Hello.
First of all sorry if this isn't a place to post this.
I recently bought an orange pi one. And I'm using Armbian OS. (Latest version downloaded from Armbian website)
But there seems to be a problem with WiFi and i searched all over the internet and i didn't found anything about it.
So here is how it was:
First time that i wrote the Armbian OS on the SD card and configured it (as said by the Armbian website I didn't connected the WiFi dongle) and after doing those stuff I did connected the WiFi dongle to it. It worked fine, but after some mins both LEDs were on. And nothing was working. I did the things I said above many times and the same happend. And once I did those and instead of putting it away with WiFi, I keept it connected to the tv with hdmi, and again after some mins system stopped. This time LEDs went off and display went off too.!
After that I reconnected the power to it. Lots of errors about setting CPU too 480mhz... (something like that) and it did boot again. And with WiFi, same problem did happend. But without the WiFi dongle it works fine.
Anyone knows how to fix this? Thanks
I use 5v with 2a power supply.
What's the output of
sudo armbianmonitor -u
armbianmonitor -c $HOME
Please do execute the first command first, get back to us with the support URL and be aware that the 2nd command might take some time since it checks your SD card for errors.
Should I do these commands with WiFi dongle in USB port or without it?
Since you always run in troubles with connected WiFi dongle of course without.
sorry i couldn't copy terminal output so i will write the results of the second command here:
health summary: ok
performance summary:
sequential reading speed: 20.54 MB/s
 4K random reading speed: 5736 KB/s
sequential writing speed: 8.91 MB/s
 4K random writing speed: 146 KB/s (way too low)
i use an 8GB, U1 300x micro sd card, i used it before on my raspberry pi and it worked fine.
armhwinfo.log
You aren't permitted to upload this kind of file
it didn't let me upload it so i will paste its content here:
Sat Apr 30 23:20:52 CEST 2016 sun8i armv7l   Orange Pi One
Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
### dmesg:
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 160 MiB at 56000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c0a3d9c0, node_mem_map c0b7f000
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 129920 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1011000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=7
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 338820k/338820k available, 185468k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0973058   (9645 kB)
[    0.000000]       .init : 0xc0974000 - 0xc09c6ec0   ( 332 kB)
[    0.000000]       .data : 0xc09c8000 - 0xc0a42810   ( 491 kB)
[    0.000000]        .bss : 0xc0a42fc4 - 0xc0b7e2d0   (1261 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.002307] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.002475] pid_max: default: 32768 minimum: 301
[    0.003306] Mount-cache hash table entries: 512
[    0.005558] Initializing cgroup subsys cpuacct
[    0.005647] Initializing cgroup subsys memory
[    0.005797] Initializing cgroup subsys devices
[    0.005874] Initializing cgroup subsys freezer
[    0.005946] Initializing cgroup subsys blkio
[    0.006044] Initializing cgroup subsys perf_event
[    0.006280] CPU: Testing write buffer coherency: ok
[    0.006435] ftrace: allocating 25999 entries in 77 pages
[    0.080501] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.080588] [sunxi_smp_prepare_cpus] enter
[    0.080687] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.082759] CPU1: Booted secondary processor
[    0.082759] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.082916] CPU2: Booted secondary processor
[    0.082916] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.090970] CPU3: Booted secondary processor
[    0.090970] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.091116] Brought up 4 CPUs
[    0.091116] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.100024] devtmpfs: initialized
[    0.109277] wakeup src cnt is : 2.
[    0.109340] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.109371] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.109400] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.109431] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.109460] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.109489] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.109518] sunxi pm init
[    0.110214] pinctrl core: initialized pinctrl subsystem
[    0.124590] NET: Registered protocol family 16
[    0.130090] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.130258] script_sysfs_init success
[    0.130364] sunxi_dump_init success
[    0.132367] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.135226] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.137113] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.137211] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.137700] script config pll_video to 297 Mhz
[    0.137773] script config pll_de to 864 Mhz
[    0.137872] script config pll_ve to 402 Mhz
[    0.137939] sunxi_default_clk_init
[    0.137959] try to set pll6ahb1 to 200000000
[    0.138007] try to set ahb clk source to pll6ahb1
[    0.138029] set ahb clk source to pll6ahb1
[    0.138052] try to set ahb1 to 200000000
[    0.138080] try to set apb1 to 100000000
[    0.152317] bio: create slab <bio-0> at 0
[    0.153166] [ARISC] :sunxi-arisc driver v1.04
[    0.171441] [ARISC] :arisc version: [v0.1.58]
[    0.261654] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.265309] SCSI subsystem initialized
[    0.265309] usbcore: registered new interface driver usbfs
[    0.265309] usbcore: registered new interface driver hub
[    0.265309] usbcore: registered new device driver usb
[    0.265309] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.265309] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.265309] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.265309] Linux video capture interface: v2.00
[    0.270159] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.271899] cfg80211: Calling CRDA to update world regulatory domain
[    0.272355] Switching to clocksource arch_sys_counter
[    0.301970] FS-Cache: Loaded
[    0.302546] CacheFiles: Loaded
[    0.329452] NET: Registered protocol family 2
[    0.357031] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.358360] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.359023] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.359701] TCP: Hash tables configured (established 16384 bind 16384)
[    0.359770] TCP: reno registered
[    0.359824] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.359927] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.360823] NET: Registered protocol family 1
[    0.361626] RPC: Registered named UNIX socket transport module.
[    0.361699] RPC: Registered udp transport module.
[    0.361753] RPC: Registered tcp transport module.
[    0.361806] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.362258] Trying to unpack rootfs image as initramfs...
[    0.786689] Freeing initrd memory: 3040K
[    0.787519] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.787865] sunxi_reg_init enter
[    0.789841] audit: initializing netlink socket (disabled)
[    0.790111] type=2000 audit(0.790:1): initialized
[    0.794237] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.794671] misc fatfs initialized
[    0.796354] NFS: Registering the id_resolver key type
[    0.797210] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.797292] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.799000] NTFS driver 2.1.30 [Flags: R/W].
[    0.799760] fuse init (API version 7.18)
[    0.801823] Btrfs loaded
[    0.801913] msgmni has been set to 987
[    0.804622] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.804737] io scheduler noop registered
[    0.804788] io scheduler deadline registered
[    0.804985] io scheduler cfq registered (default)
[    0.806038] [DISP]disp_module_init
[    0.806731] cmdline,init_disp=
[    0.806833] cmdline,disp=
[    0.824274] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.866985] Console: switching to colour frame buffer device 160x45
[    0.912478] [DISP]disp_module_init finish
[    0.913233] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.914290] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.914755] sw_uart_pm()890 - uart0 clk is already enable
[    0.916353] sunxi_cmatest_init enter
[    0.916441] sunxi_cmatest_init success
[    0.926635] brd: module loaded
[    0.936435] loop: module loaded
[    0.937295] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.937786] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.939384] spi spi0: master is unqueued, this is deprecated
[    0.940620] tun: Universal TUN/TAP device driver, 1.6
[    0.941010] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.943529] PPP generic driver version 2.4.2
[    0.944265] PPP BSD Compression module registered
[    0.944628] PPP Deflate Compression module registered
[    0.962703] PPP MPPE Compression module registered
[    0.975390] NET: Registered protocol family 24
[    0.988078] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.021142] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.034610] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.049463] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.080076] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.094770] hub 1-0:1.0: USB hub found
[    1.107758] hub 1-0:1.0: 1 port detected
[    1.120398] ehci_irq: highspeed device connect
[    1.141337] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.154552] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    1.168909] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.200097] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.213021] ehci_irq: highspeed device connect
[    1.214238] hub 2-0:1.0: USB hub found
[    1.227176] hub 2-0:1.0: 1 port detected
[    1.240626] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.273436] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.286340] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 3
[    1.299352] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.320201] ehci_irq: highspeed device disconnect
[    1.375336] hub 3-0:1.0: USB hub found
[    1.388297] hub 3-0:1.0: 1 port detected
[    1.421826] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.434894] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 4
[    1.447888] ehci_irq: highspeed device disconnect
[    1.447994] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.525303] hub 4-0:1.0: USB hub found
[    1.538377] hub 4-0:1.0: 1 port detected
[    1.552133] Initializing USB Mass Storage driver...
[    1.565560] usbcore: registered new interface driver usb-storage
[    1.578974] USB Mass Storage support registered.
[    1.592330] usbcore: registered new interface driver ums-alauda
[    1.605823] usbcore: registered new interface driver ums-cypress
[    1.618987] usbcore: registered new interface driver ums-datafab
[    1.631935] usbcore: registered new interface driver ums_eneub6250
[    1.644562] usbcore: registered new interface driver ums-freecom
[    1.657056] usbcore: registered new interface driver ums-isd200
[    1.669247] usbcore: registered new interface driver ums-jumpshot
[    1.681402] usbcore: registered new interface driver ums-karma
[    1.693302] usbcore: registered new interface driver ums-onetouch
[    1.705284] usbcore: registered new interface driver ums-realtek
[    1.716995] usbcore: registered new interface driver ums-sddr09
[    1.728469] usbcore: registered new interface driver ums-sddr55
[    1.739688] usbcore: registered new interface driver ums-usbat
[    1.751359] file system registered
[    1.766235] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.777462] android_usb gadget: Number of LUNs=3
[    1.780119] usb 3-1: new low-speed USB device number 2 using sunxi-ohci
[    1.799747]  lun0: LUN: removable file: (no medium)
[    1.810912]  lun1: LUN: removable file: (no medium)
[    1.821653]  lun2: LUN: removable file: (no medium)
[    1.833039] android_usb gadget: android_usb ready
[    1.844024]  uinput result 0 , vmouse_init
[    1.845552] mousedev: PS/2 mouse device common for all mice
[    1.857748] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    1.868584] =========script_get_err============
[    1.879441] ltr_init: ls_fetch_sysconfig_para err.
[    1.880217] [RTC] WARNING: Rtc time will be wrong!!
[    1.890937] [RTC] WARNING: use *internal OSC* as clock source
[    1.902184] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.913086] i2c /dev entries driver
[    1.924777] IR RC5(x) protocol handler initialized
[    1.935882] sunxi cedar version 0.1
[    1.935974] [cedar]: install start!!!
[    1.936425] [cedar]: install end!!!
[    1.936804] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.948432] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.959744] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.970667] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.981414] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.991892] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.002097] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.012267] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.022061] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.031659] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    2.041241] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    2.050353] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    2.059296] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    2.068123] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    2.076670] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.084917] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.092872] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.100796] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.108407] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.116616] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    2.117701] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    2.134129] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    2.143041] timeout_to_interv, line 167
[    2.152026] interv_to_timeout, line 189
[    2.161068] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    2.171691] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.182016] calibrat: max_cpufreq 1200Mhz Type 0!
[    2.188271] [ARISC ERROR] :message process error
[    2.198586] [ARISC ERROR] :message addr   : f004b840
[    2.208937] [ARISC ERROR] :message state  : 5
[    2.219059] [ARISC ERROR] :message attr   : 2
[    2.228868] [ARISC ERROR] :message type   : 30
[    2.238581] [ARISC ERROR] :message result : ff
[    2.247939] [ARISC WARING] :callback not install
[    2.250177] usb 4-1: new low-speed USB device number 2 using sunxi-ohci
[    2.266867] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.277449] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    2.277526] [mmc]: get mmc0's sdc_power is null!
[    2.277593] [mmc]: get mmc1's sdc_power is null!
[    2.277619] [mmc]: get mmc1's 2xmode ok, val = 1
[    2.277643] [mmc]: get mmc1's ddrmode ok, val = 1
[    2.277682] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    2.283115] [ARISC ERROR] :message process error
[    2.293015] [ARISC ERROR] :message addr   : f004b840
[    2.302731] [ARISC ERROR] :message state  : 5
[    2.312154] [ARISC ERROR] :message attr   : 2
[    2.321268] [ARISC ERROR] :message type   : 30
[    2.330229] [ARISC ERROR] :message result : ff
[    2.339016] [ARISC WARING] :callback not install
[    2.347675] [cpu_freq] ERR:set cpu frequency to 1008MHz failed!
[    2.362795] [ARISC ERROR] :message process error
[    2.371472] [ARISC ERROR] :message addr   : f004b840
[    2.379812] [ARISC ERROR] :message state  : 5
[    2.388210] [ARISC ERROR] :message attr   : 2
[    2.396620] [ARISC ERROR] :message type   : 30
[    2.405066] [ARISC ERROR] :message result : ff
[    2.413568] [ARISC WARING] :callback not install
[    2.422227] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.437650] [ARISC ERROR] :message process error
[    2.446827] [ARISC ERROR] :message addr   : f004b840
[    2.456127] [ARISC ERROR] :message state  : 5
[    2.465423] [ARISC ERROR] :message attr   : 2
[    2.474749] [ARISC ERROR] :message type   : 30
[    2.484104] [ARISC ERROR] :message result : ff
[    2.493504] [ARISC WARING] :callback not install
[    2.503089] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.519428] [ARISC ERROR] :message process error
[    2.529517] [ARISC ERROR] :message addr   : f004b840
[    2.539737] [ARISC ERROR] :message state  : 5
[    2.549959] [ARISC ERROR] :message attr   : 2
[    2.559828] [ARISC ERROR] :message type   : 30
[    2.569250] [ARISC ERROR] :message result : ff
[    2.578274] [ARISC WARING] :callback not install
[    2.587146] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.602535] [ARISC ERROR] :message process error
[    2.611598] [ARISC ERROR] :message addr   : f004b840
[    2.620367] [ARISC ERROR] :message state  : 5
[    2.628707] [ARISC ERROR] :message attr   : 2
[    2.636653] [ARISC ERROR] :message type   : 30
[    2.644569] [ARISC ERROR] :message result : ff
[    2.652440] [ARISC WARING] :callback not install
[    2.660457] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.675035] [ARISC ERROR] :message process error
[    2.683515] [ARISC ERROR] :message addr   : f004b840
[    2.691942] [ARISC ERROR] :message state  : 5
[    2.700076] [ARISC ERROR] :message attr   : 2
[    2.707903] [ARISC ERROR] :message type   : 30
[    2.715535] [ARISC ERROR] :message result : ff
[    2.723151] [ARISC WARING] :callback not install
[    2.730850] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.745274] [ARISC ERROR] :message process error
[    2.753448] [ARISC ERROR] :message addr   : f004b840
[    2.761695] [ARISC ERROR] :message state  : 5
[    2.769786] [ARISC ERROR] :message attr   : 2
[    2.777653] [ARISC ERROR] :message type   : 30
[    2.785309] [ARISC ERROR] :message result : ff
[    2.792933] [ARISC WARING] :callback not install
[    2.800656] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[    2.809904] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.811253] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.812687] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.812850] [mmc]: sdc0 power_supply is null
[    2.816002] no blue_led, ignore it!
[    2.824729] Registered led device: red_led
[    2.825013] Registered led device: green_led
[    2.825056] no led_0, ignore it!
[    2.830120] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.833262] no led_1, ignore it!
[    2.841298] no led_2, ignore it!
[    2.849019] no led_3, ignore it!
[    2.851865] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.854526] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.856524] no led_4, ignore it!
[    2.860215] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.860457] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.863109] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.863929] no led_5, ignore it!
[    2.871270] no led_6, ignore it!
[    2.878553] no led_7, ignore it!
[    2.881761] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.885817] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.886035] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.886343] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    2.886564] mmc0: new high speed SDHC card at address 0007
[    2.895378] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    2.905709]  mmcblk0: p1
[    2.906824] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    2.922778] mmcblk mmc0:0007: Card claimed for testing.
[    2.923649] generic-usb 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-sunxi-ohci-1/input0
[    2.931354] generic-usb 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-sunxi-ohci-1/input1
[    2.931543] usbcore: registered new interface driver usbhid
[    2.931563] usbhid: USB HID core driver
[    2.970172] mmc0:0007: SD08G 7.42 GiB
[    2.980241] *******************sd init ok*******************
[    2.994868] asoc: sndcodec <-> sunxi-codec mapping ok
[    3.007070] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    3.018243] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    3.029373] [DAUDIO0] driver not init,just return.
[    3.049125] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.063174] oprofile: using arm/armv7-ca7
[    3.075095] u32 classifier
[    3.086576]     Actions configured
[    3.098375] IPv4 over IPv4 tunneling driver
[    3.111193] TCP: bic registered
[    3.122554] TCP: cubic registered
[    3.133913] TCP: westwood registered
[    3.145341] TCP: highspeed registered
[    3.156857] TCP: hybla registered
[    3.168404] TCP: htcp registered
[    3.179869] TCP: vegas registered
[    3.191157] TCP: veno registered
[    3.202250] TCP: scalable registered
[    3.213376] TCP: lp registered
[    3.224502] TCP: yeah registered
[    3.235695] TCP: illinois registered
[    3.247064] Initializing XFRM netlink socket
[    3.259100] NET: Registered protocol family 10
[    3.273293] NET: Registered protocol family 17
[    3.284614] NET: Registered protocol family 15
[    3.295667] Registering the dns_resolver key type
[    3.307417] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    3.319104] ThumbEE CPU extension supported.
[    3.330898] Registering SWP/SWPB emulation handler
[    3.344222] registered taskstats version 1
[    3.357497] cmdline,disp=
[    3.370091] [HDMI] power vcc-hdmi-18
[    3.401284] ths_fetch_sysconfig_para: type err  device_used = 1.
[    3.417365] CPU Budget:Register notifier
[    3.430248] CPU Budget:register Success
[    3.442886] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    3.463433] [rf_pm]: module power0 name vcc-wifi-33
[    3.463470] [rf_pm]: Did not config module_power1 in sys_config
[    3.463498] [rf_pm]: Did not config module_power2 in sys_config
[    3.463525] [rf_pm]: Did not config module_power3 in sys_config
[    3.463550] [rf_pm]: mod has no chip_en gpio
[    3.463572] [rf_pm]: failed to fetch lpo_use_apclk
[    3.463592] [rf_pm]: regulator on.
[    3.464122] [wifi_pm]: wifi gpio init is OK !!
[    3.464248] [rfkill]: init no bt used in configuration
[    3.464275] ALSA device list:
[    3.477464]   #0: audiocodec
[    3.490045]   #1: sndhdmi
[    3.503383] Freeing init memory: 328K
[    3.619443] systemd-udevd[97]: starting version 215
[    4.010143] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    6.372565] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.680633] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    7.695260] systemd[1]: Detected architecture 'arm'.
[    7.767336] systemd[1]: Set hostname to <orangepih3>.
[    8.259636] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    8.296648] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    8.313665] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.330457] systemd[1]: Expecting device dev-ttySAC2.device...
[    8.364659] systemd[1]: Starting Remote File Systems (Pre).
[    8.399566] systemd[1]: Reached target Remote File Systems (Pre).
[    8.417163] systemd[1]: Starting Encrypted Volumes.
[    8.452263] systemd[1]: Reached target Encrypted Volumes.
[    8.469521] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    8.487425] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    8.505152] systemd[1]: Starting Paths.
[    8.540776] systemd[1]: Reached target Paths.
[    8.558503] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    8.595765] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.614147] systemd[1]: Starting Swap.
[    8.651545] systemd[1]: Reached target Swap.
[    8.669948] systemd[1]: Starting Root Slice.
[    8.707035] systemd[1]: Created slice Root Slice.
[    8.724712] systemd[1]: Starting User and Session Slice.
[    8.761161] systemd[1]: Created slice User and Session Slice.
[    8.778815] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    8.815130] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    8.832840] systemd[1]: Starting Delayed Shutdown Socket.
[    8.868736] systemd[1]: Listening on Delayed Shutdown Socket.
[    8.886105] systemd[1]: Starting Journal Socket (/dev/log).
[    8.921423] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.938912] systemd[1]: Starting udev Control Socket.
[    8.973153] systemd[1]: Listening on udev Control Socket.
[    8.989971] systemd[1]: Starting udev Kernel Socket.
[    9.023854] systemd[1]: Listening on udev Kernel Socket.
[    9.040550] systemd[1]: Starting Journal Socket.
[    9.073110] systemd[1]: Listening on Journal Socket.
[    9.088572] systemd[1]: Starting System Slice.
[    9.119778] systemd[1]: Created slice System Slice.
[    9.134948] systemd[1]: Started File System Check on Root Device.
[    9.149983] systemd[1]: Starting system-getty.slice.
[    9.180864] systemd[1]: Created slice system-getty.slice.
[    9.195742] systemd[1]: Starting system-serial\x2dgetty.slice.
[    9.226538] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.241638] systemd[1]: Starting Increase datagram queue length...
[    9.331438] systemd[1]: Starting Restore / save the current clock...
[    9.541463] systemd[1]: Starting udev Coldplug all Devices...
[    9.661785] systemd[1]: Mounting POSIX Message Queue File System...
[    9.777780] systemd[1]: Starting Load Kernel Modules...
[    9.912104] systemd[1]: Mounting Debug File System...
[   10.041196] systemd[1]: Mounted Huge Pages File System.
[   10.043332] RTL871X: module init start
[   10.043356] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[   10.043545] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.045177] [mmc]: sdc1 power_supply is null
[   10.057556] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   10.060161] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.083420] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.086098] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.094997] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.096187] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.096598] [mmc]: sdc1 power_supply is null
[   10.099362] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.100955] [mmc]: sdc1 power_supply is null
[   10.120168] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.134869] systemd[1]: Started Set Up Additional Binary Formats.
[   10.143496] [wifi_pm]: set wl_reg_on 1 !
[   10.143747] RTL871X: module init ret=0
[   10.143960] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.146831] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.150938] systemd[1]: Starting LSB: Set keymap...
[   10.158027] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.159417] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.159760] [mmc]: sdc1 power_supply is null
[   10.162499] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.164070] [mmc]: sdc1 power_supply is null
[   10.180162] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.204978] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.208099] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.224110] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.226051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.226397] [mmc]: sdc1 power_supply is null
[   10.229138] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.230715] [mmc]: sdc1 power_supply is null
[   10.240980] systemd[1]: Starting Slices.
[   10.250197] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.272178] systemd[1]: Reached target Slices.
[   10.276010] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.279351] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.300256] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.302775] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.303117] [mmc]: sdc1 power_supply is null
[   10.306722] systemd[1]: Mounted Debug File System.
[   10.337355] systemd[1]: Mounted POSIX Message Queue File System.
[   10.486029] systemd[1]: Started Increase datagram queue length.
[   10.576270] systemd[1]: Started Restore / save the current clock.
[   10.736758] systemd[1]: Started Load Kernel Modules.
[   10.896982] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   11.017089] systemd[1]: Started LSB: Set keymap.
[   11.147191] systemd[1]: Started udev Coldplug all Devices.
[   11.167726] systemd[1]: Time has been changed
[   11.184812] systemd[1]: Starting Create Static Device Nodes in /dev...
[   11.382010] systemd[1]: Mounted Configuration File System.
[   11.399075] systemd[1]: Starting Apply Kernel Variables...
[   11.551497] systemd[1]: Mounting FUSE Control File System...
[   11.680806] systemd[1]: Starting Syslog Socket.
[   11.714723] systemd[1]: Listening on Syslog Socket.
[   11.730732] systemd[1]: Starting Journal Service...
[   11.868269] systemd[1]: Started Journal Service.
[   12.395260] systemd-udevd[177]: starting version 215
[   20.336509] [ARISC ERROR] :message process error
[   20.351102] [ARISC ERROR] :message addr   : f004b840
[   20.366024] [ARISC ERROR] :message state  : 5
[   20.380721] [ARISC ERROR] :message attr   : 2
[   20.395103] [ARISC ERROR] :message type   : 30
[   20.409195] [ARISC ERROR] :message result : ff
[   20.423022] [ARISC WARING] :callback not install
[   20.436717] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[   20.457128] [ARISC ERROR] :message process error
[   20.470689] [ARISC ERROR] :message addr   : f004b840
[   20.484092] [ARISC ERROR] :message state  : 5
[   20.497100] [ARISC ERROR] :message attr   : 2
[   20.509618] [ARISC ERROR] :message type   : 30
[   20.521677] [ARISC ERROR] :message result : ff
[   20.533533] [ARISC WARING] :callback not install
[   20.545328] [cpu_freq] ERR:set cpu frequency to 1296MHz failed!
[   24.097082] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   25.792881] systemd-journald[176]: Received request to flush runtime journal from PID 1
[   26.244952] gmac0: probed
[   26.258761] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   37.050097] eth0: no IPv6 routers present
### lsusb:
Bus 004 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x1c4f SiGma Micro
  idProduct          0x0002 Keyboard TRACER Gamma Ivory
  bcdDevice            1.10
  iManufacturer           1 (error)
  iProduct                2 USB Keykoard
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               98mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      54
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      50
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0003  1x 3 bytes
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0001 1.1 root hub
  bcdDevice            3.04
  iManufacturer           3 Linux 3.4.112-sun8i ohci_hcd
  iProduct                2 SW USB2.0 'Open' Host Controller (OHCI) Driver
  iSerial                 1 sunxi-ohci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0012
    No power switching (usb 1.0)
    No overcurrent protection
  bPwrOn2PwrGood        2 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0303 lowspeed power enable connect
Device Status:     0x0001
  Self Powered
Bus 003 Device 002: ID 0000:0538
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0000
  idProduct          0x0538
  bcdDevice            1.00
  iManufacturer           0
  iProduct                1  USB OPTICAL MOUSE
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      2 Mouse
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      66
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0006  1x 6 bytes
        bInterval              10
  (Bus Powered)
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.04
  iManufacturer           3 Linux 3.4.112-sun8i ehci_hcd
  iProduct                2 SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  iSerial                 1 sunxi-ehci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x000a
    Per-port overcurrent protection
  bPwrOn2PwrGood       10 * 2 milli seconds
 Hub Port Status:
   Port 1: 0000.0100 power
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
### lscpu:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
CPU max MHz:           1296.0000
CPU min MHz:           480.0000
### cpuinfo:
Processor	: ARMv7 Processor rev 5 (v7l)
processor	: 0
BogoMIPS	: 4800.00
processor	: 1
BogoMIPS	: 4800.00
processor	: 2
BogoMIPS	: 4800.00
processor	: 3
BogoMIPS	: 4800.00
Features	: swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
Serial		: 4435502f024e3c000000
### meminfo:
MemTotal:         506028 kB
MemFree:          415380 kB
Buffers:            7796 kB
Cached:            33880 kB
SwapCached:            0 kB
Active:            28392 kB
Inactive:          31168 kB
Active(anon):      18212 kB
Inactive(anon):     4380 kB
Active(file):      10180 kB
Inactive(file):    26788 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          415380 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:               208 kB
Writeback:             0 kB
AnonPages:         18004 kB
Mapped:             7920 kB
Shmem:              4592 kB
Slab:              12328 kB
SReclaimable:       4644 kB
SUnreclaim:         7684 kB
KernelStack:         728 kB
PageTables:          480 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      253012 kB
Committed_AS:      57284 kB
VmallocTotal:     499712 kB
VmallocUsed:       16592 kB
VmallocChunk:     253840 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
  3:          1          0          0          0  sunxi_gpio_irq_chip  gk_EINT
 29:       1926       2607       2805       1752       GIC  arch_timer
 30:          0          0          0          0       GIC  arch_timer
 38:         18          0          0          0       GIC  twi0
 39:         18          0          0          0       GIC  twi1
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 50:          0          0          0          0       GIC  sunxi_timer0
 63:          0          0          0          0       GIC  Thermal
 72:          0          0          0          0       GIC  sunxi-rtc alarm
 77:          1          0          0          0       GIC  PL
 81:          0          0          0          0       GIC  arisc_hwmsgbox_irq
 82:          0          0          0          0       GIC  sunxi_dmac
 90:          0          0          0          0       GIC  cedar_dev
 92:       5494          0          0          0       GIC  sunxi-mmc
 93:         52          0          0          0       GIC  sunxi-mmc
 97:          0          0          0          0       GIC  spi0
104:          2          0          0          0       GIC  ehci_hcd:usb1
105:         23          0          8          0       GIC  ohci_hcd:usb3
106:          2          0          0          0       GIC  ehci_hcd:usb2
107:         49          0          0          0       GIC  ohci_hcd:usb4
114:          4          0          0          0       GIC  gmac0
118:       2280          0          0          0       GIC  dispaly
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       3642       2715       1522       1241  Rescheduling interrupts
IPI3:          9        162        161        162  Function call interrupts
IPI4:          2          4          2          1  Single function call interrupts
IPI5:          0          0          0          0  CPU stop interrupts
IPI6:          0          0          0          0  CPU backtrace
IPI7:          0          0          0          0  completion interrupts
Err:          0
### ifconfig:
eth0      Link encap:Ethernet  HWaddr de:99:0c:13:2d:eb
          inet6 addr: fe80::dc99:cff:fe13:2deb/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:580 (580.0
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0   TX bytes:0 (0.0
### df:
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1  2.3G  1.9G  309M  87% /
udev             10M     0   10M   0% /dev
tmpfs            99M  4.5M   95M   5% /run
tmpfs           248M     0  248M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           248M     0  248M   0% /sys/fs/cgroup
tmpfs           248M   36K  248M   1% /tmp
### mmc0:0007 info:
                 cid: 275048534430384730dae82e3d00ebb1
                 csd: 400e00325b5900003b5f7f800a400075
                 scr: 0235800001000000
                date: 11/2014
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD08G MODALIAS=mmc:block
          erase_size: 512
Sat Apr 30 23:23:39 CEST 2016 sun8i armv7l   Orange Pi One
### dmesg:
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000539] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000598] pid_max: default: 32768 minimum: 301
[    0.001381] Mount-cache hash table entries: 512
[    0.003579] Initializing cgroup subsys cpuacct
[    0.003614] Initializing cgroup subsys memory
[    0.003718] Initializing cgroup subsys devices
[    0.003747] Initializing cgroup subsys freezer
[    0.003774] Initializing cgroup subsys blkio
[    0.003828] Initializing cgroup subsys perf_event
[    0.004016] CPU: Testing write buffer coherency: ok
[    0.004115] ftrace: allocating 25999 entries in 77 pages
[    0.070500] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.070537] [sunxi_smp_prepare_cpus] enter
[    0.070608] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.072631] CPU1: Booted secondary processor
[    0.072631] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.072787] CPU2: Booted secondary processor
[    0.072787] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.080970] CPU3: Booted secondary processor
[    0.080970] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.081116] Brought up 4 CPUs
[    0.081116] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.090025] devtmpfs: initialized
[    0.099256] wakeup src cnt is : 2.
[    0.099284] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099313] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.099343] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099373] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099402] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.099431] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099460] sunxi pm init
[    0.099773] pinctrl core: initialized pinctrl subsystem
[    0.114149] NET: Registered protocol family 16
[    0.115741] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.115741] script_sysfs_init success
[    0.115741] sunxi_dump_init success
[    0.121837] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.124644] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.126449] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.126484] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.126932] script config pll_video to 297 Mhz
[    0.126970] script config pll_de to 864 Mhz
[    0.127039] script config pll_ve to 402 Mhz
[    0.127076] sunxi_default_clk_init
[    0.127096] try to set pll6ahb1 to 200000000
[    0.127143] try to set ahb clk source to pll6ahb1
[    0.127164] set ahb clk source to pll6ahb1
[    0.127188] try to set ahb1 to 200000000
[    0.127216] try to set apb1 to 100000000
[    0.141636] bio: create slab <bio-0> at 0
[    0.142427] [ARISC] :sunxi-arisc driver v1.04
[    0.160672] [ARISC] :arisc version: [v0.1.58]
[    0.247594] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.251360] SCSI subsystem initialized
[    0.251847] usbcore: registered new interface driver usbfs
[    0.252018] usbcore: registered new interface driver hub
[    0.252251] usbcore: registered new device driver usb
[    0.252518] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.252551] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.252581] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.253939] Linux video capture interface: v2.00
[    0.254456] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.256136] cfg80211: Calling CRDA to update world regulatory domain
[    0.256534] Switching to clocksource arch_sys_counter
[    0.281979] FS-Cache: Loaded
[    0.282518] CacheFiles: Loaded
[    0.310121] NET: Registered protocol family 2
[    0.337595] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.338884] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.339488] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.340191] TCP: Hash tables configured (established 16384 bind 16384)
[    0.340221] TCP: reno registered
[    0.340253] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.340319] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.341092] NET: Registered protocol family 1
[    0.341931] RPC: Registered named UNIX socket transport module.
[    0.341962] RPC: Registered udp transport module.
[    0.341985] RPC: Registered tcp transport module.
[    0.342007] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.342464] Trying to unpack rootfs image as initramfs...
