martinayotte Posted July 5, 2019 Posted July 5, 2019 12 hours ago, shaddow501 said: ads7846_device: version magic '5.1.15 SMP mod_unload aarch64' should be '5.1.15-sunxi64 SMP mod_unload aarch64' It seems that "out-of-the-tree" tooks/include the wrong magic header file. It maybe easier to create a patch for that driver to make it included part of the kernel tree and then create a new image.
shaddow501 Posted July 5, 2019 Author Posted July 5, 2019 1 hour ago, martinayotte said: It seems that "out-of-the-tree" tooks/include the wrong magic header file. It maybe easier to create a patch for that driver to make it included part of the kernel tree and then create a new image. Well in the previous kernels I havent got any issues and also I could compile the "make modules" in the linux headers without any errors. How do you create that patch? it is easier sure for someone that know how to do it? Remember I moved to this kernel because I wanted to fix the functionality of the 1-wire & now I am facing a whole new problems. It like going to the car repair shop to fix an oil leak, but no lets replace all the engine, but not the engine doesnt fit so lets replace the whole car really??? Surely it is a problem with the "Linux headers" it should have been compiled without any issues. Please help.
martinayotte Posted July 5, 2019 Posted July 5, 2019 1 hour ago, shaddow501 said: Surely it is a problem with the "Linux headers" it should have been compiled without any issues. Please, provide link where you took "out-of-the-tree" driver, I will give it a try ...
shaddow501 Posted July 5, 2019 Author Posted July 5, 2019 1 hour ago, shaddow501 said: Well in the previous kernels I havent got any issues and also I could compile the "make modules" in the linux headers without any errors. How do you create that patch? it is easier sure for someone that know how to do it? Remember I moved to this kernel because I wanted to fix the functionality of the 1-wire & now I am facing a whole new problems. It like going to the car repair shop to fix an oil leak, but no lets replace all the engine, but not the engine doesnt fit so lets replace the whole car really??? Surely it is a problem with the "Linux headers" it should have been compiled without any issues. Please help. git clone https://github.com/notro/fbtft_tools/
shaddow501 Posted July 5, 2019 Author Posted July 5, 2019 4 minutes ago, martinayotte said: Please, provide link where you took "out-of-the-tree" driver, I will give it a try ... git clone https://github.com/notro/fbtft_tools/
martinayotte Posted July 5, 2019 Posted July 5, 2019 1 hour ago, shaddow501 said: git clone https://github.com/notro/fbtft_tools/ Ok ! I've tooked the only ads7846.c source and created a patch, and compiled kernel, I got a working modules with good magic signature. But I'm unable to test it, since I don't have such display, and I don't know what parameters/arguments to provide to it. At least, here is output of "modinfo" : modinfo ads7846_device filename: /lib/modules/5.1.15-sunxi64/kernel/drivers/staging/fbtft/ads7846_device.ko license: GPL author: Noralf Tronnes description: Adds a ADS7846 device depends: staging: Y intree: Y name: ads7846_device vermagic: 5.1.15-sunxi64 SMP mod_unload aarch64 parm: verbose:0-2 (uint) parm: busnum:SPI bus number (default=0) (uint) parm: cs:SPI chip select (default=1) (uint) parm: speed:SPI speed (default 2MHz) (uint) parm: irq:int parm: mode:SPI mode (default: SPI_MODE_0) (int) parm: model:Touch Controller model: 7843, 7845, 7846, 7873 (default=7846) (int) parm: gpio_pendown:The GPIO used to decide the pendown state (required) (int) parm: x_plate_ohms:Used to calculate pressure (uint) parm: swap_xy:Swap x and y axes (bool) parm: x_min:Minimum value for x-axis (uint) parm: x_max:Maximum value for x-axis (uint) parm: y_min:Minimum value for y-axis (uint) parm: y_max:Maximum value for x-axis (uint) parm: pressure_min:uint parm: pressure_max:uint parm: keep_vref_on:Keep vref on for differential measurements as well (default=true) (bool) parm: vref_delay_usecs:int parm: vref_mv:int parm: settle_delay_usecs:uint parm: penirq_recheck_delay_usecs:uint parm: y_plate_ohms:Not used by driver (uint) parm: debounce_max:Max number of additional readings per sample (0,1,2) (uint) parm: debounce_tol:Tolerance used for filtering (uint) parm: debounce_rep:uint parm: irq_flags:ulong BTW, on a side note, why you didn't use the existing driver which is already part of the kernel ? ie : the one located here : /lib/modules/5.1.15-sunxi64/kernel/drivers/input/touchscreen/ads7846.ko add-ads7846_device.patch
