Cubox-i does not boot anymore
Aoz
Sorry to be back here :unsure:
I run a Cubox-i.
I upgraded to kernel 5.1.16 yesterday.
Then I rebooted and everything was running fine.
But today my server looked dead: none of my services was answering, no way to ssh to the cubox...
I tryied a hard reboot with no success.
Here is the log on a putty console:
U-Boot SPL 2013.10-rc4-ge4bc4c3 (Dec 18 2014 - 14:55:42)
Boot Device: SD1
spl: error reading image u-boot.img, err - -1
Load image from RAW...
U-Boot 2013.10-rc4-ge4bc4c3 (Dec 18 2014 - 14:55:42)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: MX6-CuBox-i
DRAM:  2 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   vga
Err:   vga
Net:   FEC [PRIME]
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
mmc0 is current device
** File not found /boot.scr **
** File not found /uEnv.txt **
** File not found /zImage **
** File not found /uImage **
1816 bytes read in 122 ms (13.7 KiB/s)
Running bootscript from mmc ...
## Executing script at 10800000
** File not found .next **
94 bytes read in 114 ms (0 Bytes/s)
37237 bytes read in 854 ms (42 KiB/s)
4820085 bytes read in 375 ms (12.3 MiB/s)
5961616 bytes read in 564 ms (10.1 MiB/s)
Kernel image @ 0x10800000 [ 0x000000 - 0x5af790 ]
## Loading init Ramdisk from Legacy Image at 14800000 ...
   Image Name:   uInitrd
   Data Size:    4820021 Bytes = 4.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800c174
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 5.1.16-cubox (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.90 SMP Sun Jul 7 11:37:47 CEST 2019
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=50c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: SolidRun Cubox-i Dual/Quad
Memory policy: Data cache writealloc
cma: Reserved 256 MiB at 0x70000000
random: get_random_bytes called from start_kernel+0x85/0x376 with crng_init=0
percpu: Embedded 17 pages/cpu s37196 r8192 d24244 u69632
Built 1 zonelists, mobility grouping on.  Total pages: 520256
Kernel command line: root=/dev/sda1 rootfstype=ext4 rootwait console=ttymxc0,115200 consoleblank=0 video=mxcfb0:dev=hdmi,1920x1080m60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi vt.global_cursor_default=0 loglevel=7 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1796204K/2097152K available (8192K kernel code, 391K rwdata, 2472K rodata, 1024K init, 461K bss, 38804K reserved, 262144K cma-reserved, 262144K highmem)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
rcu: Hierarchical RCU implementation.
rcu:    RCU event tracing is enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
L2C: DT/platform modifies aux control register: 0x72070000 -> 0x72470000
L2C-310 errata 752271 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=12000)
pid_max: default: 32768 minimum: 301
LSM: Security Framework initializing
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
*** VALIDATE proc ***
*** VALIDATE cgroup1 ***
*** VALIDATE cgroup2 ***
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100054
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU2: Spectre v2: using BPIALL workaround
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
CPU3: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes)
xor: measuring software checksum speed
   arm4regs  :  1233.000 MB/sec
   8regs     :   916.000 MB/sec
   32regs    :   882.000 MB/sec
   neon      :   899.000 MB/sec
xor: using function: arm4regs (1233.000 MB/sec)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 2048 KiB pool for atomic coherent allocations
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
cpuidle: using governor ladder
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.2