[    0.767102] Freeing initrd memory: 3040K
[    0.767921] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.768184] sunxi_reg_init enter
[    0.770231] audit: initializing netlink socket (disabled)
[    0.770381] type=2000 audit(0.770:1): initialized
[    0.774501] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.774884] misc fatfs initialized
[    0.776591] NFS: Registering the id_resolver key type
[    0.777425] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.777459] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.779126] NTFS driver 2.1.30 [Flags: R/W].
[    0.779830] fuse init (API version 7.18)
[    0.781808] Btrfs loaded
[    0.781865] msgmni has been set to 987
[    0.784721] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.784768] io scheduler noop registered
[    0.784792] io scheduler deadline registered
[    0.784956] io scheduler cfq registered (default)
[    0.785853] [DISP]disp_module_init
[    0.786529] cmdline,init_disp=
[    0.786597] cmdline,disp=
[    0.803824] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.846493] Console: switching to colour frame buffer device 160x45
[    0.891595] [DISP]disp_module_init finish
[    0.892055] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.892689] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.892722] sw_uart_pm()890 - uart0 clk is already enable
[    0.893929] sunxi_cmatest_init enter
[    0.894022] sunxi_cmatest_init success
[    0.904105] brd: module loaded
[    0.913765] loop: module loaded
[    0.914329] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.914366] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.915563] spi spi0: master is unqueued, this is deprecated
[    0.916311] tun: Universal TUN/TAP device driver, 1.6
[    0.916336] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.918423] PPP generic driver version 2.4.2
[    0.918872] PPP BSD Compression module registered
[    0.918903] PPP Deflate Compression module registered
[    0.924198] PPP MPPE Compression module registered
[    0.924237] NET: Registered protocol family 24
[    0.924382] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.944585] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.944666] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.945882] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.960094] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.961502] hub 1-0:1.0: USB hub found
[    0.961555] hub 1-0:1.0: 1 port detected
[    0.982417] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.982492] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.983391] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.000086] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.000121] ehci_irq: highspeed device connect
[    1.001353] hub 2-0:1.0: USB hub found
[    1.001411] hub 2-0:1.0: 1 port detected
[    1.022300] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022373] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.023278] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.040081] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.040627] ehci_irq: highspeed device connect
[    1.041354] hub 3-0:1.0: USB hub found
[    1.041413] hub 3-0:1.0: 1 port detected
[    1.062287] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.062358] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.063255] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.080084] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.081354] hub 4-0:1.0: USB hub found
[    1.081400] hub 4-0:1.0: 1 port detected
[    1.082311] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.102462] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.102533] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.102612] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.160207] ehci_irq: highspeed device disconnect
[    1.160253] ohci_irq: fullspeed or lowspeed device connect
[    1.165360] hub 5-0:1.0: USB hub found
[    1.165408] hub 5-0:1.0: 1 port detected
[    1.186331] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.186400] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.186478] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.220238] ehci_irq: highspeed device disconnect
[    1.245445] hub 6-0:1.0: USB hub found
[    1.245493] hub 6-0:1.0: 1 port detected
[    1.266393] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.266463] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.266539] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.325381] hub 7-0:1.0: USB hub found
[    1.325427] hub 7-0:1.0: 1 port detected
[    1.346360] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.346432] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.346509] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    1.405221] hub 8-0:1.0: USB hub found
[    1.405267] hub 8-0:1.0: 1 port detected
[    1.406095] Initializing USB Mass Storage driver...
[    1.406608] usbcore: registered new interface driver usb-storage
[    1.406633] USB Mass Storage support registered.
[    1.406760] usbcore: registered new interface driver ums-alauda
[    1.406884] usbcore: registered new interface driver ums-cypress
[    1.407025] usbcore: registered new interface driver ums-datafab
[    1.407142] usbcore: registered new interface driver ums_eneub6250
[    1.407260] usbcore: registered new interface driver ums-freecom
[    1.407380] usbcore: registered new interface driver ums-isd200
[    1.407495] usbcore: registered new interface driver ums-jumpshot
[    1.407610] usbcore: registered new interface driver ums-karma
[    1.407731] usbcore: registered new interface driver ums-onetouch
[    1.407884] usbcore: registered new interface driver ums-realtek
[    1.408020] usbcore: registered new interface driver ums-sddr09
[    1.408140] usbcore: registered new interface driver ums-sddr55
[    1.408260] usbcore: registered new interface driver ums-usbat
[    1.408955] file system registered
[    1.412830] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.412865] android_usb gadget: Number of LUNs=3
[    1.412894]  lun0: LUN: removable file: (no medium)
[    1.412922]  lun1: LUN: removable file: (no medium)
[    1.412949]  lun2: LUN: removable file: (no medium)
[    1.413761] android_usb gadget: android_usb ready
[    1.414262]  uinput result 0 , vmouse_init
[    1.415708] mousedev: PS/2 mouse device common for all mice
[    1.417660] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    1.417689] =========script_get_err============
[    1.417711] ltr_init: ls_fetch_sysconfig_para err.
[    1.418426] [RTC] WARNING: Rtc time will be wrong!!
[    1.418456] [RTC] WARNING: use *internal OSC* as clock source
[    1.419061] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.419184] i2c /dev entries driver
[    1.420278] IR RC5(x) protocol handler initialized
[    1.420596] sunxi cedar version 0.1
[    1.420694] [cedar]: install start!!!
[    1.421156] [cedar]: install end!!!
[    1.421537] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.421779] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.422017] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.422252] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.422487] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.422720] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.422956] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.423190] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.423423] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.423685] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.423941] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.424195] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.424449] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.424702] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.424957] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.425210] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.425463] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.425717] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.425756] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.426169] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.426521] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.426554] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.426582] timeout_to_interv, line 167
[    1.426603] interv_to_timeout, line 189
[    1.426629] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.427574] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.427796] calibrat: max_cpufreq 1200Mhz Type 0!
[    1.427826] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    1.433437] [ARISC ERROR] :message process error
[    1.433461] [ARISC ERROR] :message addr   : f004b840
[    1.433480] [ARISC ERROR] :message state  : 5
[    1.433498] [ARISC ERROR] :message attr   : 2
[    1.433516] [ARISC ERROR] :message type   : 30
[    1.433533] [ARISC ERROR] :message result : ff
[    1.433550] [ARISC WARING] :callback not install
[    1.433572] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    1.434115] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    1.434189] [mmc]: get mmc0's sdc_power is null!
[    1.434250] [mmc]: get mmc1's sdc_power is null!
[    1.434271] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.434292] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.434326] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    1.436106] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.437334] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438449] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438908] [mmc]: sdc0 power_supply is null
[    1.441599] no blue_led, ignore it!
[    1.442051] Registered led device: red_led
[    1.442264] Registered led device: green_led
[    1.442299] no led_0, ignore it!
[    1.442316] no led_1, ignore it!
[    1.442333] no led_2, ignore it!
[    1.442349] no led_3, ignore it!
[    1.442365] no led_4, ignore it!
[    1.442381] no led_5, ignore it!
[    1.442397] no led_6, ignore it!
[    1.442413] no led_7, ignore it!
[    1.444066] usbcore: registered new interface driver usbhid
[    1.444090] usbhid: USB HID core driver
[    1.452043] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.453844] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.454234] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.454265] [DAUDIO0] driver not init,just return.
[    1.460087] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.461246] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.463417] oprofile: using arm/armv7-ca7
[    1.463775] u32 classifier
[    1.463795]     Actions configured
[    1.464172] IPv4 over IPv4 tunneling driver
[    1.465418] TCP: bic registered
[    1.465443] TCP: cubic registered
[    1.465460] TCP: westwood registered
[    1.465479] TCP: highspeed registered
[    1.465496] TCP: hybla registered
[    1.465513] TCP: htcp registered
[    1.465529] TCP: vegas registered
[    1.465546] TCP: veno registered
[    1.465563] TCP: scalable registered
[    1.465580] TCP: lp registered
[    1.465596] TCP: yeah registered
[    1.465613] TCP: illinois registered
[    1.465629] Initializing XFRM netlink socket
[    1.466100] NET: Registered protocol family 10
[    1.468379] NET: Registered protocol family 17
[    1.468442] NET: Registered protocol family 15
[    1.468540] Registering the dns_resolver key type
[    1.469162] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.469208] ThumbEE CPU extension supported.
[    1.469248] Registering SWP/SWPB emulation handler
[    1.470523] registered taskstats version 1
[    1.471041] cmdline,disp=
[    1.471347] [HDMI] power vcc-hdmi-18
[    1.481743] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.484267] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489635] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489759] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.492259] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.502093] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.503630] CPU Budget:Register notifier
[    1.503644] CPU Budget:register Success
[    1.503659] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.506897] [rf_pm]: module power0 name vcc-wifi-33
[    1.506913] [rf_pm]: Did not config module_power1 in sys_config
[    1.506925] [rf_pm]: Did not config module_power2 in sys_config
[    1.506936] [rf_pm]: Did not config module_power3 in sys_config
[    1.506946] [rf_pm]: mod has no chip_en gpio
[    1.506955] [rf_pm]: failed to fetch lpo_use_apclk
[    1.506964] [rf_pm]: regulator on.
[    1.506975] [wifi_pm]: no wifi used in configuration
[    1.506986] [rfkill]: init no bt used in configuration
[    1.506995] ALSA device list:
[    1.507003]   #0: audiocodec
[    1.507010]   #1: sndhdmi
[    1.507610] Freeing init memory: 328K
[    1.511692] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.515603] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515727] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515899] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.516006] mmc0: new high speed SDHC card at address 0007
[    1.516537] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    1.518087]  mmcblk0: p1
[    1.518740] mmcblk mmc0:0007: Card claimed for testing.
[    1.518757] mmc0:0007: SD08G 7.42 GiB
[    1.518798] *******************sd init ok*******************
[    1.540089] usb 5-1: new low-speed USB device number 2 using sunxi-ohci
[    1.547284] systemd-udevd[97]: starting version 215
[    1.767826] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    1.940054] usb 6-1: new low-speed USB device number 2 using sunxi-ohci
[    2.074926] [ARISC ERROR] :message process error
[    2.074952] [ARISC ERROR] :message addr   : f004b840
[    2.074972] [ARISC ERROR] :message state  : 5
[    2.074990] [ARISC ERROR] :message attr   : 2
[    2.075007] [ARISC ERROR] :message type   : 30
[    2.075025] [ARISC ERROR] :message result : ff
[    2.075041] [ARISC WARING] :callback not install
[    2.075064] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.079012] [ARISC ERROR] :message process error
[    2.079033] [ARISC ERROR] :message addr   : f004b840
[    2.079052] [ARISC ERROR] :message state  : 5
[    2.079069] [ARISC ERROR] :message attr   : 2
[    2.079086] [ARISC ERROR] :message type   : 30
[    2.079104] [ARISC ERROR] :message result : ff
[    2.079120] [ARISC WARING] :callback not install
[    2.079140] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.110085] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    2.182084] generic-usb 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-sunxi-ohci-1/input0
[    2.189773] generic-usb 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-sunxi-ohci-1/input1
[    2.977236] [ARISC ERROR] :message process error
[    2.977269] [ARISC ERROR] :message addr   : f004b840
[    2.977288] [ARISC ERROR] :message state  : 5
[    2.977307] [ARISC ERROR] :message attr   : 2
[    2.977325] [ARISC ERROR] :message type   : 30
[    2.977342] [ARISC ERROR] :message result : ff
[    2.977359] [ARISC WARING] :callback not install
[    2.977382] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    3.112874] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.466740] [ARISC ERROR] :message process error
[    3.466772] [ARISC ERROR] :message addr   : f004b840
[    3.466792] [ARISC ERROR] :message state  : 5
[    3.466810] [ARISC ERROR] :message attr   : 2
[    3.466828] [ARISC ERROR] :message type   : 30
[    3.466846] [ARISC ERROR] :message result : ff
[    3.466863] [ARISC WARING] :callback not install
[    3.466885] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    3.985169] [ARISC ERROR] :message process error
[    3.985200] [ARISC ERROR] :message addr   : f004b840
[    3.985219] [ARISC ERROR] :message state  : 5
[    3.985237] [ARISC ERROR] :message attr   : 2
[    3.985255] [ARISC ERROR] :message type   : 30
[    3.985273] [ARISC ERROR] :message result : ff
[    3.985290] [ARISC WARING] :callback not install
[    3.985311] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    4.380551] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    4.381109] systemd[1]: Detected architecture 'arm'.
[    4.395787] systemd[1]: Set hostname to <orangepione>.
[    4.744615] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    4.746988] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.747323] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.747394] systemd[1]: Expecting device dev-ttySAC2.device...
[    4.747927] systemd[1]: Starting Remote File Systems (Pre).
[    4.748267] systemd[1]: Reached target Remote File Systems (Pre).
[    4.748356] systemd[1]: Starting Encrypted Volumes.
[    4.748657] systemd[1]: Reached target Encrypted Volumes.
[    4.748732] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    4.748924] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.748977] systemd[1]: Starting Paths.
[    4.749248] systemd[1]: Reached target Paths.
[    4.749351] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.750226] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.750314] systemd[1]: Starting Root Slice.
[    4.750699] systemd[1]: Created slice Root Slice.
[    4.750754] systemd[1]: Starting User and Session Slice.
[    4.751185] systemd[1]: Created slice User and Session Slice.
[    4.751238] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.751719] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.751774] systemd[1]: Starting Delayed Shutdown Socket.
[    4.752177] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.752232] systemd[1]: Starting Journal Socket (/dev/log).
[    4.752629] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.752701] systemd[1]: Starting udev Control Socket.
[    4.753042] systemd[1]: Listening on udev Control Socket.
[    4.753107] systemd[1]: Starting udev Kernel Socket.
[    4.753442] systemd[1]: Listening on udev Kernel Socket.
[    4.753519] systemd[1]: Starting Journal Socket.
[    4.753902] systemd[1]: Listening on Journal Socket.
[    4.754009] systemd[1]: Starting System Slice.
[    4.754404] systemd[1]: Created slice System Slice.
[    4.754505] systemd[1]: Started File System Check on Root Device.
[    4.754550] systemd[1]: Starting system-getty.slice.
[    4.755032] systemd[1]: Created slice system-getty.slice.
[    4.755087] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.755545] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.755678] systemd[1]: Starting Increase datagram queue length...
[    4.830669] systemd[1]: Starting Restore / save the current clock...
[    4.890679] systemd[1]: Starting udev Coldplug all Devices...
[    4.951021] systemd[1]: Mounting POSIX Message Queue File System...
[    5.027654] systemd[1]: Starting Load Kernel Modules...
[    5.091076] systemd[1]: Mounting Debug File System...
[    5.182517] systemd[1]: Mounted Huge Pages File System.
[    5.183065] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.193693] RTL871X: module init start
[    5.193708] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[    5.193790] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.195328] [mmc]: sdc1 power_supply is null
[    5.210039] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.233194] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.235686] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.244150] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.245080] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.245201] [mmc]: sdc1 power_supply is null
[    5.247784] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.249309] [mmc]: sdc1 power_supply is null
[    5.253702] systemd[1]: Started Set Up Additional Binary Formats.
[    5.253808] systemd[1]: Starting LSB: Set keymap...
[    5.270081] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.293760] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.293771] [wifi_pm]: set wl_reg_on 1 !
[    5.293893] RTL871X: module init ret=0
[    5.296408] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.300603] systemd[1]: Starting Slices.
[    5.301067] systemd[1]: Reached target Slices.
[    5.303392] systemd[1]: Mounted Debug File System.
[    5.303998] systemd[1]: Mounted POSIX Message Queue File System.
[    5.307375] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.308620] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.308746] [mmc]: sdc1 power_supply is null
[    5.311118] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.312648] [mmc]: sdc1 power_supply is null
[    5.330040] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.354783] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.357663] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.370528] systemd[1]: Started Increase datagram queue length.
[    5.373381] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.375180] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.375302] [mmc]: sdc1 power_supply is null
[    5.377893] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.379424] [mmc]: sdc1 power_supply is null
[    5.400031] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.425864] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.429007] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.449537] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.451871] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.451988] [mmc]: sdc1 power_supply is null
[    5.474412] systemd[1]: Started Restore / save the current clock.
[    5.655421] systemd[1]: Started Load Kernel Modules.
[    5.725342] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.782691] [ARISC ERROR] :message process error
[    5.782714] [ARISC ERROR] :message addr   : f004b840
[    5.782730] [ARISC ERROR] :message state  : 5
[    5.782745] [ARISC ERROR] :message attr   : 2
[    5.782759] [ARISC ERROR] :message type   : 30
[    5.782774] [ARISC ERROR] :message result : ff
[    5.782787] [ARISC WARING] :callback not install
[    5.782806] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    5.790672] systemd[1]: Started LSB: Set keymap.
[    5.870529] systemd[1]: Started udev Coldplug all Devices.
[    5.874380] systemd[1]: Time has been changed
[    5.875358] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.991710] systemd[1]: Mounted Configuration File System.
[    5.991955] systemd[1]: Starting Apply Kernel Variables...
[    6.111321] systemd[1]: Mounting FUSE Control File System...
[    6.180738] systemd[1]: Starting Syslog Socket.
[    6.191552] systemd[1]: Listening on Syslog Socket.
[    6.191830] systemd[1]: Starting Journal Service...
[    6.321418] systemd[1]: Started Journal Service.
[    6.613949] [ARISC ERROR] :message process error
[    6.613979] [ARISC ERROR] :message addr   : f004b840
[    6.613999] [ARISC ERROR] :message state  : 5
[    6.614017] [ARISC ERROR] :message attr   : 2
[    6.614035] [ARISC ERROR] :message type   : 30
[    6.614053] [ARISC ERROR] :message result : ff
[    6.614070] [ARISC WARING] :callback not install
[    6.614092] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.752451] systemd-udevd[178]: starting version 215
[    7.598790] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.685183] [ARISC ERROR] :message process error
[    7.685215] [ARISC ERROR] :message addr   : f004b840
[    7.685235] [ARISC ERROR] :message state  : 5
[    7.685253] [ARISC ERROR] :message attr   : 2
[    7.685271] [ARISC ERROR] :message type   : 30
[    7.685288] [ARISC ERROR] :message result : ff
[    7.685305] [ARISC WARING] :callback not install
[    7.685327] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    7.813358] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[    8.735209] [ARISC ERROR] :message process error
[    8.735239] [ARISC ERROR] :message addr   : f004b840
[    8.735259] [ARISC ERROR] :message state  : 5
[    8.735277] [ARISC ERROR] :message attr   : 2
[    8.735295] [ARISC ERROR] :message type   : 30
[    8.735313] [ARISC ERROR] :message result : ff
[    8.735330] [ARISC WARING] :callback not install
[    8.735352] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.836243] systemd-journald[177]: Received request to flush runtime journal from PID 1
[    9.138243] gmac0: probed
[    9.138581] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[    9.425220] [ARISC ERROR] :message process error
[    9.425242] [ARISC ERROR] :message addr   : f004b840
[    9.425257] [ARISC ERROR] :message state  : 5
[    9.425270] [ARISC ERROR] :message attr   : 2
[    9.425284] [ARISC ERROR] :message type   : 30
[    9.425297] [ARISC ERROR] :message result : ff
[    9.425309] [ARISC WARING] :callback not install
[    9.425326] [cpu_freq] ERR:set cpu frequency to 648MHz failed!
[    9.575142] [ARISC ERROR] :message process error
[    9.575167] [ARISC ERROR] :message addr   : f004b840
[    9.575187] [ARISC ERROR] :message state  : 5
[    9.575204] [ARISC ERROR] :message attr   : 2
[    9.575222] [ARISC ERROR] :message type   : 30
[    9.575240] [ARISC ERROR] :message result : ff
[    9.575257] [ARISC WARING] :callback not install
[    9.575277] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   12.544073] [ARISC ERROR] :message process error
[   12.544104] [ARISC ERROR] :message addr   : f004b840
[   12.544124] [ARISC ERROR] :message state  : 5
[   12.544142] [ARISC ERROR] :message attr   : 2
[   12.544160] [ARISC ERROR] :message type   : 30
[   12.544178] [ARISC ERROR] :message result : ff
[   12.544195] [ARISC WARING] :callback not install
[   12.544218] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   19.190059] eth0: no IPv6 routers present
### lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 005 Device 002: ID 0000:0538
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
### lscpu:
CPU(s):                4
Socket(s):             1
CPU max MHz:           1200.0000
### cpuinfo:
processor	: 0
BogoMIPS	: 1.34
processor	: 1
BogoMIPS	: 1.34
processor	: 2
BogoMIPS	: 1.34
processor	: 3
BogoMIPS	: 1.34
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
### meminfo:
MemTotal:         506028 kB
MemFree:          417400 kB
Buffers:            7096 kB
Cached:            32192 kB
SwapCached:            0 kB
Active:            26904 kB
Inactive:          30332 kB
Active(anon):      18068 kB
Inactive(anon):     4404 kB
Active(file):       8836 kB
Inactive(file):    25928 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          417400 kB
SwapTotal:        131068 kB
SwapFree:         131068 kB
Dirty:               232 kB
Writeback:             0 kB
AnonPages:         17928 kB
Mapped:             7680 kB
Shmem:              4620 kB
Slab:              12736 kB
SReclaimable:       4668 kB
SUnreclaim:         8068 kB
KernelStack:         752 kB
PageTables:          444 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      384080 kB
Committed_AS:      57564 kB
VmallocUsed:       16636 kB
VmallocChunk:     252088 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
 29:       1922       1089       2069       1119       GIC  arch_timer
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 77:          1          0          0          0       GIC  PL
 92:       4347          0          0          0       GIC  sunxi-mmc
105:         25          0          0          0       GIC  ohci_hcd:usb5
107:         36          0          0          0       GIC  ohci_hcd:usb6
108:          0          0          0          0       GIC  ehci_hcd:usb3
109:          0          0          0          0       GIC  ohci_hcd:usb7
110:          0          0          0          0       GIC  ehci_hcd:usb4
111:          0          0          0          0       GIC  ohci_hcd:usb8
118:       4328          0          0          0       GIC  dispaly
IPI2:       1849       2487       1712       1517  Rescheduling interrupts
IPI3:        109        167         78        155  Function call interrupts
IPI4:          2          3          0          0  Single function call interrupts
Err:          0
### ifconfig:
          Interrupt:114
### df:
/dev/mmcblk0p1  7.4G  2.1G  5.2G  29% /
tmpfs           248M   40K  248M   1% /tmp
### mmc0:0007 info:
                date: 11/2014
                type: SD
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
          erase_size: 512
Sat Apr 30 23:29:37 CEST 2016 sun8i armv7l   Orange Pi One
Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
### dmesg:
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 160 MiB at 56000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c0a3d9c0, node_mem_map c0b7f000
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 129920 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1011000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 338820k/338820k available, 185468k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0973058   (9645 kB)
[    0.000000]       .init : 0xc0974000 - 0xc09c6ec0   ( 332 kB)
[    0.000000]       .data : 0xc09c8000 - 0xc0a42810   ( 491 kB)
[    0.000000]        .bss : 0xc0a42fc4 - 0xc0b7e2d0   (1261 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000535] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000594] pid_max: default: 32768 minimum: 301
[    0.001374] Mount-cache hash table entries: 512
[    0.003574] Initializing cgroup subsys cpuacct
[    0.003609] Initializing cgroup subsys memory
[    0.003715] Initializing cgroup subsys devices
[    0.003744] Initializing cgroup subsys freezer
[    0.003771] Initializing cgroup subsys blkio
[    0.003825] Initializing cgroup subsys perf_event
[    0.004011] CPU: Testing write buffer coherency: ok
[    0.004111] ftrace: allocating 25999 entries in 77 pages
[    0.070502] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.070539] [sunxi_smp_prepare_cpus] enter
[    0.070609] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.072617] CPU1: Booted secondary processor
[    0.072617] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.072775] CPU2: Booted secondary processor
[    0.072775] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.080972] CPU3: Booted secondary processor
[    0.080972] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.081117] Brought up 4 CPUs
[    0.081117] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.090042] devtmpfs: initialized
[    0.099289] wakeup src cnt is : 2.
[    0.099318] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099347] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.099377] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099408] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099436] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.099465] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099494] sunxi pm init
[    0.099805] pinctrl core: initialized pinctrl subsystem
[    0.114157] NET: Registered protocol family 16
[    0.115749] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.115749] script_sysfs_init success
[    0.115749] sunxi_dump_init success
[    0.121844] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.124653] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.126458] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.126493] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.126938] script config pll_video to 297 Mhz
[    0.126976] script config pll_de to 864 Mhz
[    0.127045] script config pll_ve to 402 Mhz
[    0.127084] sunxi_default_clk_init
[    0.127103] try to set pll6ahb1 to 200000000
[    0.127151] try to set ahb clk source to pll6ahb1
[    0.127173] set ahb clk source to pll6ahb1
[    0.127196] try to set ahb1 to 200000000
[    0.127224] try to set apb1 to 100000000
[    0.141648] bio: create slab <bio-0> at 0
[    0.142432] [ARISC] :sunxi-arisc driver v1.04
[    0.160683] [ARISC] :arisc version: [v0.1.58]
[    0.247597] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.251359] SCSI subsystem initialized
[    0.251844] usbcore: registered new interface driver usbfs
[    0.252016] usbcore: registered new interface driver hub
[    0.252248] usbcore: registered new device driver usb
[    0.253932] Linux video capture interface: v2.00
[    0.254448] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.256542] Switching to clocksource arch_sys_counter
[    0.281952] FS-Cache: Loaded
[    0.282493] CacheFiles: Loaded
[    0.309934] NET: Registered protocol family 2
[    0.337477] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.338761] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.339365] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.340001] TCP: Hash tables configured (established 16384 bind 16384)
[    0.340099] TCP: reno registered
[    0.340133] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.340199] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.340976] NET: Registered protocol family 1
[    0.341753] RPC: Registered named UNIX socket transport module.
[    0.341783] RPC: Registered udp transport module.
[    0.341805] RPC: Registered tcp transport module.
[    0.341828] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.342223] Trying to unpack rootfs image as initramfs...
[    0.766537] Freeing initrd memory: 3040K
[    0.767320] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.767613] sunxi_reg_init enter
[    0.769564] audit: initializing netlink socket (disabled)
[    0.769715] type=2000 audit(0.760:1): initialized
[    0.773869] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.774254] misc fatfs initialized
[    0.775942] NFS: Registering the id_resolver key type
[    0.776742] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.776775] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.778446] NTFS driver 2.1.30 [Flags: R/W].
[    0.779156] fuse init (API version 7.18)
[    0.781078] Btrfs loaded
[    0.781130] msgmni has been set to 987
[    0.783785] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.783831] io scheduler noop registered
[    0.783854] io scheduler deadline registered
[    0.784018] io scheduler cfq registered (default)
[    0.784925] [DISP]disp_module_init
[    0.785590] cmdline,init_disp=
[    0.785654] cmdline,disp=
[    0.803004] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.845695] Console: switching to colour frame buffer device 160x45
[    0.890743] [DISP]disp_module_init finish
[    0.891207] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.891822] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.891854] sw_uart_pm()890 - uart0 clk is already enable
[    0.893094] sunxi_cmatest_init enter
[    0.893189] sunxi_cmatest_init success
[    0.903324] brd: module loaded
[    0.912969] loop: module loaded
[    0.913571] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.913608] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.914753] spi spi0: master is unqueued, this is deprecated
[    0.915492] tun: Universal TUN/TAP device driver, 1.6
[    0.915519] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.917588] PPP generic driver version 2.4.2
[    0.918011] PPP BSD Compression module registered
[    0.918051] PPP Deflate Compression module registered
[    0.923428] PPP MPPE Compression module registered
[    0.923469] NET: Registered protocol family 24
[    0.923601] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.943794] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.943879] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.945319] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.960080] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.961521] hub 1-0:1.0: USB hub found
[    0.961583] hub 1-0:1.0: 1 port detected
[    0.982444] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.982515] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.983672] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.000113] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.000148] ehci_irq: highspeed device connect
[    1.001424] hub 2-0:1.0: USB hub found
[    1.001471] hub 2-0:1.0: 1 port detected
[    1.022342] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022415] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.023623] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.039860] ehci_irq: highspeed device connect
[    1.040071] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.041324] hub 3-0:1.0: USB hub found
[    1.041368] hub 3-0:1.0: 1 port detected
[    1.062244] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.062314] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.063405] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.080070] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.081332] hub 4-0:1.0: USB hub found
[    1.081377] hub 4-0:1.0: 1 port detected
[    1.082266] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.102399] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.102469] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.102546] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.160234] ehci_irq: highspeed device disconnect
[    1.160282] ohci_irq: fullspeed or lowspeed device connect
[    1.165336] hub 5-0:1.0: USB hub found
[    1.165384] hub 5-0:1.0: 1 port detected
[    1.186272] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.186342] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.186432] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.245357] hub 6-0:1.0: USB hub found
[    1.245406] hub 6-0:1.0: 1 port detected
[    1.266320] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.266392] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.266466] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.325376] hub 7-0:1.0: USB hub found
[    1.325424] hub 7-0:1.0: 1 port detected
[    1.340101] usb 2-1: new high-speed USB device number 2 using sunxi-ehci
[    1.346358] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.346430] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.346519] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    1.405212] hub 8-0:1.0: USB hub found
[    1.405259] hub 8-0:1.0: 1 port detected
[    1.406100] Initializing USB Mass Storage driver...
[    1.406615] usbcore: registered new interface driver usb-storage
[    1.406646] USB Mass Storage support registered.
[    1.406779] usbcore: registered new interface driver ums-alauda
[    1.406900] usbcore: registered new interface driver ums-cypress
[    1.407024] usbcore: registered new interface driver ums-datafab
[    1.407143] usbcore: registered new interface driver ums_eneub6250
[    1.407263] usbcore: registered new interface driver ums-freecom
[    1.407384] usbcore: registered new interface driver ums-isd200
[    1.407497] usbcore: registered new interface driver ums-jumpshot
[    1.407612] usbcore: registered new interface driver ums-karma
[    1.407730] usbcore: registered new interface driver ums-onetouch
[    1.407891] usbcore: registered new interface driver ums-realtek
[    1.408030] usbcore: registered new interface driver ums-sddr09
[    1.408151] usbcore: registered new interface driver ums-sddr55
[    1.408271] usbcore: registered new interface driver ums-usbat
[    1.412946] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.412981] android_usb gadget: Number of LUNs=3
[    1.413010]  lun0: LUN: removable file: (no medium)
[    1.413037]  lun1: LUN: removable file: (no medium)
[    1.413064]  lun2: LUN: removable file: (no medium)
[    1.413872] android_usb gadget: android_usb ready
[    1.414396]  uinput result 0 , vmouse_init
[    1.415850] mousedev: PS/2 mouse device common for all mice
[    1.417475] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    1.417504] =========script_get_err============
[    1.417526] ltr_init: ls_fetch_sysconfig_para err.
[    1.418258] [RTC] WARNING: Rtc time will be wrong!!
[    1.418285] [RTC] WARNING: use *internal OSC* as clock source
[    1.418917] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.419043] i2c /dev entries driver
[    1.419967] IR RC5(x) protocol handler initialized
[    1.420389] sunxi cedar version 0.1
[    1.420493] [cedar]: install start!!!
[    1.420961] [cedar]: install end!!!
[    1.421364] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.421596] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.421820] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.422040] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.422260] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.422481] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.422699] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.422935] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.423169] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.423429] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.423682] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.423935] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.424187] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.424443] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.424695] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.424947] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.425201] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.425456] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.425495] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.425895] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.426249] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.426282] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.426310] timeout_to_interv, line 167
[    1.426331] interv_to_timeout, line 189
[    1.426357] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.427351] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.427567] calibrat: max_cpufreq 1200Mhz Type 0!
[    1.427598] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    1.433184] [ARISC ERROR] :message process error
[    1.433208] [ARISC ERROR] :message addr   : f004b840
[    1.433228] [ARISC ERROR] :message state  : 5
[    1.433246] [ARISC ERROR] :message attr   : 2
[    1.433264] [ARISC ERROR] :message type   : 30
[    1.433281] [ARISC ERROR] :message result : ff
[    1.433298] [ARISC WARING] :callback not install
[    1.433321] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    1.433861] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    1.433926] [mmc]: get mmc0's sdc_power is null!
[    1.433983] [mmc]: get mmc1's sdc_power is null!
[    1.434004] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.434025] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.434059] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    1.435904] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.437131] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438328] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438705] [mmc]: sdc0 power_supply is null
[    1.441483] no blue_led, ignore it!