shaddow501 Posted July 5, 2019 Author Posted July 5, 2019 1 hour ago, martinayotte said: Ok ! I've tooked the only ads7846.c source and created a patch, and compiled kernel, I got a working modules with good magic signature. But I'm unable to test it, since I don't have such display, and I don't know what parameters/arguments to provide to it. At least, here is output of "modinfo" : modinfo ads7846_device filename: /lib/modules/5.1.15-sunxi64/kernel/drivers/staging/fbtft/ads7846_device.ko license: GPL author: Noralf Tronnes description: Adds a ADS7846 device depends: staging: Y intree: Y name: ads7846_device vermagic: 5.1.15-sunxi64 SMP mod_unload aarch64 parm: verbose:0-2 (uint) parm: busnum:SPI bus number (default=0) (uint) parm: cs:SPI chip select (default=1) (uint) parm: speed:SPI speed (default 2MHz) (uint) parm: irq:int parm: mode:SPI mode (default: SPI_MODE_0) (int) parm: model:Touch Controller model: 7843, 7845, 7846, 7873 (default=7846) (int) parm: gpio_pendown:The GPIO used to decide the pendown state (required) (int) parm: x_plate_ohms:Used to calculate pressure (uint) parm: swap_xy:Swap x and y axes (bool) parm: x_min:Minimum value for x-axis (uint) parm: x_max:Maximum value for x-axis (uint) parm: y_min:Minimum value for y-axis (uint) parm: y_max:Maximum value for x-axis (uint) parm: pressure_min:uint parm: pressure_max:uint parm: keep_vref_on:Keep vref on for differential measurements as well (default=true) (bool) parm: vref_delay_usecs:int parm: vref_mv:int parm: settle_delay_usecs:uint parm: penirq_recheck_delay_usecs:uint parm: y_plate_ohms:Not used by driver (uint) parm: debounce_max:Max number of additional readings per sample (0,1,2) (uint) parm: debounce_tol:Tolerance used for filtering (uint) parm: debounce_rep:uint parm: irq_flags:ulong BTW, on a side note, why you didn't use the existing driver which is already part of the kernel ? ie : the one located here : /lib/modules/5.1.15-sunxi64/kernel/drivers/input/touchscreen/ads7846.ko add-ads7846_device.patch 8.59 kB · 2 downloads Dear martinayotte Thanks for the help, my parameters are: ads7846_device model=7846 cs=1 gpio_pendown=234 keep_vref_on=1 swap_xy=0 pressure_max=255 x_plate_ohms=150 x_min=3900 x_max=200 y_min=3900 y_max=200 busnum=1 I was finally was able to trick and install the driver. I dont say it is the correct way but it worked. 1. Install kernel headers => dpkg -i linux-headers-dev-sunxi64_5.90_arm64.deb 2. go into the /usr/src/headers... & make modules (till it it has the error I posted before) 3. go into the make the driver in the ads7846_device and just "make" (not make install !!!) 4. Delete /usr/src/linux-headers.. 5. Install kernel headers => dpkg -i linux-headers-dev-sunxi64_5.90_arm64.deb => but now not to "make modules" anything just to have it there. 6. go into the make the driver in the ads7846_device and now perform the "make install" + depmod (now to goes to the right location) 7. Reboot. And now the touch is working!!! I am not sure if I had to do all those steps but hey it is working, I am happy and now I have battery support + 1-wire support, the python GPIO are working, the WiringPI is working. the only thing that I am now facing is to have u-boot - logo... but it is not that important since everything else is working. Thanks for your help. sure I would like to have your patch install but I do not know were exactly to put my values....
shaddow501 Posted July 5, 2019 Author Posted July 5, 2019 8 minutes ago, shaddow501 said: Dear martinayotte Thanks for the help, my parameters are: ads7846_device model=7846 cs=1 gpio_pendown=234 keep_vref_on=1 swap_xy=0 pressure_max=255 x_plate_ohms=150 x_min=3900 x_max=200 y_min=3900 y_max=200 busnum=1 I was finally was able to trick and install the driver. I dont say it is the correct way but it worked. 1. Install kernel headers => dpkg -i linux-headers-dev-sunxi64_5.90_arm64.deb 2. go into the /usr/src/headers... & make modules (till it it has the error I posted before) 3. go into the make the driver in the ads7846_device and just "make" (not make install !!!) 4. Delete /usr/src/linux-headers.. 5. Install kernel headers => dpkg -i linux-headers-dev-sunxi64_5.90_arm64.deb => but now not to "make modules" anything just to have it there. 6. go into the make the driver in the ads7846_device and now perform the "make install" + depmod (now to goes to the right location) 7. Reboot. And now the touch is working!!! I am not sure if I had to do all those steps but hey it is working, I am happy and now I have battery support + 1-wire support, the python GPIO are working, the WiringPI is working. the only thing that I am now facing is to have u-boot - logo... but it is not that important since everything else is working. Thanks for your help. sure I would like to have your patch install but I do not know were exactly to put my values.... I moved to the newer image based on Ubuntu 18x since with the older image that I have had installed that was based on kernel 4.x , when updated to the new kernel the xfce were kind of slow and unresponsive, it also didnt let me update the u-boot to the new one so decided to go with a fresh new image. I am still looking how to create the u-boot logo, but it is not so important. 8 minutes ago, shaddow501 said:
shaddow501 Posted July 10, 2019 Author Posted July 10, 2019 I have a another question. Do you happen to know how to enable the DSI interface to work with DSI LCD?
