Hello
Does anyone know how to toggle GPIO output at boot / power up as an overlay or similar?
I have seen only examples that show GPIO in function and I didnt find much information how to toggle GPIO out function.
Basically I would like to be able to turn LCD back light on when the board is booting and than to be able to control the brightness. (That I can do after the Linux is up and running)
but before the Linux is up I still want to be able to control the LCD back light.
Can anyone help with that matter?
  On 6/13/2019 at 7:17 AM, nradulovic said:
Hello,
Did you have a look at this? https://www.kernel.org/doc/Documentation/devicetree/bindings/gpio/gpio.txt
There are some attributes that can set initial value during initialization. See for example: output-low and output-high properties.
Is that what you need?
Expand
Actually I need to see a working example of the dts file...
Because I do not know how to build it correctly.