[    1.441899] Registered led device: red_led
[    1.442124] Registered led device: green_led
[    1.442159] no led_0, ignore it!
[    1.442177] no led_1, ignore it!
[    1.442193] no led_2, ignore it!
[    1.442209] no led_3, ignore it!
[    1.442225] no led_4, ignore it!
[    1.442241] no led_5, ignore it!
[    1.442257] no led_6, ignore it!
[    1.442273] no led_7, ignore it!
[    1.443839] usbcore: registered new interface driver usbhid
[    1.443864] usbhid: USB HID core driver
[    1.451879] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.453753] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.454142] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.454178] [DAUDIO0] driver not init,just return.
[    1.460084] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.461402] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.463588] oprofile: using arm/armv7-ca7
[    1.463896] u32 classifier
[    1.463914]     Actions configured
[    1.464292] IPv4 over IPv4 tunneling driver
[    1.465557] TCP: bic registered
[    1.465582] TCP: cubic registered
[    1.465599] TCP: westwood registered
[    1.465617] TCP: highspeed registered
[    1.465634] TCP: hybla registered
[    1.465651] TCP: htcp registered
[    1.465667] TCP: vegas registered
[    1.465684] TCP: veno registered
[    1.465701] TCP: scalable registered
[    1.465718] TCP: lp registered
[    1.465734] TCP: yeah registered
[    1.465751] TCP: illinois registered
[    1.465767] Initializing XFRM netlink socket
[    1.466231] NET: Registered protocol family 10
[    1.468528] NET: Registered protocol family 17
[    1.468594] NET: Registered protocol family 15
[    1.468682] Registering the dns_resolver key type
[    1.469333] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.469380] ThumbEE CPU extension supported.
[    1.469419] Registering SWP/SWPB emulation handler
[    1.470550] registered taskstats version 1
[    1.471047] cmdline,disp=
[    1.471351] [HDMI] power vcc-hdmi-18
[    1.481697] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.484212] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489547] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489669] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.492168] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.502121] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.503530] CPU Budget:Register notifier
[    1.503544] CPU Budget:register Success
[    1.503558] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.506773] [rf_pm]: module power0 name vcc-wifi-33
[    1.506789] [rf_pm]: Did not config module_power1 in sys_config
[    1.506800] [rf_pm]: Did not config module_power2 in sys_config
[    1.506811] [rf_pm]: Did not config module_power3 in sys_config
[    1.506822] [rf_pm]: mod has no chip_en gpio
[    1.506831] [rf_pm]: failed to fetch lpo_use_apclk
[    1.506839] [rf_pm]: regulator on.
[    1.506850] [wifi_pm]: no wifi used in configuration
[    1.506861] [rfkill]: init no bt used in configuration
[    1.506870] ALSA device list:
[    1.506878]   #0: audiocodec
[    1.506885]   #1: sndhdmi
[    1.507487] Freeing init memory: 328K
[    1.511668] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.515779] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515908] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.516061] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.516158] mmc0: new high speed SDHC card at address 0007
[    1.516719] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    1.518318]  mmcblk0: p1
[    1.518973] mmcblk mmc0:0007: Card claimed for testing.
[    1.518995] mmc0:0007: SD08G 7.42 GiB
[    1.519042] *******************sd init ok*******************
[    1.547136] systemd-udevd[97]: starting version 215
[    1.670092] usb 5-1: new low-speed USB device number 2 using sunxi-ohci
[    1.897819] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    1.945000] [ARISC ERROR] :message process error
[    1.945030] [ARISC ERROR] :message addr   : f004b840
[    1.945050] [ARISC ERROR] :message state  : 5
[    1.945068] [ARISC ERROR] :message attr   : 2
[    1.945086] [ARISC ERROR] :message type   : 30
[    1.945103] [ARISC ERROR] :message result : ff
[    1.945120] [ARISC WARING] :callback not install
[    1.945143] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.110091] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    3.065089] [ARISC ERROR] :message process error
[    3.065120] [ARISC ERROR] :message addr   : f004b840
[    3.065139] [ARISC ERROR] :message state  : 5
[    3.065157] [ARISC ERROR] :message attr   : 2
[    3.065175] [ARISC ERROR] :message type   : 30
[    3.065193] [ARISC ERROR] :message result : ff
[    3.065209] [ARISC WARING] :callback not install
[    3.065232] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    4.122206] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.566798] [ARISC ERROR] :message process error
[    4.566830] [ARISC ERROR] :message addr   : f004b840
[    4.566850] [ARISC ERROR] :message state  : 5
[    4.566868] [ARISC ERROR] :message attr   : 2
[    4.566885] [ARISC ERROR] :message type   : 30
[    4.566903] [ARISC ERROR] :message result : ff
[    4.566920] [ARISC WARING] :callback not install
[    4.566943] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    5.295163] [ARISC ERROR] :message process error
[    5.295194] [ARISC ERROR] :message addr   : f004b840
[    5.295214] [ARISC ERROR] :message state  : 5
[    5.295232] [ARISC ERROR] :message attr   : 2
[    5.295250] [ARISC ERROR] :message type   : 30
[    5.295268] [ARISC ERROR] :message result : ff
[    5.295284] [ARISC WARING] :callback not install
[    5.295306] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    5.330557] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.331112] systemd[1]: Detected architecture 'arm'.
[    5.345826] systemd[1]: Set hostname to <orangepione>.
[    5.700413] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    5.702753] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    5.703077] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.703144] systemd[1]: Expecting device dev-ttySAC2.device...
[    5.703687] systemd[1]: Starting Remote File Systems (Pre).
[    5.704025] systemd[1]: Reached target Remote File Systems (Pre).
[    5.704113] systemd[1]: Starting Encrypted Volumes.
[    5.704413] systemd[1]: Reached target Encrypted Volumes.
[    5.704490] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    5.704664] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.704715] systemd[1]: Starting Paths.
[    5.704986] systemd[1]: Reached target Paths.
[    5.705090] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    5.705880] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.705959] systemd[1]: Starting Root Slice.
[    5.706325] systemd[1]: Created slice Root Slice.
[    5.706379] systemd[1]: Starting User and Session Slice.
[    5.706801] systemd[1]: Created slice User and Session Slice.
[    5.706854] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    5.707336] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.707390] systemd[1]: Starting Delayed Shutdown Socket.
[    5.707784] systemd[1]: Listening on Delayed Shutdown Socket.
[    5.707839] systemd[1]: Starting Journal Socket (/dev/log).
[    5.708243] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.708317] systemd[1]: Starting udev Control Socket.
[    5.708662] systemd[1]: Listening on udev Control Socket.
[    5.708729] systemd[1]: Starting udev Kernel Socket.
[    5.709055] systemd[1]: Listening on udev Kernel Socket.
[    5.709129] systemd[1]: Starting Journal Socket.
[    5.709499] systemd[1]: Listening on Journal Socket.
[    5.709609] systemd[1]: Starting System Slice.
[    5.710073] systemd[1]: Created slice System Slice.
[    5.710191] systemd[1]: Started File System Check on Root Device.
[    5.710239] systemd[1]: Starting system-getty.slice.
[    5.710750] systemd[1]: Created slice system-getty.slice.
[    5.710804] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.711295] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.711414] systemd[1]: Starting Increase datagram queue length...
[    5.780645] systemd[1]: Starting Restore / save the current clock...
[    5.830725] systemd[1]: Starting udev Coldplug all Devices...
[    5.890839] systemd[1]: Mounting POSIX Message Queue File System...
[    5.967512] systemd[1]: Starting Load Kernel Modules...
[    6.061074] systemd[1]: Mounting Debug File System...
[    6.163175] RTL871X: module init start
[    6.163190] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[    6.163262] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.164803] [mmc]: sdc1 power_supply is null
[    6.180064] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.203205] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.205700] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.210552] systemd[1]: Mounted Huge Pages File System.
[    6.211009] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.214489] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.215515] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.215659] [mmc]: sdc1 power_supply is null
[    6.218293] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.219832] [mmc]: sdc1 power_supply is null
[    6.240032] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.253549] systemd[1]: Started Set Up Additional Binary Formats.
[    6.253664] systemd[1]: Starting LSB: Set keymap...
[    6.263248] [wifi_pm]: set wl_reg_on 1 !
[    6.263389] RTL871X: module init ret=0
[    6.263774] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.266442] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.277302] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.278519] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.278644] [mmc]: sdc1 power_supply is null
[    6.281092] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.282619] [mmc]: sdc1 power_supply is null
[    6.290481] systemd[1]: Starting Slices.
[    6.290940] systemd[1]: Reached target Slices.
[    6.293263] systemd[1]: Mounted Debug File System.
[    6.293839] systemd[1]: Mounted POSIX Message Queue File System.
[    6.300070] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.324794] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.327677] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.343360] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.345136] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.345260] [mmc]: sdc1 power_supply is null
[    6.347846] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.349376] [mmc]: sdc1 power_supply is null
[    6.350521] systemd[1]: Started Increase datagram queue length.
[    6.370045] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.395851] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.398995] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.419528] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.421871] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.421992] [mmc]: sdc1 power_supply is null
[    6.454460] systemd[1]: Started Restore / save the current clock.
[    6.526611] [ARISC ERROR] :message process error
[    6.526642] [ARISC ERROR] :message addr   : f004b840
[    6.526662] [ARISC ERROR] :message state  : 5
[    6.526680] [ARISC ERROR] :message attr   : 2
[    6.526697] [ARISC ERROR] :message type   : 30
[    6.526715] [ARISC ERROR] :message result : ff
[    6.526732] [ARISC WARING] :callback not install
[    6.526754] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.585411] systemd[1]: Started Load Kernel Modules.
[    6.655461] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    6.705167] systemd[1]: Started LSB: Set keymap.
[    6.755064] systemd[1]: Started udev Coldplug all Devices.
[    6.757097] systemd[1]: Time has been changed
[    6.757652] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.840995] systemd[1]: Mounted Configuration File System.
[    6.841151] systemd[1]: Starting Apply Kernel Variables...
[    6.846919] [ARISC ERROR] :message process error
[    6.846942] [ARISC ERROR] :message addr   : f004b840
[    6.846958] [ARISC ERROR] :message state  : 5
[    6.846972] [ARISC ERROR] :message attr   : 2
[    6.846987] [ARISC ERROR] :message type   : 30
[    6.847001] [ARISC ERROR] :message result : ff
[    6.847015] [ARISC WARING] :callback not install
[    6.847034] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.941313] systemd[1]: Mounting FUSE Control File System...
[    7.020752] systemd[1]: Starting Syslog Socket.
[    7.031563] systemd[1]: Listening on Syslog Socket.
[    7.031843] systemd[1]: Starting Journal Service...
[    7.121419] systemd[1]: Started Journal Service.
[    7.455580] systemd-udevd[173]: starting version 215
[    7.465221] [ARISC ERROR] :message process error
[    7.465244] [ARISC ERROR] :message addr   : f004b840
[    7.465260] [ARISC ERROR] :message state  : 5
[    7.465274] [ARISC ERROR] :message attr   : 2
[    7.465289] [ARISC ERROR] :message type   : 30
[    7.465303] [ARISC ERROR] :message result : ff
[    7.465317] [ARISC WARING] :callback not install
[    7.465337] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    7.988342] RTL871X: module init start
[    7.988364] RTL871X: rtl8188eu v4.3.0.6_12167.20140828
[    7.988376] RTL871X: build time: Apr 30 2016 19:47:19
[    7.988392] sw_usb_enable_hcd: usbc_num = 5
[    7.988400] [rf_pm]: regulator on.
[    7.998423] WRN:L148(drivers/usb/sunxi_usb/manager/usb_hcd_servers.c):ERR: unkown usbc_no(5)
[    8.003346] bFWReady == _FALSE call reset 8051...
[    8.042531] RTL871X: MAC Address from Efuse is 80:3f:5d:13:d1:e7
[    8.058406] RTL871X: rtw_ndev_init(wlan0)
[    8.059603] RTL871X: rtw_ndev_init(wlan1)
[    8.060970] usbcore: registered new interface driver rtl8188eu
[    8.060983] RTL871X: module init ret=0
[    8.339100] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.385180] [ARISC ERROR] :message process error
[    8.385210] [ARISC ERROR] :message addr   : f004b840
[    8.385229] [ARISC ERROR] :message state  : 5
[    8.385247] [ARISC ERROR] :message attr   : 2
[    8.385265] [ARISC ERROR] :message type   : 30
[    8.385283] [ARISC ERROR] :message result : ff
[    8.385300] [ARISC WARING] :callback not install
[    8.385322] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.601607] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[    8.825277] [ARISC ERROR] :message process error
[    8.825299] [ARISC ERROR] :message addr   : f004b840
[    8.825315] [ARISC ERROR] :message state  : 5
[    8.825330] [ARISC ERROR] :message attr   : 2
[    8.825344] [ARISC ERROR] :message type   : 30
[    8.825359] [ARISC ERROR] :message result : ff
[    8.825372] [ARISC WARING] :callback not install
[    8.825391] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.823942] [ARISC ERROR] :message process error
[    9.823973] [ARISC ERROR] :message addr   : f004b840
[    9.823993] [ARISC ERROR] :message state  : 5
[    9.824012] [ARISC ERROR] :message attr   : 2
[    9.824029] [ARISC ERROR] :message type   : 30
[    9.824047] [ARISC ERROR] :message result : ff
[    9.824064] [ARISC WARING] :callback not install
[    9.824086] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   10.069293] systemd-journald[172]: Received request to flush runtime journal from PID 1
[   10.424052] gmac0: probed
[   10.424394] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   10.835020] [ARISC ERROR] :message process error
[   10.835048] [ARISC ERROR] :message addr   : f004b840
[   10.835068] [ARISC ERROR] :message state  : 5
[   10.835086] [ARISC ERROR] :message attr   : 2
[   10.835104] [ARISC ERROR] :message type   : 30
[   10.835121] [ARISC ERROR] :message result : ff
[   10.835138] [ARISC WARING] :callback not install
[   10.835161] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   13.925315] [ARISC ERROR] :message process error
[   13.925346] [ARISC ERROR] :message addr   : f004b840
[   13.925365] [ARISC ERROR] :message state  : 5
[   13.925384] [ARISC ERROR] :message attr   : 2
[   13.925402] [ARISC ERROR] :message type   : 30
[   13.925420] [ARISC ERROR] :message result : ff
[   13.925437] [ARISC WARING] :callback not install
[   13.925458] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.530059] eth0: no IPv6 routers present
[   71.865272] [ARISC ERROR] :message process error
[   71.865291] [ARISC ERROR] :message addr   : f004b840
[   71.865304] [ARISC ERROR] :message state  : 5
[   71.865318] [ARISC ERROR] :message attr   : 2
[   71.865328] [ARISC ERROR] :message type   : 30
[   71.865338] [ARISC ERROR] :message result : ff
[   71.865348] [ARISC WARING] :callback not install
[   71.865362] [cpu_freq] ERR:set cpu frequency to 720MHz failed!
### lsusb:
Bus 002 Device 002: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
### lscpu:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
CPU min MHz:           480.0000
### cpuinfo:
Processor	: ARMv7 Processor rev 5 (v7l)
processor	: 0
BogoMIPS	: 1.34
processor	: 1
BogoMIPS	: 1.34
processor	: 2
BogoMIPS	: 1.34
processor	: 3
BogoMIPS	: 1.34
Features	: swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
Serial		: 4435502f024e3c000000
### meminfo:
MemTotal:         506028 kB
MemFree:          409632 kB
Buffers:            7112 kB
Cached:            36520 kB
SwapCached:            0 kB
Active:            26736 kB
Inactive:          34564 kB
Active(anon):      17952 kB
Inactive(anon):     4428 kB
Active(file):       8784 kB
Inactive(file):    30136 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          409632 kB
SwapFree:         131068 kB
Dirty:               112 kB
Writeback:             0 kB
AnonPages:         17848 kB
Mapped:             8540 kB
Shmem:              4616 kB
Slab:              12748 kB
SReclaimable:       4576 kB
SUnreclaim:         8172 kB
KernelStack:         784 kB
PageTables:          540 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:      58508 kB
VmallocTotal:     499712 kB
VmallocUsed:       17624 kB
VmallocChunk:     249668 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
  3:          1          0          0          0  sunxi_gpio_irq_chip  gk_EINT
 29:       1574       1099       2024       2005       GIC  arch_timer
 30:          0          0          0          0       GIC  arch_timer
 38:         18          0          0          0       GIC  twi0
 39:         18          0          0          0       GIC  twi1
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 50:          0          0          0          0       GIC  sunxi_timer0
 63:          0          0          0          0       GIC  Thermal
 72:          0          0          0          0       GIC  sunxi-rtc alarm
 77:          1          0          0          0       GIC  PL
 81:          0          0          0          0       GIC  arisc_hwmsgbox_irq
 82:          0          0          0          0       GIC  sunxi_dmac
 90:          0          0          0          0       GIC  cedar_dev
 92:      15353          0          0          0       GIC  sunxi-mmc
 93:         52          0          0          0       GIC  sunxi-mmc
 97:          0          0          0          0       GIC  spi0
104:          2          0          0          0       GIC  ehci_hcd:usb1
105:         24          0          0          0       GIC  ohci_hcd:usb5
106:        265          0          0          0       GIC  ehci_hcd:usb2
107:          0          0          0          0       GIC  ohci_hcd:usb6
114:          4          0          0          0       GIC  gmac0
118:       4301          0          0          0       GIC  dispaly
129:          0          0          0          0       GIC  mali_gp_irq_handlers
130:          0          0          0          0       GIC  mali_mmu_irq_handlers
131:          0          0          0          0       GIC  mali_pp_irq_handlers
132:          0          0          0          0       GIC  mali_mmu_irq_handlers
134:          0          0          0          0       GIC  mali_pp_irq_handlers
135:          0          0          0          0       GIC  mali_mmu_irq_handlers
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       1857       2605       2375       1278  Rescheduling interrupts
IPI3:         27        187        183        168  Function call interrupts
IPI4:         19         22          6          1  Single function call interrupts
IPI5:          0          0          0          0  CPU stop interrupts
IPI6:          0          0          0          0  CPU backtrace
IPI7:          0          0          0          0  completion interrupts
Err:          0
### ifconfig:
eth0      Link encap:Ethernet  HWaddr de:99:0c:13:2d:eb
          inet6 addr: fe80::dc99:cff:fe13:2deb/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:580 (580.0
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0   TX bytes:0 (0.0
### df:
Filesystem      Size  Used Avail Use% Mounted on
udev             10M     0   10M   0% /dev
tmpfs            99M  4.5M   95M   5% /run
tmpfs           248M     0  248M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           248M     0  248M   0% /sys/fs/cgroup
tmpfs           248M   44K  248M   1% /tmp
### mmc0:0007 info:
                 cid: 275048534430384730dae82e3d00ebb1
                 csd: 400e00325b5900003b5f7f800a400075
                 scr: 0235800001000000
                date: 11/2014
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD08G MODALIAS=mmc:block
          erase_size: 512
Sat Apr 30 23:29:38 CEST 2016 sun8i armv7l   Orange Pi One
### dmesg:
[    0.002418] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.002586] pid_max: default: 32768 minimum: 301
[    0.003418] Mount-cache hash table entries: 512
[    0.005670] Initializing cgroup subsys cpuacct
[    0.005760] Initializing cgroup subsys memory
[    0.005910] Initializing cgroup subsys devices
[    0.005986] Initializing cgroup subsys freezer
[    0.006059] Initializing cgroup subsys blkio
[    0.006157] Initializing cgroup subsys perf_event
[    0.006393] CPU: Testing write buffer coherency: ok
[    0.006551] ftrace: allocating 25999 entries in 77 pages
[    0.080499] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.080587] [sunxi_smp_prepare_cpus] enter
[    0.080685] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.082756] CPU1: Booted secondary processor
[    0.082756] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.082915] CPU2: Booted secondary processor
[    0.082915] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.090969] CPU3: Booted secondary processor
[    0.090969] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.091114] Brought up 4 CPUs
[    0.091114] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.100025] devtmpfs: initialized
[    0.109296] wakeup src cnt is : 2.
[    0.109358] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.109388] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.109418] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.109448] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.109477] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.109506] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.109535] sunxi pm init
[    0.110249] pinctrl core: initialized pinctrl subsystem
[    0.124623] NET: Registered protocol family 16
[    0.130169] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.130327] script_sysfs_init success
[    0.130434] sunxi_dump_init success
[    0.132436] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.135285] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.137175] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.137273] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.137758] script config pll_video to 297 Mhz
[    0.137829] script config pll_de to 864 Mhz
[    0.137926] script config pll_ve to 402 Mhz
[    0.137993] sunxi_default_clk_init
[    0.138013] try to set pll6ahb1 to 200000000
[    0.138062] try to set ahb clk source to pll6ahb1
[    0.138084] set ahb clk source to pll6ahb1
[    0.138107] try to set ahb1 to 200000000
[    0.138135] try to set apb1 to 100000000
[    0.152574] bio: create slab <bio-0> at 0
[    0.153403] [ARISC] :sunxi-arisc driver v1.04
[    0.171684] [ARISC] :arisc version: [v0.1.58]
[    0.258644] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.262317] SCSI subsystem initialized
[    0.262317] usbcore: registered new interface driver usbfs
[    0.262317] usbcore: registered new interface driver hub
[    0.262360] usbcore: registered new device driver usb
[    0.262667] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.262739] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.262805] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.264214] Linux video capture interface: v2.00
[    0.264772] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.266509] cfg80211: Calling CRDA to update world regulatory domain
[    0.270189] Switching to clocksource arch_sys_counter
[    0.301941] FS-Cache: Loaded
[    0.302518] CacheFiles: Loaded
[    0.330165] NET: Registered protocol family 2
[    0.357676] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.359014] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.359675] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.360420] TCP: Hash tables configured (established 16384 bind 16384)
[    0.360491] TCP: reno registered
[    0.360549] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.360651] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.361469] NET: Registered protocol family 1
[    0.362272] RPC: Registered named UNIX socket transport module.
[    0.362346] RPC: Registered udp transport module.
[    0.362399] RPC: Registered tcp transport module.
[    0.362452] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.362895] Trying to unpack rootfs image as initramfs...
[    0.787288] Freeing initrd memory: 3040K
[    0.788116] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.788466] sunxi_reg_init enter
[    0.790523] audit: initializing netlink socket (disabled)
[    0.790719] type=2000 audit(0.790:1): initialized
[    0.794867] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.795312] misc fatfs initialized
[    0.796999] NFS: Registering the id_resolver key type
[    0.797835] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.797918] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.799629] NTFS driver 2.1.30 [Flags: R/W].
[    0.800456] fuse init (API version 7.18)
[    0.802347] Btrfs loaded
[    0.802426] msgmni has been set to 987
[    0.805102] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.805203] io scheduler noop registered
[    0.805255] io scheduler deadline registered
[    0.805451] io scheduler cfq registered (default)
[    0.806407] [DISP]disp_module_init
[    0.807100] cmdline,init_disp=
[    0.807201] cmdline,disp=
[    0.824600] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.867305] Console: switching to colour frame buffer device 160x45
[    0.912811] [DISP]disp_module_init finish
[    0.913569] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.914636] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.915098] sw_uart_pm()890 - uart0 clk is already enable
[    0.916726] sunxi_cmatest_init enter
[    0.916817] sunxi_cmatest_init success
[    0.926946] brd: module loaded
[    0.936810] loop: module loaded
[    0.937653] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.938144] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.939756] spi spi0: master is unqueued, this is deprecated
[    0.940983] tun: Universal TUN/TAP device driver, 1.6
[    0.941381] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.943903] PPP generic driver version 2.4.2
[    0.944641] PPP BSD Compression module registered
[    0.945018] PPP Deflate Compression module registered
[    0.963158] PPP MPPE Compression module registered
[    0.975911] NET: Registered protocol family 24
[    0.988663] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.021794] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.035331] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.050293] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.080076] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.094726] hub 1-0:1.0: USB hub found
[    1.107775] hub 1-0:1.0: 1 port detected
[    1.141338] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.154617] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    1.169030] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.200091] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.213074] ehci_irq: highspeed device connect
[    1.214321] hub 2-0:1.0: USB hub found
[    1.227332] hub 2-0:1.0: 1 port detected
[    1.260866] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.273885] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.287929] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.320090] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.334313] hub 3-0:1.0: USB hub found
[    1.347179] hub 3-0:1.0: 1 port detected
[    1.380676] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.393621] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.407758] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.440101] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.454424] hub 4-0:1.0: USB hub found
[    1.467371] hub 4-0:1.0: 1 port detected
[    1.481178] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.514611] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.528120] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.541540] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.560107] usb 2-1: new high-speed USB device number 2 using sunxi-ehci
[    1.575793] ehci_irq: highspeed device connect
[    1.615358] hub 5-0:1.0: USB hub found
[    1.628546] hub 5-0:1.0: 1 port detected
[    1.662364] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.675710] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.689190] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.765377] hub 6-0:1.0: USB hub found
[    1.778822] hub 6-0:1.0: 1 port detected
[    1.812887] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.826546] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.840134] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.890155] ehci_irq: highspeed device disconnect
[    1.890201] ohci_irq: fullspeed or lowspeed device connect
[    1.915236] hub 7-0:1.0: USB hub found
[    1.928589] hub 7-0:1.0: 1 port detected
[    1.962583] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.976263] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.989973] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    2.065282] hub 8-0:1.0: USB hub found
[    2.078483] hub 8-0:1.0: 1 port detected
[    2.092294] Initializing USB Mass Storage driver...
[    2.105883] usbcore: registered new interface driver usb-storage
[    2.119176] USB Mass Storage support registered.
[    2.132489] usbcore: registered new interface driver ums-alauda
[    2.146091] usbcore: registered new interface driver ums-cypress
[    2.159327] usbcore: registered new interface driver ums-datafab
[    2.172319] usbcore: registered new interface driver ums_eneub6250
[    2.185128] usbcore: registered new interface driver ums-freecom
[    2.197744] ehci_irq: highspeed device disconnect
[    2.197984] usbcore: registered new interface driver ums-isd200
[    2.210474] usbcore: registered new interface driver ums-jumpshot
[    2.223015] usbcore: registered new interface driver ums-karma
[    2.235109] usbcore: registered new interface driver ums-onetouch
[    2.247027] usbcore: registered new interface driver ums-realtek
[    2.258714] usbcore: registered new interface driver ums-sddr09
[    2.270298] usbcore: registered new interface driver ums-sddr55
[    2.281624] usbcore: registered new interface driver ums-usbat
[    2.290105] usb 5-1: new low-speed USB device number 2 using sunxi-ohci
[    2.304627] file system registered
[    2.319485] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.330760] android_usb gadget: Number of LUNs=3
[    2.341931]  lun0: LUN: removable file: (no medium)
[    2.353067]  lun1: LUN: removable file: (no medium)
[    2.364120]  lun2: LUN: removable file: (no medium)
[    2.375754] android_usb gadget: android_usb ready
[    2.386867]  uinput result 0 , vmouse_init
[    2.388398] mousedev: PS/2 mouse device common for all mice
[    2.401094] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    2.411962] =========script_get_err============
[    2.422694] ltr_init: ls_fetch_sysconfig_para err.
[    2.423471] [RTC] WARNING: Rtc time will be wrong!!
[    2.434114] [RTC] WARNING: use *internal OSC* as clock source
[    2.445497] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    2.456368] i2c /dev entries driver
[    2.467932] IR RC5(x) protocol handler initialized
[    2.478909] sunxi cedar version 0.1
[    2.479004] [cedar]: install start!!!
[    2.479456] [cedar]: install end!!!
[    2.479815] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    2.491167] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    2.502367] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    2.513176] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    2.523794] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    2.534148] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.544277] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.554326] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.563968] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.573448] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    2.582671] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    2.591648] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    2.600508] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    2.609178] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    2.617567] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    2.625717] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    2.633574] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    2.641367] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    2.648894] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.650868] usb 2-1: USB disconnect, device number 2
[    2.664778] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    2.665865] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    2.682650] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    2.691724] timeout_to_interv, line 167
[    2.700862] interv_to_timeout, line 189
[    2.710066] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    2.720908] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.731445] calibrat: max_cpufreq 1200Mhz Type 0!
[    2.731477] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    2.747895] [ARISC ERROR] :message process error
[    2.756901] [ARISC ERROR] :message addr   : f004b840
[    2.765728] [ARISC ERROR] :message state  : 5
[    2.774303] [ARISC ERROR] :message attr   : 2
[    2.782706] [ARISC ERROR] :message type   : 30
[    2.791016] [ARISC ERROR] :message result : ff
[    2.799277] [ARISC WARING] :callback not install
[    2.807709] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.816789] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    2.816844] [mmc]: get mmc0's sdc_power is null!
[    2.816886] [mmc]: get mmc1's sdc_power is null!
[    2.816901] [mmc]: get mmc1's 2xmode ok, val = 1
[    2.816916] [mmc]: get mmc1's ddrmode ok, val = 1
[    2.816939] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    2.818526] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.819649] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.820304] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.821190] [mmc]: sdc0 power_supply is null
[    2.823132] no blue_led, ignore it!
[    2.827392] Registered led device: red_led
[    2.827504] Registered led device: green_led
[    2.827523] no led_0, ignore it!
[    2.831460] no led_1, ignore it!
[    2.835231] no led_2, ignore it!
[    2.838910] no led_3, ignore it!
[    2.840052] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.842553] no led_4, ignore it!
[    2.845525] no led_5, ignore it!
[    2.848340] no led_6, ignore it!
[    2.851107] no led_7, ignore it!
[    2.859472] generic-usb 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-sunxi-ohci-1/input0
[    2.863436] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.865941] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.868268] generic-usb 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [USB USB Keykoard] on usb-sunxi-ohci-1/input1
[    2.871534] usbcore: registered new interface driver usbhid
[    2.874741] usbhid: USB HID core driver
[    2.878628] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.878751] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.881273] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.881768] asoc: sndcodec <-> sunxi-codec mapping ok
[    2.885980] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    2.889763] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    2.893547] [DAUDIO0] driver not init,just return.
[    2.900424] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    2.901613] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.905307] oprofile: using arm/armv7-ca7
[    2.905396] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.905474] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.905590] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    2.905666] mmc0: new high speed SDHC card at address 0007
[    2.913372] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    2.917531] u32 classifier
[    2.919224]  mmcblk0: p1
[    2.919731] mmcblk mmc0:0007: Card claimed for testing.
[    2.919744] mmc0:0007: SD08G 7.42 GiB
[    2.919762] *******************sd init ok*******************
[    2.938770]     Actions configured
[    2.943293] IPv4 over IPv4 tunneling driver
[    2.948153] TCP: bic registered
[    2.952345] TCP: cubic registered
[    2.956387] TCP: westwood registered
[    2.960369] TCP: highspeed registered
[    2.964289] TCP: hybla registered
[    2.968193] TCP: htcp registered
[    2.971999] TCP: vegas registered
[    2.975679] TCP: veno registered
[    2.979226] TCP: scalable registered
[    2.982694] TCP: lp registered
[    2.986139] TCP: yeah registered
[    2.989588] TCP: illinois registered
[    2.993121] Initializing XFRM netlink socket
[    2.996905] NET: Registered protocol family 10
[    3.001558] NET: Registered protocol family 17
[    3.005155] NET: Registered protocol family 15
[    3.008653] Registering the dns_resolver key type
[    3.012544] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    3.016168] ThumbEE CPU extension supported.
[    3.019824] Registering SWP/SWPB emulation handler
[    3.024073] registered taskstats version 1
[    3.028255] cmdline,disp=
[    3.032370] [HDMI] power vcc-hdmi-18
[    3.063091] ths_fetch_sysconfig_para: type err  device_used = 1.
[    3.068348] CPU Budget:Register notifier
[    3.072444] CPU Budget:register Success
[    3.076618] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    3.083552] [rf_pm]: module power0 name vcc-wifi-33
[    3.083567] [rf_pm]: Did not config module_power1 in sys_config
[    3.083576] [rf_pm]: Did not config module_power2 in sys_config
[    3.083586] [rf_pm]: Did not config module_power3 in sys_config
[    3.083595] [rf_pm]: mod has no chip_en gpio
[    3.083603] [rf_pm]: failed to fetch lpo_use_apclk
[    3.083610] [rf_pm]: regulator on.