vdd1p1: supplied by regulator-dummy
vdd3p0: supplied by regulator-dummy
vdd2p5: supplied by regulator-dummy
vddarm: supplied by regulator-dummy
vddpu: supplied by regulator-dummy
vddsoc: supplied by regulator-dummy
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
raid6: neonx8   gen()   529 MB/s
raid6: neonx8   xor()   496 MB/s
raid6: neonx4   gen()   685 MB/s
raid6: neonx4   xor()   652 MB/s
raid6: neonx2   gen()   661 MB/s
raid6: neonx2   xor()   669 MB/s
raid6: neonx1   gen()   615 MB/s
raid6: neonx1   xor()   571 MB/s
raid6: int32x8  gen()   217 MB/s
raid6: int32x8  xor()   157 MB/s
raid6: int32x4  gen()   192 MB/s
raid6: int32x4  xor()   157 MB/s
raid6: int32x2  gen()   174 MB/s
raid6: int32x2  xor()   159 MB/s
raid6: int32x1  gen()   134 MB/s
raid6: int32x1  xor()   129 MB/s
raid6: using algorithm neonx4 gen() 685 MB/s
raid6: .... xor() 652 MB/s, rmw enabled
raid6: using neon recovery algorithm
mxs-dma 110000.dma-apbh: initialized
v_usb2: supplied by v_5v0
vcc_3v3: supplied by v_5v0
v_usb1: supplied by v_5v0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 1024 (order: 1, 12288 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 4708K
hw perfevents: no interrupt-affinity property for /pmu, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Initialise system trusted keyrings
workingset: timestamp_bits=14 max_order=19 bucket_order=5
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFS: nTxBlock = 8192, nTxLock = 65536
SGI XFS with ACLs, security attributes, realtime, no debug enabled
Key type asymmetric registered
Asymmetric key parser 'x509' registered
bounce: pool size: 64 pages
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
imx-pgc-pd imx-pgc-power-domain.0: DMA mask not set
imx-pgc-pd imx-pgc-power-domain.1: DMA mask not set
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 26, base_baud = 5000000) is a IMX
printk: console [ttymxc0] enabled
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 66, base_baud = 5000000) is a IMX
etnaviv etnaviv: bound 130000.gpu (ops 0x809686a4)
etnaviv etnaviv: bound 134000.gpu (ops 0x809686a4)
etnaviv etnaviv: bound 2204000.gpu (ops 0x809686a4)
etnaviv-gpu 130000.gpu: model: GC2000, revision: 5108
etnaviv-gpu 130000.gpu: command buffer outside valid memory window
etnaviv-gpu 134000.gpu: model: GC320, revision: 5007
etnaviv-gpu 134000.gpu: command buffer outside valid memory window
etnaviv-gpu 2204000.gpu: model: GC355, revision: 1215
etnaviv-gpu 2204000.gpu: Ignoring GPU with VG and FE2.0
[drm] Initialized etnaviv 1.2.0 20151214 for etnaviv on minor 0
brd: module loaded
loop: module loaded
ahci-imx 2200000.sata: fsl,transmit-level-mV value 1104, using 00000044
ahci-imx 2200000.sata: fsl,transmit-boost-mdB value 0, using 00000000
ahci-imx 2200000.sata: fsl,transmit-atten-16ths value 9, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi host0: ahci-imx
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 69
libphy: Fixed MDIO Bus: probed
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
imx_usb 2184000.usb: No over current polarity defined
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 5.1.16-cubox ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
imx_usb 2184200.usb: No over current polarity defined
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 5.1.16-cubox ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
rtc-pcf8523 2-0068: registered as rtc0
snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
i2c /dev entries driver
Registered IR keymap rc-empty
rc rc0: gpio_ir_recv as /devices/soc0/ir-receiver/rc/rc0
input: gpio_ir_recv as /devices/soc0/ir-receiver/rc/rc0/input0
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver r8712u
