Bug(?): NCP installation fails: Debian Buster not supported
Short:
NCP - NextCloudPi - is not installable via armbian-config , log reporting that "Debian Buster is not supported"
Tested on:
Armbian_5.89_Rk3328-tv_Debian_buster_default_4.4.154_20190628.img on A5V / H96Max ( RK3328,4GB DDR3, 32GB Flash )
Armbian_5.91_Aml-s905_Debian_buster_default_5.1.0_20190708.img on mecool M8S PRO W ( S905w, 3GB DDR3, 16GB Flash )
Appeared:
After Buster went stable, installs of NCP fail with message "Debian Buster is not supported"
Can this be addressed by the Armbian community?
Is the error with NCP provided components?
How can this issue be addressed as to make NCP installable again?
With kind regards
Rüdiger
Ahhh! Okay.
I wonder why it worked when Debian Buster was still in testing. And if, if it would work to switch to the current testing, install NCP, and then switch back to buster once its installed. After all, it already was working on Buster when Buster was testing....
Anyway: Thank you! Now I have at least an indicator what to try!
Probably if you ping people at https://github.com/nextcloud/nextcloudpi that their script is not working for Buster they will fix it. Once they fix armbian-config way will work again. Perhaps there is some working involved. I am not familiar with this software in details.