[    3.083619] [wifi_pm]: no wifi used in configuration
[    3.083629] [rfkill]: init no bt used in configuration
[    3.083636] ALSA device list:
[    3.087659]   #0: audiocodec
[    3.091498]   #1: sndhdmi
[    3.095701] Freeing init memory: 328K
[    3.139449] systemd-udevd[97]: starting version 215
[    3.596471] [ARISC ERROR] :message process error
[    3.605920] [ARISC ERROR] :message addr   : f004b840
[    3.614628] [ARISC ERROR] :message state  : 5
[    3.623132] [ARISC ERROR] :message attr   : 2
[    3.631487] [ARISC ERROR] :message type   : 30
[    3.639627] [ARISC ERROR] :message result : ff
[    3.647705] [ARISC WARING] :callback not install
[    3.655885] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    3.670102] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    4.477149] [ARISC ERROR] :message process error
[    4.487040] [ARISC ERROR] :message addr   : f004b840
[    4.496680] [ARISC ERROR] :message state  : 5
[    4.506734] [ARISC ERROR] :message attr   : 2
[    4.515965] [ARISC ERROR] :message type   : 30
[    4.525481] [ARISC ERROR] :message result : ff
[    4.534686] [ARISC WARING] :callback not install
[    4.534711] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.830887] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    8.890206] ehci_irq: highspeed device connect
[    9.040146] ehci_irq: highspeed device disconnect
[    9.040172] ohci_irq: fullspeed or lowspeed device connect
[    9.095095] [ARISC ERROR] :message process error
[    9.106316] [ARISC ERROR] :message addr   : f004b840
[    9.117661] [ARISC ERROR] :message state  : 5
[    9.128910] [ARISC ERROR] :message attr   : 2
[    9.140047] [ARISC ERROR] :message type   : 30
[    9.150998] [ARISC ERROR] :message result : ff
[    9.161743] [ARISC WARING] :callback not install
[    9.172598] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.470062] usb 6-1: new low-speed USB device number 2 using sunxi-ohci
[    9.697730] generic-usb 0003:0000:0538.0003: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    9.815196] [ARISC ERROR] :message process error
[    9.826964] [ARISC ERROR] :message addr   : f004b840
[    9.838593] [ARISC ERROR] :message state  : 5
[    9.850034] [ARISC ERROR] :message attr   : 2
[    9.861293] [ARISC ERROR] :message type   : 30
[    9.872524] [ARISC ERROR] :message result : ff
[    9.883715] [ARISC WARING] :callback not install
[    9.895058] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   10.030346] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[   10.036721] systemd[1]: Detected architecture 'arm'.
[   10.073214] systemd[1]: Set hostname to <orangepione>.
[   10.413807] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[   10.426471] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[   10.432098] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.437385] systemd[1]: Expecting device dev-ttySAC2.device...
[   10.448490] systemd[1]: Starting Remote File Systems (Pre).
[   10.459768] systemd[1]: Reached target Remote File Systems (Pre).
[   10.465529] systemd[1]: Starting Encrypted Volumes.
[   10.476808] systemd[1]: Reached target Encrypted Volumes.
[   10.482332] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[   10.487993] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.493539] systemd[1]: Starting Paths.
[   10.504644] systemd[1]: Reached target Paths.
[   10.510081] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[   10.521695] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.527326] systemd[1]: Starting Root Slice.
[   10.538646] systemd[1]: Created slice Root Slice.
[   10.544260] systemd[1]: Starting User and Session Slice.
[   10.556024] systemd[1]: Created slice User and Session Slice.
[   10.561900] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[   10.573969] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   10.579821] systemd[1]: Starting Delayed Shutdown Socket.
[   10.591461] systemd[1]: Listening on Delayed Shutdown Socket.
[   10.597122] systemd[1]: Starting Journal Socket (/dev/log).
[   10.608962] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.614907] systemd[1]: Starting udev Control Socket.
[   10.627147] systemd[1]: Listening on udev Control Socket.
[   10.633181] systemd[1]: Starting udev Kernel Socket.
[   10.644929] systemd[1]: Listening on udev Kernel Socket.
[   10.650649] systemd[1]: Starting Journal Socket.
[   10.662351] systemd[1]: Listening on Journal Socket.
[   10.668100] systemd[1]: Starting System Slice.
[   10.679257] systemd[1]: Created slice System Slice.
[   10.684566] systemd[1]: Started File System Check on Root Device.
[   10.689791] systemd[1]: Starting system-getty.slice.
[   10.700577] systemd[1]: Created slice system-getty.slice.
[   10.705732] systemd[1]: Starting system-serial\x2dgetty.slice.
[   10.716424] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.721720] systemd[1]: Starting Increase datagram queue length...
[   10.784964] [ARISC ERROR] :message process error
[   10.797705] [ARISC ERROR] :message addr   : f004b840
[   10.810197] [ARISC ERROR] :message state  : 5
[   10.822454] [ARISC ERROR] :message attr   : 2
[   10.834583] [ARISC ERROR] :message type   : 30
[   10.846536] [ARISC ERROR] :message result : ff
[   10.858208] [ARISC WARING] :callback not install
[   10.861262] systemd[1]: Starting Restore / save the current clock...
[   10.881076] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   10.980732] systemd[1]: Starting udev Coldplug all Devices...
[   11.030841] systemd[1]: Mounting POSIX Message Queue File System...
[   11.107700] systemd[1]: Starting Load Kernel Modules...
[   11.181041] systemd[1]: Mounting Debug File System...
[   11.282769] RTL871X: module init start
[   11.282784] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[   11.282863] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.284404] [mmc]: sdc1 power_supply is null
[   11.300038] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.310514] systemd[1]: Mounted Huge Pages File System.
[   11.315706] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.323661] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.326186] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.334671] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.335622] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.335747] [mmc]: sdc1 power_supply is null
[   11.338334] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.339861] [mmc]: sdc1 power_supply is null
[   11.360029] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.373459] systemd[1]: Started Set Up Additional Binary Formats.
[   11.378366] systemd[1]: Starting LSB: Set keymap...
[   11.382845] [wifi_pm]: set wl_reg_on 1 !
[   11.382986] RTL871X: module init ret=0
[   11.383773] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.386427] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.397347] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.398585] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.398710] [mmc]: sdc1 power_supply is null
[   11.401111] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.402640] [mmc]: sdc1 power_supply is null
[   11.420036] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.444785] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.447670] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.463340] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.465110] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.465227] [mmc]: sdc1 power_supply is null
[   11.467809] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.469334] [mmc]: sdc1 power_supply is null
[   11.470465] systemd[1]: Starting Slices.
[   11.480439] systemd[1]: Reached target Slices.
[   11.490080] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.491748] systemd[1]: Mounted Debug File System.
[   11.501506] systemd[1]: Mounted POSIX Message Queue File System.
[   11.515888] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.519045] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.539597] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.541951] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   11.542097] [mmc]: sdc1 power_supply is null
[   11.586128] systemd[1]: Started Increase datagram queue length.
[   11.676235] systemd[1]: Started Restore / save the current clock.
[   11.735192] [ARISC ERROR] :message process error
[   11.747291] [ARISC ERROR] :message addr   : f004b840
[   11.759253] [ARISC ERROR] :message state  : 5
[   11.771199] [ARISC ERROR] :message attr   : 2
[   11.783178] [ARISC ERROR] :message type   : 30
[   11.794825] [ARISC ERROR] :message result : ff
[   11.806017] [ARISC WARING] :callback not install
[   11.817118] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   11.840360] systemd[1]: Started Load Kernel Modules.
[   11.955315] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   12.035338] systemd[1]: Started LSB: Set keymap.
[   12.079999] [ARISC ERROR] :message process error
[   12.092500] [ARISC ERROR] :message addr   : f004b840
[   12.104886] [ARISC ERROR] :message state  : 5
[   12.117029] [ARISC ERROR] :message attr   : 2
[   12.128953] [ARISC ERROR] :message type   : 30
[   12.140635] [ARISC ERROR] :message result : ff
[   12.152136] [ARISC WARING] :callback not install
[   12.163571] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   12.175065] systemd[1]: Started udev Coldplug all Devices.
[   12.182592] systemd[1]: Time has been changed
[   12.188534] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.311054] systemd[1]: Mounted Configuration File System.
[   12.316724] systemd[1]: Starting Apply Kernel Variables...
[   12.445321] [ARISC ERROR] :message process error
[   12.456205] [ARISC ERROR] :message addr   : f004b840
[   12.466952] [ARISC ERROR] :message state  : 5
[   12.471368] systemd[1]: Mounting FUSE Control File System...
[   12.488409] [ARISC ERROR] :message attr   : 2
[   12.488428] [ARISC ERROR] :message type   : 30
[   12.488444] [ARISC ERROR] :message result : ff
[   12.488458] [ARISC WARING] :callback not install
[   12.488479] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   12.650683] systemd[1]: Starting Syslog Socket.
[   12.672963] systemd[1]: Listening on Syslog Socket.
[   12.683245] systemd[1]: Starting Journal Service...
[   12.782403] systemd[1]: Started Journal Service.
[   13.074129] [ARISC ERROR] :message process error
[   13.084606] [ARISC ERROR] :message addr   : f004b840
[   13.094797] [ARISC ERROR] :message state  : 5
[   13.104784] [ARISC ERROR] :message attr   : 2
[   13.114440] [ARISC ERROR] :message type   : 30
[   13.123663] [ARISC ERROR] :message result : ff
[   13.132510] [ARISC WARING] :callback not install
[   13.141288] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   13.192466] systemd-udevd[176]: starting version 215
[   14.039026] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   14.085268] [ARISC ERROR] :message process error
[   14.094926] [ARISC ERROR] :message addr   : f004b840
[   14.104267] [ARISC ERROR] :message state  : 5
[   14.113482] [ARISC ERROR] :message attr   : 2
[   14.113499] [ARISC ERROR] :message type   : 30
[   14.113514] [ARISC ERROR] :message result : ff
[   14.113528] [ARISC WARING] :callback not install
[   14.113549] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   14.280844] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[   14.945433] [ARISC ERROR] :message process error
[   14.955867] [ARISC ERROR] :message addr   : f004b840
[   14.966571] [ARISC ERROR] :message state  : 5
[   14.977118] [ARISC ERROR] :message attr   : 2
[   14.987740] [ARISC ERROR] :message type   : 30
[   14.998186] [ARISC ERROR] :message result : ff
[   15.008727] [ARISC WARING] :callback not install
[   15.018769] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   15.424073] [ARISC ERROR] :message process error
[   15.434072] [ARISC ERROR] :message addr   : f004b840
[   15.443894] [ARISC ERROR] :message state  : 5
[   15.453515] [ARISC ERROR] :message attr   : 2
[   15.463070] [ARISC ERROR] :message type   : 30
[   15.472417] [ARISC ERROR] :message result : ff
[   15.481631] [ARISC WARING] :callback not install
[   15.490890] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   15.515805] systemd-journald[175]: Received request to flush runtime journal from PID 1
[   15.843457] gmac0: probed
[   15.848069] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   16.246728] [ARISC ERROR] :message process error
[   16.257041] [ARISC ERROR] :message addr   : f004b840
[   16.267178] [ARISC ERROR] :message state  : 5
[   16.277054] [ARISC ERROR] :message attr   : 2
[   16.286722] [ARISC ERROR] :message type   : 30
[   16.296323] [ARISC ERROR] :message result : ff
[   16.305737] [ARISC WARING] :callback not install
[   16.315114] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   16.545614] [ARISC ERROR] :message process error
[   16.554716] [ARISC ERROR] :message addr   : f004b840
[   16.563800] [ARISC ERROR] :message state  : 5
[   16.572802] [ARISC ERROR] :message attr   : 2
[   16.581710] [ARISC ERROR] :message type   : 30
[   16.590421] [ARISC ERROR] :message result : ff
[   16.598976] [ARISC WARING] :callback not install
[   16.607480] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   16.795616] [ARISC ERROR] :message process error
[   16.804099] [ARISC ERROR] :message addr   : f004b840
[   16.812532] [ARISC ERROR] :message state  : 5
[   16.820802] [ARISC ERROR] :message attr   : 2
[   16.828852] [ARISC ERROR] :message type   : 30
[   16.836869] [ARISC ERROR] :message result : ff
[   16.844879] [ARISC WARING] :callback not install
[   16.852983] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   17.095635] [ARISC ERROR] :message process error
[   17.104192] [ARISC ERROR] :message addr   : f004b840
[   17.112661] [ARISC ERROR] :message state  : 5
[   17.120915] [ARISC ERROR] :message attr   : 2
[   17.128906] [ARISC ERROR] :message type   : 30
[   17.136747] [ARISC ERROR] :message result : ff
[   17.144578] [ARISC WARING] :callback not install
[   17.152471] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   17.395611] [ARISC ERROR] :message process error
[   17.403929] [ARISC ERROR] :message addr   : f004b840
[   17.412317] [ARISC ERROR] :message state  : 5
[   17.420566] [ARISC ERROR] :message attr   : 2
[   17.428586] [ARISC ERROR] :message type   : 30
[   17.436304] [ARISC ERROR] :message result : ff
[   17.443696] [ARISC WARING] :callback not install
[   17.450954] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   17.695619] [ARISC ERROR] :message process error
[   17.702970] [ARISC ERROR] :message addr   : f004b840
[   17.710125] [ARISC ERROR] :message state  : 5
[   17.716913] [ARISC ERROR] :message attr   : 2
[   17.723586] [ARISC ERROR] :message type   : 30
[   17.730100] [ARISC ERROR] :message result : ff
[   17.736542] [ARISC WARING] :callback not install
[   17.743129] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   17.994021] [ARISC ERROR] :message process error
[   18.001008] [ARISC ERROR] :message addr   : f004b840
[   18.007998] [ARISC ERROR] :message state  : 5
[   18.014895] [ARISC ERROR] :message attr   : 2
[   18.021593] [ARISC ERROR] :message type   : 30
[   18.028088] [ARISC ERROR] :message result : ff
[   18.034550] [ARISC WARING] :callback not install
[   18.041124] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   18.245473] [ARISC ERROR] :message process error
[   18.252470] [ARISC ERROR] :message addr   : f004b840
[   18.259466] [ARISC ERROR] :message state  : 5
[   18.266357] [ARISC ERROR] :message attr   : 2
[   18.273042] [ARISC ERROR] :message type   : 30
[   18.279522] [ARISC ERROR] :message result : ff
[   18.285960] [ARISC WARING] :callback not install
[   18.292517] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   18.545634] [ARISC ERROR] :message process error
[   18.552655] [ARISC ERROR] :message addr   : f004b840
[   18.559650] [ARISC ERROR] :message state  : 5
[   18.566535] [ARISC ERROR] :message attr   : 2
[   18.573224] [ARISC ERROR] :message type   : 30
[   18.579698] [ARISC ERROR] :message result : ff
[   18.586134] [ARISC WARING] :callback not install
[   18.592698] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   18.845645] [ARISC ERROR] :message process error
[   18.853847] [ARISC ERROR] :message addr   : f004b840
[   18.862400] [ARISC ERROR] :message state  : 5
[   18.870199] [ARISC ERROR] :message attr   : 2
[   18.876916] [ARISC ERROR] :message type   : 30
[   18.883417] [ARISC ERROR] :message result : ff
[   18.889825] [ARISC WARING] :callback not install
[   18.896373] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   19.294004] [ARISC ERROR] :message process error
[   19.300996] [ARISC ERROR] :message addr   : f004b840
[   19.307968] [ARISC ERROR] :message state  : 5
[   19.314853] [ARISC ERROR] :message attr   : 2
[   19.321533] [ARISC ERROR] :message type   : 30
[   19.328000] [ARISC ERROR] :message result : ff
[   19.334429] [ARISC WARING] :callback not install
[   19.340970] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   19.545619] [ARISC ERROR] :message process error
[   19.552567] [ARISC ERROR] :message addr   : f004b840
[   19.559530] [ARISC ERROR] :message state  : 5
[   19.566390] [ARISC ERROR] :message attr   : 2
[   19.573045] [ARISC ERROR] :message type   : 30
[   19.579498] [ARISC ERROR] :message result : ff
[   19.585909] [ARISC WARING] :callback not install
[   19.592445] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   19.844083] [ARISC ERROR] :message process error
[   19.851019] [ARISC ERROR] :message addr   : f004b840
[   19.858006] [ARISC ERROR] :message state  : 5
[   19.864885] [ARISC ERROR] :message attr   : 2
[   19.871542] [ARISC ERROR] :message type   : 30
[   19.877995] [ARISC ERROR] :message result : ff
[   19.884424] [ARISC WARING] :callback not install
[   19.890964] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.095625] [ARISC ERROR] :message process error
[   20.102598] [ARISC ERROR] :message addr   : f004b840
[   20.109585] [ARISC ERROR] :message state  : 5
[   20.116470] [ARISC ERROR] :message attr   : 2
[   20.123148] [ARISC ERROR] :message type   : 30
[   20.129621] [ARISC ERROR] :message result : ff
[   20.136065] [ARISC WARING] :callback not install
[   20.142640] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.395456] [ARISC ERROR] :message process error
[   20.402426] [ARISC ERROR] :message addr   : f004b840
[   20.409416] [ARISC ERROR] :message state  : 5
[   20.416319] [ARISC ERROR] :message attr   : 2
[   20.423004] [ARISC ERROR] :message type   : 30
[   20.429479] [ARISC ERROR] :message result : ff
[   20.435923] [ARISC WARING] :callback not install
[   20.442483] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.695465] [ARISC ERROR] :message process error
[   20.702432] [ARISC ERROR] :message addr   : f004b840
[   20.709410] [ARISC ERROR] :message state  : 5
[   20.716290] [ARISC ERROR] :message attr   : 2
[   20.722958] [ARISC ERROR] :message type   : 30
[   20.729419] [ARISC ERROR] :message result : ff
[   20.735852] [ARISC WARING] :callback not install
[   20.742413] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.993862] [ARISC ERROR] :message process error
[   21.000814] [ARISC ERROR] :message addr   : f004b840
[   21.007782] [ARISC ERROR] :message state  : 5
[   21.014690] [ARISC ERROR] :message attr   : 2
[   21.021388] [ARISC ERROR] :message type   : 30
[   21.027868] [ARISC ERROR] :message result : ff
[   21.034312] [ARISC WARING] :callback not install
[   21.040866] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   21.245322] [ARISC ERROR] :message process error
[   21.252300] [ARISC ERROR] :message addr   : f004b840
[   21.259284] [ARISC ERROR] :message state  : 5
[   21.266160] [ARISC ERROR] :message attr   : 2
[   21.272837] [ARISC ERROR] :message type   : 30
[   21.279310] [ARISC ERROR] :message result : ff
[   21.285753] [ARISC WARING] :callback not install
[   21.292320] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   21.545473] [ARISC ERROR] :message process error
[   21.552854] [ARISC ERROR] :message addr   : f004b840
[   21.560788] [ARISC ERROR] :message state  : 5
[   21.568574] [ARISC ERROR] :message attr   : 2
[   21.576187] [ARISC ERROR] :message type   : 30
[   21.583597] [ARISC ERROR] :message result : ff
[   21.590968] [ARISC WARING] :callback not install
[   21.598406] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   21.845483] [ARISC ERROR] :message process error
[   21.853366] [ARISC ERROR] :message addr   : f004b840
[   21.861282] [ARISC ERROR] :message state  : 5
[   21.869052] [ARISC ERROR] :message attr   : 2
[   21.876742] [ARISC ERROR] :message type   : 30
[   21.884167] [ARISC ERROR] :message result : ff
[   21.891607] [ARISC WARING] :callback not install
[   21.899037] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   22.095498] [ARISC ERROR] :message process error
[   22.103786] [ARISC ERROR] :message addr   : f004b840
[   22.112627] [ARISC ERROR] :message state  : 5
[   22.121341] [ARISC ERROR] :message attr   : 2
[   22.129838] [ARISC ERROR] :message type   : 30
[   22.138172] [ARISC ERROR] :message result : ff
[   22.146479] [ARISC WARING] :callback not install
[   22.154858] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   22.395608] [ARISC ERROR] :message process error
[   22.404405] [ARISC ERROR] :message addr   : f004b840
[   22.413275] [ARISC ERROR] :message state  : 5
[   22.422006] [ARISC ERROR] :message attr   : 2
[   22.430529] [ARISC ERROR] :message type   : 30
[   22.438828] [ARISC ERROR] :message result : ff
[   22.447118] [ARISC WARING] :callback not install
[   22.455476] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   22.695615] [ARISC ERROR] :message process error
[   22.704803] [ARISC ERROR] :message addr   : f004b840
[   22.714567] [ARISC ERROR] :message state  : 5
[   22.724205] [ARISC ERROR] :message attr   : 2
[   22.733663] [ARISC ERROR] :message type   : 30
[   22.742938] [ARISC ERROR] :message result : ff
[   22.752155] [ARISC WARING] :callback not install
[   22.761458] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   22.995612] [ARISC ERROR] :message process error
[   23.005338] [ARISC ERROR] :message addr   : f004b840
[   23.015119] [ARISC ERROR] :message state  : 5
[   23.024783] [ARISC ERROR] :message attr   : 2
[   23.034246] [ARISC ERROR] :message type   : 30
[   23.043144] [ARISC ERROR] :message result : ff
[   23.051439] [ARISC WARING] :callback not install
[   23.059801] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   23.295610] [ARISC ERROR] :message process error
[   23.304753] [ARISC ERROR] :message addr   : f004b840
[   23.314410] [ARISC ERROR] :message state  : 5
[   23.323941] [ARISC ERROR] :message attr   : 2
[   23.333283] [ARISC ERROR] :message type   : 30
[   23.342455] [ARISC ERROR] :message result : ff
[   23.351557] [ARISC WARING] :callback not install
[   23.360751] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   23.595614] [ARISC ERROR] :message process error
[   23.605241] [ARISC ERROR] :message addr   : f004b840
[   23.614908] [ARISC ERROR] :message state  : 5
[   23.624467] [ARISC ERROR] :message attr   : 2
[   23.633832] [ARISC ERROR] :message type   : 30
[   23.642632] [ARISC ERROR] :message result : ff
[   23.650824] [ARISC WARING] :callback not install
[   23.659094] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   23.895640] [ARISC ERROR] :message process error
[   23.904679] [ARISC ERROR] :message addr   : f004b840
[   23.914317] [ARISC ERROR] :message state  : 5
[   23.923773] [ARISC ERROR] :message attr   : 2
[   23.933029] [ARISC ERROR] :message type   : 30
[   23.942092] [ARISC ERROR] :message result : ff
[   23.951073] [ARISC WARING] :callback not install
[   23.960154] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   24.195468] [ARISC ERROR] :message process error
[   24.204991] [ARISC ERROR] :message addr   : f004b840
[   24.214574] [ARISC ERROR] :message state  : 5
[   24.224026] [ARISC ERROR] :message attr   : 2
[   24.233270] [ARISC ERROR] :message type   : 30
[   24.241960] [ARISC ERROR] :message result : ff
[   24.250038] [ARISC WARING] :callback not install
[   24.258169] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   24.495616] [ARISC ERROR] :message process error
[   24.504535] [ARISC ERROR] :message addr   : f004b840
[   24.513948] [ARISC ERROR] :message state  : 5
[   24.523239] [ARISC ERROR] :message attr   : 2
[   24.532336] [ARISC ERROR] :message type   : 30
[   24.541250] [ARISC ERROR] :message result : ff
[   24.550103] [ARISC WARING] :callback not install
[   24.559023] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   24.745628] [ARISC ERROR] :message process error
[   24.754966] [ARISC ERROR] :message addr   : f004b840
[   24.764376] [ARISC ERROR] :message state  : 5
[   24.773647] [ARISC ERROR] :message attr   : 2
[   24.782730] [ARISC ERROR] :message type   : 30
[   24.791296] [ARISC ERROR] :message result : ff
[   24.799325] [ARISC WARING] :callback not install
[   24.807448] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   24.995621] [ARISC ERROR] :message process error
[   25.004562] [ARISC ERROR] :message addr   : f004b840
[   25.014067] [ARISC ERROR] :message state  : 5
[   25.023472] [ARISC ERROR] :message attr   : 2
[   25.032665] [ARISC ERROR] :message type   : 30
[   25.041705] [ARISC ERROR] :message result : ff
[   25.050645] [ARISC WARING] :callback not install
[   25.059642] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   25.295614] [ARISC ERROR] :message process error
[   25.305043] [ARISC ERROR] :message addr   : f004b840
[   25.314526] [ARISC ERROR] :message state  : 5
[   25.323884] [ARISC ERROR] :message attr   : 2
[   25.333056] [ARISC ERROR] :message type   : 30
[   25.341746] [ARISC ERROR] :message result : ff
[   25.349852] [ARISC WARING] :callback not install
[   25.358067] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   25.595624] [ARISC ERROR] :message process error
[   25.604666] [ARISC ERROR] :message addr   : f004b840
[   25.614278] [ARISC ERROR] :message state  : 5
[   25.623755] [ARISC ERROR] :message attr   : 2
[   25.633027] [ARISC ERROR] :message type   : 30
[   25.642121] [ARISC ERROR] :message result : ff
[   25.651146] [ARISC WARING] :callback not install
[   25.660253] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   25.895634] [ARISC ERROR] :message process error
[   25.905202] [ARISC ERROR] :message addr   : f004b840
[   25.914792] [ARISC ERROR] :message state  : 5
[   25.924240] [ARISC ERROR] :message attr   : 2
[   25.933495] [ARISC ERROR] :message type   : 30
[   25.942264] [ARISC ERROR] :message result : ff
[   25.950496] [ARISC WARING] :callback not install
[   25.958802] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   26.195486] [ARISC ERROR] :message process error
[   26.204637] [ARISC ERROR] :message addr   : f004b840
[   26.214320] [ARISC ERROR] :message state  : 5
[   26.223896] [ARISC ERROR] :message attr   : 2
[   26.233276] [ARISC ERROR] :message type   : 30
[   26.242482] [ARISC ERROR] :message result : ff
[   26.251616] [ARISC WARING] :callback not install
[   26.260862] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   26.495613] [ARISC ERROR] :message process error
[   26.505257] [ARISC ERROR] :message addr   : f004b840
[   26.514957] [ARISC ERROR] :message state  : 5
[   26.524529] [ARISC ERROR] :message attr   : 2
[   26.533900] [ARISC ERROR] :message type   : 30
[   26.542717] [ARISC ERROR] :message result : ff
[   26.550948] [ARISC WARING] :callback not install
[   26.559265] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   26.660059] eth0: no IPv6 routers present
[   26.794012] [ARISC ERROR] :message process error
[   26.803085] [ARISC ERROR] :message addr   : f004b840
[   26.812697] [ARISC ERROR] :message state  : 5
[   26.822203] [ARISC ERROR] :message attr   : 2
[   26.831521] [ARISC ERROR] :message type   : 30
[   26.840620] [ARISC ERROR] :message result : ff
[   26.849641] [ARISC WARING] :callback not install
[   26.858768] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   27.045642] [ARISC ERROR] :message process error
[   27.055201] [ARISC ERROR] :message addr   : f004b840
[   27.064805] [ARISC ERROR] :message state  : 5
[   27.074279] [ARISC ERROR] :message attr   : 2
[   27.083561] [ARISC ERROR] :message type   : 30
[   27.092291] [ARISC ERROR] :message result : ff
[   27.100438] [ARISC WARING] :callback not install
[   27.108677] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   27.345620] [ARISC ERROR] :message process error
[   27.354623] [ARISC ERROR] :message addr   : f004b840
[   27.364124] [ARISC ERROR] :message state  : 5
[   27.373493] [ARISC ERROR] :message attr   : 2
[   27.382669] [ARISC ERROR] :message type   : 30
[   27.391694] [ARISC ERROR] :message result : ff
[   27.400635] [ARISC WARING] :callback not install
[   27.409651] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   27.645622] [ARISC ERROR] :message process error
[   27.655399] [ARISC ERROR] :message addr   : f004b840
[   27.665694] [ARISC ERROR] :message state  : 5
[   27.675872] [ARISC ERROR] :message attr   : 2
[   27.685840] [ARISC ERROR] :message type   : 30
[   27.695259] [ARISC ERROR] :message result : ff
[   27.704093] [ARISC WARING] :callback not install
[   27.713028] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   27.945621] [ARISC ERROR] :message process error
[   27.954975] [ARISC ERROR] :message addr   : f004b840
[   27.964373] [ARISC ERROR] :message state  : 5
[   27.973638] [ARISC ERROR] :message attr   : 2
[   27.982711] [ARISC ERROR] :message type   : 30
[   27.991630] [ARISC ERROR] :message result : ff
[   28.000470] [ARISC WARING] :callback not install
[   28.009398] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   28.245479] [ARISC ERROR] :message process error
[   28.255242] [ARISC ERROR] :message addr   : f004b840
[   28.265573] [ARISC ERROR] :message state  : 5
[   28.275791] [ARISC ERROR] :message attr   : 2
[   28.285797] [ARISC ERROR] :message type   : 30
[   28.295305] [ARISC ERROR] :message result : ff
[   28.304282] [ARISC WARING] :callback not install
[   28.313361] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   28.545620] [ARISC ERROR] :message process error
[   28.555118] [ARISC ERROR] :message addr   : f004b840
[   28.564658] [ARISC ERROR] :message state  : 5
[   28.574074] [ARISC ERROR] :message attr   : 2
[   28.583298] [ARISC ERROR] :message type   : 30
[   28.592343] [ARISC ERROR] :message result : ff
[   28.601321] [ARISC WARING] :callback not install
[   28.610396] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   28.845633] [ARISC ERROR] :message process error
[   28.855623] [ARISC ERROR] :message addr   : f004b840
[   28.866126] [ARISC ERROR] :message state  : 5
[   28.876473] [ARISC ERROR] :message attr   : 2
[   28.886612] [ARISC ERROR] :message type   : 30
[   28.896257] [ARISC ERROR] :message result : ff
[   28.905464] [ARISC WARING] :callback not install
[   28.914719] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   29.145644] [ARISC ERROR] :message process error
[   29.155686] [ARISC ERROR] :message addr   : f004b840
[   29.166284] [ARISC ERROR] :message state  : 5
[   29.176761] [ARISC ERROR] :message attr   : 2
[   29.187025] [ARISC ERROR] :message type   : 30
[   29.196801] [ARISC ERROR] :message result : ff
[   29.206040] [ARISC WARING] :callback not install
[   29.215407] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   29.445625] [ARISC ERROR] :message process error
[   29.455383] [ARISC ERROR] :message addr   : f004b840
[   29.465190] [ARISC ERROR] :message state  : 5
[   29.474863] [ARISC ERROR] :message attr   : 2
[   29.484349] [ARISC ERROR] :message type   : 30
[   29.493676] [ARISC ERROR] :message result : ff
[   29.502924] [ARISC WARING] :callback not install
[   29.512299] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   29.745634] [ARISC ERROR] :message process error
[   29.755734] [ARISC ERROR] :message addr   : f004b840
[   29.766354] [ARISC ERROR] :message state  : 5
[   29.776847] [ARISC ERROR] :message attr   : 2
[   29.787128] [ARISC ERROR] :message type   : 30
[   29.796857] [ARISC ERROR] :message result : ff
[   29.805998] [ARISC WARING] :callback not install
[   29.815231] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   30.045635] [ARISC ERROR] :message process error
[   30.055300] [ARISC ERROR] :message addr   : f004b840
[   30.065040] [ARISC ERROR] :message state  : 5
[   30.074616] [ARISC ERROR] :message attr   : 2
[   30.084001] [ARISC ERROR] :message type   : 30
[   30.093210] [ARISC ERROR] :message result : ff
[   30.102352] [ARISC WARING] :callback not install
[   30.111612] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   30.345466] [ARISC ERROR] :message process error
[   30.355481] [ARISC ERROR] :message addr   : f004b840
[   30.366002] [ARISC ERROR] :message state  : 5
[   30.376403] [ARISC ERROR] :message attr   : 2
[   30.386588] [ARISC ERROR] :message type   : 30
[   30.396216] [ARISC ERROR] :message result : ff
[   30.405245] [ARISC WARING] :callback not install
[   30.414370] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   30.645464] [ARISC ERROR] :message process error
[   30.655339] [ARISC ERROR] :message addr   : f004b840
[   30.665738] [ARISC ERROR] :message state  : 5
[   30.676017] [ARISC ERROR] :message attr   : 2
[   30.686081] [ARISC ERROR] :message type   : 30
[   30.695594] [ARISC ERROR] :message result : ff
[   30.704502] [ARISC WARING] :callback not install
[   30.713520] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   30.945484] [ARISC ERROR] :message process error
[   30.954941] [ARISC ERROR] :message addr   : f004b840
[   30.964441] [ARISC ERROR] :message state  : 5
[   30.973774] [ARISC ERROR] :message attr   : 2
[   30.982911] [ARISC ERROR] :message type   : 30
[   30.991901] [ARISC ERROR] :message result : ff
[   31.000803] [ARISC WARING] :callback not install