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address b368
mmcblk0: mmc0:b368 USD   7.47 GiB
 mmcblk0: p1
imx-spdif sound-spdif: ASoC: failed to init link S/PDIF PCM
NET: Registered protocol family 10
Segment Routing with IPv6
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
Registering SWP/SWPB emulation handler
registered taskstats version 1
Loading compiled-in X.509 certificates
zswap: default zpool zbud not available
zswap: pool creation failed
Btrfs loaded, crc32c=crc32c-generic
Key type encrypted registered
usb usb2-port1: over-current condition
imx_thermal tempmon: Extended Commercial CPU temperature grade - max:105C critical:100C passive:95C
input: gpio-keys as /devices/soc0/gpio-keys/input/input1
rtc-pcf8523 2-0068: setting system clock to 2019-07-21T14:06:11 UTC (1563717971)
Duplicate name in testcase-data, renamed to "duplicate-name#1"
### dt-test ### start of unittest - you will see error messages
OF: /testcase-data/phandle-tests/consumer-a: could not get #phandle-cells-missing for /testcase-data/phandle-tests/provider1
OF: /testcase-data/phandle-tests/consumer-a: could not find phandle
OF: /testcase-data/phandle-tests/consumer-a: arguments longer than property
OF: /testcase-data/phandle-tests/consumer-b: could not get #phandle-missing-cells for /testcase-data/phandle-tests/provider1
OF: /testcase-data/phandle-tests/consumer-b: could not find phandle
OF: /testcase-data/phandle-tests/consumer-b: arguments longer than property
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest0/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest1/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest2/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest3/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest5/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest6/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest7/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/test-unittest8/property-foo
OF: overlay: node_overlaps_later_cs: #6 overlaps with #7 @/testcase-data/overlay-node/test-bus/test-unittest8
OF: overlay: overlay #6 is not topmost
i2c i2c-3: Added multiplexed i2c bus 4
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest12/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data/overlay-node/test-bus/i2c-test-bus/test-unittest13/status
i2c i2c-3: Added multiplexed i2c bus 5
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@30/incline-up
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/fairway-1/ride@100/track@40/incline-up
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/status
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/color
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/lights@40000/rate
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/hvac_2
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_left
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /__symbols__/ride_200_right
OF: overlay: ERROR: multiple fragments add and/or delete node /testcase-data-2/substation@100/motor-1/controller
OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/controller/name
OF: overlay: WARNING: memory leak will occur if overlay removed, property: /testcase-data-2/substation@100/motor-1/rpm_avail
OF: overlay: ERROR: multiple fragments add, update, and/or delete property /testcase-data-2/substation@100/motor-1/rpm_avail
### dt-test ### end of unittest - 224 passed, 0 failed
brcm_reg: disabling
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 1024K
Run /init as init process
Loading, please wait...
starting version 232
random: systemd-udevd: uninitialized urandom read (16 bytes read)
random: udevadm: uninitialized urandom read (16 bytes read)
