gkkpch Posted August 27, 2019 Posted August 27, 2019 The Volumio team is currently investigating whether our sopine64 based motivo board (https://volumio.org/epic-journey-called-volumio-motivo/) could boot from usb using SPI flash. I'm aware of the sunxi SPI developments in u-boot and mainline kernel, and that we theoretically should be able to flash the SPI-NOR chip with the correct u-boot version using FEL mode. I also read that armbian has been prepared for booting from usb (as @martinayotte mentioned in other places). My question is, did anyone actually do anything in this direction, is there something I could help testing with? I know how to compile u-boot as I've done this with armbian's u-boot version 2019-04 which works fine with our motivo board. I must admit i'm not skilled enough to get this done on my own, any help or pointer in the right direction would be very much appreciated. Cheers - Gé
martinayotte Posted August 28, 2019 Posted August 28, 2019 14 hours ago, gkkpch said: I also read that armbian has been prepared for booting from usb (as @martinayotte mentioned in other places). You need to create a patch that will add the following to "configs/pine64_plus_defconfig" : CONFIG_SPL_SPI_FLASH_SUPPORT=y
