Could you please add the usbtv driver ?
i have an Easycap with UTV007 chip the driver are not present in kernel 3.4.110-sun8i,
and are available from 3.13-rc5
I have try to compile using the standart way, and using dkms with no success.
I have also try to install the backported version
wget http://www.kernel.org/pub/linux/kernel/projects/backports/stable/v3.18.1/backports-3.18.1-1.tar.xz
tar xvfJ backports-3.18.1-1.tar.xz
cd backports-3.18.1-1
make menuconfig
make ARCH=arm -j4
make install
rmmod videobuf2-core
rmmod videobuf2-vmalloc
rmmod videobuf2_memops
modprobe videobuf2_memops
modprobe videobuf2-core
modprobe videobuf2-vmalloc
modprobe usbtv
root@orangepipc:~# modprobe usbtv
modprobe: ERROR: could not insert 'usbtv': Invalid argument
root@orangepipc:~# lsmod
videobuf2_vmalloc       2348  0
videobuf2_memops        1815  1 videobuf2_vmalloc
gpio_sunxi              8253  0
8189es                896688  0
root@orangepipc:~# dmesg
[  801.412977] videobuf2_core: Unknown symbol v4l2_get_timestamp (err 0)
[  801.413126] videobuf2_core: disagrees about version of symbol video_devdata
[  801.413154] videobuf2_core: Unknown symbol video_devdata (err -22)
[  801.413205] videobuf2_core: disagrees about version of symbol v4l2_event_pending
[  801.413233] videobuf2_core: Unknown symbol v4l2_event_pending (err -22)
[  803.883505] videobuf2_core: Unknown symbol v4l2_get_timestamp (err 0)
[  803.883653] videobuf2_core: disagrees about version of symbol video_devdata
[  803.883681] videobuf2_core: Unknown symbol video_devdata (err -22)
[  803.883733] videobuf2_core: disagrees about version of symbol v4l2_event_pending
[  803.883760] videobuf2_core: Unknown symbol v4l2_event_pending (err -22)
Hi, here is working version:
https://goo.gl/Q8H6Gl
upgrade to last kernel (original old v4l2 is as module):
dpkg -i *
reboot
backported new v4l2 and usbtv from updates.tar.gz extract to /lib/modules/3.4.112-sun8i
depmod -a
modprobe usbtv
demo:
Work only NTSC. PAL does not work. I do not know why. Only green screen.
Ready for Ambilight ;-)
Quick guide:
on PC:
https://github.com/igorpecovnik/lib
Edit compile.sh and set
KERNEL_ONLY="yes"
KERNEL_CONFIGURE="yes"
./compile.sh
select your board, default kernel.
in kernel configuration:
device drivers -> multimedia support -> video for linux change (space) from "*" to "M", save and exit
copy kernel 3 debs (u-boot no need) from output dir to orange pi and upgrade (dpkg -i *)
on Orange PI:
(start is the same)
cd backports
-3.18.1-1
make menuconfig
select only usbtv (dependence automatically selected also v4l2)
and now little hack:
in file compat/backport-3.10.c remove get_random_int function (line 35-44)
make ARCH=arm -j4
make install
depmod -a
modprobe usbtv
vuala !
thanks i will check this process later
I do nealy the same before the last armbian upgrade.
where did you find the hack  " remove get_random_int function (line 35-44)" ???
Nowhere.
After the first successful compilation, v4l2 functions collided with those who were hard part of a kernel (dmesg messages). This made me to compile my own kernel with v4l2 as a module. Then the module compat did not go insert, because of that, that this function already found itself in the kernel (dmesq). So I search where it is and simply delete it.
Maybe it was in reverse order (hack <-> v4l2 as a module). Immemorial, it was late at night (or early morning?) :-D
How did you recompile the kernel?
I am used to Debian, but here uname -a states kernel version "3.4.112", package linux-image-sun8i claims to be version "5.23" and installing linux-source leads to linux-source-3.16.
I am somewhat lost with these seemingly inconsistent versions and some help will be greatly appreciated.
Thanks.
To answer my own questions..
I build kernel 3.4.113 on an Ubuntu guest, following Igor's documentation. But that was actually not really necessary..
I found a backported usbtv driver at: https://github.com/mwelchuk/usbtv
it is installed on its own (not part of a V4L2 backport) using dkms. It does not require rebuilding the kernel and there is no symbol or V4L2 version conflict.
It works as "well" on NanoPi Neo as on PC: grabbing only a few frames per second with motion (or zoneminder) seems to cause some weird images with half the content old. I wonder if that could be because it tries to start capture in the middle of a frame?
 Now I do have another problem with uvcvideo (another "EasyCap" device that was reported as using an USBTV007, but is a different chipset). The device is recognized, but generates error when opening /dev/video0 -- that same device works on PC Debian Linux 4.7.8. (Sorry for changing topic, but if anyone has tips, I welcome any.)
Thanks.
Alternatively you can try our DEV kernel (4.9.0) for H3 boards. It's still experimental so problems are expected. Nevertheless, you might get further than with this old kernel.
Igor,
In the (very unlikely) case that the DEV kernel happens to not boot, how do I reinstate the 3.4.113 kernel?
(BTW, I tried to see if the uvcvideo module from 4.8 would compile, but V4L2 data structures have changed since then, so it is quite a bit beyond my level as a short term solution.)
Thank you for the help.