[   31.009873] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   31.245328] [ARISC ERROR] :message process error
[   31.255136] [ARISC ERROR] :message addr   : f004b840
[   31.265502] [ARISC ERROR] :message state  : 5
[   31.275742] [ARISC ERROR] :message attr   : 2
[   31.285765] [ARISC ERROR] :message type   : 30
[   31.295284] [ARISC ERROR] :message result : ff
[   31.304255] [ARISC WARING] :callback not install
[   31.313332] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   31.545468] [ARISC ERROR] :message process error
[   31.554968] [ARISC ERROR] :message addr   : f004b840
[   31.564497] [ARISC ERROR] :message state  : 5
[   31.573890] [ARISC ERROR] :message attr   : 2
[   31.583091] [ARISC ERROR] :message type   : 30
[   31.592112] [ARISC ERROR] :message result : ff
[   31.601064] [ARISC WARING] :callback not install
[   31.610128] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   31.845469] [ARISC ERROR] :message process error
[   31.855324] [ARISC ERROR] :message addr   : f004b840
[   31.865749] [ARISC ERROR] :message state  : 5
[   31.876047] [ARISC ERROR] :message attr   : 2
[   31.886133] [ARISC ERROR] :message type   : 30
[   31.895719] [ARISC ERROR] :message result : ff
[   31.904761] [ARISC WARING] :callback not install
[   31.913902] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   32.145474] [ARISC ERROR] :message process error
[   32.155441] [ARISC ERROR] :message addr   : f004b840
[   32.165949] [ARISC ERROR] :message state  : 5
[   32.176336] [ARISC ERROR] :message attr   : 2
[   32.186512] [ARISC ERROR] :message type   : 30
[   32.196189] [ARISC ERROR] :message result : ff
[   32.205324] [ARISC WARING] :callback not install
[   32.214567] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   32.445625] [ARISC ERROR] :message process error
[   32.455286] [ARISC ERROR] :message addr   : f004b840
[   32.464992] [ARISC ERROR] :message state  : 5
[   32.474568] [ARISC ERROR] :message attr   : 2
[   32.483953] [ARISC ERROR] :message type   : 30
[   32.493176] [ARISC ERROR] :message result : ff
[   32.502321] [ARISC WARING] :callback not install
[   32.511584] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   32.745622] [ARISC ERROR] :message process error
[   32.755629] [ARISC ERROR] :message addr   : f004b840
[   32.766138] [ARISC ERROR] :message state  : 5
[   32.776519] [ARISC ERROR] :message attr   : 2
[   32.786702] [ARISC ERROR] :message type   : 30
[   32.796344] [ARISC ERROR] :message result : ff
[   32.805392] [ARISC WARING] :callback not install
[   32.814539] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   33.045640] [ARISC ERROR] :message process error
[   33.055254] [ARISC ERROR] :message addr   : f004b840
[   33.064911] [ARISC ERROR] :message state  : 5
[   33.074418] [ARISC ERROR] :message attr   : 2
[   33.083727] [ARISC ERROR] :message type   : 30
[   33.092866] [ARISC ERROR] :message result : ff
[   33.101940] [ARISC WARING] :callback not install
[   33.111127] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   33.395620] [ARISC ERROR] :message process error
[   33.405550] [ARISC ERROR] :message addr   : f004b840
[   33.416000] [ARISC ERROR] :message state  : 5
[   33.426314] [ARISC ERROR] :message attr   : 2
[   33.436401] [ARISC ERROR] :message type   : 30
[   33.445944] [ARISC ERROR] :message result : ff
[   33.454906] [ARISC WARING] :callback not install
[   33.463972] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   33.695627] [ARISC ERROR] :message process error
[   33.705440] [ARISC ERROR] :message addr   : f004b840
[   33.715745] [ARISC ERROR] :message state  : 5
[   33.725928] [ARISC ERROR] :message attr   : 2
[   33.735897] [ARISC ERROR] :message type   : 30
[   33.745324] [ARISC ERROR] :message result : ff
[   33.754161] [ARISC WARING] :callback not install
[   33.763095] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   33.995622] [ARISC ERROR] :message process error
[   34.004985] [ARISC ERROR] :message addr   : f004b840
[   34.014395] [ARISC ERROR] :message state  : 5
[   34.023682] [ARISC ERROR] :message attr   : 2
[   34.032768] [ARISC ERROR] :message type   : 30
[   34.041700] [ARISC ERROR] :message result : ff
[   34.050543] [ARISC WARING] :callback not install
[   34.059458] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   34.295616] [ARISC ERROR] :message process error
[   34.305371] [ARISC ERROR] :message addr   : f004b840
[   34.315688] [ARISC ERROR] :message state  : 5
[   34.325878] [ARISC ERROR] :message attr   : 2
[   34.335844] [ARISC ERROR] :message type   : 30
[   34.345321] [ARISC ERROR] :message result : ff
[   34.354266] [ARISC WARING] :callback not install
[   34.363308] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   34.595623] [ARISC ERROR] :message process error
[   34.605086] [ARISC ERROR] :message addr   : f004b840
[   34.614595] [ARISC ERROR] :message state  : 5
[   34.624014] [ARISC ERROR] :message attr   : 2
[   34.633231] [ARISC ERROR] :message type   : 30
[   34.642268] [ARISC ERROR] :message result : ff
[   34.642284] [ARISC WARING] :callback not install
[   34.642303] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   35.014074] [ARISC ERROR] :message process error
[   35.023929] [ARISC ERROR] :message addr   : f004b840
[   35.034339] [ARISC ERROR] :message state  : 5
[   35.044637] [ARISC ERROR] :message attr   : 2
[   35.054697] [ARISC ERROR] :message type   : 30
[   35.064333] [ARISC ERROR] :message result : ff
[   35.073390] [ARISC WARING] :callback not install
[   35.082534] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   35.295625] [ARISC ERROR] :message process error
[   35.305586] [ARISC ERROR] :message addr   : f004b840
[   35.316105] [ARISC ERROR] :message state  : 5
[   35.326513] [ARISC ERROR] :message attr   : 2
[   35.336705] [ARISC ERROR] :message type   : 30
[   35.346412] [ARISC ERROR] :message result : ff
[   35.355588] [ARISC WARING] :callback not install
[   35.364863] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   35.595623] [ARISC ERROR] :message process error
[   35.605322] [ARISC ERROR] :message addr   : f004b840
[   35.615058] [ARISC ERROR] :message state  : 5
[   35.624708] [ARISC ERROR] :message attr   : 2
[   35.634150] [ARISC ERROR] :message type   : 30
[   35.643417] [ARISC ERROR] :message result : ff
[   35.643432] [ARISC WARING] :callback not install
[   35.643452] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   35.974076] [ARISC ERROR] :message process error
[   35.984081] [ARISC ERROR] :message addr   : f004b840
[   35.994606] [ARISC ERROR] :message state  : 5
[   36.004985] [ARISC ERROR] :message attr   : 2
[   36.015181] [ARISC ERROR] :message type   : 30
[   36.024812] [ARISC ERROR] :message result : ff
[   36.033874] [ARISC WARING] :callback not install
[   36.043047] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   36.245478] [ARISC ERROR] :message process error
[   36.255399] [ARISC ERROR] :message addr   : f004b840
[   36.265836] [ARISC ERROR] :message state  : 5
[   36.276147] [ARISC ERROR] :message attr   : 2
[   36.286252] [ARISC ERROR] :message type   : 30
[   36.296189] [ARISC ERROR] :message result : ff
[   36.306052] [ARISC WARING] :callback not install
[   36.316014] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   36.544089] [ARISC ERROR] :message process error
[   36.554450] [ARISC ERROR] :message addr   : f004b840
[   36.564865] [ARISC ERROR] :message state  : 5
[   36.575190] [ARISC ERROR] :message attr   : 2
[   36.585301] [ARISC ERROR] :message type   : 30
[   36.594854] [ARISC ERROR] :message result : ff
[   36.603816] [ARISC WARING] :callback not install
[   36.612880] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   36.845627] [ARISC ERROR] :message process error
[   36.855452] [ARISC ERROR] :message addr   : f004b840
[   36.865804] [ARISC ERROR] :message state  : 5
[   36.876040] [ARISC ERROR] :message attr   : 2
[   36.886065] [ARISC ERROR] :message type   : 30
[   36.895531] [ARISC ERROR] :message result : ff
[   36.904395] [ARISC WARING] :callback not install
[   36.913475] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   37.144141] [ARISC ERROR] :message process error
[   37.153939] [ARISC ERROR] :message addr   : f004b840
[   37.164327] [ARISC ERROR] :message state  : 5
[   37.174562] [ARISC ERROR] :message attr   : 2
[   37.184599] [ARISC ERROR] :message type   : 30
[   37.194461] [ARISC ERROR] :message result : ff
[   37.204355] [ARISC WARING] :callback not install
[   37.214286] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   37.445632] [ARISC ERROR] :message process error
[   37.455941] [ARISC ERROR] :message addr   : f004b840
[   37.466294] [ARISC ERROR] :message state  : 5
[   37.476546] [ARISC ERROR] :message attr   : 2
[   37.486602] [ARISC ERROR] :message type   : 30
[   37.496163] [ARISC ERROR] :message result : ff
[   37.505183] [ARISC WARING] :callback not install
[   37.514292] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   37.745633] [ARISC ERROR] :message process error
[   37.755558] [ARISC ERROR] :message addr   : f004b840
[   37.766040] [ARISC ERROR] :message state  : 5
[   37.776407] [ARISC ERROR] :message attr   : 2
[   37.786561] [ARISC ERROR] :message type   : 30
[   37.796221] [ARISC ERROR] :message result : ff
[   37.805328] [ARISC WARING] :callback not install
[   37.814531] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   38.045644] [ARISC ERROR] :message process error
[   38.055279] [ARISC ERROR] :message addr   : f004b840
[   38.064957] [ARISC ERROR] :message state  : 5
[   38.074507] [ARISC ERROR] :message attr   : 2
[   38.083868] [ARISC ERROR] :message type   : 30
[   38.093058] [ARISC ERROR] :message result : ff
[   38.102174] [ARISC WARING] :callback not install
[   38.111399] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   38.345624] [ARISC ERROR] :message process error
[   38.355653] [ARISC ERROR] :message addr   : f004b840
[   38.366245] [ARISC ERROR] :message state  : 5
[   38.376714] [ARISC ERROR] :message attr   : 2
[   38.386971] [ARISC ERROR] :message type   : 30
[   38.396732] [ARISC ERROR] :message result : ff
[   38.405945] [ARISC WARING] :callback not install
[   38.415290] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   38.645631] [ARISC ERROR] :message process error
[   38.655688] [ARISC ERROR] :message addr   : f004b840
[   38.666251] [ARISC ERROR] :message state  : 5
[   38.676697] [ARISC ERROR] :message attr   : 2
[   38.686932] [ARISC ERROR] :message type   : 30
[   38.696607] [ARISC ERROR] :message result : ff
[   38.705681] [ARISC WARING] :callback not install
[   38.714855] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   38.944102] [ARISC ERROR] :message process error
[   38.953694] [ARISC ERROR] :message addr   : f004b840
[   38.963337] [ARISC ERROR] :message state  : 5
[   38.972849] [ARISC ERROR] :message attr   : 2
[   38.982173] [ARISC ERROR] :message type   : 30
[   38.991325] [ARISC ERROR] :message result : ff
[   39.000432] [ARISC WARING] :callback not install
[   39.009598] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   39.245502] [ARISC ERROR] :message process error
[   39.255447] [ARISC ERROR] :message addr   : f004b840
[   39.265887] [ARISC ERROR] :message state  : 5
[   39.276306] [ARISC ERROR] :message attr   : 2
[   39.286449] [ARISC ERROR] :message type   : 30
[   39.296010] [ARISC ERROR] :message result : ff
[   39.304969] [ARISC WARING] :callback not install
[   39.314036] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   39.545632] [ARISC ERROR] :message process error
[   39.555110] [ARISC ERROR] :message addr   : f004b840
[   39.564636] [ARISC ERROR] :message state  : 5
[   39.574031] [ARISC ERROR] :message attr   : 2
[   39.583229] [ARISC ERROR] :message type   : 30
[   39.592252] [ARISC ERROR] :message result : ff
[   39.601215] [ARISC WARING] :callback not install
[   39.610267] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   39.845631] [ARISC ERROR] :message process error
[   39.855420] [ARISC ERROR] :message addr   : f004b840
[   39.865725] [ARISC ERROR] :message state  : 5
[   39.875899] [ARISC ERROR] :message attr   : 2
[   39.885864] [ARISC ERROR] :message type   : 30
[   39.895271] [ARISC ERROR] :message result : ff
[   39.904089] [ARISC WARING] :callback not install
[   39.913017] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   40.145638] [ARISC ERROR] :message process error
[   40.155375] [ARISC ERROR] :message addr   : f004b840
[   40.165657] [ARISC ERROR] :message state  : 5
[   40.175821] [ARISC ERROR] :message attr   : 2
[   40.185771] [ARISC ERROR] :message type   : 30
[   40.195229] [ARISC ERROR] :message result : ff
[   40.204165] [ARISC WARING] :callback not install
[   40.213221] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   40.445474] [ARISC ERROR] :message process error
[   40.454919] [ARISC ERROR] :message addr   : f004b840
[   40.464420] [ARISC ERROR] :message state  : 5
[   40.473782] [ARISC ERROR] :message attr   : 2
[   40.482953] [ARISC ERROR] :message type   : 30
[   40.491983] [ARISC ERROR] :message result : ff
[   40.500909] [ARISC WARING] :callback not install
[   40.509923] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   40.745476] [ARISC ERROR] :message process error
[   40.755296] [ARISC ERROR] :message addr   : f004b840
[   40.765677] [ARISC ERROR] :message state  : 5
[   40.775927] [ARISC ERROR] :message attr   : 2
[   40.785963] [ARISC ERROR] :message type   : 30
[   40.795508] [ARISC ERROR] :message result : ff
[   40.804524] [ARISC WARING] :callback not install
[   40.813642] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   41.045491] [ARISC ERROR] :message process error
[   41.055037] [ARISC ERROR] :message addr   : f004b840
[   41.064628] [ARISC ERROR] :message state  : 5
[   41.074085] [ARISC ERROR] :message attr   : 2
[   41.083353] [ARISC ERROR] :message type   : 30
[   41.092452] [ARISC ERROR] :message result : ff
[   41.101497] [ARISC WARING] :callback not install
[   41.110622] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   41.345482] [ARISC ERROR] :message process error
[   41.355522] [ARISC ERROR] :message addr   : f004b840
[   41.366061] [ARISC ERROR] :message state  : 5
[   41.376451] [ARISC ERROR] :message attr   : 2
[   41.386622] [ARISC ERROR] :message type   : 30
[   41.396308] [ARISC ERROR] :message result : ff
[   41.405462] [ARISC WARING] :callback not install
[   41.414811] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   41.645479] [ARISC ERROR] :message process error
[   41.655497] [ARISC ERROR] :message addr   : f004b840
[   41.666032] [ARISC ERROR] :message state  : 5
[   41.676449] [ARISC ERROR] :message attr   : 2
[   41.686654] [ARISC ERROR] :message type   : 30
[   41.696320] [ARISC ERROR] :message result : ff
[   41.705395] [ARISC WARING] :callback not install
[   41.714572] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   41.945475] [ARISC ERROR] :message process error
[   41.955076] [ARISC ERROR] :message addr   : f004b840
[   41.964720] [ARISC ERROR] :message state  : 5
[   41.974228] [ARISC ERROR] :message attr   : 2
[   41.983541] [ARISC ERROR] :message type   : 30
[   41.992685] [ARISC ERROR] :message result : ff
[   42.001766] [ARISC WARING] :callback not install
[   42.010962] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   42.245475] [ARISC ERROR] :message process error
[   42.255424] [ARISC ERROR] :message addr   : f004b840
[   42.265888] [ARISC ERROR] :message state  : 5
[   42.276230] [ARISC ERROR] :message attr   : 2
[   42.286368] [ARISC ERROR] :message type   : 30
[   42.295962] [ARISC ERROR] :message result : ff
[   42.304970] [ARISC WARING] :callback not install
[   42.314085] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   42.545621] [ARISC ERROR] :message process error
[   42.555159] [ARISC ERROR] :message addr   : f004b840
[   42.564741] [ARISC ERROR] :message state  : 5
[   42.574193] [ARISC ERROR] :message attr   : 2
[   42.583453] [ARISC ERROR] :message type   : 30
[   42.592529] [ARISC ERROR] :message result : ff
[   42.601538] [ARISC WARING] :callback not install
[   42.610646] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   42.845619] [ARISC ERROR] :message process error
[   42.855473] [ARISC ERROR] :message addr   : f004b840
[   42.865857] [ARISC ERROR] :message state  : 5
[   42.876119] [ARISC ERROR] :message attr   : 2
[   42.886172] [ARISC ERROR] :message type   : 30
[   42.895667] [ARISC ERROR] :message result : ff
[   42.904592] [ARISC WARING] :callback not install
[   42.913605] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   43.145636] [ARISC ERROR] :message process error
[   43.155478] [ARISC ERROR] :message addr   : f004b840
[   43.165881] [ARISC ERROR] :message state  : 5
[   43.176165] [ARISC ERROR] :message attr   : 2
[   43.186235] [ARISC ERROR] :message type   : 30
[   43.195803] [ARISC ERROR] :message result : ff
[   43.204833] [ARISC WARING] :callback not install
[   43.213952] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   43.445637] [ARISC ERROR] :message process error
[   43.455185] [ARISC ERROR] :message addr   : f004b840
[   43.464866] [ARISC ERROR] :message state  : 5
[   43.474358] [ARISC ERROR] :message attr   : 2
[   43.483657] [ARISC ERROR] :message type   : 30
[   43.492759] [ARISC ERROR] :message result : ff
[   43.501794] [ARISC WARING] :callback not install
[   43.510921] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   43.745633] [ARISC ERROR] :message process error
[   43.755592] [ARISC ERROR] :message addr   : f004b840
[   43.766106] [ARISC ERROR] :message state  : 5
[   43.776499] [ARISC ERROR] :message attr   : 2
[   43.786679] [ARISC ERROR] :message type   : 30
[   43.796350] [ARISC ERROR] :message result : ff
[   43.805475] [ARISC WARING] :callback not install
[   43.814710] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   44.045643] [ARISC ERROR] :message process error
[   44.055302] [ARISC ERROR] :message addr   : f004b840
[   44.065001] [ARISC ERROR] :message state  : 5
[   44.074565] [ARISC ERROR] :message attr   : 2
[   44.083959] [ARISC ERROR] :message type   : 30
[   44.093165] [ARISC ERROR] :message result : ff
[   44.102302] [ARISC WARING] :callback not install
[   44.111588] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   44.345659] [ARISC ERROR] :message process error
[   44.355741] [ARISC ERROR] :message addr   : f004b840
[   44.366367] [ARISC ERROR] :message state  : 5
[   44.376868] [ARISC ERROR] :message attr   : 2
[   44.387168] [ARISC ERROR] :message type   : 30
[   44.396946] [ARISC ERROR] :message result : ff
[   44.406198] [ARISC WARING] :callback not install
[   44.415537] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   44.644103] [ARISC ERROR] :message process error
[   44.654197] [ARISC ERROR] :message addr   : f004b840
[   44.664800] [ARISC ERROR] :message state  : 5
[   44.675283] [ARISC ERROR] :message attr   : 2
[   44.685571] [ARISC ERROR] :message type   : 30
[   44.695284] [ARISC ERROR] :message result : ff
[   44.704415] [ARISC WARING] :callback not install
[   44.713639] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   44.944096] [ARISC ERROR] :message process error
[   44.953742] [ARISC ERROR] :message addr   : f004b840
[   44.963431] [ARISC ERROR] :message state  : 5
[   44.973004] [ARISC ERROR] :message attr   : 2
[   44.982376] [ARISC ERROR] :message type   : 30
[   44.991576] [ARISC ERROR] :message result : ff
[   45.000720] [ARISC WARING] :callback not install
[   45.009922] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   45.243954] [ARISC ERROR] :message process error
[   45.253934] [ARISC ERROR] :message addr   : f004b840
[   45.264422] [ARISC ERROR] :message state  : 5
[   45.274789] [ARISC ERROR] :message attr   : 2
[   45.284954] [ARISC ERROR] :message type   : 30
[   45.294546] [ARISC ERROR] :message result : ff
[   45.303554] [ARISC WARING] :callback not install
[   45.312652] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   45.544098] [ARISC ERROR] :message process error
[   45.553620] [ARISC ERROR] :message addr   : f004b840
[   45.563182] [ARISC ERROR] :message state  : 5
[   45.572624] [ARISC ERROR] :message attr   : 2
[   45.581861] [ARISC ERROR] :message type   : 30
[   45.590919] [ARISC ERROR] :message result : ff
[   45.599898] [ARISC WARING] :callback not install
[   45.608996] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   45.844102] [ARISC ERROR] :message process error
[   45.853941] [ARISC ERROR] :message addr   : f004b840
[   45.864286] [ARISC ERROR] :message state  : 5
[   45.874508] [ARISC ERROR] :message attr   : 2
[   45.884530] [ARISC ERROR] :message type   : 30
[   45.893969] [ARISC ERROR] :message result : ff
[   45.902826] [ARISC WARING] :callback not install
[   45.911781] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   46.144133] [ARISC ERROR] :message process error
[   46.153897] [ARISC ERROR] :message addr   : f004b840
[   46.164213] [ARISC ERROR] :message state  : 5
[   46.174419] [ARISC ERROR] :message attr   : 2
[   46.184421] [ARISC ERROR] :message type   : 30
[   46.193902] [ARISC ERROR] :message result : ff
[   46.202854] [ARISC WARING] :callback not install
[   46.211913] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   46.444099] [ARISC ERROR] :message process error
[   46.453573] [ARISC ERROR] :message addr   : f004b840
[   46.463087] [ARISC ERROR] :message state  : 5
[   46.472474] [ARISC ERROR] :message attr   : 2
[   46.481659] [ARISC ERROR] :message type   : 30
[   46.490671] [ARISC ERROR] :message result : ff
[   46.499608] [ARISC WARING] :callback not install
[   46.508636] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   46.744108] [ARISC ERROR] :message process error
[   46.753982] [ARISC ERROR] :message addr   : f004b840
[   46.764550] [ARISC ERROR] :message state  : 5
[   46.774845] [ARISC ERROR] :message attr   : 2
[   46.784934] [ARISC ERROR] :message type   : 30
[   46.794523] [ARISC ERROR] :message result : ff
[   46.803580] [ARISC WARING] :callback not install
[   46.812726] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   47.044130] [ARISC ERROR] :message process error
[   47.053707] [ARISC ERROR] :message addr   : f004b840
[   47.063322] [ARISC ERROR] :message state  : 5
[   47.072820] [ARISC ERROR] :message attr   : 2
[   47.082115] [ARISC ERROR] :message type   : 30
[   47.091238] [ARISC ERROR] :message result : ff
[   47.100298] [ARISC WARING] :callback not install
[   47.109427] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   47.344102] [ARISC ERROR] :message process error
[   47.354059] [ARISC ERROR] :message addr   : f004b840
[   47.364559] [ARISC ERROR] :message state  : 5
[   47.374936] [ARISC ERROR] :message attr   : 2
[   47.385109] [ARISC ERROR] :message type   : 30
[   47.394782] [ARISC ERROR] :message result : ff
[   47.403952] [ARISC WARING] :callback not install
[   47.413198] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   47.644107] [ARISC ERROR] :message process error
[   47.654099] [ARISC ERROR] :message addr   : f004b840
[   47.664590] [ARISC ERROR] :message state  : 5
[   47.674958] [ARISC ERROR] :message attr   : 2
[   47.685127] [ARISC ERROR] :message type   : 30
[   47.694734] [ARISC ERROR] :message result : ff
[   47.703776] [ARISC WARING] :callback not install
[   47.712911] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   47.944098] [ARISC ERROR] :message process error
[   47.953656] [ARISC ERROR] :message addr   : f004b840
[   47.963258] [ARISC ERROR] :message state  : 5
[   47.972732] [ARISC ERROR] :message attr   : 2
[   47.982006] [ARISC ERROR] :message type   : 30
[   47.991102] [ARISC ERROR] :message result : ff
[   48.000155] [ARISC WARING] :callback not install
[   48.009273] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   48.223969] [ARISC ERROR] :message process error
[   48.233876] [ARISC ERROR] :message addr   : f004b840
[   48.244264] [ARISC ERROR] :message state  : 5
[   48.254550] [ARISC ERROR] :message attr   : 2
[   48.264627] [ARISC ERROR] :message type   : 30
[   48.274144] [ARISC ERROR] :message result : ff
[   48.283093] [ARISC WARING] :callback not install
[   48.292123] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   48.624124] [ARISC ERROR] :message process error
[   48.633905] [ARISC ERROR] :message addr   : f004b840
[   48.644202] [ARISC ERROR] :message state  : 5
[   48.654380] [ARISC ERROR] :message attr   : 2
[   48.664359] [ARISC ERROR] :message type   : 30
[   48.674143] [ARISC ERROR] :message result : ff
[   48.683885] [ARISC WARING] :callback not install
[   48.693700] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   49.014126] [ARISC ERROR] :message process error
[   49.024382] [ARISC ERROR] :message addr   : f004b840
[   49.034671] [ARISC ERROR] :message state  : 5
[   49.044837] [ARISC ERROR] :message attr   : 2
[   49.054809] [ARISC ERROR] :message type   : 30
[   49.064220] [ARISC ERROR] :message result : ff
[   49.073049] [ARISC WARING] :callback not install
[   49.081981] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   49.295646] [ARISC ERROR] :message process error
[   49.305429] [ARISC ERROR] :message addr   : f004b840
[   49.315755] [ARISC ERROR] :message state  : 5
[   49.325956] [ARISC ERROR] :message attr   : 2
[   49.335954] [ARISC ERROR] :message type   : 30
[   49.345441] [ARISC ERROR] :message result : ff
[   49.354411] [ARISC WARING] :callback not install
[   49.363465] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   49.624127] [ARISC ERROR] :message process error
[   49.633995] [ARISC ERROR] :message addr   : f004b840
[   49.644433] [ARISC ERROR] :message state  : 5
[   49.654754] [ARISC ERROR] :message attr   : 2
[   49.664865] [ARISC ERROR] :message type   : 30
[   49.674802] [ARISC ERROR] :message result : ff
[   49.684675] [ARISC WARING] :callback not install
[   49.694637] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   49.924098] [ARISC ERROR] :message process error
[   49.934471] [ARISC ERROR] :message addr   : f004b840
[   49.944884] [ARISC ERROR] :message state  : 5
[   49.955179] [ARISC ERROR] :message attr   : 2
[   49.965275] [ARISC ERROR] :message type   : 30
[   49.974864] [ARISC ERROR] :message result : ff
[   49.983940] [ARISC WARING] :callback not install
[   49.993091] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   50.223821] [ARISC ERROR] :message process error
[   50.233797] [ARISC ERROR] :message addr   : f004b840
[   50.244335] [ARISC ERROR] :message state  : 5
[   50.254757] [ARISC ERROR] :message attr   : 2
[   50.264975] [ARISC ERROR] :message type   : 30
[   50.274688] [ARISC ERROR] :message result : ff
[   50.283870] [ARISC WARING] :callback not install
[   50.293140] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   50.523950] [ARISC ERROR] :message process error
[   50.533644] [ARISC ERROR] :message addr   : f004b840
[   50.543369] [ARISC ERROR] :message state  : 5
[   50.552985] [ARISC ERROR] :message attr   : 2
[   50.562402] [ARISC ERROR] :message type   : 30
[   50.571632] [ARISC ERROR] :message result : ff
[   50.580806] [ARISC WARING] :callback not install
[   50.590068] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   50.823951] [ARISC ERROR] :message process error
[   50.833976] [ARISC ERROR] :message addr   : f004b840
[   50.844513] [ARISC ERROR] :message state  : 5
[   50.854940] [ARISC ERROR] :message attr   : 2
[   50.865161] [ARISC ERROR] :message type   : 30
[   50.874810] [ARISC ERROR] :message result : ff
[   50.883877] [ARISC WARING] :callback not install
[   50.893034] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   51.123952] [ARISC ERROR] :message process error
[   51.133886] [ARISC ERROR] :message addr   : f004b840
[   51.144330] [ARISC ERROR] :message state  : 5
[   51.154668] [ARISC ERROR] :message attr   : 2
[   51.164810] [ARISC ERROR] :message type   : 30
[   51.174380] [ARISC ERROR] :message result : ff
[   51.183365] [ARISC WARING] :callback not install
[   51.192417] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   51.423941] [ARISC ERROR] :message process error
[   51.433419] [ARISC ERROR] :message addr   : f004b840
[   51.442938] [ARISC ERROR] :message state  : 5
[   51.452354] [ARISC ERROR] :message attr   : 2
[   51.461572] [ARISC ERROR] :message type   : 30
[   51.470613] [ARISC ERROR] :message result : ff
[   51.479585] [ARISC WARING] :callback not install
[   51.488672] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   51.723948] [ARISC ERROR] :message process error
[   51.733781] [ARISC ERROR] :message addr   : f004b840
[   51.744121] [ARISC ERROR] :message state  : 5
[   51.754348] [ARISC ERROR] :message attr   : 2
[   51.764372] [ARISC ERROR] :message type   : 30
[   51.773821] [ARISC ERROR] :message result : ff
[   51.782698] [ARISC WARING] :callback not install
[   51.791653] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   52.023969] [ARISC ERROR] :message process error
[   52.033356] [ARISC ERROR] :message addr   : f004b840
[   52.042773] [ARISC ERROR] :message state  : 5
[   52.052082] [ARISC ERROR] :message attr   : 2
[   52.061191] [ARISC ERROR] :message type   : 30
[   52.070130] [ARISC ERROR] :message result : ff
[   52.079003] [ARISC WARING] :callback not install
[   52.088036] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   52.324069] [ARISC ERROR] :message process error
[   52.333862] [ARISC ERROR] :message addr   : f004b840
[   52.344242] [ARISC ERROR] :message state  : 5
[   52.354477] [ARISC ERROR] :message attr   : 2
[   52.364513] [ARISC ERROR] :message type   : 30
[   52.374007] [ARISC ERROR] :message result : ff
[   52.382993] [ARISC WARING] :callback not install
[   52.392089] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   52.595623] [ARISC ERROR] :message process error
[   52.605095] [ARISC ERROR] :message addr   : f004b840
[   52.614628] [ARISC ERROR] :message state  : 5
[   52.624080] [ARISC ERROR] :message attr   : 2
[   52.633332] [ARISC ERROR] :message type   : 30
[   52.642073] [ARISC ERROR] :message result : ff
[   52.642089] [ARISC WARING] :callback not install
[   52.642108] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   52.974074] [ARISC ERROR] :message process error
[   52.983117] [ARISC ERROR] :message addr   : f004b840
[   52.992736] [ARISC ERROR] :message state  : 5
[   53.002213] [ARISC ERROR] :message attr   : 2
[   53.011509] [ARISC ERROR] :message type   : 30
[   53.020636] [ARISC ERROR] :message result : ff
[   53.029686] [ARISC WARING] :callback not install
[   53.038822] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   53.263386] [ARISC ERROR] :message process error
[   53.273313] [ARISC ERROR] :message addr   : f004b840
[   53.283814] [ARISC ERROR] :message state  : 5
[   53.294205] [ARISC ERROR] :message attr   : 2
[   53.304400] [ARISC ERROR] :message type   : 30
[   53.314066] [ARISC ERROR] :message result : ff
[   53.323206] [ARISC WARING] :callback not install
[   53.332457] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   53.613540] [ARISC ERROR] :message process error
[   53.623234] [ARISC ERROR] :message addr   : f004b840
[   53.632967] [ARISC ERROR] :message state  : 5
[   53.642583] [ARISC ERROR] :message attr   : 2
[   53.642600] [ARISC ERROR] :message type   : 30
[   53.642615] [ARISC ERROR] :message result : ff
[   53.642628] [ARISC WARING] :callback not install
[   53.642647] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   53.983991] [ARISC ERROR] :message process error
[   53.993918] [ARISC ERROR] :message addr   : f004b840
[   54.004354] [ARISC ERROR] :message state  : 5
[   54.014695] [ARISC ERROR] :message attr   : 2
[   54.024837] [ARISC ERROR] :message type   : 30
[   54.034408] [ARISC ERROR] :message result : ff
[   54.043420] [ARISC WARING] :callback not install
[   54.052524] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   54.212146] [ARISC ERROR] :message process error
[   54.221955] [ARISC ERROR] :message addr   : f004b840
[   54.232309] [ARISC ERROR] :message state  : 5
[   54.242527] [ARISC ERROR] :message attr   : 2
[   54.252554] [ARISC ERROR] :message type   : 30
[   54.262379] [ARISC ERROR] :message result : ff
[   54.272142] [ARISC WARING] :callback not install
[   54.282005] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   54.562291] [ARISC ERROR] :message process error
[   54.572535] [ARISC ERROR] :message addr   : f004b840
[   54.582865] [ARISC ERROR] :message state  : 5
[   54.593076] [ARISC ERROR] :message attr   : 2
[   54.603097] [ARISC ERROR] :message type   : 30
[   54.612541] [ARISC ERROR] :message result : ff
[   54.621457] [ARISC WARING] :callback not install
[   54.630458] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   54.812296] [ARISC ERROR] :message process error
[   54.821977] [ARISC ERROR] :message addr   : f004b840
[   54.832180] [ARISC ERROR] :message state  : 5
[   54.842280] [ARISC ERROR] :message attr   : 2
[   54.852173] [ARISC ERROR] :message type   : 30
[   54.861491] [ARISC ERROR] :message result : ff
[   54.870247] [ARISC WARING] :callback not install
[   54.879071] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   55.062310] [ARISC ERROR] :message process error
[   55.071557] [ARISC ERROR] :message addr   : f004b840
[   55.080871] [ARISC ERROR] :message state  : 5
[   55.090068] [ARISC ERROR] :message attr   : 2
[   55.099043] [ARISC ERROR] :message type   : 30
[   55.107877] [ARISC ERROR] :message result : ff
[   55.116657] [ARISC WARING] :callback not install
[   55.125548] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   55.312291] [ARISC ERROR] :message process error
[   55.321943] [ARISC ERROR] :message addr   : f004b840
[   55.332191] [ARISC ERROR] :message state  : 5
[   55.342338] [ARISC ERROR] :message attr   : 2
[   55.352300] [ARISC ERROR] :message type   : 30
[   55.361740] [ARISC ERROR] :message result : ff
[   55.370656] [ARISC WARING] :callback not install
[   55.379633] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   55.612295] [ARISC ERROR] :message process error
