I own a Orange PI One and I wanted to create a compile environment in a virtualbox as I did not find any available.
So I followed the instructions found here: http://www.armbian.com/using-armbian-tools/
1) downloaded "ubuntu-14.04.4-server-amd64.iso"
2) create a new virtual box image (ubuntu 64bit)
3) Execute the following command:
The process end with the following lines:
[ o.k. ] Building deb [ linux-u-boot-orangepih3-5.07-armhf.deb ]
[ error ] ERROR in function compilte_uboot [ common.sh:155 ]
[ error ] Building u-boot failed, check configuration
[ o.k. ] Process terminated
If any one could help me with this issue (and/or have any link to a compile environment virtualbox), I would be grateful.
What kernel branch did you select(default/next/dev)? It must be "default" based on u-boot file name. Can you repeat compilation process with
PROGRESS_LOG_TO_FILE=yes
added to compile.sh and then post contents of "output/debug/compilation.log" somewhere (like pastebin.com)?
One patch is failing, what happens when you do a
touch /home/armbian/ArmbianGit/userpatches/u-boot/u-boot-default/u-boot-02-support-cheap-mmc.patch
and retry then?
If these logs are from second compilation attempt, then problem is in host dependencies installation (aptly package) - it already happened before when aptly repository signing key expired.
WARNING: The following packages cannot be authenticated!
  aptly
@quentin
You can try removing "aptly" from general.sh, line 288 304 and repeat compilation attempt.
Alternatively you can try using Ubuntu Xenial (16.04 beta ) as your build host instead of 14.04.
and retry then?
Only difference is:
/home/armbian/ArmbianGit/lib/patch/u-boot/u-boot-default/u-boot-02-support-cheap-mmc.patch u-boot-default 2016.03
patch unexpectedly ends in middle of line
Displaying message: ... u-boot-02-support-cheap-mmc.patch succeeded info
became:
Displaying message: ... u-boot-02-support-cheap-mmc.patch skipped info
  aptly
@quentin
Yes I made the modification on the line 304 as it was the closest ;)
It seems to correct the issue as the compilation is progressing.
Thanks,
