I'm having some trouble with my OrangePi Zero with Armbian running with Armbien. I'm trying to setup a proxy with the IP address and port without any success... I need the proxy to be for everything (http, https, ftp..)
I've tried everything I found on google
- editing  /etc/apt/apt.conf.d/10proxy with Acquire::http::Proxy "http://proxy_server_address:port";
- editing /etc/environnement with : export http_proxy="http://proxyipaddress:proxyport" (also https, ftp, no_proxy)
- editing visudo with Defaults env_keep+="http_proxy https_proxy no_proxy"
- uncommenting /etc/wgetrc where the proxy is enabled
- adding in ~/.bashrc the "export ...' lines
but with all this my Orange pi still appears with my regular IP when accessing my server and not the proxy IP... I'm using a random public proxy server running in elite mode and working on my computer for testing.
The proxy is
- 103.106.119.170
- 46988
Thanks for helping ! :D
3 minutes ago, Alexis said:
The proxy is
- 103.106.119.170
- 46988
nto sure wha tall supports the enviornent proxy vars but you may need
ALL_PROXY
HTTPS_PROXY
HTTP_PROXY
NO_PROXY=127.0.0.1,localhost
and do lowercase versions as well
I've set the /etc/environment with :
export ALL_PROXY="http://proxyip:proxyport/"
same for http, https, ftp  the no_proxy in uppercase and lowercase and still not working.