[   55.621741] [ARISC ERROR] :message addr   : f004b840
[   55.631234] [ARISC ERROR] :message state  : 5
[   55.640595] [ARISC ERROR] :message attr   : 2
[   55.640612] [ARISC ERROR] :message type   : 30
[   55.640627] [ARISC ERROR] :message result : ff
[   55.640640] [ARISC WARING] :callback not install
[   55.640659] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   55.912299] [ARISC ERROR] :message process error
[   55.921267] [ARISC ERROR] :message addr   : f004b840
[   55.930819] [ARISC ERROR] :message state  : 5
[   55.940255] [ARISC ERROR] :message attr   : 2
[   55.949473] [ARISC ERROR] :message type   : 30
[   55.958555] [ARISC ERROR] :message result : ff
[   55.967563] [ARISC WARING] :callback not install
[   55.976669] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   56.212144] [ARISC ERROR] :message process error
[   56.222051] [ARISC ERROR] :message addr   : f004b840
[   56.232545] [ARISC ERROR] :message state  : 5
[   56.242931] [ARISC ERROR] :message attr   : 2
[   56.253118] [ARISC ERROR] :message type   : 30
[   56.262787] [ARISC ERROR] :message result : ff
[   56.271945] [ARISC WARING] :callback not install
[   56.281195] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   56.462291] [ARISC ERROR] :message process error
[   56.471941] [ARISC ERROR] :message addr   : f004b840
[   56.481649] [ARISC ERROR] :message state  : 5
[   56.491225] [ARISC ERROR] :message attr   : 2
[   56.500631] [ARISC ERROR] :message type   : 30
[   56.509805] [ARISC ERROR] :message result : ff
[   56.518943] [ARISC WARING] :callback not install
[   56.528182] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   56.712298] [ARISC ERROR] :message process error
[   56.722275] [ARISC ERROR] :message addr   : f004b840
[   56.732784] [ARISC ERROR] :message state  : 5
[   56.743187] [ARISC ERROR] :message attr   : 2
[   56.753389] [ARISC ERROR] :message type   : 30
[   56.763003] [ARISC ERROR] :message result : ff
[   56.772043] [ARISC WARING] :callback not install
[   56.781259] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   56.962313] [ARISC ERROR] :message process error
[   56.971860] [ARISC ERROR] :message addr   : f004b840
[   56.981465] [ARISC ERROR] :message state  : 5
[   56.990947] [ARISC ERROR] :message attr   : 2
[   57.000265] [ARISC ERROR] :message type   : 30
[   57.009353] [ARISC ERROR] :message result : ff
[   57.018408] [ARISC WARING] :callback not install
[   57.027576] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   57.212143] [ARISC ERROR] :message process error
[   57.222068] [ARISC ERROR] :message addr   : f004b840
[   57.232516] [ARISC ERROR] :message state  : 5
[   57.242872] [ARISC ERROR] :message attr   : 2
[   57.253034] [ARISC ERROR] :message type   : 30
[   57.262609] [ARISC ERROR] :message result : ff
[   57.271620] [ARISC WARING] :callback not install
[   57.280708] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   57.462295] [ARISC ERROR] :message process error
[   57.471787] [ARISC ERROR] :message addr   : f004b840
[   57.481344] [ARISC ERROR] :message state  : 5
[   57.490776] [ARISC ERROR] :message attr   : 2
[   57.499993] [ARISC ERROR] :message type   : 30
[   57.508672] [ARISC ERROR] :message result : ff
[   57.516756] [ARISC WARING] :callback not install
[   57.524947] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   57.762302] [ARISC ERROR] :message process error
[   57.771218] [ARISC ERROR] :message addr   : f004b840
[   57.780661] [ARISC ERROR] :message state  : 5
[   57.789959] [ARISC ERROR] :message attr   : 2
[   57.799090] [ARISC ERROR] :message type   : 30
[   57.808042] [ARISC ERROR] :message result : ff
[   57.816955] [ARISC WARING] :callback not install
[   57.825973] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   58.012298] [ARISC ERROR] :message process error
[   58.021714] [ARISC ERROR] :message addr   : f004b840
[   58.031188] [ARISC ERROR] :message state  : 5
[   58.040540] [ARISC ERROR] :message attr   : 2
[   58.049668] [ARISC ERROR] :message type   : 30
[   58.058324] [ARISC ERROR] :message result : ff
[   58.066440] [ARISC WARING] :callback not install
[   58.074623] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   58.312293] [ARISC ERROR] :message process error
[   58.321301] [ARISC ERROR] :message addr   : f004b840
[   58.330890] [ARISC ERROR] :message state  : 5
[   58.340372] [ARISC ERROR] :message attr   : 2
[   58.349629] [ARISC ERROR] :message type   : 30
[   58.358740] [ARISC ERROR] :message result : ff
[   58.367781] [ARISC WARING] :callback not install
[   58.376928] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   58.612292] [ARISC ERROR] :message process error
[   58.621851] [ARISC ERROR] :message addr   : f004b840
[   58.631474] [ARISC ERROR] :message state  : 5
[   58.640964] [ARISC ERROR] :message attr   : 2
[   58.640980] [ARISC ERROR] :message type   : 30
[   58.640995] [ARISC ERROR] :message result : ff
[   58.641008] [ARISC WARING] :callback not install
[   58.641027] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   58.904096] [ARISC ERROR] :message process error
[   58.913187] [ARISC ERROR] :message addr   : f004b840
[   58.922824] [ARISC ERROR] :message state  : 5
[   58.932362] [ARISC ERROR] :message attr   : 2
[   58.941733] [ARISC ERROR] :message type   : 30
[   58.950885] [ARISC ERROR] :message result : ff
[   58.959961] [ARISC WARING] :callback not install
[   58.969142] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   59.162313] [ARISC ERROR] :message process error
[   59.172290] [ARISC ERROR] :message addr   : f004b840
[   59.182830] [ARISC ERROR] :message state  : 5
[   59.193254] [ARISC ERROR] :message attr   : 2
[   59.203481] [ARISC ERROR] :message type   : 30
[   59.213186] [ARISC ERROR] :message result : ff
[   59.222378] [ARISC WARING] :callback not install
[   59.231659] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   59.412289] [ARISC ERROR] :message process error
[   59.421953] [ARISC ERROR] :message addr   : f004b840
[   59.431684] [ARISC ERROR] :message state  : 5
[   59.441289] [ARISC ERROR] :message attr   : 2
[   59.450716] [ARISC ERROR] :message type   : 30
[   59.459902] [ARISC ERROR] :message result : ff
[   59.469063] [ARISC WARING] :callback not install
[   59.478315] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   59.662298] [ARISC ERROR] :message process error
[   59.672274] [ARISC ERROR] :message addr   : f004b840
[   59.682765] [ARISC ERROR] :message state  : 5
[   59.693148] [ARISC ERROR] :message attr   : 2
[   59.703335] [ARISC ERROR] :message type   : 30
[   59.712933] [ARISC ERROR] :message result : ff
[   59.721947] [ARISC WARING] :callback not install
[   59.731051] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   59.912297] [ARISC ERROR] :message process error
[   59.921802] [ARISC ERROR] :message addr   : f004b840
[   59.931371] [ARISC ERROR] :message state  : 5
[   59.940819] [ARISC ERROR] :message attr   : 2
[   59.950095] [ARISC ERROR] :message type   : 30
[   59.959135] [ARISC ERROR] :message result : ff
[   59.968145] [ARISC WARING] :callback not install
[   59.977241] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   60.162309] [ARISC ERROR] :message process error
[   60.172147] [ARISC ERROR] :message addr   : f004b840
[   60.182511] [ARISC ERROR] :message state  : 5
[   60.192771] [ARISC ERROR] :message attr   : 2
[   60.202838] [ARISC ERROR] :message type   : 30
[   60.212324] [ARISC ERROR] :message result : ff
[   60.221234] [ARISC WARING] :callback not install
[   60.230244] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   60.412127] [ARISC ERROR] :message process error
[   60.421533] [ARISC ERROR] :message addr   : f004b840
[   60.430991] [ARISC ERROR] :message state  : 5
[   60.440330] [ARISC ERROR] :message attr   : 2
[   60.449453] [ARISC ERROR] :message type   : 30
[   60.458025] [ARISC ERROR] :message result : ff
[   60.466033] [ARISC WARING] :callback not install
[   60.474120] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   60.662141] [ARISC ERROR] :message process error
[   60.670949] [ARISC ERROR] :message addr   : f004b840
[   60.680283] [ARISC ERROR] :message state  : 5
[   60.689471] [ARISC ERROR] :message attr   : 2
[   60.698498] [ARISC ERROR] :message type   : 30
[   60.707334] [ARISC ERROR] :message result : ff
[   60.716128] [ARISC WARING] :callback not install
[   60.725037] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   60.912132] [ARISC ERROR] :message process error
[   60.921411] [ARISC ERROR] :message addr   : f004b840
[   60.930755] [ARISC ERROR] :message state  : 5
[   60.939958] [ARISC ERROR] :message attr   : 2
[   60.948985] [ARISC ERROR] :message type   : 30
[   60.957510] [ARISC ERROR] :message result : ff
[   60.965525] [ARISC WARING] :callback not install
[   60.973631] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   61.162150] [ARISC ERROR] :message process error
[   61.171029] [ARISC ERROR] :message addr   : f004b840
[   61.180479] [ARISC ERROR] :message state  : 5
[   61.189782] [ARISC ERROR] :message attr   : 2
[   61.198910] [ARISC ERROR] :message type   : 30
[   61.207874] [ARISC ERROR] :message result : ff
[   61.216786] [ARISC WARING] :callback not install
[   61.225807] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   61.412129] [ARISC ERROR] :message process error
[   61.421527] [ARISC ERROR] :message addr   : f004b840
[   61.430994] [ARISC ERROR] :message state  : 5
[   61.440357] [ARISC ERROR] :message attr   : 2
[   61.449492] [ARISC ERROR] :message type   : 30
[   61.458146] [ARISC ERROR] :message result : ff
[   61.466292] [ARISC WARING] :callback not install
[   61.474515] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   61.662143] [ARISC ERROR] :message process error
[   61.671163] [ARISC ERROR] :message addr   : f004b840
[   61.680750] [ARISC ERROR] :message state  : 5
[   61.690220] [ARISC ERROR] :message attr   : 2
[   61.699475] [ARISC ERROR] :message type   : 30
[   61.708602] [ARISC ERROR] :message result : ff
[   61.717647] [ARISC WARING] :callback not install
[   61.726792] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   61.962144] [ARISC ERROR] :message process error
[   61.971679] [ARISC ERROR] :message addr   : f004b840
[   61.981280] [ARISC ERROR] :message state  : 5
[   61.990758] [ARISC ERROR] :message attr   : 2
[   62.000063] [ARISC ERROR] :message type   : 30
[   62.008829] [ARISC ERROR] :message result : ff
[   62.017105] [ARISC WARING] :callback not install
[   62.025493] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   62.212132] [ARISC ERROR] :message process error
[   62.221291] [ARISC ERROR] :message addr   : f004b840
[   62.231028] [ARISC ERROR] :message state  : 5
[   62.240640] [ARISC ERROR] :message attr   : 2
[   62.250076] [ARISC ERROR] :message type   : 30
[   62.259281] [ARISC ERROR] :message result : ff
[   62.268452] [ARISC WARING] :callback not install
[   62.277723] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   62.462289] [ARISC ERROR] :message process error
[   62.471966] [ARISC ERROR] :message addr   : f004b840
[   62.481704] [ARISC ERROR] :message state  : 5
[   62.491321] [ARISC ERROR] :message attr   : 2
[   62.500755] [ARISC ERROR] :message type   : 30
[   62.509585] [ARISC ERROR] :message result : ff
[   62.517861] [ARISC WARING] :callback not install
[   62.526248] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   62.712287] [ARISC ERROR] :message process error
[   62.721400] [ARISC ERROR] :message addr   : f004b840
[   62.731036] [ARISC ERROR] :message state  : 5
[   62.740553] [ARISC ERROR] :message attr   : 2
[   62.749850] [ARISC ERROR] :message type   : 30
[   62.759009] [ARISC ERROR] :message result : ff
[   62.768087] [ARISC WARING] :callback not install
[   62.777257] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   63.012299] [ARISC ERROR] :message process error
[   63.021873] [ARISC ERROR] :message addr   : f004b840
[   63.031510] [ARISC ERROR] :message state  : 5
[   63.041021] [ARISC ERROR] :message attr   : 2
[   63.050357] [ARISC ERROR] :message type   : 30
[   63.059077] [ARISC ERROR] :message result : ff
[   63.067247] [ARISC WARING] :callback not install
[   63.075515] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   63.262143] [ARISC ERROR] :message process error
[   63.271156] [ARISC ERROR] :message addr   : f004b840
[   63.280702] [ARISC ERROR] :message state  : 5
[   63.290128] [ARISC ERROR] :message attr   : 2
[   63.299330] [ARISC ERROR] :message type   : 30
[   63.308389] [ARISC ERROR] :message result : ff
[   63.317378] [ARISC WARING] :callback not install
[   63.326463] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   63.562293] [ARISC ERROR] :message process error
[   63.571749] [ARISC ERROR] :message addr   : f004b840
[   63.581283] [ARISC ERROR] :message state  : 5
[   63.590688] [ARISC ERROR] :message attr   : 2
[   63.599871] [ARISC ERROR] :message type   : 30
[   63.608526] [ARISC ERROR] :message result : ff
[   63.616592] [ARISC WARING] :callback not install
[   63.624799] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   63.862300] [ARISC ERROR] :message process error
[   63.871200] [ARISC ERROR] :message addr   : f004b840
[   63.880631] [ARISC ERROR] :message state  : 5
[   63.889917] [ARISC ERROR] :message attr   : 2
[   63.899026] [ARISC ERROR] :message type   : 30
[   63.907951] [ARISC ERROR] :message result : ff
[   63.916836] [ARISC WARING] :callback not install
[   63.925813] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   64.112294] [ARISC ERROR] :message process error
[   64.121695] [ARISC ERROR] :message addr   : f004b840
[   64.121713] [ARISC ERROR] :message state  : 5
[   64.121728] [ARISC ERROR] :message attr   : 2
[   64.121743] [ARISC ERROR] :message type   : 30
[   64.121757] [ARISC ERROR] :message result : ff
[   64.121771] [ARISC WARING] :callback not install
[   64.121788] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   64.404084] [ARISC ERROR] :message process error
[   64.413009] [ARISC ERROR] :message addr   : f004b840
[   64.422525] [ARISC ERROR] :message state  : 5
[   64.431921] [ARISC ERROR] :message attr   : 2
[   64.441096] [ARISC ERROR] :message type   : 30
[   64.450095] [ARISC ERROR] :message result : ff
[   64.459007] [ARISC WARING] :callback not install
[   64.468021] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   64.662297] [ARISC ERROR] :message process error
[   64.672105] [ARISC ERROR] :message addr   : f004b840
[   64.682506] [ARISC ERROR] :message state  : 5
[   64.692796] [ARISC ERROR] :message attr   : 2
[   64.702885] [ARISC ERROR] :message type   : 30
[   64.712454] [ARISC ERROR] :message result : ff
[   64.721486] [ARISC WARING] :callback not install
[   64.730616] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   64.912289] [ARISC ERROR] :message process error
[   64.921809] [ARISC ERROR] :message addr   : f004b840
[   64.931388] [ARISC ERROR] :message state  : 5
[   64.940844] [ARISC ERROR] :message attr   : 2
[   64.950131] [ARISC ERROR] :message type   : 30
[   64.959199] [ARISC ERROR] :message result : ff
[   64.968227] [ARISC WARING] :callback not install
[   64.977346] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   65.162306] [ARISC ERROR] :message process error
[   65.172226] [ARISC ERROR] :message addr   : f004b840
[   65.182724] [ARISC ERROR] :message state  : 5
[   65.193116] [ARISC ERROR] :message attr   : 2
[   65.203311] [ARISC ERROR] :message type   : 30
[   65.212979] [ARISC ERROR] :message result : ff
[   65.222138] [ARISC WARING] :callback not install
[   65.231380] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   65.412289] [ARISC ERROR] :message process error
[   65.421927] [ARISC ERROR] :message addr   : f004b840
[   65.431622] [ARISC ERROR] :message state  : 5
[   65.441190] [ARISC ERROR] :message attr   : 2
[   65.450576] [ARISC ERROR] :message type   : 30
[   65.459730] [ARISC ERROR] :message result : ff
[   65.468854] [ARISC WARING] :callback not install
[   65.478084] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   65.662296] [ARISC ERROR] :message process error
[   65.672277] [ARISC ERROR] :message addr   : f004b840
[   65.682799] [ARISC ERROR] :message state  : 5
[   65.693227] [ARISC ERROR] :message attr   : 2
[   65.703467] [ARISC ERROR] :message type   : 30
[   65.713123] [ARISC ERROR] :message result : ff
[   65.722196] [ARISC WARING] :callback not install
[   65.731370] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   65.912292] [ARISC ERROR] :message process error
[   65.921856] [ARISC ERROR] :message addr   : f004b840
[   65.931493] [ARISC ERROR] :message state  : 5
[   65.941010] [ARISC ERROR] :message attr   : 2
[   65.950354] [ARISC ERROR] :message type   : 30
[   65.959073] [ARISC ERROR] :message result : ff
[   65.967232] [ARISC WARING] :callback not install
[   65.975496] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   66.162307] [ARISC ERROR] :message process error
[   66.171301] [ARISC ERROR] :message addr   : f004b840
[   66.180821] [ARISC ERROR] :message state  : 5
[   66.190223] [ARISC ERROR] :message attr   : 2
[   66.199402] [ARISC ERROR] :message type   : 30
[   66.208443] [ARISC ERROR] :message result : ff
[   66.217419] [ARISC WARING] :callback not install
[   66.226492] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   66.462296] [ARISC ERROR] :message process error
[   66.471750] [ARISC ERROR] :message addr   : f004b840
[   66.481276] [ARISC ERROR] :message state  : 5
[   66.490676] [ARISC ERROR] :message attr   : 2
[   66.499849] [ARISC ERROR] :message type   : 30
[   66.508483] [ARISC ERROR] :message result : ff
[   66.516523] [ARISC WARING] :callback not install
[   66.524644] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   66.762304] [ARISC ERROR] :message process error
[   66.771152] [ARISC ERROR] :message addr   : f004b840
[   66.780524] [ARISC ERROR] :message state  : 5
[   66.789752] [ARISC ERROR] :message attr   : 2
[   66.798827] [ARISC ERROR] :message type   : 30
[   66.807702] [ARISC ERROR] :message result : ff
[   66.816538] [ARISC WARING] :callback not install
[   66.825485] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   67.012304] [ARISC ERROR] :message process error
[   67.021640] [ARISC ERROR] :message addr   : f004b840
[   67.031047] [ARISC ERROR] :message state  : 5
[   67.040329] [ARISC ERROR] :message attr   : 2
[   67.049389] [ARISC ERROR] :message type   : 30
[   67.057950] [ARISC ERROR] :message result : ff
[   67.065994] [ARISC WARING] :callback not install
[   67.074120] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   67.262154] [ARISC ERROR] :message process error
[   67.271072] [ARISC ERROR] :message addr   : f004b840
[   67.280560] [ARISC ERROR] :message state  : 5
[   67.289900] [ARISC ERROR] :message attr   : 2
[   67.299061] [ARISC ERROR] :message type   : 30
[   67.308038] [ARISC ERROR] :message result : ff
[   67.316975] [ARISC WARING] :callback not install
[   67.326000] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   67.512290] [ARISC ERROR] :message process error
[   67.521702] [ARISC ERROR] :message addr   : f004b840
[   67.531183] [ARISC ERROR] :message state  : 5
[   67.540537] [ARISC ERROR] :message attr   : 2
[   67.549674] [ARISC ERROR] :message type   : 30
[   67.558345] [ARISC ERROR] :message result : ff
[   67.566475] [ARISC WARING] :callback not install
[   67.574690] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   67.812295] [ARISC ERROR] :message process error
[   67.821307] [ARISC ERROR] :message addr   : f004b840
[   67.830892] [ARISC ERROR] :message state  : 5
[   67.840351] [ARISC ERROR] :message attr   : 2
[   67.849597] [ARISC ERROR] :message type   : 30
[   67.858707] [ARISC ERROR] :message result : ff
[   67.867734] [ARISC WARING] :callback not install
[   67.876856] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   68.112298] [ARISC ERROR] :message process error
[   68.121857] [ARISC ERROR] :message addr   : f004b840
[   68.121875] [ARISC ERROR] :message state  : 5
[   68.121890] [ARISC ERROR] :message attr   : 2
[   68.121904] [ARISC ERROR] :message type   : 30
[   68.121918] [ARISC ERROR] :message result : ff
[   68.121932] [ARISC WARING] :callback not install
[   68.121949] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   68.404091] [ARISC ERROR] :message process error
[   68.413177] [ARISC ERROR] :message addr   : f004b840
[   68.422825] [ARISC ERROR] :message state  : 5
[   68.432349] [ARISC ERROR] :message attr   : 2
[   68.441678] [ARISC ERROR] :message type   : 30
[   68.450802] [ARISC ERROR] :message result : ff
[   68.459849] [ARISC WARING] :callback not install
[   68.468999] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   68.662303] [ARISC ERROR] :message process error
[   68.672185] [ARISC ERROR] :message addr   : f004b840
[   68.682586] [ARISC ERROR] :message state  : 5
[   68.692879] [ARISC ERROR] :message attr   : 2
[   68.702971] [ARISC ERROR] :message type   : 30
[   68.712494] [ARISC ERROR] :message result : ff
[   68.721443] [ARISC WARING] :callback not install
[   68.730485] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   68.962304] [ARISC ERROR] :message process error
[   68.971753] [ARISC ERROR] :message addr   : f004b840
[   68.981268] [ARISC ERROR] :message state  : 5
[   68.990652] [ARISC ERROR] :message attr   : 2
[   68.999825] [ARISC ERROR] :message type   : 30
[   69.008857] [ARISC ERROR] :message result : ff
[   69.017826] [ARISC WARING] :callback not install
[   69.026900] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   69.262157] [ARISC ERROR] :message process error
[   69.271950] [ARISC ERROR] :message addr   : f004b840
[   69.282267] [ARISC ERROR] :message state  : 5
[   69.292481] [ARISC ERROR] :message attr   : 2
[   69.302490] [ARISC ERROR] :message type   : 30
[   69.311927] [ARISC ERROR] :message result : ff
[   69.320792] [ARISC WARING] :callback not install
[   69.329732] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   69.512292] [ARISC ERROR] :message process error
[   69.521641] [ARISC ERROR] :message addr   : f004b840
[   69.531055] [ARISC ERROR] :message state  : 5
[   69.540354] [ARISC ERROR] :message attr   : 2
[   69.549438] [ARISC ERROR] :message type   : 30
[   69.558371] [ARISC ERROR] :message result : ff
[   69.567225] [ARISC WARING] :callback not install
[   69.576182] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   69.812299] [ARISC ERROR] :message process error
[   69.822013] [ARISC ERROR] :message addr   : f004b840
[   69.832278] [ARISC ERROR] :message state  : 5
[   69.842438] [ARISC ERROR] :message attr   : 2
[   69.852410] [ARISC ERROR] :message type   : 30
[   69.861799] [ARISC ERROR] :message result : ff
[   69.870619] [ARISC WARING] :callback not install
[   69.879521] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   70.062316] [ARISC ERROR] :message process error
[   70.071630] [ARISC ERROR] :message addr   : f004b840
[   70.081013] [ARISC ERROR] :message state  : 5
[   70.090281] [ARISC ERROR] :message attr   : 2
[   70.099336] [ARISC ERROR] :message type   : 30
[   70.107901] [ARISC ERROR] :message result : ff
[   70.115964] [ARISC WARING] :callback not install
[   70.124134] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   70.312132] [ARISC ERROR] :message process error
[   70.321077] [ARISC ERROR] :message addr   : f004b840
[   70.330608] [ARISC ERROR] :message state  : 5
[   70.339998] [ARISC ERROR] :message attr   : 2
[   70.349210] [ARISC ERROR] :message type   : 30
[   70.358267] [ARISC ERROR] :message result : ff
[   70.367240] [ARISC WARING] :callback not install
[   70.376309] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   70.562140] [ARISC ERROR] :message process error
[   70.571598] [ARISC ERROR] :message addr   : f004b840
[   70.581119] [ARISC ERROR] :message state  : 5
[   70.590515] [ARISC ERROR] :message attr   : 2
[   70.599691] [ARISC ERROR] :message type   : 30
[   70.608400] [ARISC ERROR] :message result : ff
[   70.616579] [ARISC WARING] :callback not install
[   70.624871] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   70.862153] [ARISC ERROR] :message process error
[   70.871220] [ARISC ERROR] :message addr   : f004b840
[   70.880876] [ARISC ERROR] :message state  : 5
[   70.890414] [ARISC ERROR] :message attr   : 2
[   70.899745] [ARISC ERROR] :message type   : 30
[   70.908921] [ARISC ERROR] :message result : ff
[   70.918041] [ARISC WARING] :callback not install
[   70.927258] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   71.162161] [ARISC ERROR] :message process error
[   71.172173] [ARISC ERROR] :message addr   : f004b840
[   71.182771] [ARISC ERROR] :message state  : 5
[   71.193252] [ARISC ERROR] :message attr   : 2
[   71.203541] [ARISC ERROR] :message type   : 30
[   71.213307] [ARISC ERROR] :message result : ff
[   71.222570] [ARISC WARING] :callback not install
[   71.231926] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   71.512134] [ARISC ERROR] :message process error
[   71.521881] [ARISC ERROR] :message addr   : f004b840
[   71.531692] [ARISC ERROR] :message state  : 5
[   71.541387] [ARISC ERROR] :message attr   : 2
[   71.550900] [ARISC ERROR] :message type   : 30
[   71.560204] [ARISC ERROR] :message result : ff
[   71.569420] [ARISC WARING] :callback not install
[   71.578756] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   71.762156] [ARISC ERROR] :message process error
[   71.772252] [ARISC ERROR] :message addr   : f004b840
[   71.782892] [ARISC ERROR] :message state  : 5
[   71.793416] [ARISC ERROR] :message attr   : 2
[   71.803747] [ARISC ERROR] :message type   : 30
[   71.813493] [ARISC ERROR] :message result : ff
[   71.822662] [ARISC WARING] :callback not install
[   71.831923] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   72.012148] [ARISC ERROR] :message process error
[   72.021838] [ARISC ERROR] :message addr   : f004b840
[   72.031575] [ARISC ERROR] :message state  : 5
[   72.041195] [ARISC ERROR] :message attr   : 2
[   72.050620] [ARISC ERROR] :message type   : 30
[   72.059819] [ARISC ERROR] :message result : ff
[   72.069007] [ARISC WARING] :callback not install
[   72.078272] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   72.262172] [ARISC ERROR] :message process error
[   72.272199] [ARISC ERROR] :message addr   : f004b840
[   72.282756] [ARISC ERROR] :message state  : 5
[   72.293194] [ARISC ERROR] :message attr   : 2
[   72.303446] [ARISC ERROR] :message type   : 30
[   72.313105] [ARISC ERROR] :message result : ff
[   72.322191] [ARISC WARING] :callback not install
[   72.331356] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   72.554089] [ARISC ERROR] :message process error
[   72.563669] [ARISC ERROR] :message addr   : f004b840
[   72.573284] [ARISC ERROR] :message state  : 5
[   72.582797] [ARISC ERROR] :message attr   : 2
[   72.592100] [ARISC ERROR] :message type   : 30
[   72.600836] [ARISC ERROR] :message result : ff
[   72.608963] [ARISC WARING] :callback not install
[   72.617220] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   72.854084] [ARISC ERROR] :message process error
[   72.863081] [ARISC ERROR] :message addr   : f004b840
[   72.872616] [ARISC ERROR] :message state  : 5
[   72.882037] [ARISC ERROR] :message attr   : 2
[   72.891247] [ARISC ERROR] :message type   : 30
[   72.900281] [ARISC ERROR] :message result : ff
[   72.909238] [ARISC WARING] :callback not install
[   72.918300] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   73.154128] [ARISC ERROR] :message process error
[   73.164020] [ARISC ERROR] :message addr   : f004b840
[   73.174488] [ARISC ERROR] :message state  : 5
[   73.184850] [ARISC ERROR] :message attr   : 2
[   73.194999] [ARISC ERROR] :message type   : 30
[   73.204622] [ARISC ERROR] :message result : ff
[   73.213706] [ARISC WARING] :callback not install
[   73.222883] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   73.454077] [ARISC ERROR] :message process error
[   73.463668] [ARISC ERROR] :message addr   : f004b840
[   73.473307] [ARISC ERROR] :message state  : 5
[   73.482831] [ARISC ERROR] :message attr   : 2
[   73.492143] [ARISC ERROR] :message type   : 30
[   73.501273] [ARISC ERROR] :message result : ff
[   73.510358] [ARISC WARING] :callback not install
[   73.519507] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   73.754101] [ARISC ERROR] :message process error
[   73.764090] [ARISC ERROR] :message addr   : f004b840
[   73.774652] [ARISC ERROR] :message state  : 5
[   73.785108] [ARISC ERROR] :message attr   : 2
[   73.795355] [ARISC ERROR] :message type   : 30
[   73.805079] [ARISC ERROR] :message result : ff
[   73.814259] [ARISC WARING] :callback not install
[   73.823524] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   74.054099] [ARISC ERROR] :message process error
[   74.063776] [ARISC ERROR] :message addr   : f004b840
[   74.073497] [ARISC ERROR] :message state  : 5
[   74.083114] [ARISC ERROR] :message attr   : 2
[   74.092520] [ARISC ERROR] :message type   : 30
[   74.101753] [ARISC ERROR] :message result : ff
[   74.110945] [ARISC WARING] :callback not install
[   74.120258] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   74.354098] [ARISC ERROR] :message process error
[   74.364194] [ARISC ERROR] :message addr   : f004b840
[   74.374857] [ARISC ERROR] :message state  : 5
[   74.385412] [ARISC ERROR] :message attr   : 2
[   74.395769] [ARISC ERROR] :message type   : 30
[   74.405592] [ARISC ERROR] :message result : ff
[   74.414875] [ARISC WARING] :callback not install
[   74.424248] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   74.654090] [ARISC ERROR] :message process error
[   74.664213] [ARISC ERROR] :message addr   : f004b840
[   74.674852] [ARISC ERROR] :message state  : 5
[   74.685387] [ARISC ERROR] :message attr   : 2
[   74.695713] [ARISC ERROR] :message type   : 30
[   74.705462] [ARISC ERROR] :message result : ff
[   74.714625] [ARISC WARING] :callback not install
[   74.723872] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   74.954096] [ARISC ERROR] :message process error
[   74.963759] [ARISC ERROR] :message addr   : f004b840
[   74.973474] [ARISC ERROR] :message state  : 5
[   74.983074] [ARISC ERROR] :message attr   : 2
[   74.992452] [ARISC ERROR] :message type   : 30
[   75.001683] [ARISC ERROR] :message result : ff
[   75.010872] [ARISC WARING] :callback not install
[   75.020139] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   75.253940] [ARISC ERROR] :message process error
[   75.263954] [ARISC ERROR] :message addr   : f004b840
[   75.274485] [ARISC ERROR] :message state  : 5
[   75.284906] [ARISC ERROR] :message attr   : 2
[   75.295117] [ARISC ERROR] :message type   : 30
[   75.304757] [ARISC ERROR] :message result : ff
[   75.313815] [ARISC WARING] :callback not install
[   75.322961] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   75.554093] [ARISC ERROR] :message process error
[   75.563652] [ARISC ERROR] :message addr   : f004b840
[   75.573259] [ARISC ERROR] :message state  : 5
[   75.582753] [ARISC ERROR] :message attr   : 2
[   75.592040] [ARISC ERROR] :message type   : 30
[   75.601140] [ARISC ERROR] :message result : ff
[   75.610184] [ARISC WARING] :callback not install
[   75.619318] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   75.854098] [ARISC ERROR] :message process error
[   75.863983] [ARISC ERROR] :message addr   : f004b840
[   75.874384] [ARISC ERROR] :message state  : 5
[   75.884669] [ARISC ERROR] :message attr   : 2
[   75.894746] [ARISC ERROR] :message type   : 30
[   75.904247] [ARISC ERROR] :message result : ff
[   75.913167] [ARISC WARING] :callback not install
[   75.922172] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   76.223990] [ARISC ERROR] :message process error
[   76.233818] [ARISC ERROR] :message addr   : f004b840
[   76.244216] [ARISC ERROR] :message state  : 5
[   76.254501] [ARISC ERROR] :message attr   : 2
[   76.264584] [ARISC ERROR] :message type   : 30
[   76.274152] [ARISC ERROR] :message result : ff
[   76.283183] [ARISC WARING] :callback not install
[   76.292301] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   76.524083] [ARISC ERROR] :message process error
[   76.533611] [ARISC ERROR] :message addr   : f004b840
[   76.543180] [ARISC ERROR] :message state  : 5
[   76.552642] [ARISC ERROR] :message attr   : 2
[   76.561900] [ARISC ERROR] :message type   : 30
[   76.570981] [ARISC ERROR] :message result : ff
[   76.579980] [ARISC WARING] :callback not install
[   76.589090] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   76.824107] [ARISC ERROR] :message process error
[   76.834038] [ARISC ERROR] :message addr   : f004b840
[   76.844537] [ARISC ERROR] :message state  : 5
[   76.854924] [ARISC ERROR] :message attr   : 2
[   76.867115] [ARISC ERROR] :message type   : 30
[   76.877394] [ARISC ERROR] :message result : ff
[   76.886557] [ARISC WARING] :callback not install
[   76.896044] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
### lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0001 1.1 root hub
  bcdDevice            3.04
  iManufacturer           3 Linux 3.4.112-sun8i ohci_hcd
  iProduct                2 SW USB2.0 'Open' Host Controller (OHCI) Driver
  iSerial                 1 sunxi-ohci
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0012
    No power switching (usb 1.0)
    No overcurrent protection
  bPwrOn2PwrGood        2 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0100 power
Device Status:     0x0001
  Self Powered
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 006 Device 002: ID 0000:0538
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0000
  idProduct          0x0538
  bcdDevice            1.00
  iManufacturer           0
  iProduct                1  USB OPTICAL MOUSE
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      66
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0006  1x 6 bytes
