Dianne S. Posted May 8, 2019 Posted May 8, 2019 Armbianmonitor: http://ix.io/1IrG Hi, I'm running Armbian Stretch on a Tinker Board and trying to use a one-wire thermometer. I have this in /boot/armbianEnv.txt: overlays=i2c1 i2c4 spi2 spidev2 uart1 uart2 w1-gpio However, when I boot the board, I see this in dmesg: [Wed May 8 17:38:43 2019] rockchip-pinctrl pinctrl: unable to find group for node w1_pins [Wed May 8 17:38:43 2019] w1-gpio: probe of onewire@0 failed with error -22 Kernel version is Linux tinkerboard 4.19.33-rockchip #5.77 SMP PREEMPT Wed Apr 3 17:06:29 CEST 2019 armv7l GNU/Linux Any ideas? I'm using the rockchip-w1-gpio.dtbo that was installed with the system. Regards, Dianne. 1
TonyMac32 Posted May 9, 2019 Posted May 9, 2019 Thank you for the information! This was a carry over from Asus, I remember checking that it would load, but things may have changed in the DT. +/* 1-Wire GPIO +* From ASUS: https://github.com/TinkerBoard/debian_kernel/blob/develop/arch/arm/boot/dts/overlays/w1-gpio-overlay.dts +* +* +*/ + +/dts-v1/; +/plugin/; + +/ { + compatible = "rockchip,rk3288-tinker", "rockchip,rk3288"; + fragment@0 { + target-path = "/"; + __overlay__ { + w1: onewire@0 { + compatible = "w1-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&w1_pins>; + gpios = <&gpio0 17 0>; + status = "okay"; + }; + }; + }; + + fragment@1 { + target = <&gpio0>; + __overlay__ { + w1_pins: w1_pins@0 { + rockchip,pins = <0 17 0 &pcfg_pull_up>; + }; + }; + }; +}; What your error is suggesting is that fragment 1 is failing. I will try to take a look at this tomorrow, the u-boot debug message would be the easiest tell, it will say if something failed to apply.
TonyMac32 Posted May 10, 2019 Posted May 10, 2019 @Dianne S. I was only partially right. https://github.com/armbian/build/commit/5df7a1ce50529efb02c1906a71f3d89bc8546647 Please try the attached overlay rockchip-w1-gpio.dtbo
Dianne S. Posted May 10, 2019 Author Posted May 10, 2019 That fixed it! Thanks so much for your quick response; that was fantastic. Regards, Dianne. 1
