Hi, I wanted to know if there was an easy way to customize an existing released image or rebuild a released image.  I know you can use the customize image option when building, but I would like to not build the latest nightly, but instead just build whatever was released.
The customization I am looking to do is installing additional packages, downloading some personal python code, setting timezone and other similar settings.
I searched the forums, but didn't see anything helpful, any info would be appreciated.
Thanks.
you could mount the image as loopback and chroot (from an arm box)
root@cranbone:/mnt/linuxmirror/armbianImages# ls -ltrh
total 965M
drwxrwsr-x 1 lane sudo  396 May 20 02:02 backgroundpoll
-rw-rw-r-- 1 root bin  1.1G Aug  6 23:21 Armbian_5.93_Orangepipc2_Ubuntu_bionic_next_4.19.65.img
-rw-r--r-- 1 root sudo   26 Aug  9 02:15 robots.txt
root@cranbone:/mnt/linuxmirror/armbianImages# losetup -f -P Armbian_5.93_Orangepipc2_Ubuntu_bionic_next_4.19.65.img
root@cranbone:/mnt/linuxmirror/armbianImages# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0         7:0    0   1.1G  0 loop
└─loop0p1   259:0    0   1.1G  0 loop
mmcblk0     179:0    0  29.8G  0 disk
├─mmcblk0p1 179:1    0    64M  0 part /boot
└─mmcblk0p2 179:2    0  29.5G  0 part /
zram0       254:0    0    50M  0 disk /var/log
zram1       254:1    0 998.5M  0 disk [SWAP]
root@cranbone:/mnt/linuxmirror/armbianImages# mount /dev/loop0
loop0    loop0p1
root@cranbone:/mnt/linuxmirror/armbianImages# mount /dev/loop0p1 /mnt/tmp
root@cranbone:/mnt/linuxmirror/armbianImages# chroot /mnt/tmp /bin/bash
root@cranbone:/# echo Im in the image now
Im in the image now
root@cranbone:/# apt install iftop -y
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libpcap0.8
The following NEW packages will be installed:
  iftop libpcap0.8
0 upgraded, 2 newly installed, 0 to remove and 9 not upgraded.
Need to get 141 kB of archives.
After this operation, 386 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com bionic/main arm64 libpcap0.8 arm64 1.8.1-6ubuntu1 [104 kB]
Get:2 http://ports.ubuntu.com bionic/universe arm64 iftop arm64 1.0~pre4-4 [36.6 kB]
Fetched 141 kB in 1s (251 kB/s)
dpkg-preconfigure: unable to re-open stdin: No such file or directory
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (2: No such file or directory)
Selecting previously unselected package libpcap0.8:arm64.
(Reading database ... 31546 files and directories currently installed.)
Preparing to unpack .../libpcap0.8_1.8.1-6ubuntu1_arm64.deb ...
Unpacking libpcap0.8:arm64 (1.8.1-6ubuntu1) ...
Selecting previously unselected package iftop.
Preparing to unpack .../iftop_1.0~pre4-4_arm64.deb ...
Unpacking iftop (1.0~pre4-4) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Setting up libpcap0.8:arm64 (1.8.1-6ubuntu1) ...
Setting up iftop (1.0~pre4-4) ...
root@cranbone:/# exit
exit
root@cranbone:/mnt/linuxmirror/armbianImages# umount /mnt/tmp
root@cranbone:/mnt/linuxmirror/armbianImages# losetup -D
Thanks for sharing this.  I got to mount the image and when I was trying to install iftop as in your example, apt gets stuck on Waiting for headers as in the following - any apt command, even apt update gets stuck waiting for headers.  Is this just a temporary issue or is something else wrong:
root@NanoPi-M4:/# apt install iftop -y
  libpcap0.8
  iftop libpcap0.8
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 171 kB of archives.
After this operation, 414 kB of additional disk space will be used.
0% [Waiting for headers]^C
  libpcap0.8
  iftop libpcap0.8
hmmm.. that's odd.  try apt clean and then possibly check on the contents of /etc/resolv.conf and make sure its got a usable DNS server.
otherwise don't really have any ideas.
