iomari Posted July 30, 2019 Posted July 30, 2019 Greetings, After setting my tinkerboard pins 22 and 24 as an Inputs, they reverts to being an output pin on HIgh after around 30 seconds. What is the cause of this? Is this some kind of feature. I don't have this happen on any other pin other than these 2. iomari
martinayotte Posted September 23, 2019 Posted September 23, 2019 35 minutes ago, iomari said: anyone? please? What "cat /sys/kernel/debug/gpio" is reporting ? Are those pins already "in-use" by some other drivers ?
martinayotte Posted September 24, 2019 Posted September 24, 2019 2 hours ago, iomari said: see attachment. They are not "in-use" by any process... So, try using them thru "sysfs" and then check again /sys/kernel/debug/gpio every 30 secs : echo 22 > /sys/class/gpio/export echo 24 > /sys/class/gpio/export echo in > /sys/class/gpio/gpio22/direction echo in > /sys/class/gpio/gpio24/direction
iomari Posted September 24, 2019 Author Posted September 24, 2019 Thanks for your reply. I work primarily from python. But I ran the commands you suggested: # sudo echo 22 > /sys/class/gpio/export # -bash: /sys/class/gpio/export: Permission denied # sudo echo in > /sys/class/gpio/gpio22/direction # -bash: /sys/class/gpio/gpio22/direction: No such file or directory
martinayotte Posted September 24, 2019 Posted September 24, 2019 34 minutes ago, iomari said: -bash: /sys/class/gpio/export: Permission denied "sudo" doesn't work in such redirection, it is apply only on left part which is "echo" only. Try login as root first, then try again, or do it this way : sudo su - -c "echo 22 > /sys/class/gpio/export" sudo su - -c "echo in > /sys/class/gpio/gpio22/direction"
iomari Posted September 25, 2019 Author Posted September 25, 2019 same problem: # sudo su -c echo in > /sys/class/gpio/gpio/export # -bash: /sys/class/gpio/gpio/export: No such file or directory # sudo su -c echo in > /sys/class/gpio/gpio/gpio22/direction -bash: /sys/class/gpio/gpio/gpio22/direction: No such file or directory as root: root@TK-03:~# echo in > /sys/class/gpio/gpio/export -su: /sys/class/gpio/gpio/export: No such file or directory root@TK-03:~# echo in > /sys/class/gpio/gpio22/direction -su: /sys/class/gpio/gpio22/direction: No such file or directory root@TK-03:~#
martinayotte Posted September 25, 2019 Posted September 25, 2019 3 hours ago, iomari said: same problem: You've mistakenly changed the path I've provided by adding "gpio" twice ... Again : sudo su - -c "echo 22 > /sys/class/gpio/export" sudo su - -c "echo in > /sys/class/gpio/gpio22/direction"
iomari Posted September 25, 2019 Author Posted September 25, 2019 thanks. sco@TK-03:/$sudo su - -c "echo 24 > /sys/class/gpio/export" sco@TK-03:/$ sudo su - -c "echo in > /sys/class/gpio/gpio24/direction" -su: line 0: echo: write error: Invalid argument sco@TK-03:/$ sudo su - -c "echo 26 > /sys/class/gpio/export" sco@TK-03:/$ sudo su - -c "echo in > /sys/class/gpio/gpio26/direction" -su: line 0: echo: write error: Invalid argument sco@TK-03:/$ su -l Password: root@TK-03:~# echo 'in' > /sys/class/gpio/gpio26/direction -su: echo: write error: Invalid argument root@TK-03:~# ls -la /sys/class/gpio/gpio26/ total 0 drwxr-xr-x 3 root root 0 Sep 25 14:02 . drwxr-xr-x 38 root root 0 Sep 25 14:02 .. -rw-r--r-- 1 root root 4096 Sep 25 14:02 active_low lrwxrwxrwx 1 root root 0 Sep 25 14:02 device -> ../../../pinctrl -rw-r--r-- 1 root root 4096 Sep 25 14:16 direction -rw-r--r-- 1 root root 4096 Sep 25 14:02 edge drwxr-xr-x 2 root root 0 Sep 25 14:02 power lrwxrwxrwx 1 root root 0 Sep 25 14:02 subsystem -> ../../../../../class/gpio -rw-r--r-- 1 root root 4096 Sep 25 14:02 uevent -rw-r--r-- 1 root root 4096 Sep 25 14:02 value export works, 2nd line doesn't
martinayotte Posted September 25, 2019 Posted September 25, 2019 2 hours ago, iomari said: export works, 2nd line doesn't Is the SPI enabled in DT ? it seems that those pins are maybe shared ...
iomari Posted September 25, 2019 Author Posted September 25, 2019 3 minutes ago, martinayotte said: Is the SPI enabled in DT ? it seems that those pins are maybe shared ... I don't understand.
