Hans Kurscheidt
37 -
armbian-config has significantly changed in Bookworm/Kernel 6.6. It looks to me that its not reflecting the actual device settings. Please refer to the attached screenshot from /boot/armbianEnv.txt. Compared to Bullseye/Kernel 6.1.92 I see an additional line "fdt_overlays, where all the dtb settings from the new armbian-config appear, fdt_overlays=sun50i-h5-analog-codec sun50i-h5-i2c1 sun50i-h5-tve sun50i-h5-uart2 sun50i-h5-usbhost0 sun50i-h5-usbhost1 sun50i-h5-usbhost2 sun50i-h5-usbhost3 but they seem to not having any effect. In 6.1.92 this line does not exist. The real dtb settings are still in the line above overlay_prefix=sun50i-h5 overlays=i2c1 uart1 usbhost0 usbhost1 usbhost2 usbhost3 which is identical in 6.1.92 and 6.6.
OK, so I'm there! but rather than doing a fresh install, I used the following method: using armbian-config under kernel 6.1.92 to unfreeze using armbian-config to switch to "other kernel" -> 6.6.44 That worked OK and gave me Debian Bullseye w/ kernel 6.6.44 I then edited /etc/apt/sources.list and /etc/apt/sources.list.d/armbian.list, replacing Bullseye w/ Bookworm. I then started apt-get update/upgrade. After a huge upgrade I ended up w/ Debian Bookworm, but had fallen back to kernel 6.1.104. I then applied the method as described by robertoj to finally get Debian Bookworm w/ kernel 6.6.44
Well, I tried my very best to find a solution, just to run into other Armbian peculiarities. 1st, the problem with the missing signature can be solved by telling apt to ignore it. Hence I created my apt.config settings in /etc/apt/apt.config.d as following: cat 99mysettings Acquire::AllowInsecureRepositories "1"; Acquire::AllowWeakRepositories "0"; Acquire::AllowDowngradeToInsecureRepositories "1"; So apt started to work on it, giving the appropriate warnings: which I ignored, so it started the upgrade: just to learn, that I'm stuck again w/ Armbian. something w/ "unknown compression"
I'm sorry, but you misinterpreted the screenshots. Please refer to my 1st line in my 1st post: >>>>I had to freeze my device on Kernel 6.1.92 & Bullseye to remain operational. Now trying to update/upgrade to Kernel 6.6.nn <<<< I was always on Bullseye since years now and Kernel 6.1.92 frozen since early this year. Trying to move from 6.1.92 to 6.6.42 (switching kernel after defreeze in armbian-config) created a mess including throwing me back onto Buster, God knows why and how! May be, that I am using a code that is not supported on a hardware that is not supported, but normal Linux' way of upgrade should still work and for the time being, I am almost sure, that the upgrade doesn't work, because you guys haven't created the proper public key for apt.security to accept the upgrade. RGDS hk
Hi there, as expected, in my frozen image, they are pointing to 6.1.92. After unfreeze and apt-get update/upgrade I'm now lifted to 6.1.104 & Bullseye However its not want I want, 6.644. a new issued apt-get update/upgrade has no effect. looks like a security issue to me, now. https://github.armbian.... is not signed RGDS hk
Thank-you for reply. Sorry for the beginners question, but "How to"? I used armbian-config to move from 6.1.92 to 6.6.44 and I was assuming that 6.6.44 would replace 6.1.92; apparently it did not, as you said in your reply. So how can I make 6.6.44 the new 1 and only new kernel. I currently back to my old image w/ kernel 6.1.92 frozen and Debian Bullseye. I have a complex APP with tons of middleware and 3rd party SW; a fresh new installation would be a PITA.
I had to freeze my device on Kernel 6.1.92 & Bullseye to remain operational. Now trying to update/upgrade to Kernel 6.6.nn I run into following probs: 1) Using Armbian-config defreeze and subsequently switch to kernel 6.6.nn works OK 4me, but subsequent apt-get update/upgrade throws me back to kernel 6.1.104. Armbian-config has changed significantly w/ No other Kernel available. 2) Using Armbian-config defreeze, only and going directly to apt-get update/upgrade throws me back to kernel 6.1.104 as well and from Bullseye back to Buster! Its a mess! Will this eventually be corrected and when? RGDS
