shaun27
28 -
shaun27's Achievements
Just tested Integral M Series 128GB NVMe M.2 Internal SSD 694mb read. Write i assume is the same but didn't test as i installed armbian on it. I will say you will need to format this drive in gparted and check for errors if the boot from throws up errors saying not enough memory.
I assume you tried the other downloads and it worked ? like bionic server or desktop? I know bionic desktop works although i had a few errors which i had to fix in gparted to get it to install but either way it should pop up in boot from. Before you do anything type in "fdisk -l" in command terminal and see if it pops up in their. Also what is the nvme your useing ?
Review Quick review of NanoPi Fire3
shaun27 replied to tkaiser's topic in Reviews, Tutorials, Hardware hacks
Been a while since I been on these forums but if I remember correctly when I did get it to 1.6ghz the temps were quite high on load even with copper shims decent thermal paste. I use mine for mining still going strong all 10 of them in a cluster. -
I like to further add regarding Sabrent 256GB Rocket NVMe i have tested this write speed and read speed same time. Read 390mb give or take few mb and around 380 write. So i would assume this is the upper limit on the pci2.1 on the m4 of around 780 something considering the NVMe is rated 1050mb write 3100 read. Still alot faster then the ssd i tested through usb3.
The NVMe hat 12v fan socket doesn't work at all for armbian, most likely missing a drive or something. I got it to around 50c and the fan didn't even kick in. I have directly connected the fan to the 5v gpio port for the time being works fine not loud at all but downside to this is that you have to fully disconnect the device to power the fan down. Their was some information regarding controlling the port pwn0 link did try it but it completely bricked the account i exported to so. Have not tried friendlyelec desktop as i prefer armbian's clean image. As for cooling i have no problems even with fan off in the metal case as i have used copper shims and thermal paste sits at 30c idle and 40c something under load. I will say its a pain to say the least to do that in the metal case without the copper shim going misaligned. I did try their thermal pad but tbh temps were going up to 50c once the metal case was warmed up. The metal case is alot more effective though then the normal heat-sink they supplied.
Can confirm Sabrent 256GB Rocket NVMe PCIe M.2 2280 works in armbian with NVMe hat. Have included test of the read speed which is an impressive 734mbs as for write speed could not do. Exactly same conditions as nicod video above. Main website Amazon link Not sure if anyone else is having problems with the 12v fan with the NVMe hat but this doesn't work in armbian, so assume something needs to be added to armbian to activate it at p-mos switch. If it does could be i got a faulty fan, NVMe board or it activates at a higher temperature then i can get it atm in the metal case. Thanks nicod for video btw saved me some time.
Think the only problem i am finding with my m4 atm is youtube playback at 1080 in theory it should be able to do it looking at the chip (VP9 : 2160p@60fps(4096x2304)) but again its down to software etc using those hardware features. But apart from that i am using my m4 as an actual pc with armbian works very well.
Your a star!! I assume i would have to update the kernel 10 boards to do :( cant do that through fabric :( -
Bit of an update regarding power button not working on nanopi fire3. Tech support got back to me and its missing a driver which is located friendlyarm kernel source code. I am not sure how to implement this yet but will look into it as and when i get some more time, hopefully we can implement this into armbian. -
I think you would have to wire it yourself tbh. Connector wise your looking for http://www.hobbytronics.co.uk/cables-connectors/polarized-connector-housing a 3 pin one. Dont forget the crimp pins and all. Im assuming this is the right size for the pins but you will need to check the pin size. I dont have this board so cant be certain on the pin size.
Agree with that. over 22c difference for me. Anyone wants to know what size shims i used 15mm by 15mm and 1.2mm thickness with a dab of thermal paste on cpu and topside of shim to main heatsink. Temperature difference Exactly same test with youtube 1080p 60c with thermal pad, 38 to 40c with copper shim and thermal paste each side of it.
One thing i learned is to always buy the official cables purely for testing. The cable that works ok is friendly elec one which does work very well but the length is a problem for me to have the sbc on my desk without having extension leads all over it. https://www.amazon.co.uk/ACOCOBUY-Charger-Braided-Charging-Transfer/dp/B07F27DTW1 suppose to be rated 5v 4a with the dash charger i bought but bricks under load and with only hdmi connected!. https://www.amazon.co.uk/DUX-DUCIS-Oneplus-Charger-Adapter/dp/B07H5K8QG8 this dash charger works fine btw i got the load up to 2.2amps (with spikes up to 2.5amps)no problem with 4.93volts. So those in the uk who want an all in one plug (not adaptors etc) this does work for at least the stuff and load i stuck on it. Those who might be interested i used xmrig and used all cpu cores when testing which maxed out at 24h/s.
Another thing if anyone is using the official dash charger from friendly elec, under load and a few usb devices connected what is your voltage? i am getting 4.93 with hdmi, usb stick, bluetooth adaptor, ssd (powered by usb) and under full cpu load. Thing what is annoying me is as soon as i connect any cable longer then the official one it bricks which i assume min voltage is 4.85 ?
I have emailed their tech support so when they get back to me hopefully i can help others. Just a quick question regarding nanopi m4 is their a way to boot from sd card first over emmc so i can use the armbian-config to delete and reinstall the emmc ? Didnt buy the sd to emmc adaptor oh im regretting that now
