for now, it fails to compile with: $ sudo armbian-add-overlay sun8i-h3-csi.dts Compiling the overlay Error: sun8i-h3-csi.dts:27.23-24 syntax error FATAL ERROR: Unable to parse input tree Error compiling the overlay My current overlay looks like this: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { csi_mclk_pin: csi-mclk-pin { pins = "PE1"; function = "csi"; }; }; }; fragment@1 { target = <&i2c2>; __overlay__ { status = "okay"; ov5640: camera@3c { compatible = "ovti,ov5640"; reg = <0x3c>; pinctrl-names = "default"; pinctrl-0 = <&csi_mclk_pin>; clocks = <&ccu CLK_CSI_MCLK>; clock-names = "xclk"; AVDD-supply = <&reg_aldo1>; DOVDD-supply = <&reg_dldo3>; DVDD-supply = <&reg_eldo3>; reset-gpios = <&pio 4 14 GPIO_ACTIVE_LOW>; /* CSI-RST-R: PE14 */ powerdown-gpios = <&pio 4 15 GPIO_ACTIVE_HIGH>; /* CSI-STBY-R: PE15 */ port { ov5640_ep: endpoint { remote-endpoint = <&csi_ep>; bus-width = <8>; data-shift = <2>; /* lines 9:2 are used */ hsync-active = <1>; /* Active high */ vsync-active = <0>; /* Active low */ data-active = <1>; /* Active high */ pclk-sample = <1>; /* Rising */ }; }; }; }; }; fragment@2 { target = <&csi>; __overlay__ { status = "okay"; port { csi_ep: endpoint { remote-endpoint = <&ov5640_ep>; bus-width = <8>; hsync-active = <1>; /* Active high */ vsync-active = <0>; /* Active low */ data-active = <1>; /* Active high */ pclk-sample = <1>; /* Rising */ }; }; }; }; }; So the line 27, which seem to trigger the error is: `clocks = <&ccu CLK_CSI_MCLK>;` Also, according to the documentation, the regulator fields are required but this board does not have much regulators (like AXP209), so I have no idea what to write here. But this is my first time writing a device-tree overlay so I am not sure what is wrong with this line. Could someone guide me to get my overlay right? And, does anyone already got the CSI interface working with OV5460 sensor on a H3 based board? Thank you.
