KSat2_Roach2 Posted August 29, 2019 Posted August 29, 2019 Hi, I would like to use wiringPi for my NanoPi Neo Air, but after installing wiring P, I only get unable to determine board revision as output from gpio readall. I tried this approaches already: Could someone please explain me how to build wiring P for NanoPi Neo Air so that it is working? On NanoPi Neo Plus 2, I did not have to change anything when installing wiringNP under Armbian.
Alyn Posted September 4, 2019 Posted September 4, 2019 http://wiki.friendlyarm.com/wiki/index.php?title=WiringNP:_NanoPi_NEO/NEO2/Air_GPIO_Programming_with_C&redirect=no If still did not work i will send you detailed steps tomorrow
KSat2_Roach2 Posted September 24, 2019 Author Posted September 24, 2019 Hi, thank you for your answer. I am sorry that it took me so long to try this out. But unfortunately this does not work with my NanoPi Neo Air. The error message is still: piBoardRev: Unable to determine board revision from /proc/cpuinfo. Is 2(0) the board revision number? In boardtype_friendlyelec.c the corresponding line is this: {"sun8i", 0, NanoPi_NEO_Air, "NanoPi-NEO-Air", "2(0)"}, So, maybe 0 is the board revision number. I am unsure what causes the error, I did not find the error message directly in boardtype_friendlyelec.c. Most likely this function is related: getFieldValueInCpuInfo and not the getAllwinnerBoardID where I changed the two lines according to your instructions. The file /sys/devices/platform/board/info named there is empty on my devices and the corresponding folder does not exists. This seems like the error, could you post your /sys/devices/platform/board/info file content from your NanoPi Neo Air? Thank you!
Ali-leb Posted September 25, 2019 Posted September 25, 2019 all you have to do is remove wiringpi and follow these steps carefully from beginning. 1- Run command : git clone https://github.com/friendlyarm/WiringNP 2- Run command : nano /etc/sys_info and paste this content : sunxi_platform : Sun8iw7p1 sunxi_secure : normal sunxi_chipid : 2c21020e786746240000540000000000 sunxi_chiptype : 00000042 sunxi_batchno : 1 sunxi_board_id : 2(0) Note: 2(0) for nanopi_NEO air 3- access WiringNP/wiringPi and open boardtype_friendlyelec.c 4- Change : if(!(f=fopen("/sys/class/sunxi_info/sys_info","r"))){ LOGE("open /sys/class/sunxi_info/sys_info failed."); Into: if(!(f=fopen("/etc/sys_info","r"))){ LOGE("open /etc/sys_info failed."); 5- access /root/WiringNP 6- chmod 755 build 7- ./build 8- gpio readall to check if fine
KSat2_Roach2 Posted September 29, 2019 Author Posted September 29, 2019 Hi, I have tried again. The error is still the same. See also my screenshots, I added my cpuinfo because the error message is related this this. The board revision in cpuinfo is 0 and in boardtype_friendlyelec.c 0. So this seems matching, if revision is the second entry in the gAllBoardHardwareInfo entry elements (BoardHardwareInfo). Could you please crosscheck with your NanoPi Air content of cpuinfo and post it here, maybe I need to fix something there. Thank you!