pwrseq_simple: section 3 reloc 2 sym 'memset': relocation 10 out of range (0x7f800034 -> 0x80886321)
random: fast init done
Begin: Running /scripts/local-premount ... done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/sda1 does not exist.  Dropping to a shell!
If I check the boot args, as suggested:
cat /proc/cmdline
And the modules:
(initramfs) cat /proc/modules; ls /dev
drwxr-xr-x 10 0 0    3380 .
drwxr-xr-x 15 0 0       0 ..
drwxr-xr-x  7 0 0     140 disk
drwxr-xr-x  2 0 0     320 block
lrwxrwxrwx  1 0 0       4 rtc -> rtc0
drwxr-xr-x  2 0 0    3000 char
lrwxrwxrwx  1 0 0      15 stderr -> /proc/self/fd/2
lrwxrwxrwx  1 0 0      15 stdout -> /proc/self/fd/1
lrwxrwxrwx  1 0 0      15 stdin -> /proc/self/fd/0
lrwxrwxrwx  1 0 0      13 fd -> /proc/self/fd
drwxr-xr-x  2 0 0       0 pts
crw-------  1 0 0  10, 58 ubi_ctrl
crw-------  1 0 0  10,234 btrfs-control
crw-------  1 0 0  10, 59 memory_bandwidth
crw-------  1 0 0  10, 60 network_throughput
crw-------  1 0 0  10, 61 network_latency
crw-------  1 0 0  10, 62 cpu_dma_latency
brw-------  1 0 0 179,  1 mmcblk0p1
brw-------  1 0 0 179,  0 mmcblk0
drwxr-xr-x  2 0 0      60 snd
crw-------  1 0 0 250,  0 watchdog0
crw-------  1 0 0  10,130 watchdog
crw-------  1 0 0  89,  2 i2c-2
crw-------  1 0 0  89,  1 i2c-1
crw-------  1 0 0 253,  1 rtc1
crw-------  1 0 0 253,  0 rtc0
drwxr-xr-x  2 0 0     100 input
drwxr-xr-x  3 0 0      60 bus
crw-------  1 0 0 252,  0 pps0
crw-------  1 0 0 251,  0 ptp0
brw-------  1 0 0   7,  7 loop7
brw-------  1 0 0   7,  6 loop6
brw-------  1 0 0   7,  5 loop5
brw-------  1 0 0   7,  4 loop4
brw-------  1 0 0   7,  3 loop3
brw-------  1 0 0   7,  2 loop2
brw-------  1 0 0   7,  1 loop1
brw-------  1 0 0   7,  0 loop0
crw-------  1 0 0  10,237 loop-control
brw-------  1 0 0   1,  3 ram3
brw-------  1 0 0   1,  2 ram2
brw-------  1 0 0   1,  1 ram1
brw-------  1 0 0   1,  0 ram0
drwxr-xr-x  2 0 0      80 dri
crw-------  1 0 0  10,183 hwrng
crw-------  1 0 0 207, 19 ttymxc3
crw-------  1 0 0 207, 16 ttymxc0
crw-rw-rw-  1 0 0   5,  2 ptmx
crw-------  1 0 0   3, 15 ttypf
crw-------  1 0 0   3, 14 ttype
crw-------  1 0 0   3, 13 ttypd
crw-------  1 0 0   3, 12 ttypc
crw-------  1 0 0   3, 11 ttypb
crw-------  1 0 0   3, 10 ttypa
crw-------  1 0 0   3,  9 ttyp9
crw-------  1 0 0   3,  8 ttyp8
crw-------  1 0 0   3,  7 ttyp7
crw-------  1 0 0   3,  6 ttyp6
crw-------  1 0 0   3,  5 ttyp5
crw-------  1 0 0   3,  4 ttyp4
crw-------  1 0 0   3,  3 ttyp3
crw-------  1 0 0   3,  2 ttyp2
crw-------  1 0 0   3,  1 ttyp1
crw-------  1 0 0   3,  0 ttyp0
crw-------  1 0 0   2, 15 ptypf
crw-------  1 0 0   2, 14 ptype
crw-------  1 0 0   2, 13 ptypd
crw-------  1 0 0   2, 12 ptypc
crw-------  1 0 0   2, 11 ptypb
crw-------  1 0 0   2, 10 ptypa
crw-------  1 0 0   2,  9 ptyp9
crw-------  1 0 0   2,  8 ptyp8
crw-------  1 0 0   2,  7 ptyp7
crw-------  1 0 0   2,  6 ptyp6
crw-------  1 0 0   2,  5 ptyp5
crw-------  1 0 0   2,  4 ptyp4
crw-------  1 0 0   2,  3 ptyp3
crw-------  1 0 0   2,  2 ptyp2
crw-------  1 0 0   2,  1 ptyp1
crw-------  1 0 0   2,  0 ptyp0
crw-r--r--  1 0 0  10,235 autofs
crw--w----  1 0 0   4, 63 tty63
crw--w----  1 0 0   4, 62 tty62
crw--w----  1 0 0   4, 61 tty61
crw--w----  1 0 0   4, 60 tty60
crw--w----  1 0 0   4, 59 tty59
crw--w----  1 0 0   4, 58 tty58
crw--w----  1 0 0   4, 57 tty57
crw--w----  1 0 0   4, 56 tty56
crw--w----  1 0 0   4, 55 tty55
crw--w----  1 0 0   4, 54 tty54
crw--w----  1 0 0   4, 53 tty53
crw--w----  1 0 0   4, 52 tty52
crw--w----  1 0 0   4, 51 tty51
crw--w----  1 0 0   4, 50 tty50
crw--w----  1 0 0   4, 49 tty49
crw--w----  1 0 0   4, 48 tty48
crw--w----  1 0 0   4, 47 tty47
crw--w----  1 0 0   4, 46 tty46
