PaddleStroke Posted June 16, 2019 Posted June 16, 2019 Hey guys, What is in your opinion the best solution to add WIFI/BT capability to a A20 board? Currently I tried to add ESP8266 connected with SDIO. (without much success so far). Then in order to add BT too I am thinking about ESP32 (with ESP-WROOM-32 module). Do you know if there are references of using this ESP32 solution to provide wifi and bt to a allwinner board/armbian ? Also this module have a lot of different interfaces available, which should be prefered? Or alternatively, do you know other armbian supported solution for wifi/bt? Best would be a solution that does not use USB ports as I need them. Thanks!
PaddleStroke Posted June 18, 2019 Author Posted June 18, 2019 Bananapi boards are using AP6212 wifi+bt module. Maybe it's easier to use this module as it seem it already works on armbian. In your experience, is this module working correctly? Thanks!
Tido Posted June 18, 2019 Posted June 18, 2019 10 hours ago, PaddleStroke said: is this module working correctly? Working BT is rarely the target. Search box, right hand corner: AP6212
