zeroalpha Posted August 14, 2019 Posted August 14, 2019 Is it possible to install a modern OS on H3 board ? like Ubuntu 18.04 LTS or 19.04 with a kernel 5.x Only build available here are pretty old with linux kernel v3 ou v4
lanefu Posted August 14, 2019 Posted August 14, 2019 6 minutes ago, zeroalpha said: Is it possible to install a modern OS on H3 board ? like Ubuntu 18.04 LTS or 19.04 with a kernel 5.x Only build available here are pretty old with linux kernel v3 ou v4 you can use an armbian 4.19 image then after you've set it up, run armbian-config.. switch to dev kernel which is 5.x
