Darks1derCZ Posted April 25 Posted April 25 Good Morning, I am running into an issue when trying to compile an image for a SM8250 device. Most of the process is working fine until it gets to the Grub Section, at which point I get the following error: " cp: cannot stat '/usr/lib/linux-image-6.18.24-current-sm8250/qcom/sm8250-retroidpocket-rp5.dtb': No such file or directory" I have attached the logs, and would love to know if anyone has had a similar issue when trying to build an image for any device, and if so what you have done to solve it. Thanks all in advance for the support 0 Quote
Werner Posted April 25 Posted April 25 Confirmed. From first glance it looks like dts files are missing. 0 Quote
Darks1derCZ Posted April 25 Author Posted April 25 Ohhh thank you so much, I spent so much time trying to find the solution 0 Quote
Darks1derCZ Posted April 25 Author Posted April 25 So I can confirm that this solved the compiling issues, Thank you very much @Werner Now I am facing another issue with EFI when trying to boot. Will try to see if I can identify the problem and solve it. 0 Quote
Darks1derCZ Posted April 25 Author Posted April 25 So out of luck, I have tried multiple fixes that I can find, tested other SD cards and still ending up with the same error. Booting: mmc 0 error: no such partition grub rescue> Will try to do some more digging and keep the post updated 0 Quote