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
   Port 1: 0000.0303 lowspeed power enable connect
  Self Powered
Bus 005 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x1c4f SiGma Micro
  idProduct          0x0002 Keyboard TRACER Gamma Ivory
  bcdDevice            1.10
  iManufacturer           1 (error)
  iProduct                2 USB Keykoard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               98mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      54
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      50
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0003  1x 3 bytes
        bInterval              10
  (Bus Powered)
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.04
  iManufacturer           3 Linux 3.4.112-sun8i ehci_hcd
  iProduct                2 SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  iSerial                 1 sunxi-ehci
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x000a
    Per-port overcurrent protection
  bPwrOn2PwrGood       10 * 2 milli seconds
 Hub Port Status:
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
### lscpu:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
CPU max MHz:           1200.0000
CPU min MHz:           480.0000
### cpuinfo:
Processor	: ARMv7 Processor rev 5 (v7l)
processor	: 0
BogoMIPS	: 1.34
processor	: 1
BogoMIPS	: 1.34
processor	: 2
BogoMIPS	: 1.34
processor	: 3
BogoMIPS	: 1.34
Features	: swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
Serial		: 4435502f024e3c000000
### meminfo:
MemTotal:         506028 kB
MemFree:          392660 kB
Buffers:            8004 kB
Cached:            41880 kB
SwapCached:            0 kB
Active:            40204 kB
Inactive:          40356 kB
Active(anon):      31048 kB
Inactive(anon):     4368 kB
Active(file):       9156 kB
Inactive(file):    35988 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          392660 kB
SwapTotal:        131068 kB
SwapFree:         131068 kB
Dirty:               620 kB
Writeback:             0 kB
AnonPages:         30792 kB
Mapped:            10892 kB
Shmem:              4716 kB
Slab:              13236 kB
SReclaimable:       5200 kB
SUnreclaim:         8036 kB
KernelStack:         872 kB
PageTables:          920 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      384080 kB
Committed_AS:      80484 kB
VmallocTotal:     499712 kB
VmallocUsed:       16820 kB
VmallocChunk:     251428 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
  3:          1          0          0          0  sunxi_gpio_irq_chip  gk_EINT
 29:       3076       1562       2601       1604       GIC  arch_timer
 30:          0          0          0          0       GIC  arch_timer
 38:         18          0          0          0       GIC  twi0
 39:         18          0          0          0       GIC  twi1
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 50:          0          0          0          0       GIC  sunxi_timer0
 63:          0          0          0          0       GIC  Thermal
 72:          0          0          0          0       GIC  sunxi-rtc alarm
 77:          1          0          0          0       GIC  PL
 81:          0          0          0          0       GIC  arisc_hwmsgbox_irq
 82:          0          0          0          0       GIC  sunxi_dmac
 90:          0          0          0          0       GIC  cedar_dev
 92:      32302          0          0          0       GIC  sunxi-mmc
 93:         52          0          0          0       GIC  sunxi-mmc
 97:          0          0          0          0       GIC  spi0
104:          2          0          0          0       GIC  ehci_hcd:usb1
105:         51          0          0          0       GIC  ohci_hcd:usb5
106:         22          0          0          0       GIC  ehci_hcd:usb2
107:         41          0          0          0       GIC  ohci_hcd:usb6
108:          0          0          0          0       GIC  ehci_hcd:usb3
109:          0          0          0          0       GIC  ohci_hcd:usb7
110:          0          0          0          0       GIC  ehci_hcd:usb4
111:          0          0          0          0       GIC  ohci_hcd:usb8
114:          5          0          0          0       GIC  gmac0
118:       4577          0          0          0       GIC  dispaly
129:          0          0          0          0       GIC  mali_gp_irq_handlers
130:          0          0          0          0       GIC  mali_mmu_irq_handlers
131:          0          0          0          0       GIC  mali_pp_irq_handlers
132:          0          0          0          0       GIC  mali_mmu_irq_handlers
134:          0          0          0          0       GIC  mali_pp_irq_handlers
135:          0          0          0          0       GIC  mali_mmu_irq_handlers
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       2032       3135       2147       1869  Rescheduling interrupts
IPI3:         22        153        165        163  Function call interrupts
IPI4:          0          3          1          0  Single function call interrupts
IPI5:          0          0          0          0  CPU stop interrupts
IPI6:          0          0          0          0  CPU backtrace
IPI7:          0          0          0          0  completion interrupts
Err:          0
### ifconfig:
eth0      Link encap:Ethernet  HWaddr de:99:0c:13:2d:eb
          inet6 addr: fe80::dc99:cff:fe13:2deb/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:670 (670.0
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0   TX bytes:0 (0.0
### df:
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1  7.4G  2.1G  5.2G  29% /
udev             10M     0   10M   0% /dev
tmpfs            99M  4.6M   95M   5% /run
tmpfs           248M     0  248M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           248M     0  248M   0% /sys/fs/cgroup
tmpfs           248M  128K  247M   1% /tmp
tmpfs            50M     0   50M   0% /run/user/1000
### mmc0:0007 info:
                 cid: 275048534430384730dae82e3d00ebb1
                 csd: 400e00325b5900003b5f7f800a400075
                 scr: 0235800001000000
                date: 11/2014
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD08G MODALIAS=mmc:block
          erase_size: 512
Sun May  1 00:09:07 CEST 2016 sun8i armv7l   Orange Pi One
Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
### dmesg:
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 160 MiB at 56000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c0a3d9c0, node_mem_map c0b7f000
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 129920 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1011000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 338820k/338820k available, 185468k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0973058   (9645 kB)
[    0.000000]       .init : 0xc0974000 - 0xc09c6ec0   ( 332 kB)
[    0.000000]       .data : 0xc09c8000 - 0xc0a42810   ( 491 kB)
[    0.000000]        .bss : 0xc0a42fc4 - 0xc0b7e2d0   (1261 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000536] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000595] pid_max: default: 32768 minimum: 301
[    0.001374] Mount-cache hash table entries: 512
[    0.003569] Initializing cgroup subsys cpuacct
[    0.003604] Initializing cgroup subsys memory
[    0.003708] Initializing cgroup subsys devices
[    0.003737] Initializing cgroup subsys freezer
[    0.003764] Initializing cgroup subsys blkio
[    0.003818] Initializing cgroup subsys perf_event
[    0.004003] CPU: Testing write buffer coherency: ok
[    0.004102] ftrace: allocating 25999 entries in 77 pages
[    0.070501] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.070537] [sunxi_smp_prepare_cpus] enter
[    0.070607] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.072624] CPU1: Booted secondary processor
[    0.072624] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.072782] CPU2: Booted secondary processor
[    0.072782] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.080962] CPU3: Booted secondary processor
[    0.080962] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.081107] Brought up 4 CPUs
[    0.081107] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.081907] devtmpfs: initialized
[    0.099163] wakeup src cnt is : 2.
[    0.099192] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099221] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.099251] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099281] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099309] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.099339] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099368] sunxi pm init
[    0.099682] pinctrl core: initialized pinctrl subsystem
[    0.114000] NET: Registered protocol family 16
[    0.115592] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.115592] script_sysfs_init success
[    0.115592] sunxi_dump_init success
[    0.115592] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.117776] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.119547] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.119583] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.120047] script config pll_video to 297 Mhz
[    0.120085] script config pll_de to 864 Mhz
[    0.120153] script config pll_ve to 402 Mhz
[    0.120190] sunxi_default_clk_init
[    0.120210] try to set pll6ahb1 to 200000000
[    0.120257] try to set ahb clk source to pll6ahb1
[    0.120279] set ahb clk source to pll6ahb1
[    0.120302] try to set ahb1 to 200000000
[    0.120330] try to set apb1 to 100000000
[    0.140537] bio: create slab <bio-0> at 0
[    0.140710] [ARISC] :sunxi-arisc driver v1.04
[    0.158617] [ARISC] :arisc version: [v0.1.58]
[    0.243853] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.247467] SCSI subsystem initialized
[    0.247467] usbcore: registered new interface driver usbfs
[    0.247467] usbcore: registered new interface driver hub
[    0.250108] usbcore: registered new device driver usb
[    0.250108] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.250108] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.250116] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.251458] Linux video capture interface: v2.00
[    0.251988] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.253640] cfg80211: Calling CRDA to update world regulatory domain
[    0.253763] Switching to clocksource arch_sys_counter
[    0.281997] FS-Cache: Loaded
[    0.282524] CacheFiles: Loaded
[    0.309900] NET: Registered protocol family 2
[    0.337432] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.338699] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.339305] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.339943] TCP: Hash tables configured (established 16384 bind 16384)
[    0.339970] TCP: reno registered
[    0.340000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.340136] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.340918] NET: Registered protocol family 1
[    0.341708] RPC: Registered named UNIX socket transport module.
[    0.341739] RPC: Registered udp transport module.
[    0.341761] RPC: Registered tcp transport module.
[    0.341784] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.342178] Trying to unpack rootfs image as initramfs...
[    0.766408] Freeing initrd memory: 3040K
[    0.767223] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.767477] sunxi_reg_init enter
[    0.769434] audit: initializing netlink socket (disabled)
[    0.769520] type=2000 audit(0.760:1): initialized
[    0.773745] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.774151] misc fatfs initialized
[    0.775847] NFS: Registering the id_resolver key type
[    0.776684] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.776718] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.778427] NTFS driver 2.1.30 [Flags: R/W].
[    0.779122] fuse init (API version 7.18)
[    0.781113] Btrfs loaded
[    0.781168] msgmni has been set to 987
[    0.784088] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.784131] io scheduler noop registered
[    0.784154] io scheduler deadline registered
[    0.784322] io scheduler cfq registered (default)
[    0.785218] [DISP]disp_module_init
[    0.785902] cmdline,init_disp=
[    0.785968] cmdline,disp=
[    0.803224] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.845718] Console: switching to colour frame buffer device 160x45
[    0.890709] [DISP]disp_module_init finish
[    0.891173] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.891777] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.891811] sw_uart_pm()890 - uart0 clk is already enable
[    0.893030] sunxi_cmatest_init enter
[    0.893121] sunxi_cmatest_init success
[    0.903231] brd: module loaded
[    0.912821] loop: module loaded
[    0.913388] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.913426] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.914598] spi spi0: master is unqueued, this is deprecated
[    0.915357] tun: Universal TUN/TAP device driver, 1.6
[    0.915383] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.917488] PPP generic driver version 2.4.2
[    0.917922] PPP BSD Compression module registered
[    0.917948] PPP Deflate Compression module registered
[    0.923233] PPP MPPE Compression module registered
[    0.923273] NET: Registered protocol family 24
[    0.923413] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.943613] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.943692] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.944915] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.960102] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.961513] hub 1-0:1.0: USB hub found
[    0.961569] hub 1-0:1.0: 1 port detected
[    0.982433] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.982507] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.983407] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.000086] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.000121] ehci_irq: highspeed device connect
[    1.001354] hub 2-0:1.0: USB hub found
[    1.001411] hub 2-0:1.0: 1 port detected
[    1.022304] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022376] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.023290] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.040075] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.041352] hub 3-0:1.0: USB hub found
[    1.041412] hub 3-0:1.0: 1 port detected
[    1.062282] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.062354] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.063254] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.080072] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.081339] hub 4-0:1.0: USB hub found
[    1.081385] hub 4-0:1.0: 1 port detected
[    1.082294] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.102445] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.102516] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.102592] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.165295] hub 5-0:1.0: USB hub found
[    1.165343] hub 5-0:1.0: 1 port detected
[    1.186234] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.186304] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.186381] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.200179] ehci_irq: highspeed device disconnect
[    1.245383] hub 6-0:1.0: USB hub found
[    1.245439] hub 6-0:1.0: 1 port detected
[    1.266352] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.266424] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.266500] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.325363] hub 7-0:1.0: USB hub found
[    1.325410] hub 7-0:1.0: 1 port detected
[    1.346355] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.346424] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.346501] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    1.405203] hub 8-0:1.0: USB hub found
[    1.405249] hub 8-0:1.0: 1 port detected
[    1.406098] Initializing USB Mass Storage driver...
[    1.406672] usbcore: registered new interface driver usb-storage
[    1.406703] USB Mass Storage support registered.
[    1.406845] usbcore: registered new interface driver ums-alauda
[    1.406980] usbcore: registered new interface driver ums-cypress
[    1.407123] usbcore: registered new interface driver ums-datafab
[    1.407239] usbcore: registered new interface driver ums_eneub6250
[    1.407360] usbcore: registered new interface driver ums-freecom
[    1.407484] usbcore: registered new interface driver ums-isd200
[    1.407604] usbcore: registered new interface driver ums-jumpshot
[    1.407717] usbcore: registered new interface driver ums-karma
[    1.407833] usbcore: registered new interface driver ums-onetouch
[    1.407978] usbcore: registered new interface driver ums-realtek
[    1.408102] usbcore: registered new interface driver ums-sddr09
[    1.408225] usbcore: registered new interface driver ums-sddr55
[    1.408344] usbcore: registered new interface driver ums-usbat
[    1.409038] file system registered
[    1.412994] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.413029] android_usb gadget: Number of LUNs=3
[    1.413058]  lun0: LUN: removable file: (no medium)
[    1.413085]  lun1: LUN: removable file: (no medium)
[    1.413112]  lun2: LUN: removable file: (no medium)
[    1.413926] android_usb gadget: android_usb ready
[    1.414432]  uinput result 0 , vmouse_init
[    1.415920] mousedev: PS/2 mouse device common for all mice
[    1.417579] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    1.417609] =========script_get_err============
[    1.417631] ltr_init: ls_fetch_sysconfig_para err.
[    1.418358] [RTC] WARNING: Rtc time will be wrong!!
[    1.418384] [RTC] WARNING: use *internal OSC* as clock source
[    1.419021] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.419133] i2c /dev entries driver
[    1.420168] IR RC5(x) protocol handler initialized
[    1.420510] sunxi cedar version 0.1
[    1.420609] [cedar]: install start!!!
[    1.421080] [cedar]: install end!!!
[    1.421476] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.421708] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.421929] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.422149] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.422370] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.422589] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.422808] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.423051] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.423289] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.423549] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.423800] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.424051] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.424301] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.424553] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.424804] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.425055] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.425305] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.425556] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.425595] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.425998] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.426362] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.426396] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.426423] timeout_to_interv, line 167
[    1.426444] interv_to_timeout, line 189
[    1.426470] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.427444] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.427669] calibrat: max_cpufreq 1200Mhz Type 0!
[    1.427700] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    1.433246] [ARISC ERROR] :message process error
[    1.433270] [ARISC ERROR] :message addr   : f004b840
[    1.433289] [ARISC ERROR] :message state  : 5
[    1.433307] [ARISC ERROR] :message attr   : 2
[    1.433325] [ARISC ERROR] :message type   : 30
[    1.433343] [ARISC ERROR] :message result : ff
[    1.433359] [ARISC WARING] :callback not install
[    1.433381] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    1.433928] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    1.433994] [mmc]: get mmc0's sdc_power is null!
[    1.434051] [mmc]: get mmc1's sdc_power is null!
[    1.434072] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.434093] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.434127] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    1.435943] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.437166] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438351] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438739] [mmc]: sdc0 power_supply is null
[    1.441515] no blue_led, ignore it!
[    1.441921] Registered led device: red_led
[    1.442150] Registered led device: green_led
[    1.442185] no led_0, ignore it!
[    1.442203] no led_1, ignore it!
[    1.442219] no led_2, ignore it!
[    1.442235] no led_3, ignore it!
[    1.442251] no led_4, ignore it!
[    1.442267] no led_5, ignore it!
[    1.442283] no led_6, ignore it!
[    1.442299] no led_7, ignore it!
[    1.443887] usbcore: registered new interface driver usbhid
[    1.443914] usbhid: USB HID core driver
[    1.451994] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.453806] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.454196] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.454228] [DAUDIO0] driver not init,just return.
[    1.460101] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.461436] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.463569] oprofile: using arm/armv7-ca7
[    1.463871] u32 classifier
[    1.463892]     Actions configured
[    1.464271] IPv4 over IPv4 tunneling driver
[    1.465536] TCP: bic registered
[    1.465560] TCP: cubic registered
[    1.465577] TCP: westwood registered
[    1.465595] TCP: highspeed registered
[    1.465612] TCP: hybla registered
[    1.465628] TCP: htcp registered
[    1.465645] TCP: vegas registered
[    1.465662] TCP: veno registered
[    1.465678] TCP: scalable registered
[    1.465696] TCP: lp registered
[    1.465712] TCP: yeah registered
[    1.465728] TCP: illinois registered
[    1.465745] Initializing XFRM netlink socket
[    1.466225] NET: Registered protocol family 10
[    1.468545] NET: Registered protocol family 17
[    1.468606] NET: Registered protocol family 15
[    1.468694] Registering the dns_resolver key type
[    1.469296] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.469343] ThumbEE CPU extension supported.
[    1.469384] Registering SWP/SWPB emulation handler
[    1.470623] registered taskstats version 1
[    1.471117] cmdline,disp=
[    1.471431] [HDMI] power vcc-hdmi-18
[    1.481702] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.484214] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489544] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489667] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.492164] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.502132] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.503646] CPU Budget:Register notifier
[    1.503660] CPU Budget:register Success
[    1.503675] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.506901] [rf_pm]: module power0 name vcc-wifi-33
[    1.506917] [rf_pm]: Did not config module_power1 in sys_config
[    1.506929] [rf_pm]: Did not config module_power2 in sys_config
[    1.506940] [rf_pm]: Did not config module_power3 in sys_config
[    1.506950] [rf_pm]: mod has no chip_en gpio
[    1.506959] [rf_pm]: failed to fetch lpo_use_apclk
[    1.506968] [rf_pm]: regulator on.
[    1.506979] [wifi_pm]: no wifi used in configuration
[    1.506989] [rfkill]: init no bt used in configuration
[    1.506998] ALSA device list:
[    1.507006]   #0: audiocodec
[    1.507014]   #1: sndhdmi
[    1.507644] Freeing init memory: 328K
[    1.511639] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.515638] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515762] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515931] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.516035] mmc0: new high speed SDHC card at address 0007
[    1.516537] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    1.518133]  mmcblk0: p1
[    1.518782] mmcblk mmc0:0007: Card claimed for testing.
[    1.518803] mmc0:0007: SD08G 7.42 GiB
[    1.518851] *******************sd init ok*******************
[    1.549274] systemd-udevd[97]: starting version 215
[    1.620156] usb 6-1: new low-speed USB device number 2 using sunxi-ohci
[    1.847788] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    1.984983] [ARISC ERROR] :message process error
[    1.985014] [ARISC ERROR] :message addr   : f004b840
[    1.985034] [ARISC ERROR] :message state  : 5
[    1.985052] [ARISC ERROR] :message attr   : 2
[    1.985070] [ARISC ERROR] :message type   : 30
[    1.985087] [ARISC ERROR] :message result : ff
[    1.985104] [ARISC WARING] :callback not install
[    1.985125] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.110087] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    3.005161] [ARISC ERROR] :message process error
[    3.005192] [ARISC ERROR] :message addr   : f004b840
[    3.005211] [ARISC ERROR] :message state  : 5
[    3.005229] [ARISC ERROR] :message attr   : 2
[    3.005247] [ARISC ERROR] :message type   : 30
[    3.005265] [ARISC ERROR] :message result : ff
[    3.005281] [ARISC WARING] :callback not install
[    3.005303] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    3.998187] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.417264] [ARISC ERROR] :message process error
[    4.417294] [ARISC ERROR] :message addr   : f004b840
[    4.417314] [ARISC ERROR] :message state  : 5
[    4.417332] [ARISC ERROR] :message attr   : 2
[    4.417349] [ARISC ERROR] :message type   : 30
[    4.417367] [ARISC ERROR] :message result : ff
[    4.417384] [ARISC WARING] :callback not install
[    4.417407] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    4.955162] [ARISC ERROR] :message process error
[    4.955192] [ARISC ERROR] :message addr   : f004b840
[    4.955212] [ARISC ERROR] :message state  : 5
[    4.955230] [ARISC ERROR] :message attr   : 2
[    4.955248] [ARISC ERROR] :message type   : 30
[    4.955265] [ARISC ERROR] :message result : ff
[    4.955282] [ARISC WARING] :callback not install
[    4.955303] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    5.230556] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.231114] systemd[1]: Detected architecture 'arm'.
[    5.245873] systemd[1]: Set hostname to <orangepione>.
[    5.598441] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    5.600907] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    5.601240] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.601312] systemd[1]: Expecting device dev-ttySAC2.device...
[    5.601814] systemd[1]: Starting Remote File Systems (Pre).
[    5.602151] systemd[1]: Reached target Remote File Systems (Pre).
[    5.602240] systemd[1]: Starting Encrypted Volumes.
[    5.602537] systemd[1]: Reached target Encrypted Volumes.
[    5.602614] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    5.602790] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.602842] systemd[1]: Starting Paths.
[    5.603115] systemd[1]: Reached target Paths.
[    5.603217] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    5.604008] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.604087] systemd[1]: Starting Root Slice.
[    5.604450] systemd[1]: Created slice Root Slice.
[    5.604504] systemd[1]: Starting User and Session Slice.
[    5.604940] systemd[1]: Created slice User and Session Slice.
[    5.604996] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    5.605470] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.605524] systemd[1]: Starting Delayed Shutdown Socket.
[    5.605918] systemd[1]: Listening on Delayed Shutdown Socket.
[    5.605972] systemd[1]: Starting Journal Socket (/dev/log).
[    5.606369] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.606441] systemd[1]: Starting udev Control Socket.
[    5.606783] systemd[1]: Listening on udev Control Socket.
[    5.606845] systemd[1]: Starting udev Kernel Socket.
[    5.607180] systemd[1]: Listening on udev Kernel Socket.
[    5.607251] systemd[1]: Starting Journal Socket.
[    5.607635] systemd[1]: Listening on Journal Socket.
[    5.607735] systemd[1]: Starting System Slice.
[    5.608137] systemd[1]: Created slice System Slice.
[    5.608231] systemd[1]: Started File System Check on Root Device.
[    5.608275] systemd[1]: Starting system-getty.slice.
[    5.608767] systemd[1]: Created slice system-getty.slice.
[    5.608821] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.609275] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.609387] systemd[1]: Starting Increase datagram queue length...
[    5.660661] systemd[1]: Starting Restore / save the current clock...
[    5.720648] systemd[1]: Starting udev Coldplug all Devices...
[    5.790768] systemd[1]: Mounting POSIX Message Queue File System...
[    5.837237] systemd[1]: Starting Load Kernel Modules...
[    5.910964] systemd[1]: Mounting Debug File System...
[    6.009475] RTL871X: module init start
[    6.009492] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[    6.009589] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.011124] [mmc]: sdc1 power_supply is null
[    6.030038] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.050573] systemd[1]: Mounted Huge Pages File System.
[    6.051018] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.053300] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.055885] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.064382] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.065327] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.065451] [mmc]: sdc1 power_supply is null
[    6.068040] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.069566] [mmc]: sdc1 power_supply is null
[    6.090030] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.109557] [wifi_pm]: set wl_reg_on 1 !
[    6.109680] RTL871X: module init ret=0
[    6.113729] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.116360] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.123559] systemd[1]: Started Set Up Additional Binary Formats.
[    6.123659] systemd[1]: Starting LSB: Set keymap...
[    6.127336] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.128655] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.128781] [mmc]: sdc1 power_supply is null
[    6.131110] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.132637] [mmc]: sdc1 power_supply is null
[    6.150030] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.174788] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.177668] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.193338] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.195103] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.195220] [mmc]: sdc1 power_supply is null
[    6.197802] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.199327] [mmc]: sdc1 power_supply is null
[    6.220035] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.245884] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.249029] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.269563] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.271900] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.272017] [mmc]: sdc1 power_supply is null
[    6.280462] systemd[1]: Starting Slices.
[    6.280912] systemd[1]: Reached target Slices.
[    6.284759] systemd[1]: Mounted Debug File System.
[    6.285966] systemd[1]: Mounted POSIX Message Queue File System.
[    6.286651] [ARISC ERROR] :message process error
[    6.286684] [ARISC ERROR] :message addr   : f004b840
[    6.286705] [ARISC ERROR] :message state  : 5
[    6.286723] [ARISC ERROR] :message attr   : 2
[    6.286741] [ARISC ERROR] :message type   : 30
[    6.286758] [ARISC ERROR] :message result : ff
[    6.286775] [ARISC WARING] :callback not install
[    6.286799] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.371067] systemd[1]: Started Increase datagram queue length.
[    6.440757] systemd[1]: Started Restore / save the current clock.
[    6.625321] systemd[1]: Started Load Kernel Modules.
[    6.685357] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    6.745128] systemd[1]: Started LSB: Set keymap.
[    6.782596] [ARISC ERROR] :message process error
[    6.782623] [ARISC ERROR] :message addr   : f004b840
[    6.782643] [ARISC ERROR] :message state  : 5
[    6.782661] [ARISC ERROR] :message attr   : 2
[    6.782679] [ARISC ERROR] :message type   : 30
[    6.782697] [ARISC ERROR] :message result : ff
[    6.782713] [ARISC WARING] :callback not install
[    6.782735] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.800583] systemd[1]: Started udev Coldplug all Devices.
[    6.804470] systemd[1]: Time has been changed
[    6.805438] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.921797] systemd[1]: Mounted Configuration File System.
[    6.922073] systemd[1]: Starting Apply Kernel Variables...
[    7.041352] systemd[1]: Mounting FUSE Control File System...
[    7.160714] systemd[1]: Starting Syslog Socket.
[    7.171535] systemd[1]: Listening on Syslog Socket.
[    7.171809] systemd[1]: Starting Journal Service...
[    7.297974] [ARISC ERROR] :message process error
[    7.297999] [ARISC ERROR] :message addr   : f004b840
[    7.298015] [ARISC ERROR] :message state  : 5
[    7.298030] [ARISC ERROR] :message attr   : 2
[    7.298044] [ARISC ERROR] :message type   : 30
[    7.298059] [ARISC ERROR] :message result : ff
[    7.298072] [ARISC WARING] :callback not install
[    7.298092] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    7.305851] systemd[1]: Started Journal Service.