crw--w----  1 0 0   4, 45 tty45
crw--w----  1 0 0   4, 44 tty44
crw--w----  1 0 0   4, 43 tty43
crw--w----  1 0 0   4, 42 tty42
crw--w----  1 0 0   4, 41 tty41
crw--w----  1 0 0   4, 40 tty40
crw--w----  1 0 0   4, 39 tty39
crw--w----  1 0 0   4, 38 tty38
crw--w----  1 0 0   4, 37 tty37
crw--w----  1 0 0   4, 36 tty36
crw--w----  1 0 0   4, 35 tty35
crw--w----  1 0 0   4, 34 tty34
crw--w----  1 0 0   4, 33 tty33
crw--w----  1 0 0   4, 32 tty32
crw--w----  1 0 0   4, 31 tty31
crw--w----  1 0 0   4, 30 tty30
crw--w----  1 0 0   4, 29 tty29
crw--w----  1 0 0   4, 28 tty28
crw--w----  1 0 0   4, 27 tty27
crw--w----  1 0 0   4, 26 tty26
crw--w----  1 0 0   4, 25 tty25
crw--w----  1 0 0   4, 24 tty24
crw--w----  1 0 0   4, 23 tty23
crw--w----  1 0 0   4, 22 tty22
crw--w----  1 0 0   4, 21 tty21
crw--w----  1 0 0   4, 20 tty20
crw--w----  1 0 0   4, 19 tty19
crw--w----  1 0 0   4, 18 tty18
crw--w----  1 0 0   4, 17 tty17
crw--w----  1 0 0   4, 16 tty16
crw--w----  1 0 0   4, 15 tty15
crw--w----  1 0 0   4, 14 tty14
crw--w----  1 0 0   4, 13 tty13
crw--w----  1 0 0   4, 12 tty12
crw--w----  1 0 0   4, 11 tty11
crw--w----  1 0 0   4, 10 tty10
crw--w----  1 0 0   4,  9 tty9
crw--w----  1 0 0   4,  8 tty8
crw--w----  1 0 0   4,  7 tty7
crw--w----  1 0 0   4,  6 tty6
crw--w----  1 0 0   4,  5 tty5
crw--w----  1 0 0   4,  4 tty4
crw--w----  1 0 0   4,  3 tty3
crw--w----  1 0 0   4,  2 tty2
crw--w----  1 0 0   4,  1 tty1
crw-------  1 0 0   7,129 vcsa1
crw-------  1 0 0   7, 65 vcsu1
crw-------  1 0 0   7,  1 vcs1
crw-------  1 0 0   7,128 vcsa
crw-------  1 0 0   7, 64 vcsu
crw-------  1 0 0   7,  0 vcs
crw--w----  1 0 0   4,  0 tty0
crw-------  1 0 0   5,  1 console
crw-rw-rw-  1 0 0   5,  0 tty
crw-r--r--  1 0 0   1, 11 kmsg
crw-rw-rw-  1 0 0   1,  9 urandom
crw-rw-rw-  1 0 0   1,  8 random
crw-rw-rw-  1 0 0   1,  7 full
crw-rw-rw-  1 0 0   1,  5 zero
crw-r-----  1 0 0   1,  4 port
crw-rw-rw-  1 0 0   1,  3 null
crw-r-----  1 0 0   1,  1 mem
crw-------  1 0 0  10, 63 vga_arbiter
crw-------  1 0 0 254,  6 gpiochip6
crw-------  1 0 0 254,  5 gpiochip5
crw-------  1 0 0 254,  4 gpiochip4
crw-------  1 0 0 254,  3 gpiochip3
crw-------  1 0 0 254,  2 gpiochip2
crw-------  1 0 0 254,  1 gpiochip1
crw-------  1 0 0 254,  0 gpiochip0
On another computer, I fsck the hard drive and it is clean. I can even mount the file system and see all the files.
What could be investigated?
Thanks for any help.
Link to comment
Share on other sites
OK, finally got it!
I have a hard drive plugged to the Cubox-i. This HD is in a box and powered by the Cubox-i via usb. Another usb wire is used for the data. This was working fine like this for years.
For any reason, the power delivered by the Cubox-i to the hard drive seems now to be too low. I have used an external power supply for the hard drive and it fixed the issue. :thumbup:
Link to comment
Something is wrong with your SATA drive where you have your rootfs.
I guess you have made a manual transfer not with our nand-sata-install tools ... we use UUID for setting roofs locations since years.
type blkid and change /dev/sda1 with UUID=XXXXXXXXXXXXXXXXXX in your boot script or u-boot environment.
Link to comment
Apparently it was an electric power issue (see above).
But anyway, I should also implement your proposal (my OS 1st setup is from 2014...).
Should I use the UUID in "/boot/armbianEnv.txt" or/and in "/boot/boot.txt"?
Link to comment
We don't upgrade boot scripts and for the one from 2014 I can't tell without investigation. Check where /dev/sda1 is set and change that to UUID=your_hard_drive_partition_dev_sda1_uuid
... but if you don't add USB sticks to the board, just leave as is.
Link to comment
