Shamanches Posted April 19, 2016 Posted April 19, 2016 if use: mpv --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs --loop=yes /media/usb/*.mp4 hardware decoding work if use mplayer mplayer -stop-xscreensaver -ontop -quiet -fs -vo vdpau -vc ffmpeg12vdpau,ffh264vdpau, -loop 0 /media/usb/*.mp4 hardware decoding not work Howto use mplayer with hardware decoding videoplaying on Orange PI PC v1.2?
RagnerBG Posted April 19, 2016 Posted April 19, 2016 Build-in mplayer2 doesn't work. I am receiving massage for missing h264 decoder even if it's present in system. You have to build it from source, but i see no point if you already have mpv and image quality is better in mpv for my taste. But if you are like me and want to have a backup or just to play around, this are the steps i do to build it from source: wget http://www.mplayerhq.hu/MPlayer/releases/MPlayer-1.3.0.tar.xz wget http://www.mplayerhq.hu/MPlayer/releases/codecs/all-20110131.tar.bz2 tar xjvf all-20110131.tar.bz2 sudo mkdir /usr/local/lib/codecs sudo cp -v all-20110131/* /usr/local/lib/codecs tar xJvf MPlayer-1.3.0.tar.xz cd MPlayer-1.3.0 ./configure make -j4 sudo make install Then execute mplayer once to create necessary directories and you can add your config - sudo nano /usr/local/etc/mplayer/mplayer.conf: vo=vdpau vc=ffmpeg12vdpau,ffh264vdpau ao=alsa:device=hw=1.0 framedrop=yes This is basic for hw acceleration, framedrop=yes is necessary because there is some a/v async without it, even if system is no more than 40% loaded. You can also add settings for subtitles encoding, i add ''subcp=cp1251'' for cyrillic, and "fs=yes" to decrease a/v async a little if you using framebuffer version of mali driver.