[    7.612495] systemd-udevd[175]: starting version 215
[    7.624056] [ARISC ERROR] :message process error
[    7.624087] [ARISC ERROR] :message addr   : f004b840
[    7.624113] [ARISC ERROR] :message state  : 5
[    7.624132] [ARISC ERROR] :message attr   : 2
[    7.624157] [ARISC ERROR] :message type   : 30
[    7.624176] [ARISC ERROR] :message result : ff
[    7.624193] [ARISC WARING] :callback not install
[    7.624217] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.488800] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.505181] [ARISC ERROR] :message process error
[    8.505210] [ARISC ERROR] :message addr   : f004b840
[    8.505230] [ARISC ERROR] :message state  : 5
[    8.505248] [ARISC ERROR] :message attr   : 2
[    8.505266] [ARISC ERROR] :message type   : 30
[    8.505283] [ARISC ERROR] :message result : ff
[    8.505300] [ARISC WARING] :callback not install
[    8.505322] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.730650] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[    9.145234] [ARISC ERROR] :message process error
[    9.145270] [ARISC ERROR] :message addr   : f004b840
[    9.145290] [ARISC ERROR] :message state  : 5
[    9.145308] [ARISC ERROR] :message attr   : 2
[    9.145325] [ARISC ERROR] :message type   : 30
[    9.145343] [ARISC ERROR] :message result : ff
[    9.145360] [ARISC WARING] :callback not install
[    9.145383] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.536608] [ARISC ERROR] :message process error
[    9.536655] [ARISC ERROR] :message addr   : f004b840
[    9.536683] [ARISC ERROR] :message state  : 5
[    9.536706] [ARISC ERROR] :message attr   : 2
[    9.536730] [ARISC ERROR] :message type   : 30
[    9.536753] [ARISC ERROR] :message result : ff
[    9.536776] [ARISC WARING] :callback not install
[    9.536810] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.863857] [ARISC ERROR] :message process error
[    9.863888] [ARISC ERROR] :message addr   : f004b840
[    9.863908] [ARISC ERROR] :message state  : 5
[    9.863927] [ARISC ERROR] :message attr   : 2
[    9.863944] [ARISC ERROR] :message type   : 30
[    9.863962] [ARISC ERROR] :message result : ff
[    9.863980] [ARISC WARING] :callback not install
[    9.864001] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.895681] systemd-journald[174]: Received request to flush runtime journal from PID 1
[   10.218249] gmac0: probed
[   10.218591] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   10.705016] [ARISC ERROR] :message process error
[   10.705044] [ARISC ERROR] :message addr   : f004b840
[   10.705065] [ARISC ERROR] :message state  : 5
[   10.705083] [ARISC ERROR] :message attr   : 2
[   10.705101] [ARISC ERROR] :message type   : 30
[   10.705118] [ARISC ERROR] :message result : ff
[   10.705136] [ARISC WARING] :callback not install
[   10.705158] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   13.614047] [ARISC ERROR] :message process error
[   13.614077] [ARISC ERROR] :message addr   : f004b840
[   13.614097] [ARISC ERROR] :message state  : 5
[   13.614115] [ARISC ERROR] :message attr   : 2
[   13.614133] [ARISC ERROR] :message type   : 30
[   13.614151] [ARISC ERROR] :message result : ff
[   13.614168] [ARISC WARING] :callback not install
[   13.614191] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.720079] eth0: no IPv6 routers present
### lsusb:
### lscpu:
CPU(s):                4
Socket(s):             1
### cpuinfo:
processor	: 0
BogoMIPS	: 1.34
processor	: 1
BogoMIPS	: 1.34
processor	: 2
BogoMIPS	: 1.34
processor	: 3
BogoMIPS	: 1.34
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
### meminfo:
MemTotal:         506028 kB
MemFree:          407140 kB
Buffers:            7548 kB
Cached:            37780 kB
SwapCached:            0 kB
Active:            29852 kB
Inactive:          36220 kB
Active(anon):      21188 kB
Inactive(anon):     4412 kB
Active(file):       8664 kB
Inactive(file):    31808 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          407140 kB
SwapFree:         131068 kB
Dirty:               244 kB
Writeback:             0 kB
AnonPages:         20924 kB
Mapped:             9628 kB
Shmem:              4608 kB
Slab:              12508 kB
SReclaimable:       4716 kB
SUnreclaim:         7792 kB
KernelStack:         784 kB
PageTables:          712 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
Committed_AS:      63384 kB
VmallocChunk:     251644 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
 29:       2372       1069       1740       1153       GIC  arch_timer
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 77:          1          0          0          0       GIC  PL
 92:      10892          0          0          0       GIC  sunxi-mmc
104:          0          0          0          0       GIC  ehci_hcd:usb1
105:          0          0          0          0       GIC  ohci_hcd:usb5
106:          2          0          0          0       GIC  ehci_hcd:usb2
107:         26          0          0          0       GIC  ohci_hcd:usb6
118:       4272          0          0          0       GIC  dispaly
IPI2:       1552       2428       1834       1245  Rescheduling interrupts
IPI3:        141        166         40        172  Function call interrupts
IPI4:          4          4          0          0  Single function call interrupts
Err:          0
### ifconfig:
          Interrupt:114
### df:
tmpfs            99M  4.5M   95M   5% /run
tmpfs           248M   44K  248M   1% /tmp
### mmc0:0007 info:
                date: 11/2014
                type: SD
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
          erase_size: 512
Sun May  1 00:10:45 CEST 2016 sun8i armv7l   Orange Pi One
### dmesg:
[    0.000534] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000593] pid_max: default: 32768 minimum: 301
[    0.001375] Mount-cache hash table entries: 512
[    0.003566] Initializing cgroup subsys cpuacct
[    0.003602] Initializing cgroup subsys memory
[    0.003705] Initializing cgroup subsys devices
[    0.003734] Initializing cgroup subsys freezer
[    0.003761] Initializing cgroup subsys blkio
[    0.003814] Initializing cgroup subsys perf_event
[    0.004000] CPU: Testing write buffer coherency: ok
[    0.004100] ftrace: allocating 25999 entries in 77 pages
[    0.070503] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.070540] [sunxi_smp_prepare_cpus] enter
[    0.070613] Setting up static identity map for 0x406a7678 - 0x406a76d0
[    0.072632] CPU1: Booted secondary processor
[    0.072632] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.072793] CPU2: Booted secondary processor
[    0.072793] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.080974] CPU3: Booted secondary processor
[    0.080974] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.081118] Brought up 4 CPUs
[    0.081118] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.090025] devtmpfs: initialized
[    0.099255] wakeup src cnt is : 2.
[    0.099284] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099313] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.099343] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099374] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.099402] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.099431] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.099460] sunxi pm init
[    0.099775] pinctrl core: initialized pinctrl subsystem
[    0.114166] NET: Registered protocol family 16
[    0.115787] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.115787] script_sysfs_init success
[    0.115787] sunxi_dump_init success
[    0.121877] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.124680] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.126514] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.126550] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.126998] script config pll_video to 297 Mhz
[    0.127036] script config pll_de to 864 Mhz
[    0.127105] script config pll_ve to 402 Mhz
[    0.127143] sunxi_default_clk_init
[    0.127162] try to set pll6ahb1 to 200000000
[    0.127209] try to set ahb clk source to pll6ahb1
[    0.127231] set ahb clk source to pll6ahb1
[    0.127254] try to set ahb1 to 200000000
[    0.127282] try to set apb1 to 100000000
[    0.141692] bio: create slab <bio-0> at 0
[    0.142482] [ARISC] :sunxi-arisc driver v1.04
[    0.160729] [ARISC] :arisc version: [v0.1.58]
[    0.247649] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.251363] SCSI subsystem initialized
[    0.251849] usbcore: registered new interface driver usbfs
[    0.252016] usbcore: registered new interface driver hub
[    0.252255] usbcore: registered new device driver usb
[    0.252526] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.252559] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.252589] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.253946] Linux video capture interface: v2.00
[    0.254465] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.256146] cfg80211: Calling CRDA to update world regulatory domain
[    0.256547] Switching to clocksource arch_sys_counter
[    0.281934] FS-Cache: Loaded
[    0.282470] CacheFiles: Loaded
[    0.310092] NET: Registered protocol family 2
[    0.337565] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.338846] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.339451] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.340155] TCP: Hash tables configured (established 16384 bind 16384)
[    0.340186] TCP: reno registered
[    0.340218] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.340285] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.341063] NET: Registered protocol family 1
[    0.341826] RPC: Registered named UNIX socket transport module.
[    0.341856] RPC: Registered udp transport module.
[    0.341879] RPC: Registered tcp transport module.
[    0.341901] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.342297] Trying to unpack rootfs image as initramfs...
[    0.766900] Freeing initrd memory: 3040K
[    0.767681] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.767977] sunxi_reg_init enter
[    0.769935] audit: initializing netlink socket (disabled)
[    0.770169] type=2000 audit(0.770:1): initialized
[    0.774257] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.774648] misc fatfs initialized
[    0.776330] NFS: Registering the id_resolver key type
[    0.777188] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.777223] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.778896] NTFS driver 2.1.30 [Flags: R/W].
[    0.779606] fuse init (API version 7.18)
[    0.781546] Btrfs loaded
[    0.781597] msgmni has been set to 987
[    0.784247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.784288] io scheduler noop registered
[    0.784311] io scheduler deadline registered
[    0.784476] io scheduler cfq registered (default)
[    0.785395] [DISP]disp_module_init
[    0.786055] cmdline,init_disp=
[    0.786118] cmdline,disp=
[    0.803468] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.846156] Console: switching to colour frame buffer device 160x45
[    0.891216] [DISP]disp_module_init finish
[    0.891681] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.892289] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.892322] sw_uart_pm()890 - uart0 clk is already enable
[    0.893563] sunxi_cmatest_init enter
[    0.893655] sunxi_cmatest_init success
[    0.903769] brd: module loaded
[    0.913422] loop: module loaded
[    0.914025] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.914061] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.915215] spi spi0: master is unqueued, this is deprecated
[    0.915958] tun: Universal TUN/TAP device driver, 1.6
[    0.915984] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.918051] PPP generic driver version 2.4.2
[    0.918483] PPP BSD Compression module registered
[    0.918524] PPP Deflate Compression module registered
[    0.923911] PPP MPPE Compression module registered
[    0.923953] NET: Registered protocol family 24
[    0.924088] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.944284] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.944366] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.945806] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.960082] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.961527] hub 1-0:1.0: USB hub found
[    0.961588] hub 1-0:1.0: 1 port detected
[    0.982454] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.982528] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.983695] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.000116] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.000151] ehci_irq: highspeed device connect
[    1.001437] hub 2-0:1.0: USB hub found
[    1.001484] hub 2-0:1.0: 1 port detected
[    1.022360] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.022434] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    1.023637] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.040072] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.041316] hub 3-0:1.0: USB hub found
[    1.041361] hub 3-0:1.0: 1 port detected
[    1.062236] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.062306] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    1.063398] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    1.080069] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    1.081328] hub 4-0:1.0: USB hub found
[    1.081373] hub 4-0:1.0: 1 port detected
[    1.082262] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.102402] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.102473] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    1.102550] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.165334] hub 5-0:1.0: USB hub found
[    1.165381] hub 5-0:1.0: 1 port detected
[    1.186255] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.186326] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    1.186414] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    1.200174] ehci_irq: highspeed device disconnect
[    1.245342] hub 6-0:1.0: USB hub found
[    1.245391] hub 6-0:1.0: 1 port detected
[    1.266337] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.266407] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    1.266484] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    1.325355] hub 7-0:1.0: USB hub found
[    1.325401] hub 7-0:1.0: 1 port detected
[    1.346344] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.346413] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    1.346500] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    1.405229] hub 8-0:1.0: USB hub found
[    1.405275] hub 8-0:1.0: 1 port detected
[    1.406111] Initializing USB Mass Storage driver...
[    1.406628] usbcore: registered new interface driver usb-storage
[    1.406660] USB Mass Storage support registered.
[    1.406796] usbcore: registered new interface driver ums-alauda
[    1.406914] usbcore: registered new interface driver ums-cypress
[    1.407040] usbcore: registered new interface driver ums-datafab
[    1.407155] usbcore: registered new interface driver ums_eneub6250
[    1.407275] usbcore: registered new interface driver ums-freecom
[    1.407399] usbcore: registered new interface driver ums-isd200
[    1.407513] usbcore: registered new interface driver ums-jumpshot
[    1.407632] usbcore: registered new interface driver ums-karma
[    1.407747] usbcore: registered new interface driver ums-onetouch
[    1.407908] usbcore: registered new interface driver ums-realtek
[    1.408050] usbcore: registered new interface driver ums-sddr09
[    1.408170] usbcore: registered new interface driver ums-sddr55
[    1.408290] usbcore: registered new interface driver ums-usbat
[    1.408977] file system registered
[    1.412985] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.413019] android_usb gadget: Number of LUNs=3
[    1.413049]  lun0: LUN: removable file: (no medium)
[    1.413076]  lun1: LUN: removable file: (no medium)
[    1.413102]  lun2: LUN: removable file: (no medium)
[    1.413907] android_usb gadget: android_usb ready
[    1.414430]  uinput result 0 , vmouse_init
[    1.415881] mousedev: PS/2 mouse device common for all mice
[    1.417500] ls_fetch_sysconfig_para: type err  device_used = -1073054544.
[    1.417530] =========script_get_err============
[    1.417553] ltr_init: ls_fetch_sysconfig_para err.
[    1.418297] [RTC] WARNING: Rtc time will be wrong!!
[    1.418323] [RTC] WARNING: use *internal OSC* as clock source
[    1.418954] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.419079] i2c /dev entries driver
[    1.420003] IR RC5(x) protocol handler initialized
[    1.420410] sunxi cedar version 0.1
[    1.420511] [cedar]: install start!!!
[    1.420977] [cedar]: install end!!!
[    1.421368] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.421601] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.421822] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.422041] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.422260] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.422482] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.422700] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.422935] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.423169] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.423429] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    1.423683] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    1.423935] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    1.424188] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    1.424442] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    1.424695] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    1.424947] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    1.425200] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    1.425452] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    1.425491] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.425892] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.426247] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.426281] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.426308] timeout_to_interv, line 167
[    1.426329] interv_to_timeout, line 189
[    1.426355] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.427351] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.427570] calibrat: max_cpufreq 1200Mhz Type 0!
[    1.427601] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    1.433189] [ARISC ERROR] :message process error
[    1.433213] [ARISC ERROR] :message addr   : f004b840
[    1.433232] [ARISC ERROR] :message state  : 5
[    1.433250] [ARISC ERROR] :message attr   : 2
[    1.433268] [ARISC ERROR] :message type   : 30
[    1.433286] [ARISC ERROR] :message result : ff
[    1.433303] [ARISC WARING] :callback not install
[    1.433325] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    1.433863] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Apr 30 2016 at 19:46:15
[    1.433938] [mmc]: get mmc0's sdc_power is null!
[    1.433995] [mmc]: get mmc1's sdc_power is null!
[    1.434016] [mmc]: get mmc1's 2xmode ok, val = 1
[    1.434038] [mmc]: get mmc1's ddrmode ok, val = 1
[    1.434071] [mmc]: MMC host used card: 0x3, boot card: 0x1, io_card 2
[    1.435914] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.437143] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438340] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.438717] [mmc]: sdc0 power_supply is null
[    1.441495] no blue_led, ignore it!
[    1.441907] Registered led device: red_led
[    1.442134] Registered led device: green_led
[    1.442169] no led_0, ignore it!
[    1.442187] no led_1, ignore it!
[    1.442203] no led_2, ignore it!
[    1.442219] no led_3, ignore it!
[    1.442235] no led_4, ignore it!
[    1.442251] no led_5, ignore it!
[    1.442267] no led_6, ignore it!
[    1.442283] no led_7, ignore it!
[    1.443860] usbcore: registered new interface driver usbhid
[    1.443885] usbhid: USB HID core driver
[    1.451982] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.453918] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    1.454296] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    1.454332] [DAUDIO0] driver not init,just return.
[    1.460087] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.461534] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    1.463694] oprofile: using arm/armv7-ca7
[    1.464000] u32 classifier
[    1.464017]     Actions configured
[    1.464401] IPv4 over IPv4 tunneling driver
[    1.465658] TCP: bic registered
[    1.465683] TCP: cubic registered
[    1.465700] TCP: westwood registered
[    1.465718] TCP: highspeed registered
[    1.465735] TCP: hybla registered
[    1.465752] TCP: htcp registered
[    1.465768] TCP: vegas registered
[    1.465785] TCP: veno registered
[    1.465802] TCP: scalable registered
[    1.465819] TCP: lp registered
[    1.465835] TCP: yeah registered
[    1.465852] TCP: illinois registered
[    1.465868] Initializing XFRM netlink socket
[    1.466329] NET: Registered protocol family 10
[    1.468617] NET: Registered protocol family 17
[    1.468681] NET: Registered protocol family 15
[    1.468770] Registering the dns_resolver key type
[    1.469371] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.469418] ThumbEE CPU extension supported.
[    1.469458] Registering SWP/SWPB emulation handler
[    1.470606] registered taskstats version 1
[    1.471103] cmdline,disp=
[    1.471406] [HDMI] power vcc-hdmi-18
[    1.481703] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.484218] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489549] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.489671] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.492169] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.502171] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.503731] CPU Budget:Register notifier
[    1.503746] CPU Budget:register Success
[    1.503760] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.506979] [rf_pm]: module power0 name vcc-wifi-33
[    1.506997] [rf_pm]: Did not config module_power1 in sys_config
[    1.507009] [rf_pm]: Did not config module_power2 in sys_config
[    1.507019] [rf_pm]: Did not config module_power3 in sys_config
[    1.507031] [rf_pm]: mod has no chip_en gpio
[    1.507040] [rf_pm]: failed to fetch lpo_use_apclk
[    1.507048] [rf_pm]: regulator on.
[    1.507059] [wifi_pm]: no wifi used in configuration
[    1.507069] [rfkill]: init no bt used in configuration
[    1.507079] ALSA device list:
[    1.507087]   #0: audiocodec
[    1.507094]   #1: sndhdmi
[    1.507698] Freeing init memory: 328K
[    1.511673] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.515725] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.515852] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.516026] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.516133] mmc0: new high speed SDHC card at address 0007
[    1.516650] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[    1.518224]  mmcblk0: p1
[    1.518853] mmcblk mmc0:0007: Card claimed for testing.
[    1.518870] mmc0:0007: SD08G 7.42 GiB
[    1.518910] *******************sd init ok*******************
[    1.549680] systemd-udevd[98]: starting version 215
[    1.620147] usb 6-1: new low-speed USB device number 2 using sunxi-ohci
[    1.847912] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-sunxi-ohci-1/input0
[    1.894988] [ARISC ERROR] :message process error
[    1.895018] [ARISC ERROR] :message addr   : f004b840
[    1.895037] [ARISC ERROR] :message state  : 5
[    1.895055] [ARISC ERROR] :message attr   : 2
[    1.895073] [ARISC ERROR] :message type   : 30
[    1.895091] [ARISC ERROR] :message result : ff
[    1.895108] [ARISC WARING] :callback not install
[    1.895130] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.905183] [ARISC ERROR] :message process error
[    2.905213] [ARISC ERROR] :message addr   : f004b840
[    2.905233] [ARISC ERROR] :message state  : 5
[    2.905251] [ARISC ERROR] :message attr   : 2
[    2.905269] [ARISC ERROR] :message type   : 30
[    2.905287] [ARISC ERROR] :message result : ff
[    2.905304] [ARISC WARING] :callback not install
[    2.905326] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    2.909450] [ARISC ERROR] :message process error
[    2.909470] [ARISC ERROR] :message addr   : f004b840
[    2.909489] [ARISC ERROR] :message state  : 5
[    2.909507] [ARISC ERROR] :message attr   : 2
[    2.909524] [ARISC ERROR] :message type   : 30
[    2.909542] [ARISC ERROR] :message result : ff
[    2.909559] [ARISC WARING] :callback not install
[    2.909579] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    3.994162] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.397325] [ARISC ERROR] :message process error
[    4.397356] [ARISC ERROR] :message addr   : f004b840
[    4.397375] [ARISC ERROR] :message state  : 5
[    4.397393] [ARISC ERROR] :message attr   : 2
[    4.397411] [ARISC ERROR] :message type   : 30
[    4.397429] [ARISC ERROR] :message result : ff
[    4.397446] [ARISC WARING] :callback not install
[    4.397469] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    4.945170] [ARISC ERROR] :message process error
[    4.945199] [ARISC ERROR] :message addr   : f004b840
[    4.945219] [ARISC ERROR] :message state  : 5
[    4.945237] [ARISC ERROR] :message attr   : 2
[    4.945255] [ARISC ERROR] :message type   : 30
[    4.945273] [ARISC ERROR] :message result : ff
[    4.945290] [ARISC WARING] :callback not install
[    4.945311] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    5.230549] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.231110] systemd[1]: Detected architecture 'arm'.
[    5.245851] systemd[1]: Set hostname to <orangepione>.
[    5.603331] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    5.605643] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    5.605969] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.606037] systemd[1]: Expecting device dev-ttySAC2.device...
[    5.606565] systemd[1]: Starting Remote File Systems (Pre).
[    5.606905] systemd[1]: Reached target Remote File Systems (Pre).
[    5.606991] systemd[1]: Starting Encrypted Volumes.
[    5.607294] systemd[1]: Reached target Encrypted Volumes.
[    5.607368] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    5.607552] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.607604] systemd[1]: Starting Paths.
[    5.607878] systemd[1]: Reached target Paths.
[    5.607981] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    5.608770] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.608857] systemd[1]: Starting Root Slice.
[    5.609226] systemd[1]: Created slice Root Slice.
[    5.609281] systemd[1]: Starting User and Session Slice.
[    5.609708] systemd[1]: Created slice User and Session Slice.
[    5.609761] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    5.610328] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.610387] systemd[1]: Starting Delayed Shutdown Socket.
[    5.610791] systemd[1]: Listening on Delayed Shutdown Socket.
[    5.610849] systemd[1]: Starting Journal Socket (/dev/log).
[    5.611281] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.611360] systemd[1]: Starting udev Control Socket.
[    5.611715] systemd[1]: Listening on udev Control Socket.
[    5.611780] systemd[1]: Starting udev Kernel Socket.
[    5.612118] systemd[1]: Listening on udev Kernel Socket.
[    5.612194] systemd[1]: Starting Journal Socket.
[    5.612567] systemd[1]: Listening on Journal Socket.
[    5.612675] systemd[1]: Starting System Slice.
[    5.613087] systemd[1]: Created slice System Slice.
[    5.613187] systemd[1]: Started File System Check on Root Device.
[    5.613233] systemd[1]: Starting system-getty.slice.
[    5.613731] systemd[1]: Created slice system-getty.slice.
[    5.613786] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.614242] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.614358] systemd[1]: Starting Increase datagram queue length...
[    5.680636] systemd[1]: Starting Restore / save the current clock...
[    5.780653] systemd[1]: Starting udev Coldplug all Devices...
[    5.840874] systemd[1]: Mounting POSIX Message Queue File System...
[    5.917520] systemd[1]: Starting Load Kernel Modules...
[    5.981038] systemd[1]: Mounting Debug File System...
[    6.082968] RTL871X: module init start
[    6.082985] RTL871X: rtl8189es v4.3.10.1_13373.20150129
[    6.083071] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.084616] [mmc]: sdc1 power_supply is null
[    6.100086] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.100559] systemd[1]: Mounted Huge Pages File System.
[    6.101011] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.123221] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.125749] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.134179] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.135112] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.135237] [mmc]: sdc1 power_supply is null
[    6.137822] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.139347] [mmc]: sdc1 power_supply is null
[    6.160027] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.183098] [wifi_pm]: set wl_reg_on 1 !
[    6.183244] RTL871X: module init ret=0
[    6.183609] systemd[1]: Started Set Up Additional Binary Formats.
[    6.183714] systemd[1]: Starting LSB: Set keymap...
[    6.183816] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.186508] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.197423] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.198644] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.198768] [mmc]: sdc1 power_supply is null
[    6.201124] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.202652] [mmc]: sdc1 power_supply is null
[    6.220046] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.230487] systemd[1]: Starting Slices.
[    6.230946] systemd[1]: Reached target Slices.
[    6.233280] systemd[1]: Mounted Debug File System.
[    6.233856] systemd[1]: Mounted POSIX Message Queue File System.
[    6.244844] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.247760] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.263463] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.265238] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.265361] [mmc]: sdc1 power_supply is null
[    6.267948] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.269477] [mmc]: sdc1 power_supply is null
[    6.290034] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.315854] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.318999] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.339534] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.341868] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.341984] [mmc]: sdc1 power_supply is null
[    6.360513] systemd[1]: Started Increase datagram queue length.
[    6.366086] [ARISC ERROR] :message process error
[    6.366115] [ARISC ERROR] :message addr   : f004b840
[    6.366135] [ARISC ERROR] :message state  : 5
[    6.366153] [ARISC ERROR] :message attr   : 2
[    6.366171] [ARISC ERROR] :message type   : 30
[    6.366188] [ARISC ERROR] :message result : ff
[    6.366205] [ARISC WARING] :callback not install
[    6.366228] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.420790] systemd[1]: Started Restore / save the current clock.
[    6.635321] systemd[1]: Started Load Kernel Modules.
[    6.715367] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    6.765106] systemd[1]: Started LSB: Set keymap.
[    6.815043] systemd[1]: Started udev Coldplug all Devices.
[    6.817056] systemd[1]: Time has been changed
[    6.817621] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.895187] [ARISC ERROR] :message process error
[    6.895216] [ARISC ERROR] :message addr   : f004b840
[    6.895236] [ARISC ERROR] :message state  : 5
[    6.895254] [ARISC ERROR] :message attr   : 2
[    6.895272] [ARISC ERROR] :message type   : 30
[    6.895290] [ARISC ERROR] :message result : ff
[    6.895306] [ARISC WARING] :callback not install
[    6.895328] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    6.941760] systemd[1]: Mounted Configuration File System.
[    6.942025] systemd[1]: Starting Apply Kernel Variables...
[    7.071342] systemd[1]: Mounting FUSE Control File System...
[    7.150699] systemd[1]: Starting Syslog Socket.
[    7.161458] systemd[1]: Listening on Syslog Socket.
[    7.161729] systemd[1]: Starting Journal Service...
[    7.245084] [ARISC ERROR] :message process error
[    7.245108] [ARISC ERROR] :message addr   : f004b840
[    7.245123] [ARISC ERROR] :message state  : 5
[    7.245138] [ARISC ERROR] :message attr   : 2
[    7.245152] [ARISC ERROR] :message type   : 30
[    7.245166] [ARISC ERROR] :message result : ff
[    7.245180] [ARISC WARING] :callback not install
[    7.245199] [cpu_freq] ERR:set cpu frequency to 600MHz failed!
[    7.299128] systemd[1]: Started Journal Service.
[    7.696807] [ARISC ERROR] :message process error
[    7.696840] [ARISC ERROR] :message addr   : f004b840
[    7.696860] [ARISC ERROR] :message state  : 5
[    7.696878] [ARISC ERROR] :message attr   : 2
[    7.696896] [ARISC ERROR] :message type   : 30
[    7.696913] [ARISC ERROR] :message result : ff
[    7.696930] [ARISC WARING] :callback not install
[    7.696953] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    7.710619] systemd-udevd[179]: starting version 215
[    8.459036] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.539436] [ARISC ERROR] :message process error
[    8.539460] [ARISC ERROR] :message addr   : f004b840
[    8.539476] [ARISC ERROR] :message state  : 5
[    8.539491] [ARISC ERROR] :message attr   : 2
[    8.539505] [ARISC ERROR] :message type   : 30
[    8.539520] [ARISC ERROR] :message result : ff
[    8.539534] [ARISC WARING] :callback not install
[    8.539553] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    8.690903] Adding 131068k swap on /var/swap.  Priority:-1 extents:3 across:2286616k SS
[    9.395234] [ARISC ERROR] :message process error
[    9.395268] [ARISC ERROR] :message addr   : f004b840
[    9.395288] [ARISC ERROR] :message state  : 5
[    9.395306] [ARISC ERROR] :message attr   : 2
[    9.395324] [ARISC ERROR] :message type   : 30
[    9.395341] [ARISC ERROR] :message result : ff
[    9.395358] [ARISC WARING] :callback not install
[    9.395381] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[    9.765736] systemd-journald[178]: Received request to flush runtime journal from PID 1
[   10.071407] gmac0: probed
[   10.071748] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   10.695021] [ARISC ERROR] :message process error
[   10.695050] [ARISC ERROR] :message addr   : f004b840
[   10.695070] [ARISC ERROR] :message state  : 5
[   10.695089] [ARISC ERROR] :message attr   : 2
[   10.695106] [ARISC ERROR] :message type   : 30
[   10.695124] [ARISC ERROR] :message result : ff
[   10.695141] [ARISC WARING] :callback not install
[   10.695163] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   13.424076] [ARISC ERROR] :message process error
[   13.424106] [ARISC ERROR] :message addr   : f004b840
[   13.424126] [ARISC ERROR] :message state  : 5
[   13.424144] [ARISC ERROR] :message attr   : 2
[   13.424162] [ARISC ERROR] :message type   : 30
[   13.424179] [ARISC ERROR] :message result : ff
[   13.424197] [ARISC WARING] :callback not install
[   13.424219] [cpu_freq] ERR:set cpu frequency to 480MHz failed!
[   20.870042] eth0: no IPv6 routers present
### lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 0000:0538
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
### lscpu:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
CPU max MHz:           1200.0000
CPU min MHz:           480.0000
### cpuinfo:
Processor	: ARMv7 Processor rev 5 (v7l)
processor	: 0
BogoMIPS	: 1.34
processor	: 1
BogoMIPS	: 1.34
processor	: 2
BogoMIPS	: 1.34
processor	: 3
BogoMIPS	: 1.34
Features	: swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 5
Hardware	: sun8i
Revision	: 0000
Serial		: 4435502f024e3c000000
### meminfo:
MemTotal:         506028 kB
MemFree:          409496 kB
Buffers:            7540 kB
Cached:            37096 kB
SwapCached:            0 kB
Active:            27760 kB
Inactive:          35640 kB
Active(anon):      19132 kB
Inactive(anon):     4440 kB
Active(file):       8628 kB
Inactive(file):    31200 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:             0 kB
HighFree:              0 kB
LowTotal:         506028 kB
LowFree:          409496 kB
SwapTotal:        131068 kB
SwapFree:         131068 kB
Dirty:               248 kB
Writeback:             0 kB
AnonPages:         19028 kB
Mapped:             9232 kB
Shmem:              4604 kB
Slab:              12500 kB
SReclaimable:       4668 kB
SUnreclaim:         7832 kB
KernelStack:         768 kB
PageTables:          616 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      384080 kB
Committed_AS:      60732 kB
VmallocTotal:     499712 kB
VmallocUsed:       16820 kB
VmallocChunk:     251668 kB
### interrupts:
           CPU0       CPU1       CPU2       CPU3
  3:          1          0          0          0  sunxi_gpio_irq_chip  gk_EINT
 29:       1544       1750       1971       1164       GIC  arch_timer
 30:          0          0          0          0       GIC  arch_timer
 38:         18          0          0          0       GIC  twi0
 39:         18          0          0          0       GIC  twi1
 43:          0          0          0          0       GIC  PA
 49:          0          0          0          0       GIC  PG
 50:          0          0          0          0       GIC  sunxi_timer0
 63:          0          0          0          0       GIC  Thermal
 72:          0          0          0          0       GIC  sunxi-rtc alarm
 77:          1          0          0          0       GIC  PL
 81:          0          0          0          0       GIC  arisc_hwmsgbox_irq
 82:          0          0          0          0       GIC  sunxi_dmac
 90:          0          0          0          0       GIC  cedar_dev
 92:      10769          0          0          0       GIC  sunxi-mmc
 93:         52          0          0          0       GIC  sunxi-mmc
 97:          0          0          0          0       GIC  spi0
107:         23          0          0          0       GIC  ohci_hcd:usb6
108:          0          0          0          0       GIC  ehci_hcd:usb3
109:          0          0          0          0       GIC  ohci_hcd:usb7
110:          0          0          0          0       GIC  ehci_hcd:usb4
111:          0          0          0          0       GIC  ohci_hcd:usb8
114:          4          0          0          0       GIC  gmac0
118:       4321          0          0          0       GIC  dispaly
129:          0          0          0          0       GIC  mali_gp_irq_handlers
130:          0          0          0          0       GIC  mali_mmu_irq_handlers
131:          0          0          0          0       GIC  mali_pp_irq_handlers
132:          0          0          0          0       GIC  mali_mmu_irq_handlers
134:          0          0          0          0       GIC  mali_pp_irq_handlers
135:          0          0          0          0       GIC  mali_mmu_irq_handlers
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       1447       2267       2130       1277  Rescheduling interrupts
IPI3:         11        160        164        167  Function call interrupts
IPI4:          1          2          0          5  Single function call interrupts
IPI5:          0          0          0          0  CPU stop interrupts
IPI6:          0          0          0          0  CPU backtrace
IPI7:          0          0          0          0  completion interrupts
Err:          0
### ifconfig:
eth0      Link encap:Ethernet  HWaddr de:99:0c:13:2d:eb
          inet6 addr: fe80::dc99:cff:fe13:2deb/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:580 (580.0
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0   TX bytes:0 (0.0
### df:
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1  7.4G  2.1G  5.2G  29% /
udev             10M     0   10M   0% /dev
tmpfs           248M     0  248M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           248M     0  248M   0% /sys/fs/cgroup
### mmc0:0007 info:
                 cid: 275048534430384730dae82e3d00ebb1
                 csd: 400e00325b5900003b5f7f800a400075
                 scr: 0235800001000000
                date: 11/2014
                type: SD
preferred_erase_size: 4194304
               fwrev: 0x0
               hwrev: 0x3
               oemid: 0x5048
              manfid: 0x000027
              serial: 0xdae82e3d
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD08G MODALIAS=mmc:block
          erase_size: 512
thanks for the fix  :)
i forgot to say, the dongle has an LED on it, when i use it with my orange pi, it wont turn on (but wifi works)
after that i did this fix it seemd that it lasted more then before on WiFi.
Thanks again for the fix.
You provide insufficient DC-IN. The aforementioned fix leads now to the SoC being most of the times fed with 1.1V instead of 1.3V. If it it's now a bit more stable then this is a confirmation that the following is necessary: Replace your PSU with something that works more reliable and ideally measure voltage on the respective test points on the board.
