maracuja Posted June 13, 2019 Share Posted June 13, 2019 (edited) I'm trying to use PA18/PA19 for custom purposes. I need to put these pins to Input state without any pullups/pulldowns. What I can achieve is: to put these pins to input state via the command: gpio mode 30 in gpio mode 31 in ("tri" instead of "in" does not work, it accepts the command, but a multimeter shows the input is still high, as well as gpio readall) These pins are probably pulled high because they are I2C pins. I want to disable the I2C functionality but have not found any means to do so. I have tried this dts script: ##### /dts-v1/; / { compatible = "allwinner,sun8i-h3","allwinner,sun50i-h5","friendlyarm,nanopi-neo2"; fragment@0 { target-path = "/soc/pinctrl@1c20800"; __overlay__ { i2c1 { function = "gpio_in"; bias-high-impedance; }; }; }; }; ###### and had a look at the device tree after a reboot: dtc -I fs -O dts -o ./extracted.dts /proc/device-tree The values got inserted right, but pin behaviour did not change. What I also cannot do is to activate pulldown on those pins. It has no effect. Also tried a python library - https://github.com/duxingkei33/orangepi_PC_gpio_pyH3 - to no avail. Board is an Orange Pi Zero +2 with H3 processor. To sum it up: Input mode is working (with pullup still activated) Pulldown is not working Deactivating Pullup is not working Setting Pin to output mode and switching high/low is working Kernel: 4.19.38-sunxi Edited June 14, 2019 by maracuja added kernel Link to comment Share on other sites More sharing options...
